PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. YAY, my baby is on the road again
  2. brake+battery warning light
  3. Carputer in a 3rd gen
  4. Spoiler help on 3rd gen
  5. shifting points
  6. Signing Off
  7. cv axles
  8. power question
  9. Clutch purchase question....
  10. Repainted the spoiler (pics)
  11. What size is this bolt?
  12. 9004 9007?
  13. Battery Problems
  14. New info about VG's I just found
  15. e36 lights
  16. Yet Another Gauge Problem...
  17. Might be leaving the Nissan Family
  18. timing chain tensioner
  19. Pacesetter header vs. warpspeed Y pipe
  20. 5-speed swap pics? (Please Read)
  21. Just Ordered the Wrong Guages...
  22. windshield wipers quit....wiper motor or relay?
  23. Question about reseting ECU
  24. Sunroof Removal
  25. Wont make any sound
  26. auto to manual kit ve only
  27. VTC rebuild question
  28. "interesting" trunk mod
  29. Options for front bumper/cap
  30. VE Variable Intake question
  31. Master Cylinder Q
  32. VG Down for the count??
  33. I'm gong to go broke!!!!
  34. Pleasantly surprised
  35. Installing UDP and Water Pump
  36. VTC repair writeup
  37. Things to replace when changing clutch?
  38. Pics of Maroon SE
  39. $10.99 Eibach ProKits Suspension Springs
  40. Drum - Roters
  41. Well, its been real!
  42. what's the most expensive HU you ever put in a 3rd gen?
  43. Has anyone removed the ABS from theirs?
  44. is the vg and the ve tps the same????
  45. much smoother when in Drive?
  46. Window installation help
  47. How Hard are fuel Injectors?
  48. Engine Condition
  49. injector sets should consist of.....
  50. Tax Return= NEW STUFF!!!!
  51. anyone can do a VIN check for me?
  52. Is there ABS on 94 Maxima GXE
  53. 92 Maxima Bose
  54. having problems with double clutching
  55. ventilation tubes on E36 lights
  56. Fuel Pump/Relay question
  57. How much should I offer
  58. rear injector sub harness
  59. How do I get the automatic antenna to work with new head unit?
  60. Rip in leather seat
  61. it's been a long time
  62. Oh gosh, the engine's got a hole in it!
  63. Which Clutch?
  64. Slow and sluggish when cold
  65. Can I fit this into a 3rd gen?.....steering wheel.....
  66. faulty injector or excessive corrosion?
  67. i think i need a wheel bearing
  68. exhaust rusted out
  69. Need pics of underside and exhaust
  70. Rpm dipping
  71. VE Revs alot on acceleration
  72. Timing Belt Time
  73. Electrical Problem, looking for ideas
  74. R33 Tails!!
  75. Brake Booster Vacuum Hose
  76. VE doesn't run properly, need help :(
  77. valve tapping???
  78. Wiper linkage...broken, need it fast
  79. door speakers possible size
  80. door speakers
  81. VQ30DE in a 3rd gen?
  82. Slight Crankshaft Wobble
  83. shift knob thread size
  84. 3rd Gen 5sp Transmission woes
  85. How to post a pic of my car?
  86. What are some effecient and cheap performance mods?
  87. ABS light
  88. Clutch Question
  89. Bringing her back lil by lil
  90. Swaping Engines.
  91. jacking up the car
  92. Picture request: rear suspension
  93. wet rugs
  94. Transmission oil drain plug
  95. Blower motor resistor
  96. How do I bleed the coolant system on a VE?
  97. How do I get the lenses off my tail lights?
  98. yet another belt(maybe timing belt) thread
  99. Any Meets near TN?
  100. Heat only comes out of defrost vents
  101. ac & heater blower fan
  102. My 3rd gen
  103. Changing a Master Brake Cyl....
  104. Which one?....
  105. G/F just got herself a 3rd Gen!!
  106. AEed?
  107. AC not working. Blows warm air.
  108. Replacing Starter
  109. Possibly stupid tire Q..
  110. custom or ??
  111. Strange Wurring Noise 92 SE Auto
  112. Rear 91 maxima control arm ***.
  113. 92 SE or 92 SE lol
  114. 1 ugly max on Ebay
  115. nailed a curb (pics)
  116. lower temp. sensor. do they have it?
  117. Might be changing brakes yet again
  118. I've about had enough!!
  119. Engine reinforcement
  120. Pics of my Max
  121. some broken VTC pictures from my new Maxima
  122. Fluttering sound between 1500-2000 RPM
  123. foglight bulb burnt out...
  124. Driver side window will go up from inside and down from outside...
  125. What are we gonna do when Matt and Jeff get fed up with 3d gens?
  126. how much is he worth?
  127. broken axle or broken transmission?
  128. Welp, she's finally gone. *sniff*
  129. Y-Pipe question
  130. BBK finally installed.
  131. "The Gorealla Grill" Fo' Real...
  132. Villager: Rattle from the top end
  133. Coolant temp sensor Question!
  134. 5sp Man. Tranny locks up when cold...
  135. 90 max wont start
  136. My Window won't go up!
  137. Water Pump
  138. need help installing new brake lines
  139. Power Steering Noise?
  140. Why replace the PCV valve?
  141. Why I hate the winter...
  142. Wide Band 02 kit
  143. My alarm?
  144. PCV ventilation hose?
  145. Need A Good Machine Shop In Nj...
  146. place to buy KYB-GR2 or Tokico struts
  147. hard to shift in first and third....
  148. Do you have a 1/4 mile timeslip or time for your 3rd Gen?
  149. strut spring
  150. more abs problems
  151. Ban Snipa
  152. How much is y~pipe
  153. Junkyard find
  154. part # for belts
  155. Tranny slipping...
  156. VIN check link
  157. Georgia
  158. Fuel Pressure... Idle/Cruizing/Full Throttle
  159. how to clean the egr valve????
  160. Clock removal. 91 Maxima
  161. Another 92 SE 5 Speed. Ideas on Mods??
  162. Grinding noise at 1300-2000rpm range
  163. Funny thing is...
  164. ok..uhm OUCH - friggin hood struts!!!!!
  165. making the gears smoother with synchromesh fluid
  166. no idea what this part is
  167. detonation, help!!!
  168. stock radio/speaker wire question
  169. Car will idle fine but when it goes into drive it dies.
  170. Auto Trans solenoids
  171. Before swapping...
  172. Getting some strange wheel wobble
  173. Over-heating
  174. do i have a bad injector?
  175. $2006 rwd 3rd gen
  176. High idle speed
  177. took some nightshots (56k not too big 814k))
  178. Door locks not working
  179. New Shoes/Car Wash Pics!!
  180. how do I put a picture in my profile?
  181. Heater Problems
  182. camber is a monster!
  183. How to remove the brake light switch...?
  184. WHAT IS THIS??and why is there oil in it??
  185. Clicking noise when turning
  186. can I put a starter from a 5spd VG into an Auto VG?
  187. Random loss of power? help?
  188. 254xxx miles and now the car is at its last breath
  189. Checking A Tokico Insert
  190. Maxima moved by someone
  191. Idle Surge - Hesitation
  192. power lock problem
  193. Is my automatic transaxle dying?
  194. auto trunk latch wont pop
  195. What happend after braking?
  196. Should I quit now or dig myself deeper?
  197. 350Z muffler on my VE
  198. yet another turbo ve
  199. injectors installation questions
  200. chrome wheels
  201. 240 steering wheel
  202. Pace Setter Exhaust for VE/VG?
  203. car sputtering
  204. looking for a good 5-spd for my 89
  205. Where's Wiking????
  206. My battery is dead
  207. rear deck-fiberglass enclosure
  208. more low end power
  209. Help! What Should I Do?........
  210. Fuel Pump Sending Unit
  211. My buddy's son's VE5 (pic)
  212. just finished a swap
  213. Tranny question
  214. Havent posted in a while... new pics
  215. Road Tripping to get my 5-Speed!
  216. control arm bushings???
  217. Saying hello to another max
  218. well i had fun today (videos)
  219. can i replace my windshield by myself??
  220. delaware valley rust recall help
  221. Replaced O2 sensor yesterday
  222. timing chain question. sounds just like the VTC's but louder.
  223. direct fit mirrors.....
  224. Some one snatch this VE auto
  225. Happy b day jeff:-)
  226. Front Control arm bushings
  227. 92 se leather trim
  228. Road Trip!!!
  229. question about buying a 3rd gen
  230. fan wiring
  231. motar mount part 2
  232. asking a quick favor
  233. 3rd Gen Rear Sway Bar
  234. how to tell how many miles you get in a full tank
  235. 93 VG Auto trans trouble @125,000 miles
  236. Looking for Spark Plug Info
  237. how to make the e36s fit flush????
  238. motor mount wont fit
  239. (56K beware pics) i'm not a lier
  240. Digital cluster problem...
  241. thermostat
  242. Happy New Year
  243. my rack and pinion
  244. Running Rough
  245. Rear sway bar
  246. Need maxine to start HELP....
  247. Big Repair Job on my Max
  248. 92 max on the road tomorrow!
  249. Which HIGH FLOW CAT is best for the money?
  250. Need help with door locks
