- Name that noise
- PNP 5.5 > 5th Gen Headlight Harness (Still Available?)
- 02 Maxima GLE sometimes it won't start
- 2000 Maxima stalling mystery
- First mod on my 01 Max complete
- Another question regarding sound when accelerating
- Electrical Issues
- Aiming headlights with channel lock pliers
- What Triggered This!?
- Interested in 5.5 gen ECU reflash? I have good news coming soon...
- Window issue
- Replacing climate fan in Range Rover. Be glad we have Nissans.
- Do I need a new key???
- 2001 - Won't Start - No Power - Clicking Sound Under Dash
- Just some information about 10AMP meter fuse
- I broke the bolts while replacing EVAP canister (Max 03)
- Remove or replace main cat
- Heated seats/winter package question
- I'm back...sorta
- Its been a good ride. Replaced the Maxima
- Interested in a Maxima, need Advice before Purchase!
- Info on Changing Cats ?
- My Max and my GT-R
- Nwp throttle body for 5.5 gen is it worth it?
- idel air control code - need help
- Steering column rubbing on boot?
- Stiffer detent ball return springs?
- 2003 maxima hottttt
- Post 5th generation rusty rad supports?
- Mitsuboshi Belts?
- Turbo idea
- Bolt wont tighten.
- 2001 Steering Wheel Radio Controls
- 03 maxima muffler delete and put in 350z resonator??
- Intake cleaner
- Spoiler Alert ! And I'm new here
- Need Some Serious Help
- P0300 random misfire
- Possible tranny problem 01AT w/ P0740
- On the straight pipe life
- Gas pedal hack for ae pedal fitment
- quick dumb question, please help
- So Cal. - Advise with ES Inserts
- Next step after headers
- 5th gen Clutch Replacement kit, seals, and bearings.
- Radiator for 6 speed
- Will a 01 max halo projector fit on a 5.5 gen?
- Hodgepog of issues - P0300, Valve covers, coils, and boots
- 2003 shut down, cat conv engine light. help-stranded
- Ignition control module
- Popping/Clunking Noise
- What is thr name of this part!!
- Penzoil platinum high mielage 5w30 or penzoil ultra platinum?
- 2001 engine problems
- Help me with my 02 SE 6MT. Tried almost everything.
- Thoughts on this ebay cold aie intake?
- Bank 1 sensor 1 location on obx headers?
- Gauge cluster doesnt light up or work
- Overheating issue
- Radiator Fans Assembly Replacement
- What are differences btwn 02' and 03'?
- Radiator fan
- Help on upgrades (maxima 2000 3.0v6 auto)
- Wideband bung on obx headers
- 2002 maxima bose sub replacement
- Sound when idling and accelerating at low speeds
- Reflash Tuner on Amazon
- Looking at 5th generations - hot spots?
- Replacing master cylinder
- Tpms?
- Battery Hold Down
- 2000 Nissan Maxima GXE Speed Sensors
- 2000 Nissan Maxima GXE Odometer and Speedometer Not Working
- Spring weights for lowering & ride?
- Maxima Axles length
- ES Inserts in Aftermarket Engine Mounts?
- Intermittent rubbing sound from front (passenger side)
- Please help! Crank sensor!
- Huge loss of power
- sourcing a locking auto trans
- 2000 Infiniti I30: Muffler Help, Please
- Concerning Battery Charge/Alternator
- 02 vq35 desperately need exhaust help.
- 6th gen cold air intake in a 5.5 gen?
- Stalls when in gear (2002 SE automatic)
- People still sleep on the maxima.
- Obx r headers the installation
- Does Hirshberg drive a 2000 SE?
- unidentified bracket
- Silver Gauges into a 03 GLE
- Very loose shifter
- 5th gen maxima catback (FAST)
- Is this part the refrigerant pressure sensor?
- Has any one else installed H&R springs on 00-03???
- 2000 Nissan Maxima won't shift into overdrive
- After 319,000+ miles......
- No start after injector replacement
- 03 Max---->Is this Car Worth it ?
- Jerry Hirshberg
- Question about strut top hat
- Best cheap catback?
- 1998 pontiac grand prix gt vs 2000 max?
- 01 maxima d/s window switch wiring
- Infiniti I35 Beginner's Engine Replacement (not swap)
- 2003 6speed maxima-coilovers and caliper suggestions
- '02 - Front end shake on moderate to hard right turns.....
- Electrical Issue - Windows Up + BOSE = Shuts off Driving
- no fuel pump energy, security light on, no dome, no power to door locks no start
- Random Downshift
- Code po705 neutral safety switch?
- Error Code P0720 for 2000 Nissan Maxima
- TSB NTB02-051a (P0138)
- Gutting rear pre-cat, gaskets needed?
- 2001 Maxima - 2003 Maxima seats, How to install?
- Tuning Help !
- ebay vs dorman tailights?
- do I need a pre amp to power my factory Bose speakers in my 2001 maxima?
- Car died yesterday, now squeals on startup
- Cylinder Compression vs Mileage
- 5.5 to 6th Gen engine swap
- Is upgrading to a 6th gen Maxima worth the car note? would it be a good move?
- Timing Tensioner Noise
- NWP 5PC Spacers OR Warpspeed y-pipe?- 5.5gen Max
- Crankshaft Sensor location
- A/C Problem
- 2002 -- SES, SLIP and TC OFF -- wtf
- 02' MT best exhaust upgrades? Will be shopping soon
- brake question
- Noise From Engine
- Hi idle issue
- What mods would be needed for a 5th gen max to keep up with a 05 g35 sedan?
- Window question
- Motor mount quesion
- 2001 Maxima - The mystery of the foreign subwoofer
- Would a dead battery cell cause driveability issues??
- Type of seals used in power steering system?
- My 2000 Max is throwing a code for a bad maf sensor, but car runs great?
- Request for Help With Transmission Flush
- safc2 sensor voltage outputs
- car revs high under light acceleration then returns to normal
- 2001 Maxima - Are the car seats interchangeable with a 2002 Infiniti i35?
- Car will not stay on or turn on
- P0021 code??
- 2001 Maxima - Engine Mount replacement, front and right
- 2001 Maxima - Need to change axle
- Want to convert to 5spd
- Reading A/T temperature with scan tool
- auto vs manual 5.5 gen
- Rad support
- 2002 Rough spuddery acceleration when WOT...
- Headlight clip? Where to get?
- 2000 starter issues after transmission/clutch
- OBX-R headers 2002-2003 maxima
- overdrive problem
- 1 quart every 700 miles 120 pounds in cylinder 3.... I need advice on the next step
- Help. Rapid clicking coming from under dash.
- 2000 complete ignition/key tumbler replacement problems
- Truhart Coilovers??
- Bad Wheel Bearing False Alarm - Funny
- Anchor 9031 Passenger Side Engine Mount
- Should codes clear themselves after repair?
- 01' Shifter knob removal?
- Clunk when turning steering wheel all the way
- IACV gaskets available?
- Intro and possible 5.7 engine swap
- Vq35 oil cooler line rubber or metal replacement?
- Torque steer
- Stock 5th gen 0-60/ 1/4 mile
- Oh god another coolant leak?! read thread?
- High Idle and Misfires
- Long rough start?
- 5th Gen Valve Cover question?
- Newb with a motor dilemma
- G35 Sedan Muffler + g35 coupe resonator = WIN!
- How to know what mods i have?!
- evaporator temp sensor
- Has anyone ever done nitrous or ECU tuning
- evapororator temp sensor location
- 5.5 Gen Transmission Return Line
- 5.5. gen automatic transmission pan bolt pattern
- Interior, License Plate and Trunk LEDS
- Climate Control Assembly Lights: ON / OFF
- Can not get to bolt to change thermostat
- Start Problems
- OEM header gaskets @ $45 USD a pop?
- What is the new MAF to buy
- Strut Tower Installation Problem
- 75mm throttle body?
- 2000 3.0 p0304 loss of power under hard acceleration
- Help With Possible Rack and Pinion Leak
- P0011 code and bad accelaration
- rod knock or lifter
- ECM woes, IACV
- Volume control problem on Bose sound system
- Lowered for $584.99
- High idle after car is warmed up
- P0430 in California
- Oil Leak Advice
- Brand new CV, shaking when accelerating
- I've encountered so many VQ35s with this noise
- White Smoke & SES Light after spark plug change
- rusted lower tie bar creates costly repairs
- A/C cooling problems (detailed) need help!
- 10 things I hate about my 5th gen
- Intake camshaft gear cracking at pin
- Front Brake Slider Pin
- Minor freakout over reconnected engine mounts....
- Clunk from Passenger side area
- New maxima owner
- compress rear springs *help*
- Whats the highest known mileage of the VQ30? How many miles yours got?
- Gunpowder smell
- HELP! Why did the engine blow? Best replacement?
- LED Sidemarkers?
- Feel like i just got schooled
- IACV issue again
- Oil smells like fuel
- Does this engine mount look bad?
- Upper Oil Pan Confusion
- Cadillac ATS Brembo Brake Kit
- Timing tensioner noise?
- 2001 Ae with 198k
- Will Greddy sp2 catback fit
- A/c problem
- idler pulley keeps squeking and rattling even after i tighten bolt? help!!
- CV boot repair kit
- spark plug change
- Cranks but won't start
- ABS problem?
- 5th Generation passenger Drive Shaft replacement
- 03 max, rebuilt engine now no spark on 246
- Are 2000, 2001, 2002, and 2003 Shocks all interchangeable?
- Possible gains to be had, just need clearances from IM to Hood
- DAMN IT. R.I.P another one :(
- how do adjust the idle 02 max
- New regulator cannot close the window.
- 2000 Inifiniti I30: Strange headlight problem?
- Sporty steering wheel for 5th gen Maxima?
- OBX Headers related
- Rear speaker and subwoofer cutting out
- 00 kit on 02?
- 2003 Maxima Starter issue
- 02 maxima not shifting correctly
- Driver Window Switch Problem
- 02 won't crank, tons of troublsheooting .. no luck
- Metra axxess steering wheel adapter install
- ProZ Flexomats All weather floor mats
- VQ35 running rich, what are the signs?
- VQ35DE & Lucas
- What's the warranty on parts?
