- 03 automatic fstb fitment issue -
- Order Brake Pads/Rotors Now...Decision Time
- Sway Bars
- Car died on highway-Help!
- High Cost of Cabin Air Filters
- Car vibration/shudder from 35-50mph??
- Wiring harness
- AC Won't Turn Off... Help Please
- Just purch'd Kumho 235-50-17's on OEM wheels...
- Carfax
- Full red LED swapout
- A/C question
- AC problems during high heat.
- manual transmission noise
- Why it runs better on 87 than 91-93?
- Help! HIDs were stolen.
- whats the best way to clean the IM....
- Odd Cruise Control
- mud guard question..
- Idk wat to buy
- Window Stuck Open
- H3 HID Kit in OEM FOGs question for owners
- whats going on with the CustomMaxima smoked REAR corners?
- Progress RSB - impressions
- anyone know the answer to this question?/....
- cruise control quit working...wtf?
- 00-02 same as 03
- Engine gurus...please step in...
- cattman CAI or cattman COMBO WAI
- opinions of stock brakes?
- Battery and Brake light ...
- Headers
- Another Cam ?
- pics of "M3" Style Rear Lip Spoiler, 5th gen
- STS is hard to shift?
- Ebay exhaust
- Stock muffler -vs- nonstock
- Carbon Fiber Exhaust Tips
- Here's my luck with Umnitza DDE's
- where to order front/rear clear corners with bulbs?
- Do i need rear fender modification....
- Got my revenge on the Stealership
- bad news... worst mood...
- Re: Driving on three 19's... one 15
- 3.5 oil consumption
- y-pipe on factory exhaust?
- New Products for the Maxima
- Progress report
- What to choose?
- For those who think blowby is minimal....
- ••ü•• REVERSE HID - We're Almost Done - Taking Requests
- Has Anyone Installed An Intercooler?
- Can Someone Help?
- Have y-pipe + Frankencar catback + intake? step in...
- Improving A/C performance
- Airbag Sensor Failed
- Rotors and Pads Recommendations
- Front License Plate Bracket
- Opinions on the 2002-03 Stock Navi System?
- Best mod?
- which wire for the LED alarm
- Removing side vents
- battery question
- Get injectors & tb flushed??
- help! metal grinding noise from left front tire area when turning right
- JMD taillight probs
- want to try this mod for my 01
- What brand of RSB should i buy?
- bad maf replaced...still throwing p0113 code...will 5yr/60k mile warranty cover?
- Projector headlights
- need help: problem w/ the car
- sway bar bracket bent. what to do?!
- LTB vs. FSB
- Some engine n other questions...
- The dreaded clunking from the front strut...D2 owners step in...
- Camber, caster and toe
- Parking light and Side marker bulbs
- Alright u can call me stupid but...
- Anyone have problems with their discs warping?
- Need opinions and help.
- Error Message on stock CD player.
- Warranty issue, any ideas???
- Engine won't go past 2500 rpm
- cleaning throttle body
- Yellow Fogs
- 2002 Brembo Rotors Front #25642
- **Another question about brake pads...
- Window Problem
- AC compressor GAS
- Clutch replacement at 57K?
- IDLE ISSUES- Please take a look
- Dumb question...removing engine cover
- Cams
- Questions about exhaust
- 20th ae's w/s techs and h techs
- Looking for Installer of our Predator in Chicago
- Strange brake question...
- HID Ebay Projector Mod
- any common with this?
- where to get RSB?
- Where can I find online to buy the touring lip
- has anyone ever painted their lower grille
- Lots of power loss with ac on, normal?
- paint code on my black max??
- Question and suggestions on grille.
- Best GAB design/placement
- Anyone with Dealer auction experience??
- anoying exhaust banging
- How can i reduce body roll ?
- Code P0335
- Installed new maf First Impression
- Bought this today
- Aftermarket Spring and Strut Reliability
- Throttle only opening 87% and pedal position sensor issue.
- suspension noise please help
- maxspeeds on stock struts
- SES code: P1102 maf sensor circuit range/performance problem
- Bass and MAF problems
- Redlinemax.com- Newest 5th gen pics.
- who makes the best fitted oem carbon fiber hood?
- Automatic trans
- Starting Problems
- Anyone's lights fading (brightness)?
- Front Exhaust Pipe Leaking
- EVERYONE in 5th gen forum, please note changes made to Rules
- Y-Pipe Increase Gas Mileage.
- Short shifter
- A33 Lower Tie Bar
- Special mod savings account!!!
- changing light around ignition
- I'm DONE with my MAX!
- Wheel bearings bad TireKingdom est $380 per side.
- To lip or not to lip that is the question?????
- debadged trunk pics please...
- my car feels totally different after some work
- Anyone smoke there sidemarkers??
- Heater core leak/dash removal
- headlight harness ?
- Pinging Problem
- UDP Question
- How2 for 2k AE headlight mod?
- Code P158
- need tire help for 01 SE
- Drifting with 01
- Radar Detector Mount...
- foglight question
- Wheel weight...?
- Can Anybody Scan Chilton/Haynes Ignition Coil Test Please?
- Explain this to me
- Auto-Start...what do you think??
- Code 447 - what might that be
- 2k coils
- B-pipe crimp
- Have a 5th gen ECU in my 4th gen and...
- Where are the 2k3 horns located?
- Grill Mesh question for an 02 Max
- o2 sensor simulators?
- upgraded ignition ??'s
- body kits....be constructive!!!
- Supercharge my Max or get new car?
- 5th gen Chrome Engine Dress Up Kit
- full exhaust questions
- loud click when turning...
- 5th gen in wa?
- Loud ticking...
- Brembo blanks/ Hawk HPS, Question???
- FS: frankencar intake
- i want grandma brakes !!!
- anyone gone back to stock exhaust?
- Flowmaster 50 vs. Greddy Muffler
- Car starts poorly, any solutions?
- Ouch - road projectile!
- **best place to order brake pads??
- 2002 trans oil change
- Curb rash repair...(Help)
- Clutch???
- Niteshades question
- $1.99 ebay FSB!!!
- Replacing CV boots...Anyone done this?
- just got my FSTB
- Best PSI for Yokohama Avid V4S?
- kicking in the VIAS sooner
- question about headlights
- I have to show this pic
- Ever felt the steering wandering??
- Speedometer problems help!
- Posting and you...
- 01 faulty wheel bearing with jics?
- V6Performance.net Ride of the Month nomination!
- Side molding all scrathed and gouged??
- POLL: Coilover Setups - Happy or Unhappy
- Frankencar catback
- Help Changing brakes Cylinder wont compress!!!
- question about warning lights??...help
- Need quick help on rear brake sliding pins
- hardwiring passport x50
- Buying a 5.5, which should i get...?
- Is this a good deal for a 5.5
- Hotshot Headers are in!
- 2k1 door panel removal
- Reverse-brake-*clunk*
- 00 Maxima - Amp. Remote Wire Color
- Otto Racing FSTB
- Quote for bumper, hood repaint?
- Boing? Rear Solid to Independent suspension conversion
- Blinkers dont work. could it be.......
- LSD in a an auto?
- Will 2004 rotors fit with modification?
- Spark Plug Wires
- XM Installs
- pics of nht tail light tint on the SE tail light wanted
- 2001 AC drain and Refill procedues and tools needed
- Who wants honey?!
- Someone Needs To Make A Camber Plate!
- running the 1/4
- Anyone with Cattman Catback whole exhaust???
- HID headlight got fogged up. *HELP*
- ***MAD*** My driver's side AE side skirt won't stay on
- Blown Strut...NEED HELP FAST!
- I need a new drive belt...which to buy?
- HomeDepot: PCV Blowby Oil Catch Reservoir
- Those with 2002 maximas step in
- 3.5 in a 2k
- Place Racing Template
- Rim Question...19's
- Magnaflow Tips
- 2k2 Auto Max is stalling and dropping revs
- Injen Heatshield Gains
- STILLEN FRONT BIG BRAKE KIT post pics please
- Someone will get ripped off...
- AE Headlight Mod, problem...
- Rusting already :mad:
- intake?
- 2K2 02 Sensor Installation
- b pipe woes...
- Techies Please Help!
- A question about the rear shock piston rod nut.
- where can i get exterior door handles?
- What key is used to open the backseats to trunk?
- Replace intake gasket w/ spark plug change?
- PIAA wipers
- NEW PRODUCT- Samco hoses
- New Stainless Muffler Tip Opinions Needed
- How much lower w/ Stillen Rear Lip?
- side graphic
- adjustable camber plates
- What size are the lug nuts and what thead?
- What's up with this Computer Chip Upgrade
- HID Projectors as fog lights
- Major Evap Leak
