PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 [72] 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. VE30DE and VG30DE
  2. How dedicated are you?
  3. Battery dead, car now whacked out!
  4. OMG This is just plain SICK!!!!!
  5. Small 'mod' I did :)
  6. Radiator fans stopped working???
  7. grounding VTC
  8. Post pics of 3rd gens with 19s
  9. power loss in 91 maxima
  10. Eibach & KYB Install complete!!!
  11. new alternator, upgrade?
  12. LEDs in tail lights of 3rd gen
  13. synthetic oil and knocking during startup
  14. Weird Tranny problem
  15. '92 Won't Read Codes (CEL on) - WTF...
  16. removing abs
  17. failed attempt at vtc rewire
  18. Will this Visor with TV fit in my Maxima?
  19. CBK Kevlar brake pads will these fit.......
  20. Air Ride Suspension
  21. How to Change the Rear Sidemarker?
  22. Removing shift knob
  23. Window not going down all the way
  24. Oil pressure sensor thread size
  25. Transmission problem?
  26. Grounded out with a Lowered Maxima
  27. Voltmeter Gauge Installation
  28. Ignition Wires - Question
  29. Cruise control ?
  30. Headlights Not Bright
  31. Front Corner lights cracked
  32. Rear Power Windows Busted
  33. wheel stud broke!!!
  34. Driving impressions after replacing the Knock sensor and a few other things
  35. the org. is awesome
  36. Could someone please tell me the fpr pressure settings
  37. Changed valve cover gasket today...pics
  38. Any Eastren Ohio Max
  39. Rear speakers quit?
  40. Rich
  41. Vg30dett?
  42. A/T fluid used as P/S fluid?
  43. E-Brake Tightening
  44. ecu for the 89-91
  45. Where to mount my amp?
  46. Motor Mounts
  47. Oily residue in intake manifold normal?
  48. Oily residue in intake manifold normal?
  49. NEW 90'SE(car/driver)
  50. New engine or 4th gen max
  51. Blew my timing belt... ARRGH!!
  52. wierd idle...
  53. new steering wheel too...
  54. tune up
  55. EGR Valve
  56. High Idle at cold start then stabilizes
  57. What Kind of Mileage Does Everyone Have?
  58. VTC Ticking????
  59. Spring Break
  60. is the ECCS control until a ecu
  61. ticking
  62. lookin for good street/strip cams
  63. 5th Cylinder.. Not working??
  64. Brake rotors
  65. What r ur opinions????
  66. digital touch entry problems
  67. 1 hour to go!!Y-pipe,stageII clutch, fidanza, 18" rims
  68. Mark who bought my maxima in TN
  69. Removing the rear deck?
  70. Tranny Question?
  71. Auto trans problem?
  72. Trouble?
  73. wheel offset
  74. Newbie question
  75. Missing When Wet/Cold
  76. Water pump
  77. Anyone in STL that can help me replace my window regulator
  78. 3rd gen supercharger: Will it ever happen?
  79. stock fuel injectors flow rating??
  80. 3rd gen MAFS vs. 4th gen MAFS
  81. Dont want a rice sound, what muffler should i get....
  82. maxima guague pod
  83. finding spark plugs and wire
  84. Mileage
  85. do i need a new tranny?
  86. Sprint Springs & ST Shocks???????
  87. will an fstb that fit on a VE work on a VG
  88. Top Speeds
  89. Has anyone tried a 35 offset on a 18" rim?
  90. new sway bars
  91. brake cost
  92. 300zx ecu
  93. 92 Maxima cold weather stalling
  94. Spacers needed for back rims....
  95. tail lights swap
  96. guess who's b-day is today????
  97. fine at dark and weird at day
  98. Quick aftermarket alarm question
  99. BlehmCo ground wire kit
  100. Air Intake
  101. I did a simple little aftermarket alarm LED mod today and did a writeup
  102. Help. Idle fluctuates,car misfires,but runs good??
  103. Any Cefiro experts ?
  104. VG30 engine problem
  105. New Steering Wheel (pic)
  106. Vids and Pics of my High Stall Torque Converter!!!
  107. Remote start/Alarm with trunk release question??????????
  108. Eibach & KYB writeup
  109. Gas Door/Lever
  110. performance auto trans
  111. Monroe Sensa-Track struts..
  112. short shifter question
  113. BlehmCo RSTB installed! (pics)
  114. car runnin like a piece of f-in sht
  115. Removing Door Moldings
  116. Updated Cardomain....
  117. Adjusting Headlights
  118. sway bar and bushings
  119. 92 Max Downshift Problem
  120. Door Lock Actuator?
  121. Power Steering ...
  122. e36 headlights
  123. Car engine
  124. sunroofs, shades, and steering racks
  125. Should I replace all the injectors or just the bad one.
  126. If I were to make...
  127. The starter replacement instruction?
  128. Firewall?
  129. regular E36 vs. projector E36
  130. Rubber roses that go in and out of the firewall
  131. VIN check anyone??
  132. Lighted trunk Plate
  133. 91 Bose Swapout, Which years?
  134. 91 Bose Swapout, Which years?
  135. Rear Windows won't go up or down
  136. removal of upper intake manifold require coolant drain for 89?
  137. Custom grill with a headlights conv. - your opinion?
  138. How can i tell if my max is misfire?
  139. transmission
  140. Dash light Change?
  141. Clicking noise draining battery?
  142. EGT guage freaking out
  143. My 4 cylinder VE20DE engine..
  144. any one have a good 5 speed tranny?
  145. Removing shift-knob
  146. What size JSP Touring Wing is Recomended?
  147. Funny Noises from the engine.
  148. Starter for manual VE
  149. VG30E Engine Diagnosis
  150. Window Regulators/Motors
  151. Indication of a bad Rear Main Seal? Pics.
  152. exhaust stud symptoms
  153. One more headlights conv. done (with AE)
  154. Consult info
  155. WTB: Bose amps
  156. Frame Damage?
  157. lack of power until 3000rpms on my VG
  158. starter squeel/honk...lube it?
  159. Ignition control module
  160. 93 GXE -- Lumpy Idle/Faulty fuel gauge
  161. Ve to Ve Swap Concerns
  162. I think I found my proplem
  163. VE30 Engine Diagnosis
  164. bad O2 sensor symptoms?
  165. VG30DE turbo
  166. Ball Joints...
  167. Where Is The Coolant Temperature Sensor?
  168. keyless entry on maxima used cars
  169. RSTB in, thanks BlehmCo!
  170. A bunch of stuff
  171. Ignition Coils Resistance
  172. Leaky roof...
  173. Owner Manual
  174. intake for vg
  175. backing up out of the driveway cause car to shack
  176. suicide seat belts messin up
  177. Happy to have my Max back!!!!!
  178. Collectable 3rd gen. Maxima
  179. What are clutch pins, can they go bad ?
  180. Motor rotation ?
  181. Heater controll valve stays open
  182. WEIRD, outside temps effecting engine.
  183. 3rd Gen Maxima In GT4
  184. Aftermarket brake lights search?
  185. Getting windows fixed..where to find part
  186. Running lean rich? vaccuum leak?
  187. Question
  188. Bushing and Control Arm
  189. Fixing up 91 SE (struts F/R and Bose problem)
  190. Anti-lock Brake Bleeding
  191. exhaust cutout
  192. Blitz or K&N
  193. Just installed OEM BMW's.......minor problems
  194. Yeah or Nah on A 93 5spd
  195. Bras?
  196. 5th gen fstb for a 3rd gen car?
  197. 3rd gen stereo
  198. Could it be fuel injector(s)? 91 SE
  199. Stolen Max
  200. tire question
  201. `92 DOHC running wiered
  202. Look what came in the mail
  203. full warpespeed w=exhaust and lilpiggie CAI
  204. Whats wrong with my max?
  205. Dual Exaust on any Maxima's?
  206. Buy a 4th Gen or Tranny Rebuild
  207. Short throw shifters for 3rd Gen
  208. sellin the max
  209. Walbro255 LPH Fuel Pump Question
  210. Power door lock weirdness
  211. is this true
  212. 5-speed swap
  213. Fantasy interior Ideas?
  214. Break in clutch?
  215. fuel pressure
  216. Timing Chain Tens, A/T, and 2 other issues.
  217. Need Audio Help!!!
  218. clutch
  219. Brakes Leak When Cold
  220. unusual clutch pb, please help
  221. fuel pressure test
  222. Master code keyless entry (Aussie RHD)
  223. Fuel pressure regulator
  224. SE seats in an S model
  225. 17" 2K SE wheel question
  226. fstb
  227. Loosing Power, Need Help
  228. replacing door panel speakers
  229. sloppy rev when car is started
  230. Interior Light Sizes...
  231. Looking for Intake & Exhaust 92'
  232. Temp controls don't work; clicking from dash
  233. Torque steer
  234. squeal driving me crazy 92 GXE
  235. Supercharger
  236. anyone with an org sticker...
  237. re: good battery voltage?
  238. Vg30et
  239. I need a tranny
  240. Ground Kits
  241. electrical problem
  242. free car fax report
  243. QUICK Question about 3rd gen parts
  244. Mustang 17x8 wheels.....pls. check weblink and suggest...
  245. Do any 3rd Gen maximas have keyless entry or anything close?
  246. loss of power at 2200 to 2700 rpms
  247. Anyone in the Pittsburgh/ New Eagle Area...
  248. Trim Swap?
  249. Needs tips installing my 3K stall torque converter -->
  250. Weird Problem
