PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 [87] 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Excessive Oil Burn, (magically disappearing)
  2. Dim aftermarket D2R bulbs?
  3. How long / much to change this out on my max...
  4. HELP! Cant put gas in the car.
  5. About to buy max on eBay. need last minute help!!!
  6. 01 max engine/tranny problems after exhaust?
  7. how do i remove the scrwes on the bose unit
  8. Nasty curb hit - did I bend the rear axle?
  9. Remote starter
  10. 02 Sensors
  11. Did my first auto transmission fluid change today: Some observations
  12. help
  13. Can't get the battery out!! Help
  14. need help how to remove the bose unit on my 2001?
  15. unified meter control unit
  16. Door Alignment
  17. headlight clip !!
  18. Front passenger seat Prob
  19. Oil Burn = Knocking/Pinging?
  20. Need a chipped key to unlock door?
  21. This is really wierd
  22. WTF - Alternator or Dead Battery? Help!
  23. P0340 - related to the recall?
  24. P0300 Random Misfire - not coils
  25. need help removing back panels.
  26. Hyperground Impressions
  27. Oops, disconnected airbag plug under glove box
  28. Front end clunking?
  29. what a diffrence
  30. i think my tranny is done
  31. Feel ripped off:berk intake
  32. To All Those With Tachometer Lighting Issues...
  33. Is this a good deal on a 2000 SE?
  34. Confirming bad wheel bearings...
  35. whats the best way 2 replace alternator belt..
  36. Climate Control Light
  37. P0303 Code? Yes, I searched first
  38. Knocking from the right side engine bay
  39. alternator belt screeching and even louder when driving
  40. Steering wheel radio controls rattles..
  41. Suspension
  42. what happened to the forum/search?
  43. Squealing/Grinding Sound When Turning Left
  44. Suspension noise ... need to find the source
  45. Struts
  46. Request for updated link
  47. P0301 code...possible cause of SSIM?
  48. Looking for steel wheels in junkyard for winter tires
  49. Problem: Car Hesitant to Start
  50. Help Please: Screeching Sound from AC when car starts
  51. new coils.....still missing
  52. Constant SES and need help
  53. need help on tools and installation....
  54. Anyone running a scangauge in their 5th gen?
  55. Replacing Alternator
  56. P1148 and P1168? What do you think?
  57. Air Bag Light Flashing NEED HELP!
  58. DOOR LATCH HELP!!!
  59. Damp Carpet Under Pedals - Please help
  60. Ebay Clear Bumper Lights
  61. where to purchase a new OEM steering wheel?
  62. PLEASE NOTE NEW RULE IN 5TH GEN FORUM
  63. Alternator Amperage
  64. 02 Suspension
  65. battery not charging.alternator is good..but terminals are corroded green and white
  66. pink dot coils?
  67. Steering wheel rattle.... Video inside...
  68. Weird mechanical whirring noise
  69. What is the band on the OEM DR2 bulb for?
  70. what does this plug go to?
  71. Bulb Size
  72. Rear Marker Lamp Assembly
  73. New maxima but power lock problem
  74. Not sure about my engine
  75. anyone have a clue?
  76. Fold down the seats, dent the leather??
  77. auto tran control device
  78. Anybody replace their tie rod ends?
  79. Looking to buy a 2002-2003 maxima 6 speed NEED SOME HELP
  80. How does my car know it is ICY?
  81. my car just hit 115k today
  82. Home Depot Grille
  83. Tachometer Not Working Fully
  84. Touch up spray-paint for pearl white...
  85. question about clutch pedal adjustment
  86. Quick! Please help save my taillight...
  87. stalling...please help
  88. Good ol MAF Sensy
  89. Blower fan switch, one level only
  90. how long did it take you to find 5.5 6spd
  91. 100K
  92. Lookin For SUPER !!!
  93. Front Sway bar diameter on 5.5 SE
  94. Which outlet type for flowmaster muffler
  95. Interior / center console disassembly
  96. 2002 se 6spd running sluggish
  97. Power Seat Base Adjustment Problem
  98. Suspicious of Water in Spare Tire Area
  99. Squealing sound from steering wheel
  100. Loop on remote broken - looking for case
  101. ECU Reprogram for 2002
  102. shifting in the manual...
  103. leaky rear 3.5 valve cover? FS:brand new gasket
  104. 02+ gated auto shifter modifications
  105. Mudgaurds
  106. motor mounts
  107. redline anyone?
  108. P0420 code
  109. Tire wear and steering wheel shake
  110. Maybe i should buy a seat cover..
  111. P1147/67 Mfr. Control A/F Metering
  112. Service Engine Soon (SES) light after new battery was put in ..
  113. I take it "traction limited" is normal in 1st gear in automatics?
  114. Acceleration Delay Issue
  115. lowering susp question...
  116. Tein H-tech questions
  117. Removing rain guards...
  118. Murano Windshield Washer Nozzles, Sprays my Roof!
  119. Wheel lock nuts
  120. Spec Stage 2
  121. Is there a way to hook up the 02' factory bose subwoofer to an aftermarket headunit?
  122. Exhaust Flange
  123. Aftermarket Exhaust Rattle?
  124. Question about rear deck rattle
  125. ABS question plz
  126. exhaust gets real loud + rattles...only in rain
  127. 2000 SE versus GXE manual shift
  128. How long to replace clutch?
  129. Farewell Guys!!....My max is gone!!
  130. Windshield Washer Nozzels
  131. totaled 2001 max for $500 good deal?
  132. M3 Lip Spoiler
  133. Q: will the altima 02-04 leather seat covers fit maxima.
  134. Finally took the plunge and gutted the IM (SSIM)
  135. Can anyone here get an accurate oil level reading?
  136. starter ocasionally wont stop when starting
  137. Going From 5th Gen Auto to 5.5 gen 6 speed... Questions...
  138. How do you determine if HID bulbs need replacing?
  139. eBay Halo headlights! SHOW EM!
  140. Odometer light not working
  141. Air Bag Light Blinking - Reset Options?
  142. Kit/Bezel for In-Dash DVD Player
  143. Replacing lower oil pan
  144. 2k Illumina Eibach install notes
  145. Need to know a part name/part number of and odd part
  146. Weird Blower Problem
  147. Had a shop do some regular maintence, now a bit worried.
  148. Rubbing noise coming from front drivers side wheel
  149. horn wire missing? help
  150. will a 3.5 pass emisions with hotshot headers ?
  151. WTF!? 2 in. of water under my spare tire
  152. Anyone tried to swap gauge clusters ?
  153. Heated seat not working need help
  154. quick question?
  155. **Non-Bose** rear deck rattle
  156. 3.5L spec stg 2 disc, sprung or unsprung?
  157. OEM rotor material - is it special?
  158. Doh - $20 job almost turned into a $568 job!
  159. StS Help 5.5 6 Speed
  160. inquiring about purchase of a max.... again :P
  161. fog light projector question...
  162. 4th gear not working
  163. is my tech messing with me?... (brakes)
  164. Weird rubbing sound
  165. Replace Gearbox or Axle bearing?.... Help!!
  166. Purchased a 2003. Have a few questions.
  167. The finish on titanium edition rims
  168. quick question???
  169. Recommend a new battery with great CCA
  170. Replacement Flex Section?
  171. Car Cover Question
  172. Installed Stillen Intake and FSTB - Impression and Questions
  173. Clear signal lights pass inspection
  174. 2002 maxima vibration
  175. Please help....maxima resonator question
  176. 2002 Maxima SE Underbody Rattling Sounds
  177. Ready Monitors Not Ready?
  178. 2k2 idling too low at 200 rpm when stopped
  179. No A/C blower at all
  180. Starting problems, resolved with $$$
  181. would a 245/45/17 tires fit on stock 02 17" se rims?
  182. I positive that im burning oil...
  183. How to tell if a Y pipe is for a '99-'01 vs. a '95-'98?
  184. Front strut tower brace (eBay kind)
  185. 2003 Max Making Rattling Sounds In Engine Bay
  186. 01 with 02-03 HIDz, question
  187. screwed up my illumina install
  188. Performance Mufflers
  189. DYI painting 5.5 grill write ups
  190. ABS line cut
  191. 2000 maxima gxe...side bumper lights dont go on?
  192. Resetting ECU (02-03)
  193. rotora rotors?
  194. loud clunk
  195. How do i clean an apexi power intake? Please read.
  196. *Video* of completed touch screen/Climate control relocate/Computer
  197. what to look for/what goes on 5th gens?
  198. 1st gear rattle/grind?
  199. What do you Guys think of these headlights???
  200. shift linkage question.
  201. Cosworth adding the VQ35DE
  202. Can't find anything about this.
  203. what kind of cat to buy?
  204. Upgrades / Changes 2000 SE
  205. New toy.
  206. Some opinionated questions
  207. Analog speedometer sticking...
  208. Oxygen Sensors - Should I replace them?
  209. new struts get rid of clunking noises
  210. Need SOme People Opinions
  211. Might need a mass airflow sensor on my 03
  212. Requesting picture of VQ35 6sp fidanza flywheel
  213. Need Pics of Eibach or H&R Springs on 20s
  214. custommaxima is back??
  215. how much does a used berk intake go for?
  216. Maxima wrecked
  217. Hollow sound coming from front end
  218. CEL - P0505
  219. Chrome door lock install
  220. Probably a repost but...
  221. Knocking and Pinging
  222. Kinetix Intake Manifold on 3.5 Engine
  223. stickie links wrong
  224. New Mesh Grille option
  225. Need Help-Fidanza Fly Install
  226. Alternator went bad on me...
  227. Where's the A/C drain hose?
  228. need help will these fit? and is it a good deal
  229. P0446 code
  230. Fuse for Sunroof
  231. Funky noises after replacing Sway Bar End Links
  232. what a steal
  233. A/C Drain Info - Water Collection Problem
  234. Am I ASKING for trouble?
  235. CEL!!!
  236. Leaking Windshield?
  237. Looking for a FOB
  238. kyowa racing wheels
  239. Anybody got a Stealin intake? What hardware does it use?
  240. Install Kit for 02 maxima
  241. Any way to Duplicate Key cheap?
  242. Annoying noise coming from the back...**soundclip included**
  243. Engine Block
  244. Hot long should front axles take to put on
  245. BBK Brake distances
  246. am i doing something wrong... is this how its supposed to be? (shifting)
  247. P1147 & P0139 codes being thrown, need some help
  248. ABS sensor
  249. crazey key fob problem
  250. 5th Gen's for MOTM?
