- Seat swap
- How do I swap the front seat cushions?
- 19's on 03 Max
- Right Headlight Bulb Went Out
- Known Problem
- Misfire Code---Coil or Not ?
- Could someone help with a serious lighting issues on a 02 Maxima please
- No power to ECM!?!?!
- Idle drop when depressing clutch
- Need help to remove manual transmission from a nissan maxima 2001!
- EBay headlight swap
- Engine oil cap always tight
- Do your brakes suck?
- 01 maxima 5 speed E-brake issue...
- Crankshaft position sensor
- 2000 Maxima starting issues
- Engine Harness
- Oil or something else in coolant?
- 2002 Maxima Project - The little things
- Need help tracking down a draw.
- famous car not firing/sensors/electrical issues
- Gas Leak or burning too much?
- New Radiator for 6 speed?
- Trunk leaking???
- 03 Maxima Performance Upgrades
- Trying to fix blown subwoofer?
- P0300
- Will 215/70R 16 fit 2000 GLE?
- Headers and Y-pipe installed, only 2x o2 sensor bungs.
- coilover suggestions
- Coil Test ? ? ?
- Get you i35 clusters Custom done
- Stainless Steel Cat-back exhaust??
- Any 03 Maximas came with CVT?
- AE shifter knob swap
- 02 Max oil drip from back of motor
- P1320, SES, SLIP and TCS OFF
- Why was there never a recall for oil consumption?
- Driving with engine cover off
- aftermarket radio no steering wheel control
- 2001 Maxima Stereo Troubles
- Should the trunk and dome light turn off after a time?
- Megan Racing Mufflers
- 2003 maxima firing order
- Supercharger build
- question about cruise control
- 2000 I30 w/ 208k - Stalling. Techron?
- DIY Mess Up
- Philips D2R HIDs
- Halos Wired Into "Smart Entry System"?
- Brake kit with only 2 clips..
- G35 Ray Rims - These Tires WILL WORK?
- Alarm/Remote Start Questions for 2003 Maxima
- Maxmium fuel range
- Idle fluctuations after long highway driving
- Will 95-99 rad hoses fit 5th gen?
- Car won't pass smog. Can't get catalyst monitor to show ready
- P0340 Code on a 2000 SE and hoses.
- Why do these Megan racing rads look different?
- So I forgot to put my oil cap back on after a fill
- front suspension pop
- Slammed on brakes, car died, wont restart
- Rod broken. Is this the end of the road??
- You Know Your Exhaust is Loud When.....
- Vibration from a CV joint? Need input
- Stereo display cracked - how fix?
- OBX headers don't look like equal length
- Heater core without discharging A/C, Possible?
- 2001 automatic, fuel mileage and other issues...
- Dropping tranny pan to clean magnets
- Nissan Maxima 2003 Lights Pumping
- Caliper slide pins
- 6-speed, just found a transmission fluid leak. On the passenger side of the car.
- Need to smog...code p0057 and p0158
- p0740 code help
- Unknown sensor location
- Fuel sender with fuel pressure regulator?
- Warm-up Catalyst monitor does not want to complete (P0430)
- Brake Caliper sticking when below freezing?
- Sccuessfully changed cam sensor, oil and thermostat questions
- check engine keeps blinking not staying solid
- Oil change
- fuel pressure sensor
- 18 rims 7.5 40 offset tires 245- 45 18
- please help
- Cat replacement question
- Led lights in 2003 Maxima
- 2002 Maxima Please Help
- 2003 Maxima Service Engine Soon Light
- Any special kind of anti-freeze for my Infiniti I30?
- 2002 Maxima unexpectedly turns off
- Driver side Axle won't stay in
- My Car is For Sale!
- How to replace horn?
- Remanufactured Rack & Pinion Replacement
- Car won't start
- Coolant hose blows? Please help asap
- Putting a turbo in an automatic
- 2003 Maxima Unknown Pigtail Sticking Out Under The Car
- Fog light bulbs
- Motor Mount Question
- Finally trying new cam sensor, ran into unexpected problem...please help!!!
- Can I put my 2003 Toyota Camry xle HU and speakers in my 2003 Nissan Maxima?
- Broken off Rotor Shield
- No coolant flow through radiator 2001
- Vq35de question
- Care will not idle
- exhaust
- Replace spark plugs or wait?
- Shop Says I need New Engine Mounts
- Cam position stumper!!!!!!!
- NWP spacers questions for 2001 AE
- Cheap 02-03 headlights
- My 01' handles way better than my 02'
- What cam sensor am I supposed to buy?
- Eliminate awful wheel hop
- Shakes on idle.
- Valve covers---pair
- Code P507
- Quick Wheel Bearing Q
- Steering wheel trip button 2002
- 02 Maxima P1800 code
- Horrible knocking, right front
- P0420 Still
- Back in a Max
- what tire size for 18 in wheels?
- AFC NEO Tuning (NEED HELP!)
- Headlight issues
- bank 1 sensor 1 part number
- Damn Misfire Wont Go Away Replaced Everything
- how to check for radiator support
- Cannot find exhaust leak on my '03 Max
- would this fit a 3.0L?
- heated seats stopped working?
- New to the Forum
- Post I35 vs 2016 Maxima Race
- Cam Sensor, is it easy to change '02 Maxima?
- My Maxima running Nurburgring (video)
- 2000 maxima turns over no start multiple codes
- Megan Racing rear muffler
- Ridiculous question: Will It Fit?
- Fuel Tank Filler Neck replacement ??s
- 2003 Nissan Max Lose of Power at 4000 RPM
- Long Rough Start
- Tried to replace my 5.5 gen...
- Help with this Sound coming from Front Wheel (possibly from Brakes)
- VQ30 Engine Pull
- 2000 GLE Automatic - ECU Failure??
- Maxina Engine Question
- Six speed swap
- Replaced water pump and chain won't tighten at all on DE-K
- gear selector swap
- [HELP] My AirCon works only at the Lowest Temp (A33)
- 2003 Best value clutch upgrade?
- P0011 after clutch install
- To fix or junk 5.5 gen Maxima?
- Fixed water leak on passenger floor.
- 09 intake manifold and plenum on 5.5 gen?
- Turbo vq30?? :) :D
- P0138/p0139/p1446
- Harsh gear change auto
- 2000 maxima oil analysis
- 5th gen catback fit 4th gen?
- Exhaust Estimate 3.5 motor
- Won't start
- 2002 nissan maxima 3.5l se
- 2000 Maxima with slow clock since birth
- oil pan
- oil pan
- Name of part?
- Questions and opinions needed
- RPMs Jumping around on highway
- Fender flare
- 3.0 engine upgrades?? More ponies!!! :)
- 5.5 headers
- 2002 Max
- Fixed Cam Sensors -Now P0507. Related? How do I tell if new throttle body is needed?
- Why did you finally sell your car?
- Strange Part Under the Hood
- Intermittent engine cutoff
- trouble with my 2002 3.5l
- lost remote key fob
- Engine swap vq30de to a newer 2003 maxima body
- 2000 I30 with water on passenger side floor
- 2000 Maxima car starts but cuts off in like 10 seconds
- 03 max headers
- P0340 Camshaft Position sensor > NHTSA Campaign # 03V455000 > Dealer says 'no'.
- Purple instrument cluster backlight
- 01 Nissan maxima
- Question on replacing REAR Wheel Bearing & Hub Assembly
- Engine knock
- Average Air to Fuel Ratio?/Slow Top End 6spd
- Noise after turning car off (Vid clip)
- 2001-2002 Maxima Steering Wheels
- Riddle me This ?
- Engine stalling 2000 nissan maxima
- Engine stalling 2000 nissan maxime
- Ebay Halo Headlights With Aftermarket HIDs?
- 2001 maxima won't start
- ECU diagram?
- 2001 Maxima SE ABS Controller Problem
- New Rims for My Max.
- 01 se steering wheel controls?
- how to know if check engine light is burned out?
- Noob installing Radiator
- Camshaft Sensor Part
- Dwindling gas mileage. Looking for possible causes.
- AC Compressor Kit
- Suspension Question
- Heated Cloth Seats (Factory -2000 2001 maxima)
- What to look for when purchasing a 5gen
- Suspension question
- Aftermarket Headunit Install
- Champion spark plugs in a 3.5 engine??
- C-Mod Front Grill
- Reverse Switch
- 2000 nissan maxima Has a problem not sure what?!
- No spark and no spray on fuel injectors
- Brakes aren't stopping as hard as I'd like.
- Oil in spark plug tube
- No Acceleration - 2k2 A/T
- knock sensor in 00 max - replace or no?
- VIAC making rattling noise
- heat issues
- Part Find - Transmission Cooling Hoses
- name this hot piece
- HELP shaking/hesitation sitting in gear and accelerating
- Please help!!!! car starts, but won't move when I step on gas
- Overheating - Thermostat
- Cold start, car sometimes shakes or chokes
- Whats the part #for VSS?
- Deckdout2s old whip
- 5th generation 6 speed
- Another car starting issues (with videos)
- 5th Gen - AT trans overheating
- Cranking but no start
- gut precats --> anti foulers?
- Replacement of new Struts, springs and mounts....does that require alignment?
- Jerking around 2500rpms
- Help!!! KONI Yellow Inserts problems
- i need help please anyone??
- 2000 wont stay on. new alternator
- 1 of 2 climate control lights out--how to replace?
- Rear BBK cad/pdf files?
- 2003 maxima slow when warmed up???? help!
- another MAF down - ISO WTB 02/03 MAF
- Distance between hot L and H marks on AT dipstick
- Tail lights 2002-2003 can fit on GLE 2001?
- Bluetooth with Factory Bose radio
