PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. I am about to punch a brick wall right now...
  2. Say hi to our newest mod - NmexMAX
  3. I bid you all goodbye!
  4. PLEASE HELP, CLUNKING NOISE OVER BUMPS!
  5. steering wheel off center
  6. Maxima Geniuses, help with electrical issue PLEASE!
  7. Camber kit
  8. Timing issue
  9. Need gasket, please help
  10. Car will not start
  11. Help: Clutch clicking/popping when pressed or released.
  12. Dave B or Courtesy?
  13. Cost for a new radiator?
  14. I'm back hello everyone! And a Couple quick Q's
  15. fantastic Car Remote Start System ??
  16. ? About Bumper and headlight compatible from 00-03 what is what is not etc?
  17. Raspy Exhaust
  18. Problems after recent repair
  19. Raspy Exhaust
  20. My A/C does not seem powerful enough to reach the back seat.
  21. Three codes
  22. DTE vs. faulty fuel gauge
  23. How to replace park / neutral switch on 03 automatic??
  24. Anyone use Duralast Gold CMAX brake pads?
  25. 4 codes (P0139, P0138, P1320, P0302)
  26. 2000 IACV question
  27. Help Identifying Break Component
  28. Tire size
  29. Illumina H-Techs & 20's
  30. Wrecked the Max today...
  31. Transmisson gone bad (no R, no D1,D abnormal) - 03 AT, only 82k kms, Toronto, CANADA
  32. 2 starters down on 6spd???
  33. big maf tuning
  34. Mechanic around Vernon, CT
  35. Will the 4th gen trans work for 5th gen maxima(5 speed)
  36. CEL p3000
  37. 5.5 Gen Maxima vs MK5 GTI
  38. BlueBat Overlays... help?
  39. Cost to cut/program a 2000 gle key?
  40. Bose Factory Radio Volume Knob, Please Help!
  41. really need help no power/ exhaust broken!
  42. Now with remote start!!
  43. Note to moderators - many many links not working - Post all dead links in here!!!!!!!
  44. Headlights Out
  45. Can it be fixed? Lower Control Arm bolt
  46. Gas smell
  47. Retrofitting fog lights
  48. 2001 Bose Volume issue
  49. New Duralast Gold brake pads and they squeak!
  50. volume control...
  51. Coolant in my Intake Manifold & TB??!!??
  52. Anyone have a picture of this?
  53. Custom LTB with headers mock up
  54. Looking for Pics of 5 gens on 20" wheels?
  55. Five Questions
  56. NWP Engine Torque Link Bracing Kit opinons
  57. Replacing Master Window Switch - Defective Part?
  58. Scraping/Grinding sound when making turns
  59. Help with this problem
  60. Time for a new transmission. How much should I expect to pay?
  61. Debadged or ...
  62. Anybody use these tires on the max before?
  63. Whose heard of this Brand?? fstb
  64. 04 and Up transmission gearing advantage.
  65. Never Ending Misfiring...
  66. Gaskets needed to install Cattman Y-Pipe
  67. Blower motor resistor - Take Two...
  68. testing oxygen sensors for functionality? voltage, resistance?
  69. 100k miles what to replace/check?
  70. Help diagnosing possible misfire
  71. May be coming back! Looking for 5.5 FSM
  72. Installing D2 Coilovers
  73. Driver side cv axle trans seal
  74. Axle help?
  75. Please help diagnosing emission problems - 2k Cali spec, 180k miles
  76. Blizzaks for cheap!! (over 80% tread). Will they fit?
  77. Largest resonator for 5.5 gen?
  78. Opinions on Megan Racing springs?
  79. Serious Engine Noise multiple P300 misfires
  80. Maxima bump n grind
  81. What do you do to make your engine look pretty? :)
  82. Weird sound from engine bay
  83. Cheapest Place to get oem nissan parts?
  84. Sunroof operation problem, I have searched
  85. Urgent question about ebay motor mounts
  86. How to replace side mirror?
  87. Infiniti Ignition Coils Interchangable with Max?
  88. o2 sensor shot - are 4th and 5th gen sensors interchangable?
  89. Installing Basslink II Behind Rear Seats
  90. ITS LEAKIN. SOMEONE TELL WUTS IT LEAKING
  91. LEDs for gauge cluster
  92. Help: battery & brake warning lights came on at the same time
  93. 2001 maxima - p0505 code. need help!
  94. idle/run problems
  95. shaved my emblems and relocated my keyhole
  96. Punching A/C Unit
  97. cattman header install problem...help :/
  98. Replacing Both Lower Control Arms
  99. SRI issue
  100. Front wheel squeak only going forward
  101. maxima vs 747
  102. If you want a Maxima vs. xxxxxx , then just go to YouTube
  103. maxima vs. enzo
  104. Maxima vs. Neon SRT-4
  105. maxima vs g35?
  106. Prepping car for snow?
  107. Motor mount help
  108. BOSE SUB rattling me crazy
  109. timing advance and vias code
  110. Possible for me to rebuild my rear calipers?
  111. Front end vibration only at certain speed
  112. safcll question ( no i dont need a pinout lol)
  113. Panel Filter Options
  114. Seafoamed My Car (Video and Questions)
  115. question about wheel offset/suspension problem
  116. AC problem or quirk?
  117. Time for new tranny (I think)
  118. modding 01' stillen lip to fit a 02'
  119. could this be the reason for my crappy gas milage??
  120. 2000 Max Power Loss / Accel Problem
  121. rear breaks
  122. CRAAAZY Problems! PLEASE HELP!!!
  123. Need some advice before tuning
  124. "Anti-mod" list?
  125. What kind of SES turns off in rainy weather?
  126. How to tap into the ignition?
  127. some some advice/tips on mods please! :)
  128. ALOT OF FAIL v.transaxlestilldoingthedougie
  129. 3.0 timing components question?
  130. 2000 SE Not Turning Over
  131. need some help...new intake filter size
  132. Complete loss of throttle
  133. Having my Eibach springs replaced under warranty after only two years on the Max
  134. Legit Tune in Ny ?
  135. Pressing out A/C compressor pulley bearing???
  136. Possibly my last thread
  137. Does this fit on the 02 maxima: 3 inch Spectre MAF Adapter?
  138. Rear Bumper Sujestions?
  139. Catback exhaust options?
  140. How do you tell if Coilovers are blown
  141. Transmission Problem...
  142. What is this?(under passanger side)
  143. Replacing right rear ABS sensor by myself?
  144. Two words I never thought I'd say: Sprint Booster
  145. A new edition
  146. Is this good, To connect the MAf to throttle body and the Filter to MAF?
  147. Need some help finding OEM Navi unit for 02 Max
  148. CM dual exhaust or Megan ?
  149. Question About H&R Springs
  150. not the alternator or battery
  151. Car shuts off
  152. eBay bumper covers
  153. Unanswered questions about DIY ambient footwell lighting w/ headlights.
  154. Top end problems..
  155. Ok so what else do I need?..
  156. 02 maxima:If you shift a 4speed auto, would the tranny break?
  157. Maybe this has been brought up before.....
  158. Clunk in passenger front wheel.
  159. Air conditioner went? Or something else?
  160. Doing a TB and MAF cleaning
  161. VQ Swap 5.5 gen to 6th gen
  162. Need EXPERT help on a P0171 code please
  163. how do i find out if my car is ("Cali") type emissions or Federal-type emissions?
  164. Wheel bearing or hub?
  165. Racingline Rear Strut Tower Brace (RSTB) - Interest Thread
  166. '00 and '01 FSM
  167. burned out taillight light comes on dashboard - ive replaced bulb already
  168. Where to buy OEM Replacement Parts ...
  169. DEK Tune Up and Mod Questions
  170. Car died on me!!!
  171. custommaxima headers review
  172. Problem while installing NWP Spacers
  173. How do you rev a drive by wire from engine compartment???
  174. Clutch Problem 01 Max
  175. Custom Maxima Hi Flow Cat any reviews?
  176. Took rear spoiler off..How do I fill the holes!?
  177. hid ballast help. Oem vs. Depot
  178. left side fron wheel(driver side )slips even when taking a turn at 10mph
  179. Collapsed flex pipe on cattman headers - check yours
  180. Options for replacing knock sensor
  181. Questions For My 5th Genners
  182. Custom Maxima Headers
  183. Climate Control Unit Lighting Question
  184. Performance Peddler ROCKS!
  185. Engine swap or rebuild??? Please share your knowledge!!!
  186. Can anyone identify the signal plate/gear for the crank sensor? (pic)
  187. anyone here try precut window tint from ebay? how were the results?
  188. Oil Flashing on startup
  189. Bent Rims?
  190. ?Clutch?
  191. BONEHEAD MOVE - NEED ADVICE
  192. black suede headliner
  193. Check engine light just came on..How bad?Costs?
  194. Need help with cabin vents
  195. 6spd max's reverse is grnding in 2 trannys
  196. Anyone else's VAFC-II stop working at 6000 RPM?
  197. 4TH Gen Snow Tires/Wheels on 5th Gen
  198. Please help!! CV joint splines seized in knuckle. how do I remove?!?
  199. Clutch Issue
  200. Advice for Removing the Rear Oil Cooler Pipe
  201. alarm stopped working
  202. automatic issue?
  203. Single HID bulb is dead, what to do?
  204. cluster question
  205. How many of you guys have gotten the P1610 and P1612 Codes
  206. Transmission or faulty sensor?
  207. how to remove fuel pump from sending unit?
  208. Time/Accel Graph = WTF
  209. Rattling sound
  210. Front End vibration after new suspension parts: Diagnosis and results
  211. Help! oil filter is stuck!
  212. Please Help! Need quick troubleshooting advice!
  213. its slowly dieing on me
  214. Pics of your adjustable fuel pressure regulators...
  215. Power Balance test
  216. Motor mount replacement.....oh fudge.
  217. 03 Headlight problem
  218. Drivers Side window problemo
  219. got rid of 4x4 look, finally.
  220. weird dome light issue
  221. Worth a try...
  222. has the power...but doesnt feel like it
  223. ECU reset???
  224. grill removal
  225. Big spender today
  226. new coilovers for the 5th gen
  227. Bodykits
  228. Cattman Y-Pipe for California Maximas is Here!!!
  229. fuel pump & fuel filter
  230. Engine knock at idle and high rpm, knock sensor?
  231. Seatbelts
  232. where can i get?
  233. Exhaust mounting question
  234. seems like when it's hot performance sucks
  235. Fuel door misalignment
  236. Bumper Brace Blackout feeler
  237. Front brake overhaul
  238. Engine knocks in hot weather (110F)
  239. Idle Air Control idea
  240. What color to powdercoat wheels???
  241. Diesal fuel in my engine!!!
  242. 00/01 vs 02/03
  243. Steering shifts left when gear change?
  244. will h&r springs from a 4 gen fit my 5th gen?
  245. How to replace park / neutral switch on 2003 automatic??
  246. Power loss after hitting curb.....
  247. cant find codes in sticky
  248. No money to fix the maxima... don't know what to do right now?
  249. What looks best
  250. Saying Farewell but Not Goodbye!!!
