- rotors
- Loud Scraping sound when turning left
- Is this a MAF syspmtom....
- 6th gen spoiler?
- Steppin Up!
- LED mod for AT Shifter lights?
- Anybody with an E-manage Ultimate working in an 02/03 ???
- 2003 NISSAN MAXIMA SE Hypergrounding kit PowerPoint Presentation.
- anyone use 4 ga. wire for grounding kit?
- Need A Carfax ***please****
- Door squeak from touching the rubber drip strip...
- Possibly buying a used Stillen muffler, what to polish with?
- Replace Brakes/Rotors
- Warm weather...high idle
- 5th gen interior = superior to fourth gen?
- I need help and i searched with no result!
- Y-pipe and Emissions Headache
- 02/03 Exterior Color Options???
- is my car idleing too low (550)? and why?
- H3 white fog light recommendations 2k2?
- GLE vs. SE wheels
- SES Code P0171 Need Help!!! Can't Search
- 00-03 all use the same trunk mat, right?
- Bluetooth for your Maxima
- Zex Questions
- Rear Clear sidemarkers? how to remove....
- 1.5 ton Jack is that pushing it?
- Altima/Maxima Quaife LSD!!
- idling at 1000 - 900 wtf?
- Swapping my tranny for 04 model HLSD s-speed
- So my strut tower brace came today and the box was torn up...help?
- Suspension warranty question....
- need a littel help guys
- darn dde ballasts
- options other than GXE kit for 2 din DVD Screens.....
- 2000 maf. should i?
- Differences Between 5.5/6th Gens
- Key
- Had a code
- To Reset or not to Reset?
- Question about automatic transmission fluid level.
- part number for 5.5 gen Side Skirts/Rockers
- I got a P1610 Code!
- Resetting ECU...Which way is correct?
- Stage 2 LTB w/ Cattman Headers Test Fit
- Must-have mods on a modest budget?
- new struts question
- Rotor/pad help.
- quick tuning question
- acceleration issue...
- Sold My Max
- 2000 GXE manual climate control issues
- Need Advice on Purchasing 02 6Spd
- Tein S vs. Coilovers?
- Parking Brake light is ON, NEED HELP!!!!
- Oil Consumption 2002 BOHICA!
- Feels like driving in the wind
- 2001 Max Horn
- door not closing and locking right.
- Finally hit 300 on a tank!
- Need a Radiator for an '02 and Air Filter
- natti max
- The Myths are true - G35c 18" rims installed and smoked tails!
- Which color touch up paint do I need and what would you recommend?
- Common 5.5 gen problems?
- Dynos indicate major problems
- One touch open/close on sunroof not working
- Rim color help
- Clutch pedal travel = too long, is it adjustable?
- Cleaned TB and installed ghetto CAI-
- Changed 6 spd fluid, and....
- Maintains on 5.5 Gen
- Flashing Air Bag Light - Help Please
- brembo x-drilled
- what kind of mileage do you guys having going?
- Oxygen Sensor buying time!
- Engine VQ30DET found
- Color codes for interior trim pieces?
- Weird sounds when I go over lil bumps
- Headlight Question 00/01 w/Projectors
- check engine light
- 6th gen needs help with crank pulley removal...
- Code P0158 and o2 Sim question
- New mod
- 2000 Maxima trans TSB
- Oil in spark plug valve 4
- Let's play the "Diagnose the brake problem" game.
- Ebay Euro Yellow Amber L+r Fog Light Oem
- If you're experiencing cold start rough idle, and power loss - READ THIS
- How do I remove 2000-2001 headlights I am trying to do AE mod
- Does brand/quality of FSTB matter?
- Parts swapping help...
- SES - P1320, New coils or what?
- Shift console boot part #
- B&M style short stifter
- power seat prob????
- Dash Clock
- vafc
- Having BIG problems!
- Slight "whistle" sound during acceleration
- Diagnose my problem - Get paypaled $5.00
- HELIOS H.I.D. BI-XENON Plug & Play Kit
- maf
- Another FOG question
- 2001 Grill Replacement
- Help, I keep blowing Starters!
- Those who have changed fluid in 6spd???
- B (mid) pipe questions. Info please
- RockAuto for Ignition Coils?
- Hmmm Clogged fuel injector?
- Lexus Capsule or HID fog?!!?
- HID fog install QUICK HELP, just about connection
- Rattling noise...
- Hit a chunk of metal
- Fog Light Problem!!!!!!!!!!!!!!!!!
- ses light p0300
- 4th Gen totalled, 5th Gen here I come!
- Will I35 side skirts fit a 5th gen?
- Leather seats install
- any good cf trunks yet?
- will 00-01 headlight LENS FIT 02 HID
- Brake Pads
- 2003 VQ35 swap in Sentra.. Lack of power!
- quiet clunking noise/ when moving wheel
- Sun Roof ???
- 2001 maxima trunk dimensions?
- Just Bought My 2002 Nissan Maxima SE
- P0507 Idle Control System RPM high ..SOLVED!!!!!
- will a 350Z thermostat help?
- 00~01 fuel injector flow ?
- how much do VQ35 engine covers cost?
- Exhaust Mating Question..
- Front 2k4 Brake Upgrade parts list needed...
- Pulsating idle speed on 2k3 only 18k miles
- muffler question
- how much would you pay
- For those with the ebay projector headlights
- Installed CAI, now SES light
- good price on maf
- Emission/pcm/fuel 10522
- tranny questinons
- HELP! - P0443 and now harness!!??
- New 02' i get to fix
- Can I see some pictures of 5th gens with 20% tint?
- 02 6 speed jerkyness
- How to remove vents
- I actually feel a difference with my new grounding kit!
- Upgrading suspension....
- Cut bumpstops?
- Frankencar Intake
- Removing Sunroof Deflector
- Clunking sound in front end on bumpy roads
- Eyebrows
- AUTO Tranny Flush
- Jet Performance V-force
- Ignition coil bolt ...help
- O2 Sim Question
- Speedometer Recalibration?
- lug nut thread size?
- i want to take my spoiler off
- Question about Ground Controls...
- High Pitch Squeek from front at 1700-1900 rpm? 2k3
- Any1 have pics of 6th gen sl wheels on 5th gen?
- Headlight stolen in NYC.
- Does this sound right??? Dealer question
- Illuminas back on sale!
- How much am I looking at?
- How do you tell between OEM and DEPO?
- Opinions!! Want 18s or 19in wheels but what about suspension
- Window problem
- 02 se..exhaust only one side
- Does anyone know which Apexi Filter we use?
- 99' brake rotors and exhaust cat. & b-pipe interchangable?
- Is my transmission dying?
- Intakes: Berk vs Cattman vs Injen vs JWT
- SE/GLE/aftermarket suspension ???
- DDE owners w/ Yellow Fogs
- Random Disconnected Hose in Engine Bay???
- Rotating Stock Rotors
- Code P1320, P0306
- Oil Pan Warranty Question
- dyno run. wonderful surprise
- 5th Gen ???????'s
- Front sway bar = waste of money???
- helios h3 mini hid fog kit owners please step inside
- ECU Question
- Got my girl a hot new black skirt!! Pics inside!
- Tranny problem...stuck in gear.
- 2000 Maxima stands up well against Elk.(pretty long)
- looks like oil on coil packs
- Performance Parts questions
- Rubbing on one side, but not the other
- Effects of trunk weight on gas mileage.
- Which rims to buy for my 5th gen?
- 2002 DriverSide Automatic window problems
- Rotors Issues
- Alarm malfunction
- Glowing Red Rotors
- Dent in my hood
- Brakes soft after new rotors/pads...now what?
- P0139 and P0138 warranty fix possible?
- Installing an air conditioning vent please help
- Towing Capacity with 02 Max?
- 2000 fog light assembly removal
- Does your car stutter when starting?
- PDR place north or west of boston
- rpm
- Screeching Sounds!!
- aftermarket exhaust.
- Key Fob- Windows- WTF?
- 02 no balls and dies... ???
- Matching sidemarkers and Head/Fog Lights
- brake pads
- Going to by 5th gen in a few weeks and I have some questions
- headlights and bulbs : the right one :)
- Siezed wheel lug, stud issue
- Is Flywheel damaged, debris in bell housing - or worse??
- Check Engine = P0720
- How fast does your tranny shift 1-2?
- when is it time to buy a new one
- Sluggish when cold and uder 2.5K rpm
- power drops after 3500 rpm .. engine stalls during warm up period ... need help
- Rear rotor removal...feels like it's welded on
- Teaser Pics - Ipod, Sat Radio, or Aux 6 disc changer option
- Suspension Help
- finally installed my illuminas with tein stech springs, :)
- Rear blinker bulb question
- Quick Question! Which postion to face the xdrilled rotors?
- Bad CV Joints?
- HELP, car won't start!!!
- JIC A1 coilovers -- are they any good?
- Ok this is a new one. (Wiper Handle broken)
- Noise gone! but now vibartion
- Baking Headlights w/ XPel
- Max No More
- Valve Body mod for 2K1 maxima
- Location of ECU 2002 Maxima
- So I found out why I need a new MAF sensor.
- 6th gen 18's
- Pic request: H&R drop, front only
- Clunk from front passenger side?
- Problems after CAI install......
- FSTB Installation
- Too good to be true? 100 bucks for a lip?
- Power Passenger Seat Problem
- Weird rotor wear on my new rotors....uneven pads?
- Maxima.org decal
- Best Brake Pads
- Need your opinion on what size of wheel spacer
- I hate to do this...but.....
