PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. New Car
  2. Ball Joints
  3. y pipe ?
  4. drop resistor before and after video
  5. Power Locks
  6. Cattman Y-pipe
  7. Very Sad pic found on ebay :(
  8. Fluttering sound on acceleration
  9. Replaced Fuel Pump...
  10. Adjusted Timing/Lost lots of power
  11. big work day tomorrow
  12. Uhh WTF window switch...
  13. Clogged Injector/Misfire/Injectors Click Fine....
  14. Bath time for the Maxima!!
  15. blown fuses
  16. 3rd Gen Lost Archives (eye candy)
  17. trying to understand VG EGR variations
  18. Auto Climate Control
  19. Transmission
  20. Blown Head Gasket?
  21. another speaker thread
  22. Speakers for front doors.
  23. Keyswitch?
  24. power valve sticky?
  25. New TPS possibly bad?
  26. New Springs
  27. Weak E-Brake/Back Brakes(might not work)
  28. stock upper intake with T/B
  29. full set of seatbealts
  30. E36's and Amber Euro corners. w/ pics
  31. headlight housing discrepancies
  32. Leaky sunroof
  33. Tachometer works on and off?
  34. Digital AC Screen
  35. Major Headlight Issue!!!!!!!!!!!!!!!!!!!!!
  36. Wires hanging down on driver side?
  37. VE30DE in an s12...old project, bringing out new ideas...
  38. SOLD. But.
  39. another cv axle saga....
  40. CV Axle Emergency (Help!)
  41. Cigarette Lighter
  42. to all the jewish 3rd genners have an easy fast
  43. fixing coding issues.......
  44. Just got hit
  45. Made a sharp turn and....
  46. Cold Engine Dies When Put in Gear?
  47. possible bad engine/tranny swap
  48. power window problem
  49. SS Brake Line
  50. Window
  51. timing chain tensioners and VTC springs
  52. Tire question
  53. Z31 Turbo engine swap? '94 GXE
  54. BATTERY OR ALTERNATOR???
  55. headers vs exhaust manifold
  56. couple exhaust questions, plz
  57. ABS breaking braking.
  58. 91 gxe ps hp hose.....
  59. Catalytic Converter?
  60. really dumb headlight problem help plz
  61. A little help for those doing a 5 spd swap...Part numbers and Diagrams
  62. dont know if this is a transmission problem
  63. Electrical Ideas
  64. Yay. New Wheels.
  65. Keyless Entry with remote on OEM?
  66. crazy sway
  67. Weird Headlight... (I wouldn't say problem?)
  68. rear disc swap, plz
  69. Jumping beans
  70. audio wiring diagram plz
  71. heater not working
  72. Drop springs
  73. Wiper problem
  74. Rear jiggling
  75. Who is the Aaron92se of the VG world?
  76. Firewall engine motor mount
  77. what's your mpg reading?
  78. New Strut Bar
  79. were gurgling feeling.
  80. Bleeding ABS brakes/installing Actuator
  81. Need help trouble shooting!
  82. Electrical Problem
  83. Intake outtake
  84. Need suggestions for stereo replacement
  85. need help identifying this part.
  86. 89 Max ABS Pump Over Ride
  87. control arm fiasco
  88. pics of clutch line cooler mounting location?
  89. identify a plug??
  90. Got my muffler
  91. Radio wiring diagram
  92. Steering
  93. The bumpers metal part.
  94. Rear Speakers/Wires
  95. Automatic sunroof
  96. Help! Leaky Sunroof in Florida Storms!
  97. Pimp My Ride Stole My front end!
  98. Smokey third gen.
  99. gauging interest: 3rd gen A/T tiptronic system
  100. A/T power switch
  101. how to remove valveboby from auto trans?
  102. Just did a transmission drain and refill
  103. fog lights
  104. NEED HELP NOW/Door lock circuit on my table.
  105. HELP!!! Transmission swap clutch pedal wiring question... auto 2 5spd
  106. Power Door Lock Timer
  107. Rear brake pad
  108. How to tell if power antenna is Working
  109. Brake Leak/Rear Brakes
  110. Mass air flow sensors
  111. discrepancies in VG oil capacity
  112. Opinion- Buy '92 SE5 as parts car or fix-n-drive?
  113. Coilovers
  114. this is what happens when i get carried away
  115. low idle, hard to start cold, wants to stall.
  116. a little more right direction on e36
  117. Factory Head Unit Options?
  118. just checking on e36 conversion
  119. Cooling Fans
  120. Should I.........
  121. body parts- GXE to SE
  122. Digital Fuel Sensor
  123. pulse spark plugs?
  124. Poly want a maxima? :-)
  125. knock sensor help
  126. pics of wash day. (repost)
  127. Maxima misfiring?
  128. Gas tank leaking?
  129. Dash light comes on when brake is pressed
  130. whats needed for 5spd swap
  131. I can smell petrol when i drive
  132. Yay, New Car. (Kinda?)
  133. the trunk
  134. crank pulley damage? replace?
  135. Is my throwout bearing on the way out?
  136. maxima or UFO?
  137. relocated coolant overflow tank.
  138. Performance and MPG affected by ECU tinkering
  139. Why is my stereo so quiet?
  140. mouse in the engine!!!
  141. weird
  142. 44psi
  143. cleaning iacv, do i need to buy a gasket first?
  144. 1992 SE Auto yep i got another maxi
  145. Cai
  146. air bag component location?
  147. Electrical buzz from tranny
  148. Automatic in a VG SE
  149. Depo e36 euro + tsx projector retro!
  150. Installing Fog Lights
  151. I found out how to make the clock white
  152. Accel problem
  153. Power Steering leak: advice from old people
  154. Need help with a problem
  155. CV Axle Problems
  156. Side mirror replacement question
  157. got a small exhaust leak/crack.. can't find it
  158. Finally got em and installed em! pics inside
  159. Have you ever noticed.....
  160. Simple question, or observation..
  161. vg30et swap
  162. oil change problem, maybe
  163. Sometimes transmission lets me shift quickly but other times I have to force it...
  164. Transmission flush
  165. Rear Exhaust Manifold studs
  166. cv joint info
  167. jwt cams
  168. Inexpensive Parts
  169. Storm damage
  170. Weird Request for those with E36 lights.
  171. This morning
  172. Pinging
  173. so finally....some body work (pics)
  174. Has any one lost there key?
  175. jwt ecu
  176. Bose died...
  177. 2 Pics of my 94 GXE with 19's
  178. Interior pics of my $500 Maxima 56k warn
  179. what is maximum overbore of the VE block
  180. fighting with the max
  181. for a VE DOHC injectors question
  182. What a load of Cr@p
  183. It's magic :-)
  184. How to install This Spoiler
  185. installed stock winger-ma-thing
  186. Install help....blehmco parallel links
  187. A lil day of boredom. [pics]
  188. VE or VG
  189. VE Died on Hwy, Fuel pump cover to blame
  190. put 19's on my max but rubbing an issue now
  191. Shakey + pull to the left at high speed.
  192. recommended tire pressure for our cars?
  193. Idle fluctuates between 50-55 mph with throttle closed
  194. How long till it will die?
  195. Grounding Kit
  196. Technical IACV Question
  197. Parts just falling off
  198. Cruise control, 5spd swap rewire troubleshooting help
  199. New Interior (kind of)
  200. Is this how it ends?
  201. new engine
  202. Overheating; I think I know what it is.
  203. The great 3rd gen mileage thread :-)
  204. Temp Gauge Twitched & Stopped Working
  205. Front left axle replacement?
  206. Completely rebuilt RE4F02A for under $900
  207. do all 3rd gens have body colored mouldings on the doors?
  208. Wierd gas/check engine light problem
  209. Someone's bound to know this Bose answer
  210. Turd gen in the drain
  211. CV Joint boot torn...bad vibration in front end
  212. headlight question
  213. other engines in 3rd gen
  214. how bad is this tie rod?
  215. How bad is this bushing?
  216. small cold engine quirk
  217. Electrical Gurus: Got a nice little problem here!
  218. Attn, ColumbianMax, others that know how to get COLD ac
  219. Antennas
  220. So I got a new problem...
  221. test pipes
  222. Grinding/Grating noise from front tire after putting axel in
  223. Question for auto climate control owners
  224. HOT Engine
  225. Org for 94 SE front struts/shocks
  226. Finally installed a tranny cooler today.
  227. belt squeel maybe AC?
  228. Does your A/C work on your 3rd gen? How cold is it?
  229. 94 SE just died - part it out or just junk it? ???
  230. What a load of Cr@p
  231. What a load of Cr@p
  232. Regional Meet (Nov.) Poll in S.E. Forum
  233. Finally Its in!!
  234. Search function dead, knock sensor Q
  235. Inner tie rod: How do you know if it's bad?
  236. dead cylinder
  237. Can R134 frigerant go into a 3gen gxe?
  238. maximum tuning is going to offer bulletproof auto transmisions
  239. Iac???
  240. stillen body kit
  241. quick q...
  242. suspension
  243. clack really, really loud---how long before BOOM!?
  244. Rear tails
  245. Rattly Sunroof Shade
  246. What spark plugs are in your Max
  247. Incorrect MPH readings after changing gauges?
  248. Adding foglights
  249. questions about car alarms and wiring them up?
  250. Alignment Issues....
