- Wire Aux Input Into 2000 Bose
- Two Qustions......
- Silly Question > Wheel Bearing, Humour me
- Stillen classic lip
- What You Must Do At 120k
- CoryXavier Bop plate install how 2
- What is the process for syncing a transponder to ignition
- You think these are original?
- Dual O2 simulators w/heater to solve o2 sensor cels??
- I hate anti freeze!
- O2 sensors
- Hood bumpers?
- Headlight restoration
- Hard Start while warm? Video included
- Front Door Speaker Installation
- Eastern Pre-cats for 2000 Max (Cali-Spec)
- How do you "warm up" your manual transmission ?
- Gen 5.5 Help Needed!
- Eibach v.s. Tein H- Tech
- trying to fix heat soak
- trans issue? need help
- Annoying Rear Suspension
- Save me from P1320 please! Help Needed
- Car Stuck In Park/ Brake Lights don't work
- I've tried it all: Idle Problem Persists
- Bleeding the clutch
- Questions regarding dropping my car
- weird noise from the front of car
- all oxygen sensors bad at once?
- front precat help
- 2k2, rear cat removal?
- poor maxi
- Help 02 AC Noise.
- Change to Synthetic Oil ?
- Frustrating mystery dash rattle (w/video)
- clearing factory corners??
- splash guard clips
- After Market Stereo Question...
- Painted 5.5 Gen Tail Lights?
- my 5.5 is making me sick with this lagggg
- IPex Motoring Angels?
- LF: good suspension thread
- Major Tune Up
- Pics: KYB GR-2/Tein H-Tech and tinting installed
- Eibach Pro Kit +++ KYB GR-2s
- Cold Start Transmission Isssue! Please Step In!!!!
- v6 3.0 MPGs???
- no shift to 3rd gear at all?
- Would you change your cat?
- P0605 Powertrain control module Rom error???
- Rubber Mats
- 2001 Maxima Se in-dash navigation and audio?
- Disable Factory Alarm In My 2000?
- Suspension Setup Question
- P0325 already replaced/bypassed KS
- 00 02 fenders diffrent
- Investigating a 3rd option for Power Steering Hose
- power steering leak, pics included
- outer tie rod testing
- 03 Maxima Issue....Help ASAP, like everyone else
- Worried from the rattling noise most of the times I starts up my car
- 5.5 gen with 5th gen sunroof reset please!!!
- rtp zinc drilled/slotted rotors shake when brake ....need help plzz
- Painting the rusty underside lip on the Chassis
- best looking grill 02 max
- BC Racing coilover gurus step on in pls....
- Low beam works but not high beam?
- installing airbags
- Need a few suggestions on my project
- Head swap to get rid of ticking?
- subwoofer and replacement problems
- eBay exhaust - video - Cruising on hwy
- crashed 02 need lights
- ELM327 OBD II scanner, Any software recommendations ?
- Need some help ASAP - looking for directions to reinstall stock intake system
- 20th anniversary edition 2 questions
- engine light and brake light came on????
- How much does this part cost to replace?
- 2002 Difficulty starting, hair pulling out
- License plate rattle anyone?
- The Official 5.5 gen engine replacement thread
- Power Steering Pressure Hose
- 2k maxima
- Wiper Blades For Maxima?
- Oxygen sensor wire harness extension question...
- Strarter Click Problem
- LEDs in window and door lock switches...
- Finally did my LED install on my climate control!
- WTF is going on at 135k.
- Hard to start issue
- horn dead on drivers side
- p0400
- help with code p0464
- Help! Help! Help! I am stuck.....
- AC making loud bearing noise.
- Kukx30de's progress thread
- Automatic trans, same speed, but different rpm
- Have a Problem with Shifting...
- Looking for SE head and tail lights
- I need a new motor asap
- wont run with maf sensor unplugged
- Fixed Armrest.. kind of! (PICS)
- wet sanding...
- 3.5 rebuild with clorox gone wrong..
- Megan Exhaust Video
- Six Month Review
- Rear Red LED Tail lights
- Turbine Speed Sensor
- throttle body adjustment
- drivers side headlight not working
- My oil light comes on then goes off **STEP INSIDE AND HELP PLEASE**
- exhaust options for 20th anniversary edition???
- P1491
- Code 113 IAT Sensor
- Diesel like ticking after acceleration
- IACV ohms
- Burning a lot less oil now...
- Mx items as preventative when removing UIM
- Shift Bushings On The Way Out?
- Benefit of a 4-speed automatic?
- Another video that makes you fall in love with your Maxima more.
- Misfire After Routine Maintenance
- Poll : Is your Maxima garage-kept or not ?
- Megan Exhaust Install
- EGR and IACV Cleaning
- Hesitation Issue - Possible Fix? (spring stretch)
- Side skirt panels
- quick question about rear brake pad install
- So how long do our engine last?
- Affordable NON-Warping Rotors
- 4th gen parts on 5 gen cars?
- 3rd gear crunch... i think???
- Sweet deal on Megan catbacks !!!
- Cattman Y Pipe Group Deal/Production (4th/5th Gen)
- RWD VK56VD
- RWD VK56VD?
- Couple quick and cheap fixes today
- Lies, Lies, Lies
- Disconnecting lower plug from ThrottlePositionSensor
- P0505 - to fix or not to fix??
- security no arming??
- Heater blower motor
- 2000 Maxima SE Idle reset/relearn?
- o2 sensor question
- Obx or Cattman heater and Y pipe????
- need a little help with codes.
- HELP!!! Max sounds like it's coming apart
- AT Check
- Question about tire size
- New ECU Needed?
- Check Engine Light is on? Only 68000 miles?
- Is the clutch "fork" and its spring a wearable item ?
- Water in trunk NOT taillights or weather trims
- Transponder chip durability
- Died at the pump and will not start
- some quick shots of my 5.5
- Quick KYB strut question..
- Need pictures of trunk tension bars underneath rear deck...
- Video on 2000 maxima
- How to clean maf?
- Installed a Wheelskins Steering Wheel Cover
- MAF sensor with no resistor
- Oil Filler "Seal" off 350z:
- New Tires = New perspective about Stance:
- 225/55/17 stock 02 maxima se wheels
- Rear window doesn't roll down... motor bad
- What do I do? Eulogy time
- Stripped airbag torx screw
- starting my l.e.d project
- Battery? Terminals? What can it be?
- Minor issue with my Cattman exhaust
- Maxi Issues Again
- Strut mount bearing regreasing
- ECU / IACV HELP!!!!!!!!
- 2000 nissan maxima SE Audio Control help
- AT Rebuild
- BC Coilovers installed
- 2000 3.0 valve cover gasket/leak
- Yes, I did it, let the flaming hatefest begin
- reverse lights?
- www.nissanpartszone.com , is it a "good" and "honest" nissan parts website ?
- Cooling Fan is not working...
- 5.5 gen wireing diagram for power seats
- Developing A Starting Issue
- Alternator change? What else?
- 02 Maxima Heated Steering wheel not working?
- Dash illumimation problem
- Nitto NT-05 for track?
- 5.5 gen Master switch problem!
- Got MT-85 fluid and the subframe collars on the car today.
- Redline MT-85 75W85 GL4
- Street Scene Grille and Valence
- 2002 Trunk leaking?
- New motor, first time build
- Sound Deadening - Stage 1
- 5th Gen Auto trans Questions
- Some new rims maybe
- Coolant stains on rear of block.
- Yet another uspension question
- New Engine Harness Require New ECU?
- Help me choose transmission replacement
- Got premade flip key today, can't program
- VIAS fix attempt, partial fail
- Dash Lights Out
- Oil Leak
- What is ThrottlePositionSwitch connector responsible for? (Not sensor)
- 02 Maxima has HID low beams, but Halogen high beams?
- steering rack leaking or some hose? pics included
- Removed spare tire area?
- Installed my water pump today...
- How to change drivers side headlight harness on a 2000 SE with auto lights
- Whining below 1000 rpm
- Oem Flex Section size
- Looking at an 03' Maxima SE
- Has anyone used Performance-Curve.com
- Need Opinion, Fix Car or Sell it?
- What clutch Master cylinder and Slave cylinder would you buy other than Nissan ones ?
- Raising coilover question
- Stillen LWFW ? !
- Drop-in LED instrument cluster lighting for 5.5 owners. Finally found one that works!
- Ghetto Air Intake
- 5.5 AT to 5-Speed
- Question... About 5.5 gen max spark plugs
- DIY custom armrest upholstry-before and after
- 2002 MAF/P1102/Limp mode Help please
- Drop Springs??
- im looking for a org member
- A/T Shift Knob pealing, need ideas
- Help! Driveshaft won't come out
- New 3" Exhaust for the Nissan Maxima
- Autolite XP Iridium Anyone???
- Energy Suspension Front End Kit?
- A month into ownership with various minor issues. Advice appreciated!
- ...to those who have replaced their radiators...
- 350Z Dead Pedal
- 2k2 Maxima clunk over speed bumps
- Shift Button Stuck
- Lug Nut questiones
- Transmission or Some sort of mount problem ? Input?
- Lots and lots of engine vibration
- Junk pre cat at 67k
- all about insurance
- Resonator ground wire - necessary?
- Touch-up spray can question
- Tire Decision/ HELP!!!
- Strange squealing from the front of the i30 - Problem AND solution!
- New shocks / struts normal at 47k? Best soft ride replacement?
- Re-working my exhaust...
- Headlight corner bulb?
