PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Which Tranny Fluid To Use
  2. VE Vacuum Lines
  3. Turning radius
  4. Rear deforster barely works
  5. VE Oil gallies
  6. Control Arm bushing
  7. Big Brake Kit
  8. minor accident, need repairs?
  9. Rsf50a tranny rebuild
  10. Help with rims please
  11. These are my symptoms.Thinking alt.
  12. Side exit exhaust
  13. VG Phenolic Spacer - DEPOSIT DUE!!
  14. FSTBs any difference?
  15. Speedometer Sensor Install on VG
  16. front window replacement
  17. what would cause a.....
  18. rear lower main bearing help
  19. so i can finally see
  20. bulb info
  21. Where to find those AWESOME chrome gauge/dash rings?
  22. Coolant issues
  23. VG Cold Air Intake Interest Thread
  24. Rear parallel link bushings
  25. 'True Clear' Corners Project
  26. Questions about CAI
  27. new turbo setup
  28. Headliner sag
  29. The sweetest 3rd gen I've ever seen!!
  30. VG30E interals
  31. Car's idle dips below 500rpm when A/C is on
  32. My New 02GLE !!
  33. Source for extended wheel studs... ~2.25in or 55mm
  34. Does not start / pin out
  35. hook up points for engine removal
  36. SE Suspension on GXE...
  37. Do I have Eibach springs?
  38. 19x8.5 wheels
  39. Bose Radio Issue...
  40. Subframe Removal
  41. Check out this awsome grill
  42. Difference between addco and ST
  43. Rear drum brakes
  44. Best Joke ever
  45. Stillen kit
  46. Clearing Lesnses???
  47. Installed Fstb....
  48. When VTC goes bad....
  49. P/s high press hose
  50. my repair scheme
  51. Autozone Repair Guides
  52. The Great 3rd Gen Picture Thread/READ RULES BEFORE POSTING!
  53. high idle speed...? WTF.....
  54. Fresh wash & wax shoots with zymol
  55. Part number...
  56. Just watched a 3rd Gen get "pimped" on MTV
  57. Anyone Had Luck Cleaning Bad Injectors?
  58. 9007 bulb upgrade**With Pics**
  59. Front Right Tire
  60. Anyone VIP a 3rd gen?
  61. Most annoying "engine-in-car" job?
  62. ive never seen a gold vg 5 sp.
  63. Motor Mounts.....is it time?
  64. Auto Sunroof Re-Wire?
  65. New eBay cold air intake for the VE
  66. Question about valve cover screws
  67. Instrument Panel Dimmer?!
  68. Need Rim Help!!!!!!!!!!!!!!!!!!
  69. Headlight bulbs
  70. e36 headlight wiring
  71. Jim Wolftech
  72. any gaskets and tips?
  73. Fuel Pressure Regulator
  74. strange hissing sound on passenger side
  75. Front Suspension For My 94 Gxe
  76. tranny removal
  77. 3000k in E55 Output Pics! (no 56k)(4 mtcookson)
  78. Maf Sensor Question Kinda Weird??
  79. A 2 door maxima? SE-R 3rd gen?
  80. Infinity FX45 projector retrofit
  81. when my 3 rd gen get out the body shop
  82. engine tranny change
  83. when if ever shold the timing chain be swaped
  84. Angle eyes...what would you do?
  85. Headlight wire harness
  86. rear window removal help
  87. fan speed.....on or off? what's wrong
  88. Crashed my Max =(
  89. Keyless entry Problems!
  90. from the general discussion forum..
  91. Super loose part on VG, need help
  92. VG rear main oil seal
  93. Carbon deposits in combustion chamber
  94. Cleaned up the Engine a Bit Today
  95. Who's Running Unorthodox Pulley Quick ?
  96. No Arranca En Frio, In Spanish...
  97. Loss of odometer/mph signal
  98. A/C removal
  99. for those who completed the 5spd swap.
  100. for those vg guys with injector issues.
  101. Alternator bearings
  102. Quick question anyone can answer
  103. FSTB question
  104. Changing Camber and Caster without aftermarket bolts
  105. quick helpe removing o2 sensor
  106. Resolved : Fuel pump followup.
  107. Need a new shift knob
  108. Does Not Start In Cold Help Me!!!!!
  109. Camber Kits with Intrax Springs
  110. Too much color?
  111. exhaust stud aftermath
  112. throttle affecting temp gauge
  113. RARE JDM, EDM "stuff"
  114. Paint Questions
  115. bbk
  116. Engine swap ????
  117. stupid question removing intake manifold vg
  118. just got my girlfriend a new max
  119. whats wrong with my car?
  120. Where in the world is the mobil filter?!
  121. Transmission go Bye-Bye
  122. HEADLIGHT teaser
  123. Question about e36 headlights
  124. Considering a 93 GXE - what to look for?
  125. VE on spray...
  126. Engine Trouble
  127. WANTED: Anyone selling 3rd gen stillen lip???
  128. Curb Weight of '07 Sentra vs. 3rd Gen
  129. Anyone have a pic of 3rd gen in satin black?
  130. Rear Poly Bushing Separated
  131. Automatic Variable Intake Manifold Swap
  132. exhaust pipe, SE/VG
  133. Which is a better Idea?
  134. Engine / Transmission Spec Questions
  135. Loss of ShiftLock?
  136. what type of car alarms do you all have?
  137. Yellow Foglight Capsules
  138. Emission System Trouble Light
  139. thinking of buying a 3rd gen
  140. How to remove a sunroof
  141. Lucas Oils
  142. Who Still Has Their Original 4DSC Sticker?
  143. Rough idle
  144. Moonroof question-
  145. Who still has their original window sticker?
  146. Temperature Sending Unit
  147. Muffler
  148. anyone rolled there fenders?
  149. Will my maxima every need a valve adjustment VG
  150. No High beams ! Need Help
  151. Who has a Stillen FSTB on their 1993-1994 VG?
  152. Stripped bolt head
  153. HELP!! VE5spd
  154. Whistling sound
  155. turbo 3rd gens
  156. 05 350Z rims and tires on a 3rd Gen?
  157. bad lifters?
  158. Zomg I Love Ve5!!!
  159. Transmission gear ratios
  160. WTB: bose deck, I read the sticky, no flame please
  161. Possible to replace axles myself ?
  162. Not exactly the RR "The Spirit of Ecstasy"
  163. VE auto speed sensor repair
  164. ve to vq swap
  165. so i bought another max!!!!
  166. Time is Ticking Away =0 !
  167. RSB mod..:-)
  168. Video
  169. Negative camber. What could cause it?
  170. A little theoretical, but...
  171. Hey guys I need some help with timing
  172. SE vs GXE road noise question
  173. Posting pics
  174. Replacing rack and pinion...what additional parts do I need?
  175. fuel pump problems
  176. Wiring Problems
  177. Possible defective fuel filter?
  178. Starting issue.
  179. brake line part #........
  180. Theres something about...that makes me...
  181. New wheel setup
  182. Got a G-Tech Pro for the weekend, need 1/4 mile tips!
  183. Will A pathfinder VG30E work in my Max??
  184. Are my injectors good or not?
  185. Torque converter install help!
  186. Why Pay Money For Something Im Not Getting???
  187. ELECTRIC SUPERCHARGER:thoughts opinions
  188. Why I like my 3rd Gen
  189. Cruise Control
  190. Slow air conditioning leak
  191. VG to VE swap..Why didn't/won't it work??
  192. VE Headers
  193. Instrument Panel/Tail Light Fuse Blowing
  194. Rust help.
  195. flapping noise from behind glove box..
  196. Need advice on changing rusty fuel lines w/ pics.
  197. Steering to a Good Alignment Shop
  198. titanium exhaust studs
  199. need Stereo receiver removal advice
  200. 4thgen steering wheel in a 3rd?
  201. injector question
  202. Oh noes I bought a 4th gen!
  203. Ac Problem
  204. Look at my new Maxima!
  205. sohc alternator on dohc
  206. Exhaust note change when in water!
  207. Aftermarket condenser
  208. problems instrument cluster
  209. rough idle after wash...but not the intake
  210. How is the market for 3rd Gens?
  211. Return Spring location on a 5spd
  212. taking off rear valve cover on VG
  213. Will they rub?
  214. Tranny leak
  215. Sagging struts?
  216. Trunk Light
  217. Poly Bushings (F&R) and Q45 Brake Install
  218. no acceleration!!!! HELP
  219. car dies with radiator fan
  220. shifting feels spongy on 5 speed
  221. SubFrame Connector Interest Thread
  222. Having problems with tranny. Need help ASAP.
  223. Need Stereo advice
  224. I want your input on this idea..
  225. VE Supercharger
  226. has anyone been to Pull-A-Part.com?
  227. wiring question
  228. Just a little driving video
  229. Headlight Condensation
  230. Which is a better idea?
  231. Trans trouble?
  232. Tire rotation
  233. Engine cuts out, fuel problem?
  234. Maxima doesn't start engine! Tried everything...
  235. Tinting Procedure and Ignition
  236. Where is the Orange Relay on 93 SE?
  237. crooked steering sometimes
  238. sunroof shade
  239. Your Opinions?
  240. Camber bolts with eccentric washers
  241. Iraggi alternators ... my experience
  242. Electric Seat Belt won't move
  243. Has anyone done this?
  244. 117WHP of pure vg FURY!!!
  245. Busted connering lens
  246. Long Story.. Long Night... Maxima Died...
  247. replacing piston rings
  248. Stock VE Injector Flow
  249. Can't get the VTC out, what the deuce?
  250. How bad is this chain tensioner?
