- TSX Projectors, Done! Some pics...
- Trunk mat question
- Steering wheels shakes above 80mph.
- How to install spark plugs?
- Door rigger wire color?
- Changed Filter now get Bee's in the Can Noise
- 5th gen owns 3rd gen and I30 (NOT street racing)
- Cold Cathode under dash Lighting Pics!
- Check Engine Light is alway on
- parting ways with my 01
- opinions on buyin a 2k3
- anyone tried "baking" the ebay/cm tail-lights?
- Sticky for Newbs
- Tein Springs
- RPMs drop and car turns off...
- Reverse Glow/Indiglo Gauge Install
- Need Help!!! Leaking OIL!!!
- Two exhaust options
- Must read for HID upgrade/info
- 350Z track wheels
- I need help from 2k3 titanium edition owner
- Help troubleshooting flasher relay? Have searched..
- Air Filter Replacement
- Questions on software update/reprogram of ECU
- How many LBS of Torque for RSB?
- atf change help
- how to flush the cooling system
- H&R springs
- O2... help... (FAQ read)...
- instrument cluster too dim?
- State inspection
- Jim Wolf Technologies flywheel
- Kamikaze Body Kit
- LTB Clearance pics....for those who asked
- So i did the home depot lower grille...
- hello all
- Ignition Light Ring
- ebay lip spoiler
- those that have had bumpers repainted...
- What does the transverse link look like?
- Just another thread thanking DaveB for his help.
- Engine rumbles at 2000-2500 rpm
- question about transmission..
- CV joint replacement or worse?
- smithhaven mall meet
- Custom grille?
- Evo Body Kit
- Deal on a new Cat???
- My car...
- Best UDP for 01 Max?
- quick help needed!!! shifter bushing install
- Flowmaster 50 Review
- Idle Air C0ntrol Valve For 02 Help!
- For those with Tein H-Techs / Tokico Blues Combos...
- All components that connect strut and shock to car
- ES bushings for LTB II
- I hate my pink clears
- Is this an emergency?!(inst panel lights)
- I35's with electric rear sunshade...step in..
- I35 sport side skirts on 01 max?
- Motorola Bluetooth Phone Kit HF850 Installed Pics
- brake lights don't work
- weird block on the clutch line
- hood fitment
- Ign. Coil problem solved...
- O2/ Knock sensor problem.. Neeed some help..
- is this poor gas milage? what could be the cause?
- Quick question
- PIAAs blew.
- Brake Pads BOSCH PADS?
- bad alternator at 32k
- Budget y/b pipe opionions plz
- Funny Maxima sale someone will get stiffed
- Windsheild Replacement
- side graphic... opinions
- need to know how to change xenon bulb! ASAP
- brake problems
- triple gauge pod mounting Q???
- Will rims that fit on a 99 Chevy Xtreme Blazer fit a 5th gen Max?
- Quote on repairing 17" 2k3 rims?
- Maxima rattling below 2000 rpm
- e-brake light on - sensor?
- The controller on the steering wheel
- Removed ugly wood...
- Bosch Xenon Projector Retro (56k ...prolly not)
- 02 Sensor Location Diagram (00-01 Cali Spec)
- Bad auto tranny?
- 00 Engine questions
- TB High Idle Fix - Jump In Here
- Suspension Question: Bounce - struts or spring?
- anyone ever try yellow ion halogens?
- AE Auto Shifter
- Paint Jobs?Need help guys.
- Why do fellow maxima drivers hate sooo much????
- Need confirmation of timing advance in Canadian 02max
- Best Place to buy G35 18"s
- JDUBS kit is now available... full kit or bumper
- Exhaust Leak?? Input needed.
- HELP.....please post your thoughts
- rear clear marker install
- Syndicate Kustomz eyelids painted & installed (56k, nobody likes you)
- Will standard h3 HID bulbs fit 02-03 Fogs?
- help please! need a new catalytic converter
- Hot weather + easy driving =
- A/C for 2002 Maxima
- Phantom Grip
- Dashboard clock rattle
- Tanny questions
- Climate Control lights to be changed
- 02-03 Grille fit on '01?
- Basic Suspension Package from Cattman review
- So I took apart my Umnitza DDE Ballast
- Tranny issue, just went away?!?
- New discovery- brake pads
- Anyone take out leather seats from a junkyard car and use them?
- Another MAF.....
- Tips on installing Stillen Classic kit
- Idle Sensor Question
- Lexus Fogs on my 5.5 Gen - PICS -
- maxima emblem?????
- Clutch options for 5.5 gen
- Word of Caution for 5.5 gen KYB GR2 owners
- Lowering Brace Under Y-pipe-How Low?
- P0135 Code...02 Sensor...Nissan vs. AutoZone
- Im going to smash my console
- car back from paint shop and the hid fog light will not work now
- changing bulbs in an 01
- Valve body and torque converter?
- Replaced coils/plugs. Still have P1320??
- 2001's (ONLY) with in-dash monitor
- SE emblem
- brake rotor/pad help
- Tv Headrests With/without Tvs
- transmission cooler
- Sticky? Fog Light/Headlight Comparison Thread
- Can anyone help me out?
- Finally Got a 5th Gen
- How to install the AE Kit?
- how to remove the rear parcel deck completly?
- Replacement Injen Filter & Brake Rotors
- More power when engine is cold?
- is this a joke???
- 02/03 headlight Q
- Need new tires and rims soon. Any suggestions?
- Piaa Fog Lights
- Need help removing rear license plate holder
- Starting Max From cold start it jerks untill engine is warm
- Videos of my newly installed WigWags/Rear Flashers
- home depot grill
- Has anyone put in a 5sp auto tranny?
- Can somebody measure the height and length of the 5.5 grille?
- installed new oil catch can
- Bosch Platinu,4 vs NGK Platinum
- Car is stalling..
- Installation Instructions for MattBlemcho Grouding kit?
- Broken Bolt
- Computer Tuning?
- Cleared Hid and Hid Fog Pics
- Stock horns...ground wire?
- Another source of "lost oil"
- Carbon fiber eyelids
- Stumped!
- WANTED: Those whom have had their 60,000 mile maintinence done...
- Warpspeed Y-pipes
- Going for new paint & graphics
- What size optima are you running
- Exhaust Banging Need Advice Please Help
- auto rpm shift points
- 02-03 maxima vs. 00-01
- valve cover...
- Ummmmm.....?????????
- Somebody Please Carfax this car for me :)
- Bright Halos
- Worst Luck With Suspensions
- reverse lights
- quick wheel question????
- wiper sprayer
- 2002 Steering wheel controls
- How Much should I sell my car for?
- 3.5 Oil Consumption Poll
- Oil filter ?
- 5th GEN Max with bodykit LIFT question
- ripped off at the dealer..do i have a case???
- Smoked rear signals?
- 2k2 - 2k3 Engine
- KYB GR2 or Tokico Blues
- FCC ID number for 2000 keyless remote
- Those with Ground Controle Coilovers ...step in
- Maxima Top Speed. Mine toped out at...
- 02-03 Navigation Owners
- Pictures of my Maxima (interior and some experior)
- Are there any 4 piston calipers that just bolt up to a 02 max?
- Difference using SAFC
- Conklin Oil
- 2002 brake shim kit
- Only went for a brake job...could have been seriously hurt...
- Cleaning the IACV
- Quick question-factory HP rating
- Testing MAF
- climate control?
- Anyone try G35 Coupe Seats in 5th gen Max?
- Timing Chain Rattle: FIXED!
- Tranny or MAF...gears slipping
- Those with experience on P0135...
- Painting stock rims
- MAF? Transmission? I can't tell!!!
- Increased low-end torque
- 01 se foglight question
- what do the speaker wires look like
- 2000 GLE Recommended Tires
- Rear brake piston stuck, what to do?
- How do I remove the door panels to install speakers?
- Stock Air Scoop, and Sensor Question
- Problem with paint job from body ship.
- Affordable Headlamp Wiring Harness
- Side Mirrors....
- New rotors,calipers,pads,and still have a grinding noise coming from the front brakes
- N E 1 With a VB stage2 mod
- performance questions
- Exhaust
- Quick question
- Need Help! Transmission
- Installing a SS Tip Need Advice
- quick question
- Battery light on, help.
- Need Help Fast, Is this car my new Maxima?
- Stupid Interior Question
- SES with no DTC's set?
- airbag light on
- Need rear rotor's
- porterfield brakes and brake dust
- New custom leather installed (pics)
- wiring help for bulbs...
- 5th gens running 235 rubber on stock 17's please step in.
- Ready to buy an 00 GLE....any advice?
- please help real quick, remove vent above bose headunit
- Exhaust Clearance?
- fuel filter install, I ALMOST MADE IT!!
- rev limiter?
- Hiss from berk intake.
- HVAC issues
- Y-pipe, O2 and ECM update - HELP!
- which to buy 01 max or 02 max?
- OEM Rear Bumper Replacement Difficulty?
- Tune up on 02 Max
- Clutch Howl Bulletin
- Warranty coverage question
- IAT trouble
- Decals on your Max, (post pics here)!!!
- help... on decision...
