- Are ebay projector lights any good?
- Best bang for the buck mods for DEK
- Opinion on LED blinkers?
- rear brake question
- Struts & Brakes
- SES Issue
- Front lip for 01 maxima
- sidemarker bulb socket
- will these headers fit an 03
- PCV oil issue possible fix
- stock intake install
- When is it time to replace o2 sensors?
- oil leak help!???
- Fog light Rewire
- 4x4 status...
- need urgent help 2001 maxima lights flashing when I brake
- Loud Bang & Result.
- My car sounds like a meat grinder! Whats happening?
- Tokico Illumina setting suggestion
- p1800 & p420 together
- Can Anyone Help?
- Improved 0-60 Time after NWP Spacers and Spark Plug Change
- 2003 6-speed - Can shift to all gears except 6th
- Dyno numbers (sucky)?!
- Are the Blinglights fog lights any good?
- countrol arms.
- 5th gen foglights on a 5.5 bumper?
- ADVAN RGII What do you guys think? need spacers in the back?
- Stock Exhaust issue.......
- HELP NEEDED- Strange issues after changing the radiator
- wanting pics of hidden hitch installed
- EBAY reflector headlight Projector retrofit
- Another one of these threads
- running lights wont work
- 5.5 gen cat on 5th gen
- Opinions please... are these real?
- HELP! 2001 Infiniti I30 Moonroof won't open
- rear suspension??
- auto tranny help
- My headlight turned purple...
- HID lights
- Painting rims black!!!!!!!!!! :)
- O'Reilly camshaft position sensor P0340
- tail light/side marker light issue!
- Clutch Adjustment?
- vq35 disapearing oil??
- When going over bumps the front makes a sound but ONLY if the wheel is turned
- Experiance with Sprint springs?
- damnit low compression!
- Rear brake calipers are the biggest pieces of crap.
- Turn Steering Wheel Car Stalls.... Axle issue too
- Blackworks SS
- Custom intake for 2001; hate to do this but...
- Engine knock + p0300
- interior LEDs
- Question about switching seats...
- Car pulls sharply left when turning left - help
- can some one diagnose this problem?
- Headlight Assembly Parts
- P1147 and P1448
- 5.5 clutch/flywheel info needed
- Fuel Gauge Issue
- Questions on differential
- How do you remove this piece...
- cats..
- 2000 Maxima maintenance
- 01 AE body kit on 5.5 gen?
- 5.5 w/ g35 Rays 19's
- Oil in intake manifold
- HATERS!!!!!!!!!!!
- Vibration
- Timing Advance: Where to go
- Brake Fade. . . help ...
- lip question
- Parasitic drain
- Looking to do a custom exhaust... need some help guys
- O2 Sensors Changed, ECU reset, still pulling codes.
- Drop question???
- Malibu Clear blinker lens mod for HIDS are discontinued, BUY SOON
- INjen RD intake Gains?
- K&N or spectre air filter..
- OEM HID Ballast Information
- My rescently acquired 03 SE
- What sensor is THIS?? 2000 maxima
- Tuneup ?
- Where can I buy a used tranny?
- HID'S
- Double Din...How? LOL.
- Bad strut mount
- Taillight disassembly?
- ABS Reset
- rear axle bushing?
- MAF sensor problem , its frustrating
- grill question.....?
- 10MPH and no stop equals.
- Oil soaked spark plug hole Help!
- Smelly in the Cabin help....
- Paint rims
- slow start followed by rough idle
- max with mmi and es subframe bushings step in
- Finally got my tail lights smoked :)......(kept it oem i dont need anymore tickets)
- stage 1 clutch question?
- Summer project
- Someone used my car!!!
- just an updated pic of my car : )
- 350 miles on Vogtland/GR-2 - Follow-up Review.
- Hwo can we make our 5th gens handle better!?
- Is is possibe to tell if a car has a limited Slip from the vin?
- Did the spark plugs on my 5.5 today. (PICS) Also some fun misc stuff...
- WERE CAN I GET A BLACK BILLIT GRILL FOR A 2000 MAXIMA!!!!
- Automatic Headlights?
- Downed Power Lines and Bumper Accidents
- Driver side LCA destroyed!!!!!! VIDEO!!!
- Need your opinion people
- Another ? on CAI Vs SRI
- o2 Sensor problems...Help needed please.
- Do secondary o2's HAVE to be on specific y??
- removed air intake snorkel
- 19" Nissan Quest SE 5 spoke wheels on a 5th gen??
- Does it look nice with fogs????i didnt like it at first but its growing on me!!!!
- Catalytic converter issue... Relpace or UPGRADE?
- Knocking Noise...Need Help??
- Tranny problem?
- Rust pictorial
- Cold running problem fixed with upper intake gasket
- No Fans
- For those of you with eBay cat-back fitment issues, here is a solution!!! (pictures)
- Reverse problem (slush/grind sound)
- I35 Seats in an 00 maxima help!!
- eBay N1 cat-back installed. Question about bracket...
- Any body in the MD, VA, DC area hit MRI?
- Oil for my 5.5 gen
- transmission/axle problem i think?
- BROWNISH-BLACK GUNK IN COOLANT RESERVE
- Does anyone know if transmission code RS5F51A is a manual or automatic?
- whats this? (pictures)
- car pulling when gear changes.
- Quesion about non-foulers
- P0340 - Camshaft Position Sensor (Phase) Circuit (Bank 1)
- Misfire- blinking SES
- side markers?
- Custommaxima FSTB
- 4th gen springs fit 5th gen?
- Illumina clunk
- 2000 dash lights wont work
- Fender roll with 350z rims?
- G8 GT vs Maxima (repost from dif. forum)
- car shut off driving yesterday, wont start, no power.
- A big thanx to my beginning
- 00 SE 50k miles, strange noises?
- 5.5 Gen + 350z Intake Manifold
- MAF or TB?
- Wheel Spacers...
- o2 sim Randomly not working?
- Sunroof "slide switch" not working, but "toggle" is
- Gas mileage averages for VQ30DEK?
- Carbon Fiber Trunk Catapult
- Sun Roof issues
- No more shakes when I brake!
- 6mt replacement tranismission options. replacement question
- Where to buy headers these days? :)
- Gathering engine cover ideas - Creative ones step inside
- 5.5 Mods/Maintenance Timetable and Stage List
- Subframe
- Best COMPLETE 5.5 gen Exhaust
- 3.5 oil loss. Should I be worried?
- Anyone Running an APEX'i Neo?
- MOTM question
- Did 6th gen bbk - now lots of pedal travel
- what LEDs are you running in your front turn signals?
- Muffler Suggestions
- Aim these headlights.....
- Installed Vogtland Springs w/KYB GR-2's...
- Outer TRE's
- My Turn 2 "Strut"
- Altima 3.5l headers/y-pipe same as 5.5 Max... ???
- Got Max back from the shop have a problem
- Guidence needed 2002 Front Calipers
- Thought it was my clutch
- Will Coilovers from a 1998 maxima fit my 2000 maxima
- Need help with speedometer!!
- gear oil leak
- muffler
- At what point is it time to stop caring about rust.
- ABS Motor turns ON when ignition turns OFF (hows that possible?)
- Direct BOSE Sub and amp replacement??
- Air Flow Meter / Sensor question..what years..
- Dilemma.. wish i had these all time (want your input)
- Lost Car Key at Work
- specs for midpipe
- 2001 Ingition hesitation (looong term issue)
- Show some VQ35DE RESPECT !!!!
- A/C compressor problems?
- Swap 2002 fuel filter, fuel line sprayed fuel inside car
- Sunroof Control Issue 2002 Maxima
- Hood Flapping
- Grounding Kit DIY
- weird dome light issue
- Instrument panel Options
- Aftermarket clutch/flywheel issues (long)
- DILEMA
- redline gear oil
- Lookin for left tail light
- wheel hop
- Another Satisfied Tein Customer!
- Who Knows where I can find cheap AM parts
- Airbags interchangable between 00-01 and 02-03?
- Installing front lip spoiler
- New Shoes
- Removing the two allen head bolts on aftermark exhaust?
- Faint service engine soon light? (searched)
- Ticking noise coming from engine
- down force for the track
- Tokico Illumina issue - HELP!?!?
- Flex/Y-pipe...UGHH
- Finished Battery relocation and tidy-up.
- SHort height shifter problem??
- Kingpin inclination, Helpo please
- advanced timing question
- Maxima 2003 is having problem starting and revving
- Do people trade taillights???
- 01 SE Alarm goes off every 30 minutes, removed fuse already
- Snow in Atlanta...Ouch!
- Water leak from anywhere but the windshield?
- 5.0 Gen Front Brakes
- Stage 1 clutch??
- Overheating Problem
- installed STS kit...slightly difficult to get into 5th and 6th gear
- When pressing lock on remote I have no beeping
- Stuttering when cold?
- 03 Maxima Overheating when speeding
- Weird starting issue
- speedometer stop working
- HELP! Radiator fan...
- Anyone have information on the RS5F51A Tranny?
- Dealer Wants Car Back?
- My new maxima problems. please help
- Any way to get the lights to go off faster in "auto" mode
- AC compressor dead? Is it a pain to change?
- Should I get the H&R sport springs?
- MEGAN OE RS TYPE CATBACK
- Energy Suspension motor mounts
- p0300 code...
- Clutch Question?
- Options for seat heaters?
- water pump replacement question.
- Looks like I need a caliper and a rotor
- This has GOT TO BE thee ugliest!
- Clutch
- 2000 Maxima SE 5sp pics.
