- Can an exhaust leak trigger the Service Engine Soon light?
- Power seat question
- Memory Seat Problem on 5.5 SE
- upper elbow porting questions???
- P0031 and P0037 codes - anything to worry about?
- 2001 I30 No Start
- another fidanza flywheel/clutch?
- Power Steering Pump Recommendations?
- 03 6 Speed Cold Shift Crunch
- The revival
- 5.5 grill in 5th Gen - Piggyback Thread - Install & Pics
- what are the symptoms of a bad boost/map sensor
- Foot-well lights?
- Switchback Dual Color Parking Light/Directional?
- What happens if rear strut mounts not fixed?
- how to fix P0507 - Idle Speed Control System RPM Higher Than Expected
- Will do spark plugs tomorrow , anything else should I replace while I'm there?
- Gas Mileage Jumped after Gutting Precats
- removing upper after spacer install
- New Headlight Suggestions
- HID Foglight Issue:
- Wrapping things in carbon fiber vinyl
- Megan Racing Catback
- has anyone seen these headers??
- new wheel and tire setup for 2011
- Front endlink clunking noise with video
- Symptoms of bad flex-section vs. CC???
- N2MB WOT box help
- What makes my car better when it's stil not fully warmed up ?
- Normal Throttle Body Movement? (video)
- Cat Bolts welded onto the Cat?
- 3" Catback owners take a look
- 2000 Maxima Non-Cali Emissions > Cali-Emissions
- 2000 Nissan MAx start up issue
- recomendations on a new clutch a light weight flywheel
- Windshield washer in engine oil place
- 8.5/9.5 19" rims wat tire size?
- 2001 "Service Engine Soon" Light Just Came On
- Transgo Shift kit with Maxxtuning VB and opinions
- Rear Sway Bar Installation Question
- Custom SRI measurements
- Transmission fluid change vs. flush on high mileage 2000 5 spd
- Tennessee lady's were u at
- Whats New Thread
- 2 Questions about my 2003
- Smoke @ WOT
- For anyone looking to get Cattman headers
- Phantom coolant loss/smell
- Need some urgent fuse help please
- HID fog kit PNP opinions/reviews...
- 2 questions before i make this purchase
- Flashing CEL, but no stored codes?
- 02 Maxima turning over but not starting. Crank/Cam sensor?
- how to do the free sts mod??
- Switchback LED in 5.5 Gen Maxima housing
- How do I make custom LED tails?
- NEED HELP OB2 Reader is not able to pull codes??
- Please help me! SECU Electrical mess!!
- Looking at New Wheels (size/offset, etc.)
- Tax return, getting headers
- Driverside window grinding
- Bad O2 Sensor?!?= Bad Gas Mileage
- New MAF, but problems are worse.
- Remote Starter
- P0430 and P0420 - new pre-cat didn't fix. Help!
- Maxima 2002 : Front oxygen sensors ,right and left banks.Are they the same parts ?
- Replaced sway bar links and now my front end noise is horrible!
- 5.5 Headlights - Quick Q's before purchase
- 5.5 Grille in 5th Gen - Can it be done?
- How to get rid of the door chime
- wheel play front passanger side
- OEM Parts Diagram Help. Please
- My wife smoked the clutch
- Dashboard clock doesn't work and odometer resets to 0 each time I turn the car on
- P0507? Could this be caused by a PCV breather filter?
- Intake Manifolds
- Klunking noise from suspension....who wants to throw the next dart.
- hesitating
- idea for more power??
- Door open light on, interior lights and keyless not working.
- ebay FSTB
- New Setup
- Hard Warm Start and 1st Gear Shudder ??
- essential1, I'm coming for you
- o2 sim gas mileage
- Quick question on rim fitment
- is it possible to put vq40 internals in a vq35 block??
- Well, it was fun while it lasted...
- 2002 & 2003 HID Help
- squeaking motor mount... i think
- Engine swap
- Is the clutch going??
- Electrical problem
- Plug and play UTEC?
- Convert High Beams to DRL's
- Where to get bright LED Tail Light Bulbs?
- Cattman 3” Catback Exhaust Systems for 00-03 Maximas back in stock!
- Camshaft Sensor issues
- Looking to replace my red plastic + battery terminal cover...
- Question about heated steering wheel?
- Any write up on rear wheel bearing replacement?
- Other Nissan headunit compatible with 5th gen?
- help with code p0160
- Car wasting to much gas.?
- Anyone have the chrome pillar posts?
- installed a high/low halogen/xenon hid kit - but the xenon low doesn't work?
- Car is sluggish and P0420..
- Pretty sure my car is totaled
- Radiator Installation Question
- should there be a gasket there????
- Turbo Specialties Kit
- Help with belts and crank pulley
- Tuning help please
- my morning hesitation in idle heres the vid please help!!!!!
- My car won't crank (includes video to help diagnose the problem)
- Installed Iconic Rear spoiler(pics)
- ATF Drain/Fill Drain Plug location
- Motor shaking while idling
- 00 ECM in 01 Maxima P0403
- WTB: ANY and all 5 speed swap parts!!! from clutch pedal to tranny!
- Few Stupid Questions
- Looking to stiff up the max
- No Pictures!?!?!? Help with Rear Deck
- How come ppl are selling their max after.....
- She's been gone for 4 days
- Any opinion about the CustomMaxima Header/Y Pipe Package?
- video of buzzing noise coming from my starter
- How Do I Make A Spare Key If I Have Remote Start?
- Help! Berk Intake
- how to test if my egr is stuck open?
- need ssim tips and tricks
- Will a 2001 hood fit a 2003?
- Steering Wheel controls (trip button)
- flywheel bolts
- low throttle hesitation
- The newest mod to the max
- Where's the IACV?
- Front windows don't roll down
- Why do we need o2 simulators
- Bank 2 Pre-Catalytic Converter Replacement
- Can I use a 4th gen ac compressor on my 5th gen?
- engine mount question
- Electric Motor Noise at startup
- which roof rack do you guys use to transport skis?
- 2000 Maxima AT Neutral Safety Switch Location
- Will this cat fit my max 2002 ?
- squeaking noise when I back up
- 2000 Maxima rough idle
- Lightweight rims
- Best Plugs? Synthetic Oil?
- Anyone see one like this?
- windshield washer motor fuse, where?????
- Tourning Redius
- turning radius
- Paint Scracthes
- Gauge lights off then on
- MAF adapter in retail?
- TS reflash no longer a tuning option for us...
- PLEASE RESPOND ASAP---->5th gen maxima major malfunctioning**(e-brake &battery light)
- Friend's Car problem
- Idle stalls in cold temps
- Exhaust work on my 2002 ? need help from you guys to make decision
- Cruise control
- ABS Speed Sensor?
- Have Tein SS w/MOOG mounts? Step in
- Good deal or No? Inifniti Wheels
- I need an MCA9 Navigation CD
- BC Racing Coilovers Discussion
- AE spoiler/aero kit replacement options
- Anybody around New Orleans? need help!!
- Lip Kit
- 5th GEN. Trans question. Fix car or part-out?
- P0135, P0!41, P0155 - Codes Not Going Away ... Any Input?
- Question about MAF for a maxima 02
- 5.5gen suspension crunching noise
- Front Flex Pipe About To Go Out, Options?
- tire sidewall bubble
- 01 might go for 06 max????
- P0172 Help
- Headlights
- gMeter Calibration
- Diamter of springs measurement?
- Cylinder Head Freeze Plug Helpful Info
- Wheel question.
- Problem with the Max
- unknown brakes/traction control problem
- hesitation at 1500-2000rpm
- Removing Throttle body, will the gasket tear?
- Rear brake line leak
- stops going after 4500 rpm
- P0011/P0021/P0300; Never-Ending Battle...Any Input?
- need some help with my fog light
- engine blew up today:) need a new one..you have one?
- Foglights
- NEED HELP Won't start
- Need Help! Trying to get the front hub nut off.
- Spark Plug Tube Seals
- Exhaust/gas smell in rear seat?
- 245/50/17 on 17x7s
- 9 hours for header install?!
- Bad Vibration, no seriously step in
- Need Reliability review on Megan COs
- Question for the 3.0 guys;
- rattling cant take it
- 2002 Maxima Berk Intake
- Headunit scratch removal (pics)
- Please help! Gas mileage issue!
- Exhaust Advice
- Tachometer needle not going down smoothly
- Help!! Car starts to shake after adding Engine Restore
- question about radio wire
- Got in a car with stock motor mounts, thinking of switching back...
- HX Car Alarm Receiver Question?
- Ratcheting sound from suspension/drivetrain when accelerating from a stop
- Snow/Ice Fun
- Interior Clips... where to get them? (Clock)
- Will This Work????
- my 01 tranny is on its way out
- Thinking of buying a Throttle body.?!
- Rear end sag Discussion
- Car died and does not start, HELP!!!
- ever replaced an axle or worked on bearings or spindle.... step inside.
- FS: Stillen Intake
- How to replace the HID bulbs?
- Need Help Finding Part Number
- Got P0011 and P0420...Wait or take action ?
- maf swap
- RICER OF THE MONTH
- Ford Mustang Cobra 39# Injector Install Write-Up
- old timer, and sadly it's time.
- Help, Problem Starting
- Stall/no start issue. PLEASE HELP!
- VLSD auto in a 5.5 gen!!
- What size o-ring for cam position sensor?
- which ?and Where to get a bigger throttle?
- I Want Projectors
- swirl control valve.... why dont i have one
- OEM Radiator
- clutch piping and ss lines ?
- Any Help? Cylinder wall Markings
- HIDextra blubs causing flickering problem?
- Alternator noise?
- Why is our hood so blahh...
- Snow storm = Shaking?
- Brief Bogging on Part-Throttle Downshifts when Cold
- Cold start problem
- i found my problem with hesitation
- dtc p0420 main cat or precat?
- has any body orderd from.....jdm hub
- Want to remove spoiler, how to plug holes!?
