- Unlock trunk to start car?
- rack and pinion?
- changing VG30E exhaust manifolds question
- Flushing The cooling system!
- Foggy windows, moisture problem?
- Driving my VE again..
- digital dash swap question
- still having cruise control issues - help
- Won't Turn Over.... Video Attached
- Reading High temp..but why?
- FRONT SWAY BAR QUESTION???
- Does this rear main seal need replacing?
- Anyone Have a Makeshift Way to Remove Crankshaft Pulley?
- cusom made headers
- Question about MAF adapter
- engine mysteriously dying while shifting gears.....
- Thinking about selling, what should I ask
- Failed emissions.....Thoughts?
- Back on the road - 3rd gen VE5
- seperate vtc's with a clamp+sockets!
- Slow start, i already searched
- Shift Lock/Brake Fuse burning out
- need help fast
- For The Don's & Don's To Be
- question about reserve radiator tank
- UNUSUAL SParK KNOCKING FROM ENGINE
- 6inch speakers in the Front doors??
- Changing Fuel Injectors????
- D.I.Y. HAI questions
- driving without alternator adjustment bolt
- mah new cah!
- odd chaffing/clicking noise for a few mins when the car's cold (with video)
- My car was jacked, I need an AM alarm
- Aftermaarket Radio Stopped working?
- where to buy e36 headlights?
- new battery terminal and wires
- oem fog lamp glass
- New [Bigger] Ride
- Failed Emissions Test
- My new tune up + MPG reading
- Longer exhaust tip effective in quieting WSP+magnaflow exhaust
- My transmission acting funny
- Got everything worked out (tuning) now how would I get more power?
- Hose Barb Terminating Fuel Lines
- Transmissions done for probably, what should i pay for a new one?
- Power to my power windows?
- CEL: Code 51 Replace Injectors
- Some more/better pics of my "new" VE
- Vent.....I hate VG Injector's..............
- spoiler options/advice
- cruise control issues, help
- No Fuel Pump Fuse...what the...
- vg30de head studs???
- Injector Changing Tip!
- changed the fuel filter today
- bose 6 disk changer upgrade
- REAR WINDOW PROBLEMS!!!!
- O2 bung
- Finally Getting Around to Re-routing my intake infront of the battery..
- How much R12 does the ac system hold?
- overheating
- 1990 VG30E installed... Finally!
- Tracking Down Misfire issues...
- ABS "chatter" on take-off?
- What color are my injectors? and what is that cap called that screws down on top?
- Pulled upper plenum and found some oil
- Removing stuck spark plugs
- SPARK PLUG WIRES??
- Trunk Bike Rack
- STRUT TOWER BAR QUESTIONS????
- Can one go into detail on how to install a subwoofer?
- new set of wheels on the beater!
- might buy a 3rd gen..need some advice
- Blower Fan Motor Replacement?...
- second gen 5spd swap into vg auto
- Auto trans fluid
- Oil Drain Pan Screws
- rediculous brake light issue
- Would You Feel Confident Dressing Your Head Gasket?
- Removing Back seats
- Wheels fitment question, using spacers?
- Pictures of the day
- 1989 VG engine - Higher Octane Gas Requirement?
- Changing transmission seals/gaskets?
- Options for Bose speaker replacement?
- Sunroof
- power steering pump
- Broken ground strap on exhaust hanger bolt
- Where is the transmission ground?
- in-cabin water leak from rain
- venom programer chip
- In desperate need of HELP! Clunking sound coming from rear right strut area!
- high idle low idle?????
- fog light opinions
- So just how rare was the GXE auto climate control?
- '02 rims fit a '94 max?
- Cheapest Online Retailer(s) For VG Re-Ring/Overhaul Kits
- What kind of mileage do you get?
- SE vs GXE sway bar??
- VIBRATION AT HIGHWAY SPEEDS FROM THE DRIVER SIDE OF CAR!
- Would Bad injectors cause the engine to miss while driving???
- Replacing valve cover gaskets (VG)
- VG Cylinder Head Bolts Reusable?
- 92 maxima SE white smoke coming out exhaust
- Carjacked!
- Power Steering Pump Questions
- 92 VE 5spd
- Ignition Coil Replacement for VG
- Throttle Body Bypass Kit
- Replacing Bose h/u
- Question regarding BBK Swaps
- So I bought another VG auto
- Where is the speedo sensor?
- Anybody ever actually "fix" their alarm?
- Watch out for flying coolers on the highways :(
- How to tell SE trim?
- 92GXE pulling to side while driving.
- Need favour from VE guys
- Once The Rear Slide Pin is Seized - Is Torque Member Junk?
- A/C Question
- Alignment problem or something else?
- my max updates
- Danger Gas+Spark=Fire (Funny Injector Changing Story)
- About to rebuild vg auto any advice on this kit or anything?
- VG Auto Tranny Issues....
- Caliper, Rotor and Pad
- VG Header/Ypipe
- How Did You Separate the Inner Tie Rod Joints?
- Replacing my brake and fuel lines questions
- dremel made me do it
- How advanced to you all run your timing?..
- Injector 2 & 6
- Injector Plastic Tip....Do I need it?
- Stubborn starts
- This car is a real PIMA !!!!
- egr removal
- speedometer going crazy
- Rims
- Need Power Steering Pump
- 4th gen Pacesetter STS fit the 3rd Gen
- fixing rear defrost strips
- Injector CC problem
- 91 Maxima's in the shop.
- my 92 maxima has a miss
- Troubling no Start Issue
- Does Y-Pipe have pre-cats?
- Spark Plug Look...Hmm
- rack and pinion steering leaking???!!
- Manually Firing an Injector???
- Temp/Perm Fix for Failed Regulator
- Sputtering at Startup to WarmUp...Hmmm.
- 1990 GXE Sun Roof Seal?...
- 91 Maxima. Starting Question...Security System causing this?
- 1991 Maxima Driver side tail light cover
- 1992 Maxima GXE Rear Brake Conversion
- Something I Was Wondering About?
- installed fog lights = low battery
- OK.Before I Call My Local Nissan Stealership
- Intermittent upper end rap when below 50 degrees
- Wheres my pcv valve located
- So I bought another '92 VE 5 speed
- 89-94 NM Diagnostics...
- Should I VG 5spd vs VE Auto...which to buy..:)
- How are you guys???
- need ignition help ASAP
- Fog Lights
- Greeny's Gone :sadwavey:
- Bose Scosche adapter
- bought a 92 max today...
- Help me clear out the confusion..
- Selling the max...
- Power Window Diagnosis Please
- Question about rear big brakes
- E-Brake not disengaging?
- clutch ?
- I pulled a Matt93SE...
- Hesitation after power washing
- overheating
- Brake light switch question
- Car Vibration
- exhaust manifold gasket and/or intake manifold gasket
- End of transmission.
- Car will not start
- Where is the vg auto trans filter?
- tranny shiftin issues...
- Should This Be connected To Something??
- No power to the ECU/No Spark
- Wheel & Tires what will fit?
- Rough Idle/ Poping sound/ missing sound comming from muffler??
- LESSON LEARNED
- Should I buy this VE 5spd
- battery isn't charging - help
- Tranny prob...??????
- OXYGEN SENSOR????
- 3rd gen floormats??
- Turn fuse blowing when ignition turned off
- Window will go down but not up?
- HOW DO U UNPLUG THE FUEL INJECTORS TO CHECK THEM??
- Not a good end...
- Question for Stereo Experts
- MT Transmission Gears ?? 91 vs 96
- 3rd gen maxima VQ swap V. craigslist ad questions
- Ignition timing?
- Custom Seat ideas
- 2 Electrical Questions
- What do you guys think?? 3rd gen for sale I want to look at
- new cluster odometer dies again?
- REMANUFACTURED FUEL INJECTORS????
- Best Way to Seal a Small Radiator Crack?
- Photo of GXE Tranny If Anyones Curious
- Best Power Band Plan
- shifter issue
- 4th Gen engine in a 3rd Gen. maxima?
- RE4F02A Torque Converter Install - Phasta Write Up
- VG Auto dies when put into gear.
- Fog Lights - re-wiring HELP !!!
- Theres something wrong with my 93 maxima. HELP!
- Where is all the oil going.
- Misfire issue
- AE Door Sills in a 3rd Gen & new shift boots
- locks not working
- Need help with fuel system / ECU issue
- Black interior
- need opinions
- Transmission concern......
- Bad EGR valve or Bad Fuel Injectors???
- Remaning a Starter
- Tan seatbelts FTL
- VE HEADS
- How Do I Fix an Error Code 51
- Jiggle Sound Gone
- Rough Low Idle Speed????
- help unclogging moonroop drainage pipe
- Replacing A/C Components Myself
- new PS hose, new groan/whine
- can these be used on a VG maxima?
- Driver's window one-touch down fix
- So, what are the odds my JDM VE has new VTC's?
- My Alarm Goes off Unexpectedly Usually At Night
- Any Tips For Driving In The Driver Side Front Axle/AT Oil Seal?
- injector no resistance
- New "Used" motor is in - Same old Problems :(
- Air conditioning! Is it on or off?
- Throttle body cleaning procedure links are dead!
- Power Steering Pump Replacement -- degree of DIY difficulty? Please chime in.
- 1993 Nissan Maxima 3.0L SOHC low voltage problem 11.5-11.6V w/ VIDEO
- Who has had to replace their ASCD relay fuse?
- Something I never experienced
- Lost thread on Wing / Spoiler repair
- Sputtering/hesitation related to worn VTC Sprocket/Springs?
