- Has anybody painted their headlight housings?
- ebc brakes
- Fuse for Gauge Needles, Odometer, and Reversel lights...
- GLE Suspension or Aftermarket.???
- People with Headers
- quick question?
- Buying FSB. Anyone get the eBay ones? How are they?
- ACC light bulbs....*******it
- warranty ?
- Wiring in o2 simulator.
- removing stripped NUT! HOW?
- Back up camera, need help!!!!!!
- Need Advice
- Rear Sway Bar Project - Need Ideas
- SES question
- rear fog light
- fixing small leather scratch
- Climate Control question
- Abbreviations Terms
- Installed Alutec FSTB...but problems
- Clear/Stock Sidemarkers & Bulbs
- 2000 SE 5 Speed, Very Rough Start
- ADM Maxima Pictures
- performance help
- Troubleshooting Misfire
- B-Pipe Removal
- keyless entry
- Reset Ecu??????
- Are these taillights any different compared to...
- mileage driven till brakes needed service?
- memory seat neat feature
- Want to do it!
- When u replace one lower control amr, replace them both
- looking for a good windshield wiper
- Any other grounding kit install guides besides irish's?
- Part name? Where to buy?
- Wiring Diagram 02-03 Bose Changer?
- stock nav
- Accidental repair (look here before you condemn your trans "pics here"
- Brake Light Just Came On
- Any one had this before?
- Can someone help me find this part #?
- Clutch engagement
- ****. Both ABS Sensors Broke
- question about light(s) for 5th gen.
- P0430 Options
- Double Din for 5th gen??
- JWT oil pan spacer
- What do you think???
- 5 speed transmission leak consequences
- HIDs & Ebay Projectors 2k
- Technosquare ecu ????????
- Projector Headlight Retrofit 02 maxima *pics*
- 2002 – 2003 Maxima (manual) Turbo Kit for Sale!!!
- Pics after Hotshot header install 56k beware
- p0021 error code please help
- Just reached 40k in mileage...what maintenance do you suggest?
- '00 Max - Too cheap for HIDs... what do you suggest?
- Door Inserts.
- VIS Hood Latch Help!!
- P0420 ECU update help
- my JIC A1s are rusting!!! what to do use on them?
- Accelerator cable and throttle drum spring loose
- Transmission problems. 2 codes pulled.
- IPOD mounting need help!!!!!!!!!!!
- Vias problem
- question about y pipes
- 2 Quick questions..1st interior..2nd exterior.
- Few problems I have noticed
- How to make a gauge cluster brighter
- is this too cheap?
- HID reverse lights
- Do you have issues with HID going off when high-beam is on? Here's the fix...
- FSM 2001 manual
- any1 gone from auto to 6 speed on 3.5
- Ghetto Air box using coat hanger
- Lookng for sound clip
- Do you have a 1/4 mile timeslip or time for your 5th Gen?
- Dyno tune after header install
- What else do I need to install these cams?
- Power Seat Blues
- How do I fix this?
- IPOD Hookups
- Pics from dealership of Cams with Cam journal caps off
- Help With Muffler Posting
- changing PS fluid, a few questions
- ZENN springs??
- Will these fit my car?
- front rattling noise over bumps
- Would you buy a car with SFCs?
- fuel filter location?
- H&R vs Eibach coparison!!! Pics inside.
- A Weird Turn Signal Issue...
- Traded in my 2003 Max...
- New Engine & Header Install Question
- how many '00 Max with engine cover mod out there?
- Can someone tell is nissan trying to play with me?
- Updated (grey dot) Ignition Coil: GOING BAD????
- Question about installation tein s tech & illumina 2000-2001 maxima
- 5.5 gen w/OEM gauge rings - how to install chrome ones?
- Feels Like Slipping!! Help Please!!
- Really Simply Question...
- HELP!!Tried Switching LEDs doing Metals New way!! Help
- Had the shop inspect the cams and Heads Here are digital pics of them
- Question about keyless entry...
- PIAA Xtreme White Foglight Install
- clicking noise when accelerating
- MAF question
- Engine Replacement Question
- 2000-2001 Airbag light
- Anyone else having trouble with backorder parts?
- Any regrets w/ 19's & mild drop?
- Are 15mm spacers too large for the front?
- buying a 02-03 soon need advice
- Does anyone know how to change the whole windshild wiper.
- Replacement K&N cone on Injen?
- Everyone is saying H&R can't bottom out but.....
- Needs y'all opinion
- SES light: OBDII code p1336
- My car rides like stock now! I'm so f-ing happy...here's what I changed.
- Replacing Springs/ Shocks this weekend...
- I need specific VQ35 info
- Anyone has Tokico springs.
- 5th Gen Suspension Thread
- Replace parking light lens in 02-03 headlight
- Headlights and Insurance Adjuster
- Are H&R 5mm spacers hubcentric?
- Quick Question
- So, I jsut changed my ignition coils
- rpm?
- How to Properly Troubleshoot P0140 Code
- Front side markers as turn signals
- Snug fit??
- Detroit
- Any thoughts...?
- New custom gauge overlays & XM-Receiver
- Greddy Evo2
- Cattman Headers
- 02 Max what exhuast option's in '06
- THE YELLOW BULB vs LEXUS CAPSULE OFFICIAL COMPARISON...head-to-head!!
- Need to know about the Bose Head unit
- Eurodezigns HID warranty
- 4th gen hacked airbox, possible with 5th genners?
- crashed my car a while ago here are pics
- What's your opinion on this trade?
- Budget Exhaust Phone Number
- Photoshop please
- Removing rear sidemarker light
- MaxxTuning lip and stillen rear, pics...
- pre cat solution?
- Fog rewire instructions
- help...click/bang noise when turning wheel
- Best Navigation Unit ( If money is not the issue)
- Alternator Blown
- URGENT!!! Please Help! Ignition/Safety Cutoff Problem..
- Lip spoiler
- 2k2/2k3 ingnition coils
- front bumper repair
- questions about headlight and engine cover.
- 5.5 fogs in a 5gen
- Can I get a quick photoshop 4 these rims please?
- My SIRIUS Satellite Radio Setup...a nice cheap option!
- New Brake Pads
- 5th Gen Muffler
- Its time for rims, help me decide!!
- Maxima fog lenses are cracked
- Anyone know what is this wire?
- Fuel Pump
- Dome/Map lights don't work?
- Parking Light on 02-03's
- Squeezed 18x10 on the back successfully?
- Any advice for header install?
- weight loss program
- misfire why why why
- Any word on aftermarket plenums for our cars?
- Spring/Strut Combo w/best Performance/Comfort Combination?
- Just sold my Maxima......Now what?
- 2002/2003 HID beam patten
- Voltage/Battery and Brake light on simultaneously
- Cause of smell?
- 2002-3 headlight
- Will a higher coolant:water ratio cause water pump failure?
- exhaust wind
- H&R Springs
- issues with '01 SE
- Installed Aftermarket deck and lost all AM radio, Help!
- Any ever had your struts replaced under KYB's lifetime warrenty?
- RPM readings at idle(park), Drive, reverse, etc...
- Where to purchase SS Clutch Line?
- I am replacing my water pump..advice?
- Yellow top battery question
- Engine Cover
- Opinions needed
- Features
- HELP!! y-pipe install
- Rebuilt Transmission questions
- Paint litigation
- 17 degree timing question
- Leaning to the left
- 02-03 brakes different?
- Suing Nissan
- Instrument cluster bulb size?
- changing ur fog bulbs from above. 00/01s
- need instructions for 02-03 lights, Got proof
- Need help reading Consult II print-out
- Screwed up Tach/Speedo...
- Quick ?
- those of you who grounded headlights
- I'm psyched! Finally got the opportunity to do some work under the hood!
- In-cabin filter write up
- anybody with pics of OEM Grille painted Sterling Mist?
- Illuminas stiffer when cold?
- Tranny problem, not slipping but...
- Squeaky Clutch....
- Need some specific info on the Powertrain Warranty
- Cleaned the throttle body, now the cars runs like kaka
- Identify the mystery hose!
- Ughhh I'm goin nuts without my car
- Auto Shifter Interlock Noise in Console
- New Years Accident
- Buzzing Sound... Short Circuit?
- Tranny Issue
- Lookinf for a new muffler
- Any non adjustable aftermarket shocks work with drops?
- need part list for 5spd comversion
- d2 coilover plates
- My Maxima rpm going up and down when cold
- Finally AE'd the Headlights...
- IM after TB restrictor plate
- Nice LED thread from a computer forum...
- cant find thread about intake resonator w/K&N vs midpipe w/K&N
- Sunova*****!
- 2000, 2004 Maxima....same axle hub?
- Max runs rough when parked on hill?
- Anniversary edition pedals
- Can someone confirm this.....
- Doing a 5 spd conversion.
- Passenger side foglight
- Automatic Ok??
- Does this sound right?
- Good bye every one!!!!!!!
- What do you think
- Locations of O2 sensors.
- 300zx BBK questions
- 2000 max SE - running very rough and ALL warning lights on??
- AE or Stillen Ground Effects
- Any info on a 2000 SE w/ 165K miles??
- Interior condensation, WTF?
- Weird vibration when stepping on gas...
- comfort and handling
