PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. 6 speed issues
  2. Where is this oil coming from?
  3. 2002 VQ35 Knock @ 2k rpm
  4. Replacing front strut mounts/bearings
  5. Idle not as smooth when car warms up BUT drives good
  6. I35/Maxima transmission problem
  7. gauges stopped working
  8. Rust repair
  9. airbag light - spiral cable?
  10. 7th gen owner in need of some help from a fellow 5th gen owner
  11. Tein ss coilovers suck!! Do not buy them
  12. 1 alarm question and 1 window question
  13. Exterior Modifications
  14. Chunks of metal inside UIM
  15. Question about exhaust
  16. Progress Anti Roll vs Rear Anti Sway Bars
  17. Placed a order for my Cattman header / y-pipe combo excited.
  18. oil pressure switch
  19. Progress RSB Order Group
  20. Ignition coil connector rewiring
  21. Electric Motor Mounts = Useless?
  22. Got in a little accident, best way to fix this?
  23. Is this worth it for a first car?
  24. 5.5.gen precat
  25. New engine...so lucky
  26. priming oil pump
  27. Muffler hitting rear beam??WTF
  28. Adding sensors to factory alarm
  29. control center not working
  30. How the f do you unplug the damn tps?!?!
  31. Cleaned TB got P0505 and P0505 Solved! This may help you...
  32. IACV to ECM Connector Diagnostic help?
  33. Throttle Body Removal by a newbie, amidoinitrite?
  34. IVT torq specs?
  35. valet key question
  36. Front headlight clearance light (small round one) not working
  37. car stalling?
  38. CEL flashing and engine Putting....twice now
  39. 5th gen having issues with it running! Help Plz!!!
  40. stuck in closed loop after headers install?
  41. Electronics Experts Needed! 1 for 2 Oxygen Sensors...Is It Possible?
  42. 2000 xle problems
  43. Transmission roaring
  44. push start a manual 5.5 gen 03
  45. My MAF Sensor keeps Frying?
  46. A/T Check message
  47. 2000 maxima solid security light, cant communicate with ecuecu
  48. Driver side power window stuck half way up
  49. Is my waterpump about to go?
  50. New warpspeed Y pipe, Questions.
  51. Idle stall problem?
  52. P1320 and cold-start issues, cheap place to buy Coils?
  53. exhaust ground
  54. 02 6 speed gear oil ?
  55. Transmission Jerking
  56. question about precat/manifold gaskets 02-03
  57. P0300, P0302, Ultra rich, stumble, step on in
  58. tie rod replacement question?
  59. Repair or replace rusted/broken rear side marker bracket?
  60. 5.5 removal thread
  61. Intermittent engine stutter
  62. O2 sensor removal
  63. Bad ecu question
  64. The common rear Seized Passenger Side Caliper
  65. Is it wheel bearing going bad?
  66. Steering wheel shake after new struts and alignment...
  67. Tire size
  68. Stuck O2 Sensor
  69. What size tire should I get on OEM rims?
  70. Multiple cylinder misfire P0300
  71. Looking for any info I missed on the A/T gear slip issue.
  72. Taking the dash out.
  73. Blehmco?
  74. Spare tire cover alternative
  75. Instrument Panel Needles
  76. Red top optima battery???
  77. Dealership Broke Something, Not Happy
  78. Where Can I get a coil pack?
  79. Drivetrain Project
  80. Eninge Ticking or tapping at idle Video included
  81. Clunk in front
  82. Plug that goes into oil pan
  83. Hub assembly???
  84. Rear Ride Height After OEM Replacement Shocks
  85. Exhaust Question???
  86. so i really like my 4th gen, no for...?
  87. Headers and Y... all a pain in my arse?
  88. SAFC/TUNE or COILOVERS.........
  89. Constantly blowing Power Window/Door Lock 40amp fuse - Need some advice
  90. Safc2 problems?
  91. Window tilts forward in down position
  92. Looks like I'm replacing a bunch of wheel studs!!!
  93. VIAS speed control actuator question
  94. upper pan install question
  95. 2002 Exhaust Question
  96. metra double din kit, thumbs up
  97. Fixed my Clutch!!
  98. Huge winter storm and now my transmission has problems
  99. 00 se 5 speed tranny problems..
  100. Potential engine failure?
  101. Most Trusted Place For Used 2001 Maxima ECMs?
  102. Weird squeeky noise
  103. Can I use closed acorn wheel nuts on 2k oem alloys (6spoke with hubcaps)
  104. why such bad mpg???
  105. HELP! Diagnosing stalling issue with 02 Manual
  106. Navigation Disc NEW YORK
  107. Pulls to the left, some clanking ... D2 coilovers
  108. 2000 Maxima Carbon Fiber hood
  109. 5.5 Gen Headlight Lens
  110. scosche kit horrible
  111. Extra plugs found behind Bose stereo?
  112. Anyone have experience fixing a 740 code Tourque Converter Clutch Curcit Malfunction
  113. Voltage Stabilizer
  114. Code Reader.....
  115. GI: 1/0 Gauge CCA 5th Gen Big Three Kit
  116. P0420 Code No More !
  117. P0300 help
  118. Connecting amps high level input to Maxima 2001
  119. 2001 Nissan Maxima withh line out converter
  120. Starting out mods
  121. p0420
  122. Maxima Hard Start Issues
  123. O2 sensor
  124. Removing headlight wiring harness on 5.5 headlight?
  125. ABS Light
  126. TIps/suggestions/how to gutting precats
  127. 2003 maxima
  128. Headlight Lens Replacement
  129. Buzz sound when idle settles?? HELP!!!
  130. 02 side rocker pnl removal
  131. 5th Gen RSTB???
  132. weird TPS issue
  133. 2000 Maxima Factory Mud Guards
  134. Need Advice Door Pillar
  135. Rear Crankshaft position sensor 2000 maxima
  136. Cv joint and clutch!!!
  137. knight_yyz pass and tranny mount install
  138. 2000 VQ30DEK advanced timing question
  139. Worthless Aftermarket Drive Shafts - What Gives?
  140. 2000 maxima transmission drain plug
  141. Ticking
  142. Torque app and ELM327 BT
  143. Engine Noise
  144. Harness cover
  145. 2 Questions
  146. Last Ride
  147. My 3 year old broke my car door-Please Help!!!!
  148. reverse issue
  149. Car Won't Start
  150. New Gen5 owner - wow- i had no idea!
  151. Optima Yellowtop Model for 03 SE?
  152. Trunk rods/springs rattling
  153. Installed a Warpspeed Y-pipe, not impressed with quality
  154. 1-3 gears on an automatic
  155. 5th gen intake from ebay??? from seller chromeintakes
  156. Motor Mounts and Flex Pipe
  157. Speaker problem - Stereo question
  158. High Flow Cats & Emissions
  159. stereo questions
  160. Hey New to the Site, just got my first maxima, need help badly!!!
  161. need help getting parts !!
  162. Giving my Max a 2nd life @ 166k
  163. Could Anyone Help a Novice With How to change IAC Valve?
  164. Valve cover CEL
  165. bolt/stud sizes for precats to exhaust manifolds
  166. Coolant on transmission?
  167. Negative battery cable for i30 same for Maxima?
  168. Stock Amp Specs?
  169. Bad motor mount possibly?
  170. Loose exhaust on my 03 max
  171. Coolant leak
  172. was my anniversary front bumper replaced?
  173. Where'd the M-10's go???
  174. Musty Smell in 2001 Max
  175. p0720 p1574 VSS transmission speed sensor issues, need help
  176. KBB Messed up?
  177. Clutch, Exhaust, Intake upgrades...thoughts and musings after the job (long read)
  178. So THAT'S where my oil is going!
  179. New fog lights, battery gets weak. Questions
  180. Lights & Exhaust questions.
  181. Hesitation After Cold Start (video Included)
  182. power steering pump whine?
  183. Car stalling ... No I didn't search.
  184. my 2001 nissan maxima wont stay charged
  185. 2000 Passenger Power Seat Control Switch
  186. map sensor help
  187. Looking for a wierd part
  188. Misfiring
  189. CV Shaft Question
  190. 2000 I-30 front grille emblem
  191. Automotive Touchup's Rubing Compound
  192. Aftermarket alarm
  193. P0420
  194. Please help! 03 maxima throttle response issue
  195. 2002 Nissan Maxima Engine knocking/rattle noise at Idle
  196. Heater amplifier
  197. Exhaust/piping modification advice.
  198. 2001 bose problems
  199. Tune with 3-3.5 inch intake?
  200. Automatic headlights not working
  201. Looking to buy an 03 Maxima
  202. 2003 Nissan Maxima SE Bose No sound
  203. oxygen sensor question (gutting cats)
  204. Best Speedy ECM Repair?
  205. Weak car start?
  206. transmission connector ?
  207. Weird crank but no start
  208. How much Hp does this give you
  209. Temp gauge not working!?
  210. 2001 Maxima will not start
  211. 5.5 gen Passenger side HID not working
  212. Complete Exhaust Breakdown + Advice?
  213. Coming up on 5 years owning my Max!
  214. Clunking/ thumping noise, front passengers
  215. pathfinder throttle bodie/ any success
  216. Rocker Cover Installation
  217. increasing tire size causing brake faulire??
  218. Transmission Rebuild... HELP!!!
  219. Strange engine vibration 2003 maxima
  220. 2000 nissan maxima choking out warm...?
  221. z32 front rotor replacement
  222. My MAX.
  223. What would be the steps for repairing a jerky transmission?
  224. Annoying noise finally found and fixed
  225. Vibration Noise
  226. Changed struts, HUGE difference
  227. Dreaded obx v2 headers install on 3.0
  228. Auto Musings......
  229. To any one who has had their interior LED modded by Shinjiduo
  230. Competition Clutch Flywheel?
  231. Exedy Stage 1 + Fidanza flywheel + STS
  232. Fog Lights get brighter with throttle
  233. 2001 Nissan Maxima w/65k miles, cranks but won't start
  234. quick question on doing compression test
  235. 08 Altima vq35 into 2003 maxima
  236. Fog Lights
  237. 2009 G37 Rear View Camer Install Questions
  238. 5th Gen Wheels Wheels Wheels!
  239. where to find grey caliper paint?
  240. 5spd transmission help!!!
  241. Steering wheel replacement?
  242. oil light
  243. Radiator support question
  244. 2002 I35 Engine Knock
  245. Very weird problem
  246. Belt squeal? How to fix, no I didn't search
  247. Quick question re: eBay parts
  248. Short sound video (G35-ish) for a De-k
  249. looking to buy coilovers
  250. Looking to purchase another Maxima..
