PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Engine knocks in hot weather (110F)
  2. Idle Air Control idea
  3. What color to powdercoat wheels???
  4. Diesal fuel in my engine!!!
  5. 00/01 vs 02/03
  6. Steering shifts left when gear change?
  7. will h&r springs from a 4 gen fit my 5th gen?
  8. How to replace park / neutral switch on 2003 automatic??
  9. Power loss after hitting curb.....
  10. cant find codes in sticky
  11. No money to fix the maxima... don't know what to do right now?
  12. What looks best
  13. Saying Farewell but Not Goodbye!!!
  14. 2003 SE Steering Wheel Size Question
  15. Loss of power, exhaust rattle, lack of power?
  16. weird noise coming from tire
  17. AT shifting into 4th issue
  18. Noise when Braking
  19. Runs rough in humidity.
  20. new idler pulley
  21. Question for all Tein SS owners.
  22. Checking engine oil
  23. Competition Clutches
  24. ob2 not reading.. ???
  25. Tranny fluid
  26. what are symptoms of a bad/faulty transmission speed sensor
  27. What could be the causes to a Sluggish throttle response in a Manual 5.5 gen?
  28. Ebay Halo Lights?
  29. My Maxima/Introduction
  30. A/C help and questions
  31. Bumper Cover Repair
  32. Driver door
  33. I need help taking off my roof liner...
  34. Where to put sound deadener to cancel out exhaust drone?
  35. Bulbs from HID EXTRA don't fit my harness?
  36. fabbed up some center caps
  37. resetting ecu
  38. projector question
  39. Need help removing the ecm
  40. Won't start, confused
  41. flooring an auto
  42. Got fed up of klunking noises
  43. Y Pipe O2 Sensors Issues
  44. FML!!!
  45. No Power Steering At Low Speed
  46. Help with code PO507
  47. Lower Control Arm Replacement Recommendations.
  48. aRe the ebay turbo good?
  49. Installing NWP spacers soon
  50. Issues running 45 sidewalls?
  51. 100k maintanence?
  52. 2002 and 2003 Maxima Production Figures.
  53. Need assistance adjusting clutch
  54. Smog issues with headers
  55. Dimming last- Flashing ABS light PLEASE HELPPPP
  56. Tokico Illumina
  57. Problems finding CV Joint for Manual Transmission car
  58. white smoke! nooooo!
  59. Rear bushings with trailing arm still on the car?
  60. Request some assistance in pricing parts
  61. Adios and good luck!
  62. Window Alignment?
  63. How to get Valve Body back in??!
  64. Catalytic Convertor Replacement
  65. Auto Trans Problem
  66. ahh leaking oil again wtf
  67. Fuel Pump does not shut off
  68. Code P0113?
  69. gas smell?
  70. New clutch master cylinder and slave cylinder for soft clutch
  71. Motor mounts
  72. Looking for some help.. Starting Issue!
  73. 2k4 seats bolt in 2k3???
  74. HELP: back door wont open
  75. smell of burned oil and check engine light
  76. Transmission problems...
  77. Trouble Shoot leak w/ Pics
  78. Frankencar intake for 5.0 gen - hole in midpipe, what is it for?
  79. Maxima FSM - Download Service Manauls!!!
  80. How difficult to replace front bumper cover?
  81. Transmission slips out of gear
  82. No ac/heat from vents
  83. name this vacuum hose
  84. Car died... Possibly alternator?
  85. Oil strainer
  86. Car turns on fine and shuts of while in gear after 30 min
  87. adjusting my coilivers and this happend
  88. vibration at highway speeds
  89. Best socal tuner?
  90. 350z/se-r transfer with 6spd?
  91. Strange leak coming from ebrake cable??
  92. blue some at high speeds
  93. Help: Front end noise
  94. 2000 auto trans issue- need advice
  95. More air at 4k RPMs?
  96. Help me get my rear seat down!
  97. HELP: 5 spd stalling in reverse
  98. Custom Maxima Exhaust System Reviews???
  99. Cali vs Fed Spec emissions: How do you tell?
  100. what K&N filter does Frankencar Intake
  101. Does 5th gen really adapts to its driver ?
  102. swap in progress 3.5 5sp vlsd.
  103. Goodbye Maxima
  104. Stupid SES light
  105. Stock B Pipe Question
  106. Power steering issues
  107. FS: 02 intake manifold
  108. Spark Plug/Intake Manifold ?'s
  109. Solutions: Engine rattle and header questions
  110. I have an iacv question
  111. y-pipe dyno charts request for 5th gen
  112. Spray paint color match?
  113. 6th gen bbk
  114. p0455 and p1448??
  115. power on top
  116. Front bumper replacement?
  117. rim suggestions?
  118. Wheel well molding..
  119. Need Help in Brake Part Identification
  120. OBX Y-pipe. Fit or Not?
  121. Vibration When Accelerating
  122. Head light sensor
  123. Harmonic Balancer
  124. ECU Software Update
  125. Alternator failed-no battery light?
  126. Getting really hard starts
  127. TL vs maxima
  128. 6spd is driving me NUTS!!!
  129. O2 sim alternative?-
  130. Found 97 Manual Max on Craigslist - Should I?
  131. Question about the Trunk.
  132. Replacing Rear Seat Belt
  133. Another Gas Mileage Thread
  134. Lighting upgrade!!! leds front and rear
  135. all season falkens?
  136. Transmission mount, bap/autozone confused (pics)
  137. headers
  138. Brake Pad wear on z32/cobra BBK
  139. Stereo Dash Kit
  140. Moved from Philly to Fairfax, VA
  141. My car smells like hot plastic on the inside.
  142. Lost Power Steering
  143. Weird clutch issue!
  144. projector foglights with stock brackets
  145. Auto tranny flush
  146. Z32/Cobra BBK Questions
  147. Who is intrested in a GD for the REAL paradox-systems 1/2 window spoiler?
  148. clutch chatter? Bad Mounts?
  149. My 2001 Maxima FX-R Projector Retro
  150. Replacing fogs.. Upgrade to HID?
  151. Sunroof starts to close....then opens
  152. No power windows & Auto lights, Any suggestions?
  153. Destroyed my rim and question about an ebay item
  154. pulley fitment`
  155. Left side speaker cutoff issue.
  156. Found my P1336 crank pos. sensor problem. :)
  157. two tone, yes or no?!
  158. How to change knock sensor on a 5th gen?
  159. Suspension noise....what can it be?
  160. Tranny dropped out of gear going....above 65mph
  161. uneven car??
  162. Maxn"out" of commission...
  163. What's wrong with my tranny!
  164. found a switch for dr mod
  165. Need some quick help
  166. 4th gen rear struts/springs on 5th gen
  167. Aftermarket Navigation System
  168. NWP DE-k spacer install
  169. Gas Mileage 5.5
  170. Clutch issue-- Help needed!
  171. Real window full roll down?
  172. How do you unbolt the side window when it is stuck all the way down?
  173. 2000 grille
  174. Has anyone baked headlights with eyelids on?
  175. New Energy Suspension Engine Mounts
  176. 2003 GLE price Opinions sought
  177. Want to install Flex LED
  178. P1800 DTC - VIAS. What am I checking first?
  179. 2000-2001 clusters dim? i can make them brighter PICS!
  180. Replacing MAF have a few questions
  181. key stuck in starter tranny related
  182. Rough start followed by tcs and slip lights
  183. help, knocking noises!
  184. 2003 rear calipers/pads - early/late build date?
  185. Concerned 5.5gen Owner
  186. will hood struts from a 5th gen fit??
  187. LTB clearance issues with headers/y pipes?
  188. What is this plug in the trunk for? It is leaking
  189. lowering vehicle
  190. New Valve Cover/Plugs Now P0300 & P1614
  191. size of metal cylinder for mount
  192. How many AE's were made?
  193. List of maintenance items needed
  194. Perks Final Exhaust Setup !!!!! Vid
  195. 6 gen Maxima seats to 5.5 gen maxima?
  196. Looking for a simple exhaust fix!
  197. "SERVICE ENGINE SOON" light on
  198. Bouncing off redline on 3.0 engine
  199. I can't aim my headlights
  200. 03 MAXIMA A/C Condensers
  201. radiator support
  202. Took my car to a tranny place... still don't know what to do!
  203. Coolant leak when starting up car
  204. Headlight question
  205. Before I jump to say it's the head gasket...
  206. how low can you go ?
  207. Update- got codes still need help
  208. why is my battery light and my brake light on?
  209. Bye!! 02 Maxima 6MT
  210. silly question
  211. ok so a little clarification
  212. I had a back weekend, need help plz
  213. 5th gen not appreciated???
  214. My fog lights are pissing me off!
  215. How to remove the Automatic Climate Control Module
  216. !!!HELP!!! weirdest thing happens
  217. new clutch car wont move
  218. What is this? (Pics)
  219. Did I just ruin my car?
  220. Intake pipe questions
  221. Halo light out???
  222. Won't Downshift When Passing
  223. H.I.D bulb replacement
  224. Why you should test your mods at night!
  225. Some acceleration issue
  226. 00 max fuel pump/sending unit
  227. VQ35 swap tips/lessons learned, etc.....
  228. 6th Gen from Cardomain... Hmm...
  229. D2 Coilovers or Megan coilovers
  230. Bionic Heart Transplant (6th Gen Engine into 5.5 Gen)
  231. Stillen Rotors/Hawk Pads question
  232. Does this sound like engine mounts or something else?
  233. Help Clutch
  234. Having trouble finding front motor mount
  235. Clutch Bypass
  236. Ignition Key won't turn unless it's jiggled.
  237. starter issue.....
  238. 5.5 gen wrecked, "total loss" pics
  239. Painting headlights and engine cover. Who also did it?
  240. Keyless entry problem
  241. video of 5th gen running open headers......
  242. Smoked my tails
  243. Need help on 3.5 swap
  244. Changing plugs ('01) - what else should I replace at same time?
  245. Need more help with this ticking
  246. what transmissions will fit in my car
  247. 1-2 Slip at WOT on 5.5 4AT
  248. 6th gen BBK question
  249. wiring problems?!?!?! help!!
  250. Cranks good, but no start and no spark
