PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 [114] 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. At what point do I need longer studs for a 5th gen?
  2. Exhaust Stinks
  3. Shaving Rotors = New Pads?
  4. First pics of LED liscense plant lights
  5. Superflux LED bar pics & Exterior Overhaul Preview
  6. Reverse Gear Weird vibration
  7. Where can I find a rear window spoiler for 2k gxe?
  8. which short shifter
  9. need pic of black 5th gen w/g35 wheels
  10. SE Suspension same as GLE or GXE??
  11. Swapping 0.9 bar radiator cap for 1.2 bar ??
  12. Found this on EBay today!
  13. In need of rear exhaust...what should I get?
  14. Vinyl???
  15. Anyone have a write up on how to install the progress RSB? Get this....
  16. is there a good leather repair product?
  17. left side of bose cutting out?
  18. HID Help
  19. feedback on brake upgrade idea
  20. Just bought a 2002 Maxima SE...first mod suggestions?
  21. apexi filters.
  22. Why no trenz Grilles for 00-01 maximas
  23. In talks with two dealers right now! Tips, suggestions? Thoughts?
  24. Is the navigation these cars come with anygood?
  25. RSB & RSTB question
  26. How can I get this O2 sensor out?
  27. Lightning strikes again
  28. Finally got pics with the 15mm spacers on(this ones for u Shurik!)
  29. There goes my oxygen sensors!
  30. Annoying Squeak from front end of the car? Time for…
  31. coilpacks
  32. Dothe 5.5gen have a ground point for the DRIVER's side headlight?
  33. STS for 6 speed
  34. Angel eye size?
  35. Another exhaust setup
  36. My baby took a spill.
  37. Stalling Problem w/ 2000 MAXIMA SE 5-SPEED
  38. need answer asap on clutch
  39. Tranny mount??
  40. Planning to make my own JWT POP intake
  41. power diminishes as car warms up... any ideas?
  42. Polk Tweeter Install
  43. 01 se needle gauge help!
  44. A couple of noob brake Q's
  45. Q's about after mkt. parts when selling car.
  46. Maxspeed vs. H&R -- Part 2... with review inside.
  47. Pully Question
  48. Are the 02 and 03 6-speeds intrchangeable.
  49. intake question
  50. rewire fogs so they stay on with high beam
  51. Where to find 02-03 HID Headlamp wiring harnesses?
  52. GAB, Berk, K&N what should I do?
  53. I found out what happened to my engine
  54. 01 AE tranny in 03
  55. Coils Or Plugs????????maxima Fans....
  56. Need exhaust plese help :)
  57. illumina settings....
  58. Oil in Intake Plenum??
  59. I found this odd....
  60. LSS Exhaust
  61. FSTB install link help request
  62. Can you please send me carfax report
  63. bulbs
  64. What is the 'auto entry' switch supposed to do? (6-speed)
  65. breaking noise
  66. my max got owned....
  67. my 02 max eats gas
  68. bose head unit
  69. Sounds like a Turbine in reverse when I stop...
  70. What do you guys think about these 2k/2k1 headlights?
  71. black rims 18 or 19
  72. sunroof mod
  73. Anyone else thought of this?
  74. H-Tech Front/H&R Rear Pics
  75. Front end feels "loose"
  76. Wind Noise in the Back
  77. Wind Noise in the Back
  78. Oxygen sensor
  79. Noticed today I only have exhaust coming out one of the muffler pipes, WTF?
  80. ANYONE with access to a junked 5th gen???
  81. VAFC-II Wiring Diagram
  82. Strut install headache
  83. Hotshot Headers on a 2K2 SE
  84. 2000 Maxima GXe headlights are showing wear....Need help with new headlights
  85. Low or normal HP results?
  86. 18 inch wheel Q
  87. Clutch question
  88. HELP! Check Engine Light, code P0160
  89. Where is the easiest spot to tap into dome light wire?
  90. Questions on code P0154
  91. just add some goodies to my car..My impression
  92. VHT niteshade and tails..
  93. Need help - multiple codes, car idles only on front 3 cylinders
  94. Accident/repair
  95. h&r or h-tech
  96. Help with what to say?
  97. does anyone have the frankencar exhaust??
  98. JIC users chime in...
  99. The hole under the spare tire?
  100. Jack Stand Locations
  101. Alright, whos good with electrical?
  102. Will This O2 Sim Work?
  103. h&r and blues rule
  104. My New audio system...
  105. I got VTEC in my Maxima!
  106. Key program not taking!
  107. Looking for the reverse indiglo gauges for a 2002 Max GLE
  108. Thanks!
  109. Help is this normal ?
  110. Removal of rear bumper
  111. The Ultimate 5th Gen Headlight Upgrade!
  112. Exhaust Shops
  113. 6spd Question
  114. P0171 and P0174 codes.....
  115. Is it worth it for me to change my struts?
  116. Help! SES light with P0133 and P0153
  117. Clutch Master Cylinder Bleeding Procedure
  118. Got my struts, springs coming this friday, and installation this weekend
  119. H&R Front Springs Arrived!
  120. Cabin Air Filters for 5th Gen Maximas
  121. question about AC
  122. Quick HPS Install Question
  123. Broken wheel stud
  124. question about aftermarket ebay hids?
  125. Maxima Taillights
  126. sooo expensive.
  127. 0138 o2 sensor discussion! Puppet, Nmex!
  128. Transmission Cooler
  129. Lower Tie Bar? Help...
  130. Normal or Abnormal After Y-pipe Sound
  131. Clunking or something.
  132. Almost got nailed today!
  133. Cali spec vs Fed spec
  134. Exhaust noise
  135. OEM airbox 5 and 5.5 gen same?
  136. Y-Pipe and Inspection Concerns
  137. Aftermarket fog light bulbs
  138. Place To Get Wheels Re-Finished?
  139. MAF Cleaner....new product!!!
  140. Max Tried to end Anaheim Chase
  141. best place for 6th calipers
  142. car drops RPMs on starts
  143. removing the shield from 02-03 fog lights
  144. 5000k Halogen Bulbs????
  145. Need Part # for 2002-03 Ballast holder
  146. Difference between....
  147. Bye Bye Max
  148. P0507 Idle Control System RPM high ... HELP!
  149. Is my 2000 Maxima a GLE, GXE, etc
  150. Vias Question
  151. Looking for a consensus on P0430 codes
  152. Rear brake calipers
  153. Alignment + New suspension question
  154. Change Struts, Change Springs?
  155. Removal of Stock Y-pipe
  156. Aftermarket suspension? Please enter....
  157. Budget Y-Pipe
  158. will 5.5 gen grill fit on 5th gen
  159. A question for people with Nissan service agreements.
  160. factory 02 upper grille or aftermarket?
  161. Creeking noise on rev
  162. New struts and springs (parts question)
  163. need help asap headlight bulbs 9003?
  164. whats that little black plastic square on the front window edges?
  165. Resonated Exhaust Tips
  166. Y-pipe
  167. FUEL FILTER CHG @ 80k - HUGE DIFFERENCE
  168. 02 Motor Mount Question?
  169. For those with cleared out turn signal lens in HID's, what bulbs are you using?
  170. whats causing this metallic rattling?
  171. Reset ECU With Viper 791XV installed
  172. for non-donating members
  173. Question about wheel fitment
  174. Progress Drop and Wheel Spacers
  175. max watts on stock bulbs?
  176. nothing works!
  177. Kyb Agx???
  178. G35 rims on a 00 SE
  179. Strange problem anyone ever have this problem.
  180. Possibly Trading 02 Maxima
  181. optima battery reccomendations...
  182. 12V (Cigarette Lighter Holder) not working
  183. I officially have the weirdest Maxima problem ever...
  184. 99-01 CE Ypipe
  185. Custom maxima race pipe
  186. Does your car "Buck"?
  187. clutch
  188. Could my speedo be off?
  189. sorry bout the pic problem. Here are the correct ones.
  190. Tranny code name
  191. "knocking" noise during 1st gear wheel slip
  192. Noise coming from back of 2k during start-up...exhaust?
  193. boost chip for real?
  194. Finally changed the tranny fluid 6-spd
  195. 02 03 headlights OEM
  196. Hearing rattling when Gas is pushed half way...
  197. Concerns with the ses light
  198. limp mode?
  199. chrome rings or chrome bezel or both?
  200. Front Light Bulb Help Please?
  201. cheapest place to buy coils for 2k....
  202. where can i buy a shift boot
  203. what starter/security combo are you runnig in your 5/5.5 gen??
  204. Alot of vibration...
  205. does anyone have a parts list for 5.5's
  206. My smashed up 2k3 Maxima photos, and pics of my new rides
  207. 01 SE AT Tranny, Throttle body, EGR ? Please help
  208. LED Fogs!!!!!!!!!!!!!!!
  209. 2002 SE Cluster in 2002 GLE
  210. Radar detector not staying in place
  211. best bulbs for clear corners
  212. Check Engine Light PLEASE HELP
  213. Optima battery which model?
  214. maf award?
  215. Random suspension questions - opinions and rants needed.
  216. first thoughts on new suspension
  217. Tein SS adjustments/settings....TEIN OWNERS NEEDED!
  218. Has anyone sucessfully opened 02/03 fogs?
  219. ebay 00 spare key?
  220. Car Sputters and really laggy..
  221. Cheapest place to get o2 sensors from?
  222. Direct HIT??
  223. Projector Headlights
  224. 2k2-2k3 console
  225. Blown Instrument Panel Fuse....where is it?
  226. 6 spd. 3rd gear synchro?
  227. 2k2 Throttle Body idle adjustment
  228. anyone ever buy a xtd clutch off ebay?
  229. transmission question
  230. quick throttle question
  231. transmission cooler
  232. The turbonator?
  233. Pulley Question
  234. rapping/ping
  235. trans question
  236. How to replace front sway bar links?
  237. how to change the auto headlight time
  238. Trans filter?
  239. Quick question..
  240. HELP 5th GEN FOG REPLACEMENT
  241. Trouble installing front sway bar
  242. h&r wow! listen to what they told me
  243. Boring 2k1 throttle body...
  244. O2 Sensor Question
  245. INNER tie rod replacement?
  246. HLSD axle replacement
  247. Brake Caliper
  248. Changing suspension tomorrow, need some advice.
  249. ECM re-programming after installing MAF
  250. Whining noise after engine warms up
