PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. 4 sale
  2. is my tranny mount bad?
  3. Auto a/c heater control problems & questions
  4. Want to change all fluids, and question about speedo
  5. On drive but does not move forward.
  6. clear headlight asssembly + HID = blinding people
  7. Coolant Temp Sensor Ohms
  8. Cooling leak near oil pump?
  9. HISSING SOUND WHILE DRIVING
  10. clutch problems
  11. Universal CAI
  12. "Clink, clank" when turning VE by hand
  13. Car audio experts/opinion?
  14. New Injectors + Seafoam = 12 mile smoke trail
  15. How did you install the Exhaust Valve Oil Seals?
  16. replacing cruise control cancel/brake switch - help
  17. keyless entry problem
  18. The Problems Continue...NEED HELP
  19. door lock timer
  20. VG Belts Before Engine Install
  21. AC vents producing fungus smell
  22. 4th gen JL stealthbox?
  23. License Plate Light Substitution
  24. Injector readings
  25. Porting project with pics
  26. tail lamp fuse
  27. Anyone have a flakey speedometer? If so, I might have the fix.
  28. Windshield washer pump not working
  29. Starter Compatibility VG/VE?
  30. wiring/rewiring fogs
  31. my max has problems
  32. will this injector pintle work?
  33. How to install fog lights
  34. Who knows how to reset or find out your Door code?
  35. dash motor problem....?
  36. heater hoses???
  37. When Purchasing a High Mileage VE...
  38. Hot Sauce on Your Harness Connectors
  39. Control arm help?
  40. It's been a long time guys...
  41. TPS malfunction or Transmission?
  42. Has Anyone Successfully Coverted VG30E Exhaust Ports to M10 Studs?
  43. Ode to the VG
  44. Automatic TRansmission Removal Procedure?
  45. Climate control wiring
  46. Can Fuel Line Hose be used as AT Oil Cooler Hose?
  47. Voltage problems
  48. wth??!!! climate control stays on?
  49. Water Pump Gasket
  50. Code 33
  51. transmission rebuild part number isnt the same
  52. Timing Belt: Square Teeth to Round
  53. Misfiring issues / replacing Engine Harness on VE30DE
  54. Anyone tried these SS brake lines?
  55. front axle replacement - advice pls
  56. Im think I have lost or am loosing my transmission!
  57. AC Compressor DOHC compatibility wSOHC
  58. Spotted: Turbo Maxima For Sale
  59. Front struts failed "solid" in compressed state
  60. Noisy power-steering after hose replacement?
  61. interchangeable door lock cylinder
  62. Intake Heal Shield.
  63. I am saying goodbye to my Maxima
  64. Will these E36's work on a 3rd gen??
  65. Are the ends of the injector tips replaceable?
  66. Transmission power light blinking?
  67. Coolant temp sensor question
  68. My 94 SE project
  69. Missfire Headache
  70. My First Thread: Lowering Springs
  71. What is the correct way to get injectors out of the fuel rail?
  72. Heater core problem?
  73. overheating question
  74. Gas mileage
  75. Ignition problems
  76. PROBLEMS PROBLEMS AND MORE PROBLEMS!!
  77. Audi LED headlight mod....
  78. Trouble on hills?
  79. weird power loss
  80. Fuel Leak
  81. Warpspeed Y pipe for VG
  82. WATER BEHIND/ IN DASHBOARD?
  83. Electric drive maxima
  84. Bonnet hydraulic hinges
  85. Which plugs and distributor cap should I get?
  86. Piston to bore clearance
  87. VG and VE 5 speed carrier bearing brackets the same?
  88. why does it do this?
  89. Thermo Amp?
  90. Pulls to the side during acceleration...
  91. Speaker Upgrade
  92. ve vg transmissions
  93. Front Sway bar end links Installation Problem!!!
  94. best way to wire fogs?
  95. Hot tanking CranKshaft cont....
  96. blower fan relay location
  97. SPARK PLUGS QUESTION.
  98. Is it Safe to Hot Tank the Crank Shaft?
  99. Why are racing air filters illegal (in CA)?
  100. my return after a year and just found out my problem! (dying battery)
  101. Leak in the trunk?
  102. Performance Air Filter??
  103. Replaced WS-Y with WS-Y SS
  104. good deal?
  105. Swapping Steering wheels.
  106. Any Tips on How To Get Out of This Situation
  107. rpm dead
  108. Water Pump Noise
  109. Picture of mounting the 3rd brake light?
  110. Can Someone Comment on How To Replace Fuel Pipes & Hoses to Tank?
  111. Classic
  112. Has anyone had a timing belt break?
  113. BRAKE PADS???
  114. Side Marker Lights MOD???
  115. image or diagram of tensioners
  116. Fuel Injector *WIRES*
  117. How long do VE timing chains last??
  118. how much would she be worth?
  119. Pintel Caps
  120. I'm getting really tired of this
  121. Power Steering Belt Replacement
  122. 92 maxima se manual sounds like worn bearings or loose pulley??
  123. Homemade Heatshield finished
  124. Left Rear window won't go up
  125. blower motor sticking
  126. the weirdest thing
  127. Pilot Bushing, Clutch Job
  128. Thoughts on buying another VE 5spd?
  129. Curious What Your Thoughts Are on This Filter for our old Trannies
  130. Transmission problem?
  131. Rusted oil pan leaking :-(
  132. Just seems like the problems keep coming
  133. Would some kind soul look in their FSM..
  134. Can't find manifold?!
  135. finally fixed all rust spots
  136. MAF Sensor, 4 or 5 prong connection???
  137. What Does the Front Sway bar actually do??
  138. Power Steering Leak pinpoint??
  139. Strong Fuel smell inside the car at Startup??
  140. tranny Qs & removal (after doing extensive search)
  141. couple issues
  142. Soundproofing
  143. muh baby got hit
  144. Starts, runs a few seconds and dies...
  145. is my trans slipping?
  146. remember last October when my forward LCA bushings unseated themselves?......
  147. oem wheel size?
  148. VG oil leak
  149. Suspension Upgrades
  150. VG-5 Swap
  151. VTC Spring
  152. We have it made
  153. Star shaped screws behind the dash??
  154. Noisy Lifters??
  155. show your gauges in your gauge pods...
  156. To Sell or to Change the Motor that is the question.
  157. GXE VG30E Engine Photos
  158. Where to get Tokico Gland Nuts?
  159. Struts
  160. Engine Noise and Fouled out Plug...Help
  161. Can Other Models Cylinder Head fit VG30E?
  162. Power Loss On Acceleration...
  163. Thinking of rebuilding caliper
  164. Injector Harness Question
  165. Damn crank pulley
  166. Master Window Switch Repair
  167. Rear Strut removal??
  168. valve cover gaskets
  169. $*^@*# cracked my bellhousing
  170. Another Window regulator question
  171. I hate these auto seat belts!
  172. Should I Clean The Hydraulic Lifters
  173. Control arm bushings
  174. Next Hotter NGK Plug?...
  175. ECM Replacement?...
  176. 92 maxima se wont start?
  177. My 1st Maxima thread :D
  178. Timing Belt Kit??
  179. New Radiator cap, and A Big difference in coolant pressure!!
  180. HOW CAN YOU TELL IF YOUR INNER TIE ROD IS BAD??
  181. Mitsubishi Galant weighted shift knob
  182. VE finally at machine shop
  183. Anyone Have a Clue Why Manifold Studs Are Narrow in Middle?
  184. question about k&n recharger on generic intake filter.
  185. Cause Of Wet Plugs?
  186. Car stalls after running, then wont start
  187. JDMblem(s)
  188. DOHC swap on VG?
  189. pick-a-part help
  190. rear winshield deflector/spoiler
  191. Any Tips on How To Separate Intake Manifold VG
  192. Ignition Upgrade for VG
  193. 92 SE 5spd
  194. Rocker Shaft Bolts - Position Important (Photo)
  195. front bumper mask suggestions
  196. Suspension problem, or axle problem... advice needed
  197. Will 1995-1999 Bose/Clarion HU work with 92-94 Bose system?
  198. STS mods ???
  199. rack bushing replacement
  200. Help Car Won't Start
  201. Removing yoke from striking rod
  202. Window.... tabs?
  203. Easy Mirror Mod
  204. Gaskets...Mounts...Manifold...
  205. What Gaskets do i need when i replace my rear injectors?
  206. CarFax Help......
  207. Torque converter lockup
  208. getting another VeeGee tomorrow (plus another addition to teh family)
  209. Bad Injector or Bad Coil Pack?
  210. Parking Lights Out Again !!!
  211. Starting up after long time
  212. Muffler question
  213. 92 SE: Recent Purchase trouble shoot
  214. Why is this bolt here??
  215. Anyone Know if This Camshaft Will Fit
  216. Is there much of a market for used Engine parts?
  217. New Strange Problem(s) going on now?....
  218. Heads up on JWT ecu's
  219. I don't Know How You Guys Removed that RH VG Drive Axle
  220. pacesetter headers w y pipe or wsp y pipe?...
  221. What are some good spark plugs?
  222. suspension overhaul!!! (pics)
  223. fog light advice/recommendations needed
  224. corner lights wiring question
  225. Just got a Magnaflow... But it sounds like CRAP! Need Help
  226. Should I Purchase? 92 GXE or maybe SE
  227. slight hesitation when accelerating?
  228. 2 SCREWS ON TOP OF EACH FUEL INJECTOR?
  229. Good project car? 92 SE Auto
  230. Wheel bearing replacement
  231. EGR VALVE BOLT SIZE??
  232. wheelwell clunking
  233. THERMOSTAT QUESTIONS??
  234. just wandering
  235. Just wondering if this was possible
  236. Stress fractures in transmission bell housing
  237. MAF?? or other things?
  238. STILLEN BODY KIT "how to?"...
  239. Flat Tappet Cam
  240. power steering fluid vs transmission fluid
  241. Acceleration power loss
  242. temp gauge
  243. 5spd swap from 89 SE to 91 GXE
  244. Valve Stem Seal
  245. VG Injector Pintle cap's....need it?
  246. digital conversion
  247. where to get a 3rd gen carbon hood?
  248. Disabling "key release"
  249. selling the vg30 5speed
  250. 1990 A/C Evap
