PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. HELP!!!!!- Car won't start......need advice!
  2. HID Replica vs. OEM
  3. Busted a Brake Line whilt traveling...
  4. Quick ECM question
  5. 2000 SE BASS BLown ??? Need replace amp, HELP!
  6. CV Joints Clicking Only when REALLY COLD
  7. Does your blower motor sound like a weedeater? Cheaper fix inside..
  8. Installing Fog Light on GXE Nissan Maxima
  9. DTC P0135....Can't get this O2 sensor out!!
  10. Goona try to make a custom "warm air intake"
  11. Need help: Strut Plates
  12. What do ya'll think about these headlights
  13. ABS LIGHT (Can it cause the whole ABS system not to work??)
  14. Maxima 2002 SE, 6SP, 120000 miles
  15. Blinkers for 2K1 SE
  16. Automatic shifter problems...gets stuck in 2nd or 3rd
  17. on the market for y-pipe...
  18. Maf Q
  19. New 3.5 SSV polished intake manifold
  20. I Hate People!
  21. Crunking and rattling noise!
  22. making a plug and play eu ecu harness?
  23. so long Maxima...
  24. Just wanted to share a pic...
  25. po505 help
  26. Suspension travel is <2 inches. Bottoming out often.
  27. Info on Big Brake Kits?
  28. tint
  29. Car dies as soon as i start it unless i keep on pressing on gas!!!
  30. heard the stupidest thing today
  31. Jack Collapse......Any Ideas?
  32. I need these side skirts
  33. CV joint noise in the cold?
  34. Am I ok padding the C Pillar
  35. Its Official... My Max Is Totalled
  36. Will a 5.5 GEN grill fit a 01 grill?
  37. Stock 01' GLE 0-60 time?
  38. anyone hear of this IM gasket insulator b4?
  39. Swaping a wing from an SE to a GLE
  40. what kinda alarm?
  41. Gas
  42. Rust-free rotors... does such a thing exist?
  43. Highway speed noise
  44. Dash kit removal
  45. which plugs to get?
  46. Cheap Ebay Maxima Turbo
  47. Keyless entry
  48. Mechanics: Step in. Need a HOW TO.
  49. Looking for masterswitch...
  50. Thoughts on Koni "Yellows" and what springs to get for them?
  51. $$$ to spend need suggestions
  52. New 2001 Maxima GLE questions
  53. How do I swap out the thermostat?
  54. Needed Maintenance
  55. What pin and wire color....?
  56. Ebay Projectors
  57. Sway Bar bushings
  58. Tranny problems 5/60k warranty question
  59. VQ30DEK: engine talk
  60. Energy Suspension shifter bushings
  61. Anyone have pictures of tinted/darkens 5.5 gen tail lights?
  62. 04 HLSD Transmission in an 02
  63. Looking to buy a 2002 Maxima, have questions.
  64. Loose E-brake...
  65. Help!! Broke down on the freeway
  66. Couldn't leave the family (new 5th Gen owner)
  67. Idle trouble....
  68. reset SES but not codes?
  69. Replace trunk mat?
  70. PBR pads squeaking real bad
  71. Tuning without afc
  72. problem w/hood
  73. 02 Max GLE vs. 98 Audi A8 4.2 Quattro
  74. 3 moderately serious issues with my 03 SE
  75. Four Point Harness Question
  76. Rear Window Spoiler
  77. SE speedo cluster swap Q
  78. Coolant leak
  79. What happened to the 2k1 parts website?
  80. Any special toold required to replace ball joints.
  81. Will a 4th gen tranny work with a 2000 max?
  82. vq35 cam
  83. HID tech fog yellow fog caps
  84. 2001 AE Maxima Low Idol
  85. 2002 Owners Manual
  86. Sub stopped working
  87. 2001 AE w/auto - reliability
  88. Low engine oil rattling noise could be linked to SES light "cam position sensor"?
  89. Wheel Bearing Front Replacement
  90. How to get that 5hp that is stock with Special Edition SE max?
  91. 5.5 Front grill interchangeable with 01?
  92. Seriously, how?
  93. 6 speed people with 7000 or 7200 redline
  94. Farewell post
  95. Need Serious Help...
  96. tranny problem
  97. 4th gener thinking of going 5th gen
  98. Will an 03 Infinity I35 MAF fit in an 02 Max?
  99. Help! Stop the Squealing!!! Awful squeal when turning left
  100. Help with a K&N part number
  101. Anybody else seen Hotshots website?
  102. Underbody Neons
  103. gas mileage went to hell
  104. rear ended a car. Help!!!
  105. Need help W/ taking off Transmisson screen/filter, bolt just spins
  106. Vogtland springs question.
  107. Rough Idle in Reverse Only
  108. Stereo Removal - Running into problems...
  109. VLSD questions
  110. 77K Service
  111. having problems with my 2k1- stalllllling
  112. Traded the Max
  113. Has anybody tried removing the navigation unit on an 02 or 03 Maxima?
  114. Y-pipe saga...weird sound...now error codes!
  115. led power
  116. BCM Location
  117. "Marbles in a can" pinging noise under deceleration
  118. Mod eBay projector headlights
  119. Timing belt or Timing Chain?
  120. ECU reflash pricing.....
  121. Dust off an old chestnut, real aluminum dash kits
  122. Has anyone tried this muffler?
  123. Short Shifter??
  124. Using Turn Signals Causes Hazzards To Flash
  125. 02 Max having trouble starting......
  126. safc for $175 bucks used
  127. LEDs for the turn signals?
  128. Help reading codes
  129. Remove Emblem from Center Cap?
  130. Cattman CAI
  131. tranny slipping can anybody help me?
  132. new headers and VIAS
  133. Dr. Roy this is about CCFL's
  134. Car wont start after clutch change
  135. how about these headers??
  136. Removing headliner from 2k2 to expose sunroof mechanism???
  137. "Bees in the Can" from Cattman y-pipe? Please help...
  138. Intake manifold mod
  139. 2000 Flasher (Relay) placement?
  140. maxima lights
  141. Sell or Supercharge
  142. ABS problems
  143. New CV Axles still slightly clunk
  144. exhaust tip finisher
  145. Got hit again
  146. Fuel Pump Cut-Off Switch
  147. i have a question
  148. Anyone need wipers?
  149. Door Noise problem
  150. Accident, hoods: oem vs. cf aftermarket
  151. Tein S Tech question
  152. battery problems
  153. Any first hand experience in evap canistor replacement?
  154. need help removing spoiler
  155. Low-Temp Thermostat
  156. car won't start... Tranny swap...
  157. I am addicted to Power
  158. Transmission breather hose?
  159. Question : Why should the oil dip stick not removed while filling oil
  160. Which suspension bushings to replace while doing struts/springs
  161. new motor mounts
  162. Where to buy 00-01 clutch kit in Canada?
  163. AGHHHH Cant Find Fuse
  164. Eibach Spring Question
  165. p0430- but no light?
  166. I Need Help W/ Stock Headunit Removal
  167. SES and codes
  168. Help with installing DDE's
  169. How Many VQ35's have done SeaFoam and Got CEL?
  170. Found a great deal on Brembo blanks 90.80 shipped
  171. hot cold guage is cold when moving. need help
  172. Best place to splice for a hardwire XM
  173. dash fan making noise
  174. Clockspring Assembly???
  175. oem intake question
  176. apexi fliter
  177. MIL Eliminators $12 bucks? Anyone have experience with this?
  178. Oil Filter Cap...
  179. Alarm question
  180. weird problem, i think its my tranny
  181. "Y" pipes
  182. 6spd shifter control arm
  183. battery issues
  184. o2 Sensor Replacement/ECM Reset Required?
  185. Noisy 5 speed?
  186. Gauge cluster bulb replacement....
  187. power steering leak
  188. Battery died -- checking on the o/p voltages
  189. Anyone have pics of 5.5 gen with 35th anniv. 350z wheels mounted?
  190. **random But Important Please Help**
  191. accident advice
  192. stealership woes!
  193. When to replace Air Filter, Cabin Micro Filter, Plugs and Fuel Filter
  194. How to remove the freon in the A/C line ?
  195. cattman catback clunking
  196. Hookin up power seats. Need some Help.....
  197. Plugs are showing lean
  198. Bose Subwoofer Cut out Problem
  199. Ground Control Coilovers Installation
  200. Ah... The infamus tranny problems...
  201. Where to buy for 2K3: Bushing for manual shifter. At end of shift cable. For STS....
  202. Lemon Law
  203. for those who have installed walbro fuel pump
  204. skipping issue continues......
  205. body kit?
  206. Need Help...
  207. Ignition Amplifier, how does it work?
  208. 6spd shifter cable bushings
  209. Need help w/ P1320. Beyond just coil packs and have searched.
  210. Belt Broke!! Help Need Immediately
  211. Headlights on with Wiper Blades
  212. Damn Ignition got me stumped!!!!
  213. which hella horns
  214. Front Bearings: hub+bearing or bearing only?
  215. Crazy accident need advice
  216. Phenolic Spacer Development for VQ35s
  217. exhaust leak or tranny slip???
  218. Looking for Advice... Factory Navigation
  219. Maf Excellent....shifting Not
  220. Possible Transmission Problem -- Confirm/Deny
  221. New exhaust vid with new headers.
  222. Dim Door open light?
  223. Help!!!!! Key Ingnition Problem
  224. clunking noise when i make turns
  225. Wierd 5.5 stalling problem
  226. Battery/Alternator Fuse on 2k2
  227. 5th gen comercials
  228. Odd light activity
  229. 2002 Speedo bulbs
  230. Groaning Sound Turning Left At Slow Speed - Opinions
  231. ECU are they really worth it?
  232. front suspension work....DIY?
  233. Milky oil in catch can. Is it due to the cold?
  234. AEM Dryflow
  235. !!wind Noise!!
  236. Help Me Understand!
  237. My custom LED lights
  238. Where does this hose go?
  239. Are we still buying y-pipes or is everyone getting headers?
  240. Finally did the GAB mod!
  241. Help! My trunk won't close!
  242. 95-96 Greddy SP on my 2k2
  243. Got Problem With Illuminas / Teins - What Do You Think? (pics)
  244. ? about ebay projectors/swap with bosch e46
  245. STS Users please step it...
  246. 6-speed swap (people who care only)
  247. To 5.5 gen. owners clutch question
  248. 02/03 front turn signal wire harness
  249. Spring question
  250. Upgrades!!!!
