- Dashboard Electrical Problems
- Problem with Gauges
- Road Trip, need help on mileage
- Nos
- Aftermarket body panels?
- 3rd Gen Gets the Beaterz Make Over
- VE 5spd Squealing!!Help!!
- polished rims
- Meineke muffler vs magnaflow muffler?????
- link to kalebs 5spd swap writeup?
- I live up to my org name, look inside and see why that is, so much more to do
- polishing intake manifold and powdercoating valve covers?
- how bad do KYB and Sprint really suuck?
- MAF Relocation/MAF Wire Extension
- 24 valve DOHC engine info needed
- Question on knock sensor....
- what is wrong?
- Speed Sensor - Again.... any gurus out there?
- Progress rear sway bar??
- strange...
- front bumper
- what color injectors do i have?
- Aftermarket Headers
- Are white tail light/center panel replacements out there?
- Engine Swap Questions
- Clutch pedal plugs
- Location
- pics of ma car
- Bent Control Arm?
- Seat belt chime
- Diary of my jdm VE swap
- Battery Disconnect = Crazy Shifing
- Brake light won't go off
- Wierd power problem
- average tint price?
- 'Engine check' with misfire on starting
- Engine + tranny
- Thermostat Question??
- 89 Max BOSE HU wiring colors?
- need pix, im considering selling my 2nd gen, for a 3rd
- Headlight won't light up, but the bulb is good?
- how many people mod their car's but dont race, and vise versa
- Matt's Mod of the Week
- Fans staying on after car is off.. Summer is hot!
- 92 fuel pump replacement
- door locks
- Track times w/new ECU
- camber
- When it rains, it sputters !?
- Radiator fans not working?
- preparing the max
- Help me im in window regulator hell
- timing belt
- Ve Pcv Valve Hose!!?? Maybe ???
- Help!!!!!
- Vibration and low pitched noise when turning
- need some help!!
- " Ah Shi?
- Old Car noise!! get it out!!
- speaker questions.
- Roughness / shaking at different times...
- my window keeps falling down
- Factory Spoiler Question
- Car runs cold on the highway ?
- apexi s-afc II
- Mods
- Torn outer CV boot - please help
- Cleaning Fuel Injector
- Radio Problem in Maxima...
- quick question: liquid gasket VS. gasket+sealant
- HELP! Can't get key out of ignition
- Indigo Pedal Installation Help
- JWT ECU is finally on its way! track time!
- Changed injectors, now car has trouble starting??
- Problem after problem
- Engine Question
- steering wheel questions
- Bad Transmission?
- Make car louder.....
- Changing bulbs behind the digital clock and digital temperature control
- Revamped Cardomain page - Check it Out !!
- 300zx Z32 Cams
- Frozen Rear Brake Caliper
- Finally put my 2000 SE rims on. New kickass tires too
- In which way should I upgrade my exhaust?
- Totaled Maxima
- Power Locks???AAGhhh
- How much is a fuse box?
- R-134 Adapter Question...
- Fuel Pump / Fuel Level Sending Unit
- cruise control is over-doing it
- HORRIBLE squeaking
- installing distributor
- 1990 Max GXE Trans axles Comments Please
- removing the side moldings
- General 3rd gen questions from a 4th gen guy
- Very long need help, please someone can help me figure this out.
- stock anti theft system
- Still no luck with my heistation, back fire, missfiring VE5spd
- Great News
- Got my Max last week...
- This is the end, thank you to everybody!
- where can find this
- air filter adapter
- Intake Manifold and TB Q's
- Mustang wheels
- cant find the link
- Vibration at HYW speeds
- WarpSpeed B-Pipe
- cant find my brain
- Water or Cooloant dripping into Car's Interior
- AC r134a conversion...long term experiences?
- which alternator
- are the 2k2 max brake systems the same as ours?
- ABS and snow...
- combo intake
- Want to learn about your car or modding?
- UK Corners and UK Grille
- Are VQ30 and VG30 transmissions the same?
- Tint thread....this time it is YOUR opinion that matters.....
- how much will i get for my car?
- max sighting in an old school advertisement
- Air conditioning
- Questions on Koni Conversion
- why does this happen
- i hear good things about them
- Noise from Engine cooling fan
- Invest more money into 91 GXe, or get 97 SE?
- Distributor Cap ?s
- "general maxima discussion" is biased
- Pwr Window
- warpspeed y-pipes
- 91 Max Recall
- Q: Shaved antennas
- condensation in my trunk
- GXE Battery Post Position?
- :( Need More Help....
- power dies ??
- Ahh now thats a clean engine..
- Homebrew CAI / MAF Relocation
- Any way to test a MAFS?
- Hood Lift Supports-a less expensive solution
- need help please!!
- What's wrong with my mom's stereo?
- ecu
- Lopy idle, running rich/lean, misfiring. Read if you have these problems!!!
- Can I replace 1992 bose HU with a 95+ HU?
- Whats wrong with my car
- anyone know the DB for a flowmaster muffler compared to stock muffler?
- Speedometer woes-- speed sensor?
- MAF Sensor Help
- creaking door
- rough start!!!
- Anyone had their MAF go bad?...
- Quick Question
- new window regulator
- (REAR) Brembo Cross Drilled/Straight Slotted Rotors
- what is the difference between a straight through muffler and reg. muffler?
- ST Shocks
- ******You wanted a triple gauge pod pillar now you will have ne******
- spark plugs
- spark knock
- Pink injectors?
- Problem with steering
- Y Pipe Removal
- need advice on broken bolt
- Rear Brake Pads
- Interesting na 300z radiator vs maxima unit
- 1994 Keyless entry maxima se
- need help with turn signals
- Noise - Wheel Bearings?
- Dull finish
- Foglights for 3rd gen gxe
- I NEED HELP!!! ALL 3rd Gen peeps who have side marker lights installed
- MAF Sensor Transfer Table & Wiring
- Thanks.....
- turbo VG30E
- ac fan problem
- Gauge Pod on the Pillar
- Quick question
- Ignition Coil Question
- I got gas
- 2002 SE wheels on a 92 SE?
- G/F's Maxima in a wreck. Please look here!
- How to add tranny fluid in a 89 SE 5-spd?
- 1990 Max SE engine to sentra?
- i want more power!!!!!!
- Fuel injector type?
- A/C does not turn on right away. Help, any ideas????
- Sway bar
- metal brake line rusted and leaking
- Fixit man wants $1500...should I spend?
- You Know You're a VG Driver When...
- Fold rear seatback...
- High Perfornace CV Shafts
- Changing the manual tranny fluid on my 92 SE
- First Mod!!
- O/D problem, please help!
- swap!!!!
- valve cover polishing
- anti hijack feature...
- Painting car need to take off spoiler
- will I need an Alignment since....
- 95+Motor fit in 3rd gen?
- Headlight help
- which high flow cat?
- how hard is it to replace auto tranny?
- quick question!!
- Spark Plug Gap?
- Removing Stock Corner Lights
- How do you shave the middle part of the trunk
- how many hours of labor for an engine change
- Fuel Pump Went! Need Help
- Redline Mt-90
- my car running a little rich
- Will you recomemd changing Timing belt together with
- Question about KS TSB Sub-Harness
- Just curious on horsepower now......
- Compression and Leak down test on VG30E
- question on blinkers
- Help with 91 SE Upgrades
- got back on the road with a max again
- wierd question, help needed
- Im up to my 3rd alternator... soon to see a 4th >:o
- Street Racing
- door keypad help
- coolant drain on block???
- questions about speed mods(jwt ecu/UR udp)
- e36
- Disappearing antifreeze
- What is this ??
- Auto Shifter Wires
- I just bought a 90 gxe give me ideas please!
- How could a 19 y/o go about getting a 3rd gen max
- need help fixing climate control display
- No fuse for keyless entry?
- turbo for 93 se
- AntonTheGrey's Gauge Swap and Intake Mod ***Pics***
- help
- What's Next?
- How Much R-134a ?
- cigarette lighter fuse
- Such a nice day to wash the car.......
- question on buying a maxima
- A/C Problems
- OK to powerwash engine?
- problems with just aquired 92 maxima
- Changed My Gauge Cluster Now I Need Help
- beamer headlights
- Gxe Stock Air Intake Warning
