PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Oil pan with a rubber plug in the middle?
  2. Youtuber exposes awesomeness of 5.7 swap
  3. Saying Goodbye :(
  4. Transmission Solenoid Pack Question
  5. wiper blades not going all the way down.
  6. CEL Not Working (funny thing about search)
  7. Any OG 5th-genners still around here?
  8. 2001 Nissan Maxima coolant engine sensor stuck
  9. Loud Engine Slapping Sound??
  10. Heat Intermittent?
  11. Wanna power up cluster
  12. Battery/body grounds
  13. Aircon running idle dips very low.
  14. 2000 ABS pump actuator bad?
  15. 2001 maxima
  16. Shifts into highest gear only when trans operating temp is reached
  17. Ignition wire routing?
  18. Did manifold upper and lower Now car starts but quits and wont start again.
  19. Weird noise when I turn vehicle off . 2000 máxima gle
  20. Will any "inverter" work for cams on 7th gen swap?
  21. Instagram
  22. 2000 Nissan Maxima Stalling problems.
  23. Sludged to hell!
  24. Tailgihts don’t work but I have breaklights
  25. Will 2005 Maxima seats work in my 2003 Maxima?
  26. Need Help with P0335 and P0725 code
  27. Can you use the 2003 i30 gauge cluster in a 2003 maxima please get back to me
  28. Solo Engine Pull, No Cigar, Requesting Advice
  29. Sporadic Alternator
  30. 5.7 Swap AC Compressor Question
  31. Grinding/scraping noise coming from rear end? Looking for help on what it could be
  32. Replacing HIDs with LED
  33. Nissan Maxima se 2002 radio problems
  34. Part ID Help
  35. Car Hesitation (2001 Infiniti I30)
  36. Easy Q' about flywheel
  37. My 02 I35 just did some crazy stuff, now its dead?
  38. 2007 Sentra Trans Swap???
  39. Radiator fans
  40. Wet Driverside Floorboard When it Rains
  41. Car over heats in traffic and going up hills then goes down I once speed is picked up
  42. T-series CamSensor already toast
  43. Got a ticket for my silly license plate cover
  44. 2000 Maxima transmission slip
  45. Auto to manual swap. I have questions.
  46. 2001-2003 radiator support
  47. ASAP HELP! no power is going to my blower motor in my 03 Maxima.
  48. 7th Gen Swap Knock Sensor
  49. Dead radio?
  50. Bosal vs Walker interchangeable
  51. 2002 nissan maxima sputtering amd skipping
  52. EVAP low input sensor location? PO452
  53. Slowing down rust
  54. One Headlight dimmer than other
  55. 7th Gen Swap Cam Sensor Signal Wheels Installed
  56. Questions on repairs and maintenance
  57. EXPERT ONLY EP LEVEL 10. Enter at own risk.
  58. I'm in trouble guys. MAF TB AAP ECM>>
  59. Trunk latch prob, alarm goes off rambunctiously
  60. Engine swap question...
  61. Tire Mechanics cant Remove my Wheel
  62. All windows not working
  63. Bose Radio Signal
  64. intake manifold gasket. re-usable?
  65. G35 brake upgrade questions??!! HELP
  66. HOT TOPIC - recently at least - Koni vs Ksport
  67. Koni Yellow
  68. Window module wiring 2002 nissan maxima
  69. Weird Starting Issue??
  70. Tokico Illumina
  71. What are the best front brake pads and rotors for an 02 Maxima/I-35
  72. Coolant leaking on bottom of oil pan.
  73. Dreaded Sunroof Problems
  74. 03 maxima
  75. Cluster LEDs - 2018
  76. Check Enhine Light Codes P1167 P0159
  77. 2002 3.5 question
  78. cross threaded a valve cover bolt
  79. Evap p1440 and refuelling
  80. Unknown part.
  81. 2003 SE Headlight Removal Conundrum
  82. Idle air control relearn
  83. Idle Air Control Valve Prices??
  84. P0340- cam or crank sensor, or all of them?
  85. Sold my Maxima
  86. '02 Bank 1 converter replacement
  87. Need Help 2001 Infiniti I30
  88. Strut problem
  89. Coilover covers
  90. Best 5 Gen suspension setup
  91. Seat Belt Retractor Assembly 2000 I30
  92. Picked up a nice '01 20th Anniversary Maxima
  93. 350z flywheel in a 5.5
  94. 3.5 into 01
  95. Acceleration hesitation 2001
  96. Pesky P0011 - Wont go away!
  97. headlight replacement
  98. Motor swap
  99. 300zx BBK Rotor Dimensions
  100. If you have a Manual Trans
  101. Seeking Duplicolor / matching spray paint for 2003 silver maxima. Code? paint #?
  102. CV Axel confusion.
  103. 02 Maxima Autolock?
  104. Slamrod's VQ35HR swap adventure
  105. Sunroof motor wiring. Please help!
  106. Is there a way to link moonroof to the circuit on front windows for the key fab?
  107. Still can't get the 8 blink airbag light off
  108. New here but need help before I just collect insurance on my 02 se
  109. Control Arm replacement
  110. Need a Favor...
  111. Supposedly OEM? Pictures of cranksensor
  112. New looking for help on what to do first
  113. Need To Clean Your Airbox?
  114. License plate lights out on 2002 SE - clueless
  115. Nissan Data scan 2 - not 5.5 compatible??
  116. More on the exhaust topic: cutouts
  117. HID to Halogen?
  118. SRS hybrid exhaust
  119. Possible timing chain noise
  120. P01574 and intermittent speedometer operation 02 i35
  121. Hood latch no longer has support
  122. Bmw 95 series wheels on a max ???
  123. 2003 Max: Ac not working need help
  124. Brake Line Leak - along firewall
  125. Wheel, suspension upgrades
  126. Timing Chain? Oil pump?
  127. replace the dampner or go solid underdrive
  128. 2002 Evap Purge Valve Replaced and functioning light remains
  129. Transmission question
  130. 6 Speed Swap Info for 00-01
  131. Rear Defrost vs Radio Reception
  132. Tcm
  133. Cluster swap please help
  134. 01 to 02 cluster swap
  135. p0300 help!!
  136. Alternator amps
  137. Well, how do they look?
  138. 2000 Maxima 5spd Engine mounts refresh
  139. All bank 2 cylinders not firing? SOS!!
  140. Clutch & flywheel questions
  141. Engine covers
  142. Double Take On Cranking
  143. will 3.0 obx headers fit the 3.5???
  144. (NYC) I need pnp harness for utec HELP
  145. Sunroof issue
  146. ECU Programming
  147. Need some help 02 I 35 battery draining.
  148. Gauge cluster swap p0462
  149. Gauge cluster swap p0462
  150. Coilovers for my maxima?
  151. Bose Radio Head Unit - No Power
  152. Brake pad / rotor difference between 3.0L and 3.5L
  153. Strange Auto Transmission behavior
  154. 2002 Bose radio dash controls
  155. Flywheel is stuck to the torque converter
  156. No fuel, no pump sound?
  157. 2000 maxima Test Pipe?
  158. Will auto and manual dash harness be the same?
  159. Ebay lower oil pan gasket, any reason not to use?
  160. Type of intake plastic
  161. P0462 confused
  162. New Misfire/code immediately following service
  163. Think my ECU is fried..!!!!!!!!!
  164. Drl light won’t shut off!?
  165. Infiniti rear shade into maxima
  166. 01 Maxima blowing “Meter” fuse
  167. Pre-Cats
  168. 2001 Maxima thermostat
  169. P0011 and P0021, Cooked ECU
  170. Gutted pre cat now I hear Air when i accelerate.
  171. Is this grinding noise my differential? New transmission needed? 2003 maxima auto
  172. VQ35HR Motor Swap
  173. Struts for Maxspeeds
  174. 2000 Maxima SE temp rising
  175. HELP! 2001 Maxima - New Alternator, Same issue
  176. P0227 P0226 Infiniti I35 2002
  177. ABS not functioning
  178. New motor (3.5L)
  179. Speedometer Not Working *Update*
  180. Question about Motor Mounts for 02-03 Maxima
  181. Infinity brake conversion
  182. LKQ Online Ebay 7th Gen Engine; Yay or Nay?
  183. Motor swap but car won’t start
  184. Overheating issue
  185. Super Time Tranny Overheats
  186. Orange/white wire behind Bose hu ?
  187. Can not bleed maxima ,i think i need to cycle ABS
  188. swap 3.0 MT with 3.5 MT ?
  189. New to the fourm 01 Maxima
  190. Warbling Noise When Moving. Any ideas?
  191. Moving electrical problem
  192. 5th Gen RTA OMG
  193. Nth TEENth non LSD to LSD 4AT conversion thread?
  194. Redline leather shift boot,Mazda shift knob
  195. Aluminum valve covers
  196. Repair help!
  197. Anyone done a 3.0 to 3.5 swap?
  198. Speedometer Not Working
  199. Clutch Pedal on the floor during bleeding process
  200. Replacement dash lights for 5th gen
  201. Exhaust Pros, I need help!!!
  202. Throw Out Bearing Tab Orientation.
  203. Adjust New Belt Tension? 2002 VQ35DE
  204. 2002 maxima front hub/ brake noise
  205. Fuel pump noise
  206. Alternator replaced but is vibrating now
  207. P0300 Help Please - Yes Ive Read the Threads lol. 2002 Maxi
  208. My sunroof is possessed.
  209. Just bought another i35
  210. Rear cup holder won't open
  211. Lack of power issue
  212. altenator replacement cost.
  213. 2000 5 Speed Manual Tranny Refresh
  214. P0171 Lean Bank 1
  215. Stalling / Stumbling at the Gas Pump after Refueling
  216. 2002 Maxima vs Honda S2000
  217. Am I crazy, or just in love with the 5th Gen?
  218. Do I Have Locking Differential OR Non-Locking Diff?? 01 3.0 SE Model
  219. New / Used I35 Toy; Couldn't Resist
  220. New Flex Pipe OBX V2
  221. 2002 maxima Inner Tie Rod Torque
  222. 2003 Nissan Maxima 3.5 6 speed transmission and clutch
  223. power steering rack
  224. clutch master cylinder quick fix
  225. Engine Support Bar - Tranny Removal
  226. Ever google "car falls on guy"?
  227. Coolant leak from back of engine
  228. Who is the OEM manufacturer of Cam sensors?
  229. 2002 Rack and Pinion question
  230. 01 extended crank but, hesitant start
  231. Battery cover and questions
  232. 2003 locked motor replacement
  233. Finally!
  234. Clutch slips
  235. Tach gauge suddenly messes up
  236. cross member bushing.
  237. New Mass Flow sensor = Limp mode?
  238. Picked up another maxima...light clean up 2002 GLE
  239. Motor Mount replacement How Much to do all 4 Knock when i take off
  240. Hello Who has the best Y-Pipe & Low cost
  241. Transmission Filter change WOW what a mess
  242. 2003 Maxima Decal/Badge??
  243. Radiator fan
  244. 2001 Maxima for parts
  245. ECM Wiring Harness - P0403 & Limp Mode
  246. Alignment after Wheel bearing replacement?
  247. Pending P1800 question.
  248. Starting Problem *i did a search and read up
  249. Input Shaft Bearing or TO Bearing issue?
  250. 2001 Maxima gear problems
