- Dead 2002 6 speed
- shift kit
- Would es t/arm bushngs make the rear feel bouncy?
- coil sleeves?
- radiator exploded-cleaup
- Maxima dies after 10min drive
- Aggressive Driver Here / Area's of focus?
- OVERHEATING - - -Radiator Cap?
- Please buy parts from one of my 3 Maximas...
- Obx collector to y-pipe gasket
- Stillen Flywheel friction plate insert.
- coolant
- Installed Alpine Stereo, now no Gauge or HVAC Illumination!!!
- lower control arm question
- 01 Maxima misfire
- Manual Tranny Drain & Fill - Confused
- Window washer fluid hoses
- Horn
- 2002 Maxima loss of power when warm...
- replacing the front fans
- power bleeder cap.
- Driver side wheel stuck after
- HELP!! 2000 5th Gen CEL codes 732/733
- NEED HELP! 2002 Nissan maxima
- Transmission Swap, HELP!
- 02 max shuts off
- anyone in the RHODE ISLAND area parting out a 2001 maxima
- how to access windshield fluid tank?
- Change transmission fluid with high mileage?
- 5 alternators in one year... HELP!
- 02 Maxima Low Rough Idle
- 01 maxima pulling to the right
- Got a new battery, AC/heat quit working...
- Blower motor noise ??
- 2000 Nissan maxima
- Heater buttons won't light up??
- How to fix this?
- 03 Max overheating worse
- 2000 se manual transmission leak
- Where's everyone from?
- How do you replace wheel bearing?
- Weird Blower Motor Issue
- 2002-2003 Heated Steering Wheel prewired?
- Is your supposed to have a seatbelt chime?
- are California and federal emission exhaust the same besides the fact that its CA?
- Do these have cars have low windshield fluid lights?
- Is Mobil 0W40 really that great?
- Door Compatibility Verification within 4th Gen
- newbie 2001 20th anni
- Special Bose Subwoofer Problem
- 2001 maxima abs sensor location to all 4
- Just bought a 5th Gen MT
- Headlight Passenger Side
- Ever flush your power steering?
- A/C Blower Problem (A/C won't shut off even when off)
- AC Issue
- 2003 Maxima SE Transmission Humming
- Transmission swap.
- 03 SE for sale
- At my wits end, codes p0300 p0021. No one can tell me WHAT's WRONG!
- Car starting trouble
- car cuts off....plz help??
- Throttle Body Cleaning Job
- Transmission issue on a 2000
- hypermiling/tire pressure 2003 maxima?
- What is this piece between intake manifold and throttle?
- Heated seat fuse
- front mount intercooler with CAI?
- maf glued
- Stolen dark blue 2003 maxima SE with black rear bumper
- Check engine light
- WEIRD Side Marker flash
- Help! Hit 2K RPM and stalls!!
- power steering fluid leak in alternator
- wheel bearing question
- 2003 Maxima w/new H&R KYB install..
- How would you guys rate your AC performance?
- Wheel bearing or end links?
- power valve assembly
- 3.0 running rich?
- Driver's Door Droops
- Crank but not starting- maxima 00
- Car cranks but won't start…Need different Suggestions
- 00 rough idle, fuel smell, vaccum leak
- Motor mount replacement advice
- How to check 6mt synchros pre-purchase?
- AC Compressor or Not ? ? ?
- 5.5 gen lug nut size
- 7th gen springs on a 5th gen
- Figuring out "skips" idling in drive
- New rear strut & lower mount alignment
- Gutting intake manifold
- After Y pipe Installation
- yet another question about valve covers
- 2003 maxima vibration and growling noise
- I got robbed.... Literally!!!!
- obx inlet size
- Newbie 2002 maxima
- 2000 Maxima transmission stick not moving
- Any affordable Retrofit Service?
- Anyone replace rear beam?
- Jprocs24's Mysterious Gas Problem Thread!
- USED Coils ? ? ?
- Megan Ez street coilovers
- Which brakes parts should I buy?
- Goodbye Maxima
- Top of the line Camber kits available to 5th gens??
- Y-Pipe!!!!!! Welding Bunge
- My next project!!!!!! Pt.2
- OE parts suppliers Nissan chose for our cars
- Car just started idling erratically...
- 2001 Maxima speaker problem
- NEW!!!!!! LED Gauges pics
- Lower Control Arm Finished Pics
- What battery?
- Noise in my front suspension....
- 350Z HR clutch
- Hello need help
- oil cooler inlet pipe
- PARTS.....PARTS....AND MORE PARTS Pt.2
- 2000 Maxima GLE electrical(?) problem
- vibration/rattle low RPM
- electrical problem
- haltech for 02 wanted
- 2003 Maxima SE - crank but no start
- Reached ludricrous speed today. 148mph
- NEW!!!!!! 2k Max Motor Mounts
- 01 Maxima tranny
- Megan racing springs on stock struts
- 2000 Nissan Maxima SE won't accelerate
- 2000 Nissan Maxima 3.0l Car Cranks but Doesnt Turn Over. Please Read
- Which Oil Catch Can from eBay?
- Right rear suspention banging, please help.
- Fog Lights and Parking Light randomly went out?
- Pic request: blk wheel brwn interior
- 2001 Model Acceleration Issue
- 2001 maxima SE 20TH annv Noise issue
- Getting correct coolant mixture after a flush
- Parts.....parts....and more parts
- Update.....I & O Tie Rod Sway Bar Link Pics
- "Whisking" noise while driving
- Looking for feedback on an available Max! Time sensitive!
- 2003 3.5 no power under load
- Difference in these two part numbers for plenum?
- No heat ...
- 2003 Maxima 3.5 Oil Disappearing
- K&N air filter
- Tein Street Advance Coilovers?
- 3M Paint Defender
- Help picking new muffler
- Ac compressor bolt loose
- Throttle body screwed?
- p0011 (yes another one)
- Intake manifold the same 04-06 and 02-03?
- all 2001 nissans maximas urgent news
- Newest dyno results.....
- New here! 5.5 gen coilovers question!
- Gas knock
- Alright guys don't kill me, but I REALLY need you
- Is this normal on new struts?
- Metra ASWC-1
- Front brakes squealing - rotors, pad and calipers are good
- 2003 Maxima Problem
- replace stock manifold & front cat??
- Sunroof parts broken. Leaking water but still functions
- Seat issue
- Modding SFR Manifold/Need Feedback
- whats this picture of?
- Rediculous Seat Belt Part Broke
- wheel spacers on the rear
- Next project pics !!!! Fuel Filter,Tie Rods,Sway Bar Link
- 03 Maxima A/C System Question
- Complete Stock Air Filter Assembly?
- HELP! 2000 Maxima SE 5sp rough idle stalling
- do I need camber bolts?
- Installed an Auto Zone license plate bracket
- Best exhaust without breaking the bank?
- Head gasket blown? How to diagnose?
- Running a 03 Manifold on the DEK?
- 5th Gen's are Everywhere
- New Serpintine Belt Squeal...
- Anyone catch the 5th Gen in tonight's season finale of The Walking Dead
- Update.....Big Brake Kit Pics
- :( Snowing in Ontario (Guelph)
- Seepage in A/C line
- just curious
- help with my new 2000 maxima
- Ehhhh what's up doc? D2 Racing lowering springs Anyone used them before???
- What to LOOK for???New Tie Tods, Sway Bar Link & Fuel Filter
- 2000 Maxima SE (Cali) PreCat stud removal
- Rear toe out of spec, debating options.
- Possible soultion for those struggling with a P0300 code.
- Blackstone Labs oil analysis
- Open End Lug Nut Acorn
- Another post where i need help asap :/
- FSM says to bleed cooling system with rad cap on?
- Stumped by a rattle...
- engine radiator support
- Camber plates?
- After market intake and exhaust for 03 automatic
- Loss of power p0455, p0011, p1448
- Monkey in My A/C----weirding out on Me ?
- 2000 nissan maxima power sunroof HELP!!
- Oil change 02-03
- Knock Sensor Replacement
- 02 Maxima Tranny Fluid. Is this ok?
- Short WOT sound vid......
- Timing Chain Question
- Thanks Everyone...!
- P1320 & p0300
- found this on amazon
- 02 max code p0401
- brake light is on
- Where does your temp gauge sit?
- 2002 oem parts/ anyone parting out i need help !!!
- No Spark No Start!! Help Appreciated
- 02 headlight removal
- She coughs & sputters at 2k rpm
- Automatic Transmission: Starting in second?
- 03 Maxima front end conversion on an 02 I35
- front end noise
- Oil smell in my cabin air...
- starts and dies, idles fine, drives okay.
- low compression
- Which o2 Sensors to buy? Codes P0031, P0051, P0037, P0057
- In dyer need of help asap
- Advice for 2003 Maxima Compressor
- Need SAFC Neo ECU pinout for 05 Altima SE-R 6spd
- About to buy 03 SE
- 2 EVAP codes and car won't rev past ~2500rpm
- can I cut the power steering belt and not damage the PS pump & rack?
- If you have replaced your own Crankshaft Position Sensor...
- All i want is mount and balance
- p0158 p0137 p0140 all 02 sensors
- Almost get killed this morning, brake on strike
- "Alternator" by BBB industries (Platinum?)
- Best Way to Stop this Leak?
- emission codes
- I stumped the dealership!
- Radiator seam leaking
- Name This Hose (Pretty Please!!)
- Need help - emergency!
- Motor Mounts
- What's the best motor oil to use? Castrol GTX Conventional or High mileage GTX?
- Torque Converter Lockup
- Touch the gas pedal & she dies
- Help me start my 2003 Maxima
- Trick Alternator ?
- Head gasket issue time for fun.
