- 2002 Maxima Retrofitting
- I just have a quick question about a window motor on my maima
- Pics of the new drop
- Stock Intake Hose - '01 Maxima?
- 02-03 bose harness picture
- Rattling Driving me Crazyyyyyyyyyyyyyyyyy
- HVAC Replacement White LED - Part #'s - Pictures
- VQ35 OE Y-Pipe Removal PITA Factor
- Bank 2 Sensor 2 Part number for Bosch
- Crank/No Start - 2001 Maxima
- LED tail signal install - fail so far.
- Wireless OBD2 and Torque app for Android?
- Need some tire size input
- Electrical Issues
- Hawk HPS pads - Put them on your car
- looking into new wheels
- Need a picture or diagram for stock wiring harness
- HELP! Ready to rebuild, but....
- P0301 an P1320. Know its a coil,need advice. Pro's and vetsstep in
- 02-03 tail lights.... ;)
- New rear KYB GR-2 struts, now clunking...HELP!!
- Help with code P0430 Catalytic Efficiency Below Threshold Bank 2
- Bye Bye MAF Sensor?
- 5.5 majestic blue color code??
- Yellow speed coilovers
- Installed my Megan M-DT muffler
- Rattle on the down rev...
- Question about an AE front bumper
- Car wont run in gear
- My speedometer has a mind of its own...wtf is going on?
- 2000 Maxima: Idle Problem Persists after $$$$
- Shifter Button Stuck
- STUPID FAN!!!!!
- 3.0 Motor in a 2002 Possible?
- Need Help w/ Cali-Spec Exhaust Please
- Car making loud cracking/gear stripping noise when turning right...
- Rough Idle
- VIP Front Tables...A33, Possibly Others.
- VQ35 NWP Spacers Temperature?
- Help!! Bosal rr mufl asm install
- Clicking noise driving me crazy
- ? about spray tint, old ? with a new twist
- Car shut off after start up
- Need some help with a strange problem.......
- what grill looks best?
- Ebay stillen rear lip replica
- bad alternator question
- Another blown A/C clutch
- 6spd cv axles
- extra vibrations in clutch pedal after 1 piece SS line?
- Removing the cigarette lighter in a gle 2000 model
- QUESTION Radiator Fan Assembly
- Mirror Glass
- door panel fixing...
- inner tie rod
- What is the trick to pulling off connecter for CPS
- 03 I35. Radiator flush
- please help!!!
- Would you buy an '03 with no ABS?
- Alternative to $71 front hub dust cap?
- If your Max had a theme song...
- time for a spacer
- Moog Endlink Installation
- Battery disconnect & ECM reset
- Something I just noticed about my flip-key
- Getting 15mpg?
- Cooling trial and error
- Finally, got 30 MPG
- What bolt is used to screw in place of the O2 Sensor???.....
- Transmission Issue
- Anyone relocated their rear bumper tabs b/c rubbing issues??
- Replaced Egnine, other issues
- Ticking only when starting
- thinking about 2000 maxima SE
- trans issue, possibly vss but confused!!!!!
- Changing FOG light bulbs - HID or NON
- timing chain tensioner
- Car Keeps Shutting Off
- Just paid more for maintenance than I dod for the car!!
- If I'm replacing the window motor do I need the regulator as well?
- Power Steering follow up help needed.
- 2 step launch
- Maxima funnies... Taiwanissan!
- Mods are ordered
- A/C Compressor Clutch Plate Missing?!?
- water pump drain plug
- Oil cooler for VQ30DE
- Hesitation/stuttering/misfire at low RPM/throttle
- need a new alternator, 2 failures in 24 days
- Brakes stopped working... AGAIN!
- 17" G35 rims
- A/C compressor cycling on/off, mechanics clueless
- Power window goes down, won't go back up...
- QUESTION ON 5-5.5 GEN INTAKE SET UP
- OEM side skirt removal ??
- gas gauge actin wakky
- Dyno'd the max today
- Recently pulled bunch of fuses / disconnected batter - starting issues now
- Heel Pad for Oem Carpet Mats
- Has anyone ever seen this? What is it?
- Tambourine sound from right rear wheel
- OEM Garage door opener
- Idler pulley
- Need help with intermitten misfires
- Need Help Big Brake Kit????
- SMD 5050 LED License Plate Lights - Different Colors?
- Wheel Help for my 5th gen
- Hood vibration when driving fast
- passenger side spring moving when i turn steering wheel
- I Think i have a Tranny Problem..
- Factory installed engine oil cooler - who has one?
- 2K3 interior questions
- Clutch Master stage 1 w/fidanza flwheel is in
- drop with 17s?
- I love you Nissan key-fob!
- how can i fix this?
- REALLY BAD PROBLEM WITH 2002 MAXIMA
- Altezza Lights Illegal?
- Which 02 Sensor is it?!?!
- Slow on the interstate
- Decision between rotors.
- Shifter Knob-What are you running?
- 2002 Max jerks in a right handed turn
- Lincoln Tech...
- Front rotor install
- 03 maxima Rear lip & tail light question
- 5th gen vs 5.5 gen Connectors
- P0300 Misfire
- Hotshot needs you help..
- CoryXavier Bop Plates Gas Mileage Increase
- why do 5.5 (02-03) gen use different strut and shock part # than 5.0 (00-01) gen?
- Gas sensitive Max
- Cattman header install...
- HELP ME PLZ
- I'm embarrassed
- How can I make it sound like a 350/g35?
- Power door locks & windows, seats, and sunroof suddenly stop working
- Water Pump and thermostat brand?
- Short ram intake filter sucking hood
- Question on radiator prices
- Lean Air Code
- MAXIMA HEADLIGHT REMOVAL
- New tires, bad handling!
- Max broke down today
- 6spd filled with GL-5 need opinion
- Motor mounts inquires ....
- Rim opinions needed
- How my maxima looks after a month of ownership :D
- made my own injen lol
- Best Sunshade
- Recommended Tail Light Vinyl
- Found the '02-03 Depo fog/driving lights on Amazon for a good price.
- Brake Masters!!
- Changed out spark plugs and VC, lots of white smoke
- Recirculation button
- I just got a new transmission...
- Where on earth to install an O2 Wideband Bung? Pictures?
- Car starts then stumbles and dies
- Summer 2011 To-Do/Plans Thread
- Sunglasses Holder
- Poor maxima
- The OLD and THE NEW
- G35 Brembo's/BBK options, Please step in
- Sunk clutch pedal question
- O2 sensor issues again..what to do what to do
- Loss Of Power/Exhaust Issues (Video)
- 5.5 Bose Dead
- HID Fogs?
- Rear Main seal , rtv or no?
- Any Suggestions? ’02 Exhaust Muffler Choices
- Update, continued issue.
- Nissan part number required please for these
- Mouse-Fresh Air Intake Location?
- Help! P0420 2000 SE Cali Spec
- Do YOU have a coolant bypass?
- AE headlights vs. Ebay Black Housing headlights
- Transverse(passenger side) Motor mount replacement
- 01 SE Engine Replacement
- WTF....Maximas are one of the worst cars out there??!!!
- reinstalled calipers.. brake light on..
- radiator problems with 02 maxima.
- Interesting SES scan...
- Post a pic of your vafc/safc location
- Temp Gauge/Overheating Issue
- Mods on hold for a while
- AT shifter question?
- well just ud all like to know
- IAT sensor - Resistance
- 350z clutch question
- Ebay headlight and drop for my 2k SE
- need help
- Auto tranny rebuild kit!?
- Timing Chain Tensioner Question
- Carbon Fiber Trunk owners step in
- 2001 Maxima - Strange sound with light rev around 1000 rpm (video)
- Nissan Pathfinder valve covers on a Maxima?
- Coolant Issue (5th gen 2003 6 spd)
- question regarding vias delete, small cannister delete
- Air intake question
- P1147
- A/C clutch plate
- Observation: 87 w/o ethynol > 93 w/ethynol
- NWP Block Off Plate discount
- difficulty shifting to reverse when parked uphill...cheap fix?
- Interested in a 2.5" Cattman Catback Poll!
- is my transmission gone???
- I give up....
- ssim questions
- Bank1 Sensor1 - Pre/post cat?
- what brand for new o2 sensors??
- Have OBD Codes and now the car shakes!!
- p0720 strange issue
- Clutch not working??? Need Help!
- CEL and Trouble Starting After LED Cluster Swap
- 02 sensor simulator?
- Transgo HD2 kit (5.5 gen)
- 02 Maxima clicking noise/screeching in reverse
- Replacing Transmission mount...
- Nismo Max :so i wanted to make it cool but not punkish.
- Have you ever had an accident like this b4?
- VQ30DE-K easy +30 HP
- i30 shake on highway
- help! codes P0430 and P0153
- CCFL Cluster Project
- HLSD: how do i check if my car has it?
- Is it necessary to drain the gear oil when changing the clutch on a 2k2 ?
- 00-01 on 02-03 black SE tailight
- Coolant leak from "Tube"
- SES code reading P0301, What to do next?
- Tips on gauge installation...help needed, writeup will result
- Does the front grill from 02-03 fit 01?
- Poll: So you watch this woman bash her door into your beautiful Maxima .. twice
- Bose/alpine help
- ECU Reset / Relearn
- 5spd Trans Guru's please chime in
- Current good deals on coilovers?
- Rotor and brake pads suggestions
- Procedure for Fail Safe Mode Recovery?
- Pass Front Window Reverses Direction on close
- New Thread? or OOOOOOLLDDD Thread?
- Installed new HID's - automatic sunroof stopped working
- Still have sulfur smell???????
- Power window trouble
- people with n2mb wot box step in please!
- FS Eibach Pro-Kit Lowering Kit dirty cheap on ebay
- Metal piece under volume knob?
- dammit broke my clear cluster cover need your help
- Are the CV's diffrent between a regualer SE MT and a 20th aniv?
- Battery drains Completely while sitting
