- The First 3.0l 5.5???
- VQ30dek cams
- should i go with ksport 2in springs?
- Car turns off 2 minutes after a jump start... what could this be?
- Call me crazy, but....
- Vq35 Injector removal
- Center console vibrating
- headlight restoration kit
- Rattlesnake sound after lift off
- Annoying rattle
- Fog lights on with parking lights??
- 5th Gen Craigslist funnies...
- who chips/tunes ecu's for 5th gens?
- oil in cps normal?
- No brake pressure after 6th Gen. BBK!
- P1320, P0304
- Loud Screeching and Whining - Rear Defrost, Heat and A/C
- does anyone recognize their car?
- vq30dek performance intake manifold
- Climate Control Lights
- The infamous steering whine...
- 2K suspension upgrade/replace
- PO420 and PO430....(Yes, this thread again)(HELP)
- cruise control button snapped off ... ideas for fixes?
- Leaking Headlight Assembly: Replacement
- Torque link
- wtf? help? lol
- Anybody got typical MAF readings
- Inconsistent Starting Issues with a 5.5 gen
- Need Help, 01 Max Coil Wiring Picture
- WHATS GOING ON!
- Engine stumbles every 10 seconds during cold weather warm up, ideas?
- Never ending problems ...
- Another A/T question
- Maxima Line no more in the future
- Throttle Problem: ABS and Batt lights flash
- CV Joint discontinued??
- New 20th anniversary (AE) lip kit, need advice
- Do both cooling fans normally cycle when car is on and auto is selected on heater?
- Best place to buy strut bearings?
- Where Should I Get My Brembos/Hawks from?
- Airbag light flashing
- h.i.d.s
- Firm shifts after car is warmed up
- Humming when stopping at high speeds ... normal?
- Rear Strut Bar
- P0300, stumble at idle, but runs well otherwise
- O2 Sensor Voltage Readings?
- Help..prob with suspension noise
- nwp block off plate
- Headlight surgery
- VIAS Vacuum Tank Delete Question
- Nissan Ester Oil for VQ35DE
- THE 02 03 Max running 350Z ECU with UpRev Osiris thread CHECK IT OUT
- Water in Fogs
- Ebay Projectors with G37 Bixenon Retrofit Build
- Anyone running 370z sport 19's?
- Losing power while driving
- 4 cylinder Maxima (sort of)...
- P0021 code turns into noisy timing chain
- OBX Exhaust system a good buy?
- My newest protoype
- spark issue
- A question regarding 20th AE Gauges?
- Need a Motor
- This is not my year, RIP 2002 6MT
- P0430 Code(s) - Confused about options
- 3.5vq thermal spacer design leak
- Removing 5th gen driver dash vent ?
- Bose CD Changer, Who has one?
- Car went into LIMP mode right off the exit !
- Help No fluid in Clutch reservoir !
- Cattman y-pipe and gutted Pre-cats, guys who have pls step in
- need advice water leaking on the right passenger side
- Cattman Header Noise
- Anyone have a ECU go bad (VQ35)?
- Spark plug change/ oil in cylinder
- Front end vibrations AFTER doing recommended maintainence @ firestone
- so my starter died... camping story
- Whats the best route to go from gauge pod to engine compartment ?
- BOP 2000
- Tein SS height adjustment
- Wheel bearing/hub replacement
- o2 Simulator Install Needed
- Low end torque/HP loss with lightweight Fidanza (non-OE)flywheel?
- 5.5 gen DIY Home Depot Oil Catch Can
- How much are mods worth when you sell?
- 240sx 3" test pipe vs. Megan Test pipe
- 2000 I30 Code P0403 and limp mode
- intake
- Would you buy a NWP Dead Pedal?
- 2003 maxima starting issue
- AC bearing
- 01 SE 5 speed backfiring at low rpm decel...maf ?
- Oxygen sensor help
- tps from a xterra
- Fixing Headlight-Bumper Gap
- 3M fuel system tune up
- EXHAUST SYSTEM
- question about oil pan
- Intermittent Brake light(console)
- How many repairs have you done
- Search function broken?
- se-r swap
- HELP!! In th middle of strut swap....
- Radio Buttons Do Not Respond
- Remove Nissan Badge from Wheels?
- New use for seafoam!
- 3" Cattman catback backorder thread
- how to fix the leather worn and torn on the steering wheel?
- Not your normal "clunk" ...or is it??
- Headers?
- could this be my problem
- 5th Gen Taxi: Local East TN Find
- Front Driver door hinges
- Replacing the battery for winter... any suggestions?
- Flywheel Help
- rear brake baffle plate
- Clogged pre cats and evap code
- o2 sensor question (sorry)
- Rattling coming from underneath car. Help needed/appreciated
- Slight knocking noise when I put car into gear...HELP!!!
- DIY Valve Cover painting project
- Fender bender. Engine cut off help
- 2003 Auto CEL Light Codes
- Getting my timing advanced
- 89 octane on fill up just to see what would happen
- 5th Gen Maxima/2004 Mustang comparison
- TheIntrepidMontti's Summer changes
- Blew My Tranny...
- knocking noise from low gas?(hope)
- my new toy!!
- Knock sensors fail much?
- P420, P430, and P1320
- some goodies came in today
- Need some Grille opinions
- WELL.... I SOLD HER....(welp)
- LED for Map light not working??
- differance between 95-99 and 00-01 coilpacks ?
- Exhaust Leak @ The Flange
- 3.5 6 speed swap with vortech in 01 ???
- Gutting cat bug...
- Maxima Appreciation Week
- Clutch engagement point changing when Idle
- Click when on and off the gas
- Got some new shoes again =)
- A/E Mod & restoration...
- Wheel Skins - Options and Questions
- 6 sec start problem, even dealer can't fix!
- Timing Chain woes! Need HELP.
- My 02 Max takes 6 secs to start, I changed the Cam, Shaft, Coolant sensor, etc.!
- HELP UD Pulley Question
- VC Gasket replace
- Putting Retrofitted 5th gen Headlights in a 5.5 gen - lighting specialists step in
- rear reflector clip needed
- Torque spec for rear caliper banjo bolt
- Car keeps dying... HEEEELP :(
- Black Roof! Pics Included
- Odd white smoke coming from engine bay, need some diagnostic help
- 10 year mark, 60k miles.. Spark plugs?
- Metal Clanking Sound When Turning?? WTF Could This Be??
- Relay Box
- Camber kit question
- Shift Knob Removal
- 5th gen 5speed Issues
- rebuilding rear calipers
- Has anyone heard of this???
- clutch hard to engauge?
- removing steering wheel
- Flywheel Torque Specs
- O2 Sensor connection location
- Throttle body Swap on 5.5 Gen
- Axle or Hub or PS?
- When i drive i had a rattling noise? any help?
- Massive oil leak?
- Some Lowering Spring Questions
- Trying to track down source of rattle in engine, pinging? rod bearings? timing chain?
- Need pics of grills on a black 5 gen
- Anyone have any pics of CustomMaxima's old bright red 5th gen
- Another Pre-cat gut thread
- Gut Rear Pre-Cat Suggestions
- Vapor Canister and Purge valve: Aftermarket or OEM
- Replacing exhaust manifold gaskets
- Anyone have continued issues with CAM sensors ?
- larger MAF with a 3.0 possible ?
- Cattman Full Exhaust JET HOT Ceramic Polish Coating!!!
- Alternator replaced: Now intermittent low idle problems?
- WHere to find a used 2k 5-speed tranny?
- 02 Auto erratic shifting only when warmed up
- 50$ tint all around
- GSP Axles...?
- School me on the Auto Seat function!
- P0455, where to look for leaks
- still have knocking noise
- Weird Noise When Turning Right And Accelerating
- 02 - Fresh Motor...Codes!
- Could this be anything besides the alternator? If not how bad is it cost wise?
- heated steering wheel not working
- 2002 6mt shift knob problems with reverse !
- 2002 6mt problems help max guys asap!
- My diesel
- 00 w/Black roof overlay
- vibration issue
- Header help
- 5th Gen Grill
- windshield wipers
- Possible steering rack issue?..Step on in.
- High idle after throttle body cleaning..
- Problem after replacing headlight socket w/Video
- Got my Cattman y-pipe installed today - I like!
- GAB mod round 2
- Magnaflow-Resonator= :Q..
- Changing my back speakers i want more (voice)
- Where I'm at since I left a year ago.
- my tensioner pulley came off while driving.
- Engine heat shield ... remove or not to remove ?
- 350z Clutch Upgrade Question
- Need help...Ignition switch or Starter or Key???
- Need mod opinions, exhaust, spacers?
- VQ35DE lower oil pan bolt
- CV Axle pulled apart at inner boot - Driver side - What are the results?
- Will 5th Gen Auto Motor Mounts in 5.5 Gen Manual work?
- Two lights flashing on dash..Help
- is there a fuse for sidemarkers?
- timing chain or ...?
- How to install wink mirror and keep your sun visors and sun glass holder useble :- )
- Car bogs when shifting from 1 to 2 (03 se AT)
- New cat-back by OBX, any thoughts?
- Changing my shocks soon..which would be the best?
- REPLACING MY HID FOG LIGHTS BULBS NEED HELP
- 350z Injector Swap - Fuel Rail?
- Anyone ever use an engine flush
- 01 ecu
- Help ASAP Max wont start
- Anyone have XM radio install tips
- o2 sim
- What brand are OEM coil packs?
- ECU Swap
- Advice on a drone-free exhaust setup.
- Need Yoda of A/C
- 2000 SE Steering Wheel & Headlights, where to find
- Engine Service Soon light came on today
- Used Flash To Pass and my dashboard shut off this morning
- Complete loss of power
- Opinions needed on AT fluid drain/ refill
- Which back-up camera fits perfectly in the trunk keyhole?
- Consult 2?
- A thread just to show my appreciation for my max
- How important is it to balance flywheel and pressure plate
- wowwwwwwww
