PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. My ACC fan is stuck on high
  2. noisy brakes please help!!
  3. hail storm.....how do you pop dents on this thing!!!!
  4. antenna adapter
  5. 300z engine question
  6. brakes
  7. 92 GXE vs 04 Mini
  8. Just washed the car, so I thought i'd show some pix
  9. what mod to start
  10. what to do
  11. Rear deck removal?
  12. grounding question...
  13. bad weather, quick alternator question(s)
  14. Tint Pics
  15. speedometer
  16. shifter knob hell
  17. Trailer HItch?
  18. Jumpy Shift- Should I be worried?
  19. throttle body upgrade
  20. Fuel Injector Removal
  21. Starting Problem
  22. anyone have a pic of a 3rd gen w/ a nose mask?
  23. Is this the hose to insulate to get colder air?
  24. my last thread; yer killing me VE
  25. Close to losing my max??? help
  26. VE Questions
  27. spark plug gapping
  28. banjo bolt on P/S pump
  29. recommedations on tint?
  30. Helios 7000k HIDs
  31. Cup holder in center ( between seats)??
  32. What to do first???
  33. 2000 Maxima Wheel
  34. Replaced my Rear Struts...
  35. Great Deal so i bought it, But...
  36. Need timing help
  37. 5 cylinders?!?!
  38. Automatic Seatbelt Question
  39. What would you guys do? Max or T-type?
  40. Chain or Belt
  41. Where To Find Jdm Motors
  42. Marble Madness under the hood?
  43. Plugged cat? (poor mileage...help!)
  44. exhaust studs
  45. getting a SE auto that wont move- sudgetions?
  46. brake light inquiry!
  47. rims pics
  48. LSD in my 92 SE?????
  49. manual tranny filler hole
  50. Wtb - 92 Ve Maf
  51. Rear ended
  52. My baby is dead - again...
  53. exhaust...
  54. seatbelt warning light comes on? O2 sens quest
  55. should I let maaco paint my car?
  56. After an Alternator install question
  57. VE Axles
  58. Need help with wiring of E36 lights
  59. Hey guys!!!! It's the REAL 5 ltr. beater talking........
  60. axle question
  61. Hi Flow Catalytic Converter!!!!!
  62. Question about running engine without oil cap
  63. List of swappable engines?
  64. Power Steering Pump
  65. Removed rear seats to check for rust recall..
  66. Anyone with the euro E36 lights please help!
  67. elecrtical question
  68. Radiator
  69. My baby is back!!
  70. Bulb check relay purpose
  71. Tranny back on, now rattling problems...
  72. is there a "how to" for resistor mod
  73. High Beam switch dosent work!!!
  74. Interior Windshield Haze
  75. problem with sway bar mounts busting
  76. exhaust size.
  77. dyno my turbo 3rd gen not real happy
  78. POST:ONLY if you want a Carbon fiber trunk
  79. VE Exhaust Manifold Outlet Size?
  80. Foggy Fog Light: Does it come apart?
  81. The gas smell
  82. Stock Timing
  83. Is My max totaled?
  84. stock wheel cleaning
  85. Any 3rd Gen drivers in Michigan?
  86. 2 new issues
  87. first rust forming, EEEEEK
  88. rear struts
  89. Odd Headlight issue
  90. My Rott Job
  91. replacing E-brake
  92. Trunk pop wire
  93. Need Help!! My Max Will Not Start!!
  94. idle
  95. ac condensor/dryer
  96. transmission question
  97. Easy window tint removal
  98. I love the smell of fresh paint
  99. spark plug info needed
  100. Repair Information!!!!!!!!!!!!!!!!!!!!!!
  101. Replacing injectors....any tips
  102. Grey Leather?
  103. Brake pedal goes to the floor after rebleeding. What does that mean?
  104. Removing Cat Back
  105. rb25det swap
  106. projectors Suck..(update)
  107. Bad strut or worn bushing??
  108. possible leaking injector, what to look for?
  109. starter is maybe going?
  110. I need to drive up hill
  111. Sprint Suspension Spring kit.
  112. CF Trunk Lid
  113. alternator function question
  114. eibach drop in the back??
  115. Possibly ridiculous question...
  116. rear stb
  117. Exhaust piping size
  118. New 1/4 mile record for the fastest NA VE Auto!
  119. Help with exhaust system please.
  120. Turbo Question
  121. eBay UDP
  122. will this steering wheel fit?
  123. Front wheel bearings
  124. Price on leather seats
  125. tensioner wheel/pulley
  126. wsp y pipe with pacesetter headers
  127. removing pass axle
  128. ignition coil boots???
  129. Grease inside axle boots
  130. re-route pcv line to intake
  131. bmw headlights
  132. Want quietest exhaust system for WSP Y
  133. Removing rear studs, how much to drop engine?
  134. car wont wont stay running
  135. 2k to blow, what to buy for the max??
  136. FSTB instal - holy cow!!!!
  137. Corner lights melting?
  138. How much does JWT advance the timing?
  139. new brake calipers
  140. VG UDP Installed.
  141. results...
  142. Rust/Rott
  143. Tranny Cooler question
  144. Another 3rd gen question
  145. 1990 Aztec red paint code
  146. shift solenoids on a VE
  147. Heads
  148. dark spot on splash guard below fuel vapor canister
  149. one more max!
  150. axel install
  151. Best shocks/struts for blue sprint 2" dropped springs?
  152. ks wiring harness replacement
  153. What is this plug for?
  154. Need your write ups/opinions please
  155. WSP VG CAI Installed! pics
  156. FuberGlass Subs
  157. 3 maximas
  158. Wing?????
  159. Does anyone have a write up on a install of lowering springs
  160. Water pump estimate
  161. Help!!! Car cuts off!!
  162. Dash Light went out...
  163. auto tran fluid check, cold or hot?
  164. Y-Pipe-Question
  165. anyway to get ahold of more than just touch up paint.....
  166. Help with power door locks
  167. parking brake / rear caliper issue
  168. A Sad Goodbye
  169. Window electronic problems
  170. to test KS while motor operation....
  171. 370cc injectors
  172. leaks everywhere
  173. Trying To Quiet My Car
  174. overfill hose
  175. Replacing my Hood
  176. 4DSC decals
  177. few new pics of my car; questions about our stock wheels
  178. brake squeal
  179. VG30 Spark Plug Question
  180. A.S.C.D. cancel switch?
  181. Confused
  182. Red Maxima
  183. Tach Signal Wire (Remote Start)
  184. warpspeed question
  185. Coolant problem!!???!!
  186. Driveshaft
  187. Just tested my ignition coil packs....
  188. For cleaning the MAF, carb cleaner?
  189. What would cause an )2 sensor to fail?
  190. Need Help Motor mounts!! Never thought it will so had!!!
  191. front end rehab........is this what I should do?
  192. Clutch Replacement Horrors
  193. will these tires fit??
  194. This Grounding Kit Any Good?
  195. VE thermostat temp
  196. 1/4 watt or 1/2watt resitor for KS?
  197. REBUILT Trans Problems
  198. bought new leather foam wear question
  199. Crank seal question.
  200. How much could I get for my 3rd gen?
  201. oil problems???
  202. Fire Wall Help
  203. Squeaking noise when driving on "un-even" roads
  204. big 3 (dont kill me)
  205. VE engine swap
  206. Remote start....alarm going off??!?!
  207. Engine Help!!!
  208. transmission help!!!
  209. Come look at my "new" Corbeau Seats
  210. Remote Start
  211. 5 spd tranny shifts hard....
  212. Will i notice not having 2 antennas?
  213. Temp gauge maxed...help!
  214. I A A idle air valve....
  215. what the ??? whats wrong with trans
  216. got new pic w/body kit and rims back on
  217. 91 gxe factory amp.. non bose
  218. spark plug q's
  219. planning on a 2,500 mile trip
  220. Floor Mats
  221. A/C with Digital Air conditioner
  222. Behind glovebox water .
  223. Cheap mods + Low budget = low power
  224. 1995-1999 maxima engine and trans?????
  225. Leaking front & rear seals
  226. aftermarket Cam kit
  227. Turn Signal Hell
  228. Smoke!
  229. supercharger
  230. transmission advice
  231. How To Go Turbo With A Vg?
  232. (Stupid?) question
  233. Whats the Diameter of the fuel return hose?
  234. strut and mount replacement
  235. Need some help!!!!
  236. BBK will this work?
  237. Digital to Analog Dash Conversion
  238. Ignition upgrades?
  239. how to get antenna out?
  240. Just Did Tune Up And....................
  241. having a bad day? this will cheer you up --> VE5spd + laughs
  242. door hinges...getting worse
  243. Bomex kit for 3gen max?
  244. Disappearing coolant
  245. Can someone help me with this????
  246. timing belt
  247. rock through window = broken window
  248. Help!!!! Disobedient passenger window........
  249. Screwed up. Turn signals aren't working...
  250. Fuse???
