PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. 2003 power window issue. Goes down by itself when trying to roll up window.
  2. loud clunking noise from front end
  3. 2002 Nissan Maxima nothing mode***
  4. Any suggestions for high consumption/leak?
  5. Pre Cat Gaskets for 5.5 ?
  6. Size wrech needed for front lower ball joint
  7. 5th gen bumper on 5.5gen?
  8. outside temp reads ICY and ----° degrees?
  9. [BUYING] stillen front lip 2002 max
  10. Can bad power valve cause intense whistle?
  11. How to shim new Input shaft bearing..
  12. New springs/struts using old parts?!
  13. Is my tranny dead?
  14. 2002 Infiniti I35 keyless entry remote program
  15. 5 gen IACV question
  16. The dreaded rattling noise
  17. Dome light fuse blowing
  18. 2000 GLE 5th Gen
  19. 2002 nissan maxima gle Charging problems
  20. 02 maxima fuel filler neck leaking
  21. Knock Sensor Replacement
  22. 5th gen evap core removal is different than 4th
  23. Diagnostic Help: ABS light, hellish squeal, groan at start
  24. Stillen Metal Matrix pads
  25. Need some help
  26. Supporting the engine by the oil pan
  27. 5th gen max
  28. 2002 Trans Swap
  29. Valve Cover Replacement Issues
  30. Test drove a 2003 6 Speed, have some questions
  31. I have a 2000 nissan maxima and i need help trying to figure out what sensor this is
  32. Manzo cheap but not shorties?
  33. 3 questions in 1 post
  34. Shaky Steering Wheel
  35. Hot air when the A/C is on
  36. 2001 ae max part out
  37. Where to get 6th gen valve covers?
  38. Need Help!!!
  39. 01 Max with 143k sputter on cold start
  40. fans running full speed after car warms up!
  41. Noise from hood
  42. Custom Lens Etching Services
  43. VIAS vacuum lines in 01 Maxima
  44. it's like Christmas, but with more headaches.
  45. 03 Maxima pre-cats failing
  46. Lateral Arm Bushings
  47. fuel injector repair
  48. fuel gauge needle recalibration
  49. Intake Camshaft Advance/Angle
  50. Top End Refresh
  51. HELP Please
  52. Rough(ish) idle when in gear
  53. Need help with electrical diagnosis
  54. Aftermarket Door Lock Actuator Retrofit.
  55. Hotshot Headers
  56. Heavy vibration
  57. 5.5 Gen 6 spd to 5 spd question
  58. Driver's Side Axle Stuck IN Tranny?!
  59. New Guy: Introduction, questions
  60. Oil Disappearing
  61. Help after replacing MAF sensor
  62. 2000 Compressor Clutch
  63. Another problem with Maxima... Rough Idle, Wheezing, clicking
  64. 2001 maxima 20th anniversary
  65. Nexus Tablet as Stereo Unit... Still a good mod?
  66. It's another whats that noise thread..
  67. 5.5 6MT shift knob replacement
  68. Half of Instrument Cluster Lights won't turn on
  69. New Member saying hello
  70. Need some noob help.
  71. where to buy dual o2 sim??
  72. 5.5 Gen Headers in 2016?
  73. Found BALL bearing inside of timing chain case?!?!?
  74. Trans swap
  75. Whats the best way to remove A.E. body kit
  76. another one bites the dust?
  77. 02 maxI'm a eats wheel bearings
  78. Engine ticking sound - what is it?
  79. 8th gen VQ swap?
  80. 2000 maxima gle 3.0 - electronic motor mounts?
  81. noisy transmission
  82. HID Headlight issue
  83. P0300 haunting me.
  84. Are there any good after market coil packs?
  85. buying o2 bung for OBX?
  86. 02 maxima brakes locking up
  87. Passenger mount bolt size
  88. Air blows only through vents
  89. Need help with bleeding clutch in 01
  90. How does this spark plug look?
  91. 2001 AE having RPM issues upon coming to a stop.
  92. Experience With A Particular Power Steering Hose
  93. Slight coolant level drop okay?
  94. 03 Maxima acceleration woes.
  95. 2000 Maxima headlight issue
  96. installing vafc and wideband
  97. Brake issue
  98. How to Make 2002 Sound Like G35 or 350Z?
  99. Jacking Point on 03 maxima
  100. Addco Rear Sway Bar Question
  101. Pulsing Vibration
  102. VQ swapped spec V in limp mode
  103. SE tail lights in a GLE?
  104. 2000 Maxima Curt Tow Hitch install and review.
  105. Bought BC coilovers
  106. P0174 - after EGR tube cleaning
  107. Auto trans ?
  108. 6th Gen Rims on 5th Gen
  109. I need clutch pedal assembly. Where to get one?
  110. Car wont start and feeling defeated
  111. Exhaust Help
  112. Strut Suggestions
  113. I'm buying parts for my 5.5 gen. Need advice and help!
  114. Is eBay pod filter worth it? On Nissan Maxima 2000
  115. Integral vs External EGR
  116. man trans engine mount part #s?
  117. TEIN Struts
  118. Alternator: best one to buy?
  119. rough idle, lack of power
  120. Idle issues
  121. 01 maxima ecm
  122. Upgrading my injectors
  123. Got me a new ride!!!
  124. Help with hub nut
  125. Is a dented oil pan an urgent issue?
  126. Overheating.... 2002 Max 6 speed
  127. Gauge needles
  128. Does anyone know how much an ECM cost?
  129. VQ35DE upgrade to aluminum valve covers?
  130. KT3 Paint
  131. Delete A Catalytic Converter
  132. How to gut pre cats.
  133. Automatic climate control
  134. Issues with 02 maxima
  135. 03 Maxima not staying started
  136. O/D Flashing 16 Times, Speedometer Not Working
  137. Running Issues 2003 GLE
  138. Welded Mounts
  139. Got bored, poly filled trans,pas mount
  140. Cranks but wont start
  141. 02 maxima gle ac problems
  142. 5.5 foglight swap with 5.0 foglights
  143. Alternator replacement
  144. Energy suspension suggestions?
  145. Sensors
  146. Map Sensor question
  147. Fuel trim differences between banks?
  148. New engine in rought start t
  149. My 2002 SE
  150. rear caliper braken differences?
  151. ABS, Battery, Brake Light wont go out
  152. Disinfecting A/C
  153. Mix and Match Clutch Disc/Pressure Plate Brands?
  154. Seized motor becuase of oil pump?
  155. Auto to Manual question!!!!!!!
  156. Need Help, Please! 3.5 engine
  157. 03 / 350z 6 disc swap?
  158. Sigh. . P0011, P0021
  159. Cali-spec header question.
  160. Slight Tranny Issue?
  161. Optimal GAB?
  162. Maxima 2002 Clutch Noise. Video inside!
  163. Pilot bearing help
  164. 01' Maxima gauges and shifter not working
  165. Hope to Own 2002 Maxima
  166. Picked up a 2001 SE,gonna clean it up............
  167. Anybody try these ?Engine Torque Damper Bushing
  168. Falls into Safe/Limp mode unless babied
  169. Spring Diameters & Recommendations
  170. Moog Rear Wheel Bearings
  171. Engine Weight? VQ35DE
  172. 02 Maxima AC Drain question
  173. Radiator Fan Relays
  174. P0128 + P0328 - Related ? Appeared same time
  175. 15a fuse to 7.5a fuse
  176. Burnt ECM. No start. Help please
  177. Overdrive issues
  178. STA509A mosfet
  179. P1448 and p0455 Help Please
  180. '02 Sunroof for sale.
  181. Transmission Dip stick Dry?????
  182. Putts out with gas smell
  183. 6 speed limp mode?
  184. IVT Torque / Horsepower
  185. My 02 SE clutch is about to go out.
  186. Brake Upgrade
  187. Need new motor
  188. P0505 Gremlin - Already fixed IACV and ECU
  189. O2 Sensor Suggestions
  190. Attemp to steal broken ignition
  191. Live Code Reader ?
  192. I sold my Max and got a Acura Tl, thinking of getting another Max?
  193. AC Drip tube 02 Max
  194. gas lid solenoid not getting power?
  195. Help 2002 Maxima gle
  196. spoiler
  197. 2001 Maxima no crank. Tried almost everything Need help
  198. Blew ECU?
  199. Wobbling under hard acceleration
  200. AUX Install
  201. Clutch adjustment
  202. Manual Transmission Fluid Recommendation
  203. Alternative Front Seat?
  204. Testing Catalytic Converters on the 3.5
  205. Cruise Control Issues
  206. Blacking out headlight housing
  207. Maxima A32 Coils????
  208. Doesn't hold idle at first
  209. What size is the breather hose? 2002
  210. Front Tilting Headrest?
  211. 2003 Maxima Recommended Tune Up List
  212. 03 Maxima engine dying
  213. Need 2000 Maxima Stock Wheel/Rims
  214. Console Molding
  215. Rod fasteners or screws
  216. Thumping when driving?
  217. Brake pads and slotted rotors?
  218. Normal A/T temps
  219. Just bought an '02 Infiniti I35, may need timing chain?
  220. Key Programming Issues
  221. Code p1448 evap vent control valve?
  222. Wire pulled loose, car won't start
  223. Hidden module preventing car to start
  224. EVAP p1800 error code
  225. Rubbery acceleration even with new mounts.
  226. A/C Bypass Belt hitting tensioner
  227. Help with ES Control Arm Bushing
  228. Need to check fuel pressure
  229. Possible Oil leak origin(s)?
  230. New
  231. Rear wheel well rust need suggestions
  232. 02 maxima muffler suggestions
  233. Did an oil change with Pennzoil Platinum High Mileage
  234. OBX headers A/T?!
  235. Gen 5 RWD Conversion Kit
  236. 2K2 Chugging - Fuel supply issues
  237. What's the name of this part?
  238. ECM location confusion
  239. Transmission stuck in 3rd.
  240. Hello Everyone IM Nick
  241. No tutorial, just my 2003 3.5 ltr rebuild
  242. Replacing engine mount on Infiniti i35 or Nissan Maxima
  243. Valve adjustment
  244. PNP relay only in M/T max?
  245. Both cooling fans stopped working
  246. Antifreeze in the brake lines?
  247. Is it possible to install a new flex pipe without welding it on?
  248. 5th gen question
  249. No spark, no fuel...no codes HELPPP
  250. Clearing Fault Codes
