PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. wowwwwwwww
  2. Motor Mounts Bad?
  3. Driving after restoring headlights
  4. Blower Motor Won't Turn Off
  5. Passenger side wheel bearing..whos done it?
  6. ecu harness/acess removal ?
  7. Sigh, Velocity Stack Round 2
  8. Exhaust help needed
  9. car has a little vibration when idling
  10. 99 Injen CAI on an 02 SE?
  11. Velocity Stack, Filter Required?
  12. Maxima HID Retrofit Build
  13. Heater acting funny: A little Pre-Diagnosis Discussion
  14. Transmission Diagnosis/Advice
  15. 3.5 intake installed and battery relocated - Idle problem
  16. Lower oil pan replacement, follow instructions on RTV Grey package?
  17. heated steering wheel wiring (plug)
  18. Stealing input and amp turn on from bose sub connector ??
  19. Pre-cat rattle, clip inside, opinions?
  20. v35 steering wheel?
  21. How much is a front lip for a SE 20th anniversary?
  22. Test Pipe Q's
  23. Fuel Running Rich????
  24. KYB Price check...
  25. Please help! Bucking while driving!
  26. Found My Next Car
  27. Opinions on eBay halogen hid bulbs
  28. Will 4th gen struts fit on a 5th gen?
  29. Auto Shifter Light
  30. Rust next to rear license plate lamp
  31. Nwp spacers + oem gaskets?
  32. Transmission Install Advice
  33. vibrating clutch fork?
  34. Alignment necessary after strut mount replacement
  35. new car!
  36. Power window, slow roll up ....
  37. 2002 maxima exhaust
  38. Need some advice car pulling right?
  39. Sway Bar Comparison
  40. SES #3 misfire and now a bad knock
  41. BOTH FRONT LOWER CONTROL ARMS
  42. voltage issue
  43. weird noise in reverse?
  44. Look at what I just got!
  45. Cattman Performance - Major Changes!
  46. How often do you pop your hood?
  47. o2 sel issue on 2002 5.5
  48. car hesitates
  49. 2.5" or 3", Please step in
  50. Tein H Techs or Megan Racing Springs?
  51. RPM guage out and starting issues....
  52. Mileage Computer Light Fix
  53. interior lights dim
  54. Harbor Freight Fuel Pressure Tester
  55. Engine replacement or odometer rollback??
  56. low fuel light bulb size and part number?
  57. 2000 SE 5 Speed Flywheel
  58. Sporatic clutch problem
  59. TC tensioner or pre cats?
  60. 2002 MAXIMA INSTALLED A TRANSMISSION COOLER
  61. what is the size of the wedge base of the cluster bulbs?
  62. Problem with MOOG sway bar endlinks
  63. Help "Nissan Immobilizer System of NAS?
  64. Obx Headers Out of Production?
  65. not again...damn you pothole
  66. Suspension Part ID?
  67. help me with these codes please!!!
  68. Snapped Power Steering Pressure Sensor
  69. Motor Compatability
  70. POWER DRIVER SEAT MOVES WHEN IT WANTS TO
  71. WTF is causing this vibration??!!
  72. Anyone with an active Carfax (or similar) account?
  73. sun roof not working:(
  74. Anybody know Mike Crombie in Canada?
  75. 2k proper TPS adjustment?
  76. Alaska Road Trip
  77. Planning to replace my clutch tomorrow...
  78. couple of quick questions...
  79. P0304 code. Does my spark plug look alright?
  80. Trouble removing idler pulley
  81. Umnitza angel eye question
  82. BC or D2 coilovers??Which one??
  83. Custom so called ice box short-ram INTAKE
  84. **BLACKKILA.GTR MAXIMA**
  85. Gab mod, and wont idle?
  86. 4 codes and a slight engine knock only at idle.
  87. HELP Car is Making an ODD noise!!!
  88. bigger maf question
  89. New brakes. Squeal/grind noise
  90. Cluster Issues
  91. Photos: C-mod Nissan Maxima 02-03 Mesh Grill
  92. Changing catalytic converter with CA Spec Cattman Y Pipe
  93. all weather floor mats
  94. Installed OBX Headers now I got a problem need help
  95. Fog Light Rewire Problems "HELP"
  96. Ebay find stillen kit
  97. New Alternator, Blinking Battery Light on Dash
  98. Dead Radiator
  99. stock hids
  100. ***Serious Problem *******
  101. rad n tranny problems
  102. Inner Tie Rods
  103. WTF!!!! Weak as* fork broke!!!! (pic inside)
  104. R and R'ing my motor
  105. LED light strips on my maxima (pics inside)
  106. Rear Brake Caliper rattle
  107. 5.5 front brake pads from Nissan, still depositing?
  108. What do you expect to have if you've got bad TB on a 5.5 gen ?
  109. Can anyone with a VIAS block plate explain to me the benefits?
  110. need to replace this bulb...
  111. Need Motor mounts???
  112. Radiator Leak
  113. TRAILER HITCH INSTALLED ON 2002 MAXIMA
  114. kinda simple safc 2 tuning ?
  115. Fed cat in a CA spec car?
  116. 5.5 gen throttle body cleaning
  117. only one speaker working...Non bose, 03 se.
  118. Clutch squeal/squeak
  119. Which CPS?
  120. Which O2 sensor to buy for Bank 1 Sensor 1 replacement?
  121. Hmm thinking about cutting the cats this week..
  122. Cattman 3 in
  123. 6th gen plastics in a 5.5
  124. want to replace the motor mounts...03 SE AT..
  125. Screwed up with one of the front cross member bolts... what to do?
  126. gauge cluster not workin!!! lil hesitation..
  127. Stock exhaust
  128. Repoed
  129. p0456 after BOP Install. Coincidence?
  130. Anyone broke their glove box...?
  131. Maxima Retrofit!!
  132. 03 Maxima Cabin Filter
  133. Service engine light
  134. muffler
  135. Exhaust problems
  136. needing some insight
  137. Wet in all the wrong places...
  138. Let's be analytical - horsepower loss and long intake...
  139. 4th gen in a 5th gen
  140. clear coat repair
  141. strange problem
  142. SSIM How To?
  143. Cant align motor mounts!
  144. If you've changed your cats or gutted them, step in
  145. Which Coilovers would you Buy?
  146. Bank 2 Sensor 2 Oxygen Sensor confusion...
  147. Berk Intake install problem
  148. Coil pack problems again????? Need advice
  149. SCRATCH REPAIR
  150. How do you launch your car?
  151. Start up engine tick tick noise
  152. Start up engine tick tick noise
  153. Procedure for removing rear caliper brake lines
  154. Clear cover insert for turn signal ?
  155. clutch pedal sinking
  156. INSTALLED NEW FOGLIGHTS & FOGLIGHT FILM & WINDOW TINT
  157. AC Tranny issue
  158. Having trouble with folding LED mirrors
  159. A blower motor upgrade?
  160. Bose Subwoofer wire codes
  161. Battery issue
  162. stumped by an electrical issue, please help??
  163. Throttle Position Sensor
  164. speed sensor?
  165. Custom intake
  166. Damn flood...need help
  167. obx header installed
  168. LED conversion complete..but light still comes on...why ?
  169. Header owners please chime in
  170. Just installed some new tweeters
  171. Need help locating EGR componets on a 01
  172. VIAS Solenoid Help
  173. Clutch condition with pics
  174. Smaller battery.
  175. Check Engine Light Replacement
  176. 03 power windows switches needed
  177. tach needle lag
  178. 6 speed transmission makes a clunking noise when letting off the gas
  179. qiuck question about motor mount
  180. Injen COLD air intake - modification
  181. cosmetic damage to wood trim shifter handle.
  182. Haltech Platinum Pro 350z PnP on 5.5Gen
  183. Vibration noise when holding on da brakes in Drive
  184. Noise at thottle body
  185. Northern owners chime in please!
  186. HELP!! Cracked Wheel/Rim
  187. Cruise won't set
  188. SES codes?
  189. About to order O2 bungs. What type?
  190. Low idle cold start
  191. Broken Battery ground on block
  192. That vibrating license plate...
  193. headlights
  194. The inconsiderates got me
  195. 7th Gen Engine Cover In a 5.5?
  196. 6spd swappers please step in.
  197. Autotrust Struts?
  198. Vacuum Line
  199. Scratched _ Rotors _
  200. Airbag compatibility, what will work for an 01?
  201. VQ35DE still amazes me!
  202. gap between the headlight and the bumper
  203. Need help: revving on own while stopped
  204. Feels lumpy at low RPMs
  205. Odd idle issue... 2003 VQ35
  206. Warpspeed Y & cat ('00 CA Spec); mating to Megan 2.5 dual-outlet catback
  207. Where to fabricate an input device on a 5th gen (pics inside)
  208. Help! Broken Spark Plug :(
  209. flywheel torque specs
  210. Rear brake noise
  211. My Maxident
  212. 036mtmax's progress thread
  213. Changing Belts...Change Idler Pulley As Well?
  214. maxima hit
  215. Best replacement HID bulb/temp for car ?
  216. Bringing my AE back
  217. Main cat good or bad?
  218. Help ... Help ... parking brake cable
  219. Labor quote (hours) for '00 Y-pipe replacement and AC fan resistor replacement?
  220. Rear Brake Caliper
  221. So suddeenly the car began to fart really loud...
  222. Berk doesn't make parts for Maxima anymore?
  223. How to Paintless Dent Removal Technique
  224. energy suspension control arm bushing
  225. evap purge valve code...replaced valve code still pops up?
  226. I put a cheap plastic AutoZone scoop on my 2001 Maxima!
  227. No spark, won't start. Why?
  228. B-Pipe install gasket
  229. 5.5gen 6 speed...I didn't like redline 75w85 gear oil , back to Amsoil or what ?
  230. Spoiler light
  231. Header question
  232. Wanna See How Dirty a "Lifetime" Fuel Filter Gets?
  233. My Maxima = PMS machine
  234. No signal at ignition coil
  235. Thumping on startup
  236. What The Squeak!
  237. at home paint job
  238. Leather Seat Swap (Heated)
  239. Hesitation/Jerking at slow speed
  240. How much does the upper intake manifold weigh?
  241. Greddy EVO 2 cat back on 5.5 gen?
  242. Fog light fuse keeps blowing! HELP!!!
  243. condensation in light
  244. What brand of HID Foglights?
  245. Floor Pan Sheet Metal Gauge
  246. part replacement
  247. Some smoke in back of engine bay
  248. Motor Mounts
  249. Me Again, now I have a crunchy sound, LOL
  250. I'm tired of the CEL, now I'll take it to a Nissan dealer
