- Front Suspension Clunk noise! Why??? help!
- Idle problem after starting
- 2001 vs. 2001 AE Owners Manual
- Steering wheel feels funny.
- Finally! My Pics and Initial Review of the Custom SFCs (56k No Way)
- Strut ?
- LED front side marker retrofit (pics inside)
- quick bulb question
- HELP!!! Can't get rid of O2 code!
- quick question
- Anyone else have rust here by the engine? (pics)
- Having a stock Flywheel turned?
- can you clean O2 sensor or must change?
- gold wheels
- In the market for a 5.5 Gen... couple of questions before I decide to purchase!
- Compare 00/01 to 02/03 front bumpers
- Question for people w/ BlehmCo Lower Tie Bar II Installed on 5.5 Gen
- 5.5gen, randomly wont start
- Optima Red Top
- 6th gen rims on 5th gen questions
- CAR AT DEALER -- Emissions Problems - Did I pay too much?
- a/c inside the car
- Belt Tensioner, order of bolts?
- Exhaust Flange rusted out???
- Anyone hear of Street Legal powdercoated calipers?
- Lexus Capsules With HIDs
- Alternator and Brake warning light....wtf?!?!?
- anyone have the O2 sensor diagram? bank 2 sensor 2 location?
- dash lights on
- Who had the G35 coupe spoiler?
- RPM's going up by themselves
- 3.0 or 3.5?????
- P0430 and P0420 pulled..
- Light bulb help
- What size belt.....
- bose stero acts up with CD's
- Need help ...po430 and po420 question
- clear corner bulbs
- Towing?
- What option should I get?
- About to buy my first Maxima, NEED HELP!
- Guaging Interest In SFC Production
- which intake???
- SS Clutch Line install...what a PITA!
- Easy bolt on 20MM spacer?
- suede?
- 2002 Coolant Bypass?
- what is pinging noise?
- Indications of transmission slippage in 2k SE..?
- SES Light
- Found out 2002 SE I'm looking at is an off-rental.. what to do?
- 5.5 gen Manual AC Climate Control LED Mod
- Do I have any choices for different Auto Transmissions?
- "service engine soon"
- $150 For A Recharge On A/c At Nissan?
- 2000 Maxima SE - First 100K Impressions
- IACV question
- Engine isnt running strong
- LED Tails...first pic
- how to get fog light bulb out?
- So I picked up my new MAx today and...
- RSB ?'s (fishtailing in winter)
- anyone use this- mikes V1 mirror mount?
- having your car learn your style
- Underhood squeak when A/c is on
- Family Drive less Ordinary
- 00-01 rotors same as 02-03?
- Sorry but im having an intake issue
- Auto transmission kickdown
- BlehmCo LTB st. 1 installed (+pics for those who are worried about ground clearance)
- Wheel vibration!
- downloadable 02-03 fsm?
- Soft Brake Pedal
- Funny Feeling in steering
- 00 Seat Covnersion Questions
- Radiator Shroud Update...prototype Is Finished
- holy sh*t! $500 for o2 sensors!!??
- battery and brake light came on, don't knwo what's going on.
- SM 5th gen OEM 17's painted request
- Clicking noise Driver Side
- Door insert ideas needed
- Possible Solutions for Stuck Oxygen Sensor After Header Install
- 2K1 Climate Control
- 01 Maxima steering wheel hub
- Correct Alternator?
- Grinding/scraping while making right turns
- Broken Fogs....again
- abs pin location
- Ae lip 4 a 03 max
- question about my hp numbers
- Failed Inspection
- Another oxygen sensor thread
- I searched but i think i just sucks at searching
- Removing oxygen sensor w/pic
- Overheating
- Screw On Exhaust Tip on my 01
- HELP!!! Car won't start!!!
- taillight ?
- Po 505 ????
- 4th Gen - Upgrade Pending
- 3.5L 5.5 guys step in
- Black Rims/ Blk Max
- Where To Find Freon On My Max 01 Se?
- Projectors 00-01
- fuel pressure regulator
- Homemade O2sim.... need help on sensor theory
- Stock Subwoofer Dead on 2000 Max SE
- no pulsing to the ignition coil???
- help with hotshot header installation
- Squeaking noise
- Max died the last two days, help diagnosing problem...
- Exhaust tip install issue
- Sensor Replacement + Clarification
- my first time driving a stick!!
- swirl control valve... wat is the purpose of this...
- What happened to the Green??
- For those with maxx tuning lip and drop.
- Anyone have the link for the ignition ring LED swap?
- Best springs?
- Just Came From My Local Sound Car Store.
- How To Make Your Headlights Clear Again?
- Weird start-up and warm-up...
- Slow to crank...
- in cabin air filter?
- Crappy find last night..(headers)
- HOW-TO WORKLOG: LED Loaded Instrument Cluster (+60 LEDs!) BRIGHTEST ORG CLUSTER YET
- Greddy Style Stainless Catback Exhaust
- Strange - Blower motor dead or alive
- why do they instruct to reprogram the ecm when mass airflow replaced
- 2K2 Intake Mods to report
- Making sure I did not get ROBBED...
- Clicking sound when applying brake
- all the info. you need for the 6th gen front brake upgrade
- brake question?
- How do I get more H.P.
- Sluggish Below 3000 rpm
- Problem with Power Driver's Seat
- Power Loss after 3k rpm+ VIAS don't know HELP
- Broken Shift Cable Bracket
- alignment necessary after cv axle job?
- Looking at some 00-01 Maximas, need some info please!
- is my A/C compressor broken?
- Changing Drive Belts
- Rattle in front susp, feel it in steering wheel also.
- 2K3 Maxima Resetting ECU problems
- big sractches in rear bumper
- need a/c part
- 15mm H&R rear wheel spacers installed *pics*
- My stock rear shocks/springs gone already??
- ground strap - 2nd cat converter
- **Class-Action Lawsuit anyone???
- 2k MAF Replacement
- Second day owning my car and SES already...
- What Are The Best Tires For Your Max?
- New Photoshopped ideas for a bodykit for 5th gens
- Stealth Front Lip
- Problems tinting back window?
- took my moms car to the dealership today..
- Modding Woe’s, Research & General Feedback…
- OEM Navigation Back-Up CD Swap
- Bad Break Smell???
- Me and some fellow friends in action(VIDEO)
- Question for those using Apexi air filters with Berk Tech. intakes
- 4th gen and 5th gen cai/intake differences...
- Machine Gun Door Lock
- Removing K-Sports Help
- Help, Air Bag light on!
- 2001 AE SE 5-speed with 200,000 miles
- Max 2k2 GLE vs Max 2k2 SE
- New to 5th Gen, help a newbie oldbie out?
- Wheel bearings
- Tear in leather
- The ULTIMATE LED Instrument Cluster...sneak peek!
- Lets hear your ticket story
- those with vis hoods?
- Post up Photos of your 2000-2001 Engine Bay
- quick 2k2 front conversion question
- My New Toy - 01 Maxima SE - Sterling Mist
- Front Bumper Swap
- IAC goes down again, third one this year wtf...
- need intake answer asap
- Which max??
- Front windows rolling down by themselves!?
- 5th gen MT tranny question.
- Maxima and Altima Air bag fitments???
- does my mpg sound right?
- JDubs side skirts
- Belt Squeek
- Muffler
- vibration after rotor change
- Car Pulling
- 6th Gen Calipers, Rotors, SS Lines, and Hawk HPS Pads installed (Pics/Review)
- 2002+ 5th Gen Tranny Questions
- Where To Get Clear Side Markers Off Internet?
- Highest Amount of Miles you'd take on a 5.5th Gen
- Need to know if its alright to bleed the brakes with the car on
- ES 6 spd shifter bushing impressions
- fog light "bulb" to match h.i.d.'s (search no worky)
- Question about windshield
- any one running the hks exhaust? (search no worky)
- 19x8 30offset rub in the front with a drop?
- Got the car back together but got some problems with the brakes
- VIDEO - 5th GENS in action....(autocross)
- warranty is still good...
- How to "hide" double DIN stereo unit on 5th gen
- Troubleshooting 02 sensor
- H-Tech owners: Do you bottom out on the street?
- Ok.....my Car Runs Great......i Need Help Now On The Outside!!
- illuminas and progress springs
- Quick mods
- Alignment Question
- Here is the Answer to our safc/vafc debate
- Anyone do housecor's rear window wind noise fix?
- FLTA2s with new wheels- 56K big no no
- Headlight aiming
- how many "SE" owners have fully loaded cars?
- Painted calipers, and colors? pics?
- what will these look like on my max? opinions
- grinding noise from transmission + whirring noise
- Interior Swap
- How to reset air bag light on an 01?
- 3.0 liter spark plug gap
- Ac Not Working.......need Help
- Possibly trading 02 6Spd for a 6th Gen
- Climate Control Swap
- Teach Me About Spark Plugs
- Napa rotors, pads + shocks
- Concerning Noise....
- Oxygen sensors
- Changing PCV Valve
- Decision on 02 SE (long winded..sorry)
- Prevented a disaster today
- Massive hesitation
- Pic request: H&R springs on an auto max
- might buy a 2000 maxima SE, 5spd.....
- I am in Love
- Grillz
- some extra cash
- VIAS intake sound change
- Anyone know of a writeup for the ES LCA Bushings
- techno ecu or AFC? 02' 6-speed
- GAB owners, do you run a snorkle?
- Whirring noise?
- WTF my clear coat came out milky colored
- Update on the fuel filter change.
- H-Techs off, Eibachs on (first impressions)
- Too Much for Paint Job?????
- Ringing sound from engine
- New headers
- Rear wheel gap
