- I have a 2000 Nissan Maxima GLE
- 2002 exhaust upgrade
- in need of 02-03 nose mask oem.
- Valve Covers
- 2001 Maxima - Transmission is on its way out
- What chip to inspect for P0505
- Is this normal wear on the magnet?
- Big a$$ spoiler
- Temp Gauge High---Water Pump???
- check engine light since vias bop :/
- 2000 vs 2001 Maxima ECU (GQ vs 3T)
- Cloth to leather seats
- Q: What's needed to swap from our 6speed to automatic?
- Foglights wont work
- 02 Sensor
- Cars starts then dies
- transmission assembly
- Vibration at Low Speeds
- Questions Regarding A 2002 Nissan Maxima Exhaust System
- Really quick front bearing question
- start no start
- car starts and then dies
- Do I need to balance my tires?
- Want to buy armrest part
- Reverse Drum Install - How Difficult
- MAF replacement
- heater core tubes
- Opinion on this 2000 SE that I may purchase?
- 03 Max, seat moved all the way back, can't get to the rear seat mounts, any ideas?
- Brake Install _ Questions
- Floor Jack Stuck in Up Position
- Anyone use Sensen shocks/struts/springs?
- Tire suggestions
- new but have a question regarding rev limiter and launch control
- Factory HID or not?
- Car stuck in park no brake lights !
- emanage where to get
- No brake lights stuck in park /5th gen Maxima
- HID headlight throw
- Throwback article about Maxima HID thefts
- My Son was given a 2001 maxima
- Wheel Sensor Location/Pic Request
- Weird Issue....
- '02 Headlight issue
- maxima
- Transmission Solenoid Problem !!!!!
- Interesting Electrical Issue
- Floor Jack Point.
- Iac help!!!!
- Bad LCA bushings?
- car stalls at idle or park help!
- Front brakes rubbing after replacing pads/rotors
- P0505 gone after IAC and TPS now high idle?
- Rare & Highly collectible Maxima in Dayton, Ohio
- manual transmission compatibility
- Who has the highest mileage 5.5?
- po303 keeps coming back!
- Idle Air Control Valve... Help please!
- 4th to 5th tranny swap?
- Rear seat belt locked
- Power steering pump?
- MaxxTuning front lip
- Moog Inner tie rod lacking accessories. Options?
- Plug Not Firing
- Engine noise seeking help
- Where is the Ignition Coil Condenser, 2001 Maxima
- Hitachi Boost Sensor Hose Location
- Correct Carpet Color?
- Issues and OBD codes on my 2003 Maxima SE
- Brake Rotor + Caliper Advice
- Very Hard Start everytime
- Remanufactured Autozone Starter Noise
- 2002 and 2005 timing questions
- 02 vq35 fuel injector replacement / installation
- Should I gap these spark plugs?
- Desire stock ride quality - Strut/Shock/parts recommendation?
- Need help with Vacuum lines
- Fatal Flaws
- P2138 Troubles
- Coolant Leak Fries ECU?
- maxima vq35
- Loping idle and slightly rough running
- Air intake vac lines
- 3.5l swap
- 2000 Nissian Maxima P0300 - First timer
- RE40FB Locking or Non-Locking?
- Spare keyless & remote and chipped key replacement suggestions
- Key Programming Issues
- Convert from HID to standard halogen
- Recommendation for Rear Sway Bar?
- Need to replace power steering high pressure line
- Throttle body alignment
- 2000 SE Rear Struts
- Ignition Coil Failure or Something Else?
- I want to see pictures of 5 gen headlights on 5.5
- Rear suspension slams around
- Different/wrong ecu part number
- Help me diagnose a front end clicking
- Occasional No Start, No Nothing
- Current 5th gen owner. Bought a 5.5gen. Questions about radio/cats/o2 sims/brakes
- which oil ?
- nissan maxima 2004
- Replacing the radio in an '02 Maxima
- Experience w/ Transgo Shift Kit?
- shift lever not responding
- Issue after clutch replacement
- O2 sensor and OBD reader
- 2001 maxima rpm surge
- Looking at 2002 w/ 210k miles: what do I need to know?
- Transmission Failure
- O2 Sensor Not the Same
- Rusted lower rad support 03 Maxima plz help
- Ashtray removal
- 2000 Nissan Maxima GXE
- HID Adjustment
- Dash Cam Rewire
- 5.5gen FRONT Valve Cover Q
- Be aware of your surroundings...
- Thinking of buying a 2000 SE: Advice Wanted!
- Alternator voltage drop at with accessories on?
- Where can I find this grille?!
- Still overheating.
- Led swtichback probelm
- catalytic converters
- Need your help on offset and tire width
- power steering pressure switch location on 02 i35
- 5th Generation. Stalling/ High Idle TCS light and Slip Light
- Timing Chain Rattle
- Flashing Air Bag light after recall.
- 2003 Maxima - Help with Part Identification
- Heating Issues
- Knocking / Rattling Noise
- Newbie Help w/ intake,mani,tb,injectors
- Lightweight pulley kit
- 01 SE idle surging issue and....
- Nurburgring Carousel
- Led swtichback problem wont turn white?
- 2000 Nissan Max - Halogen to Xenon/HID ?
- Hood Supports
- Need help and have questions on how to wire up fogs on GXE
- shaking at idle while in gear 02 VQ35
- Magnaflow 6x18 for 3" exhaust
- NEWBIE HERE. Need help! p0430 code
- Bad shock mount bushing?
- Hood vibration solution
- HID Ballast or something else?
- thinking of getting a steering wheel
- A fond and somewhat sad farewell
- Headlight / Fender Push in Reciever Clip
- WHERE is the check valve?
- 2001 Maxima - Lost 1/3 of my MPG and slow acceleration
- 2002 6MT - Axle recommendations?
- Brake pedal hard with engine off, works when on
- MAF Sensor Diode (Thermistor)
- Car is acting very strange. HELP!!
- Switching to Full Synthetic a bad idea?
- Maxi owners w/factory HIDS: Get in here!
- 2000 I30 Rear Brakes
- Car stalled and then went completely dead.
- Acceleration Problem
- Project Free BMW Rims Restoration
- 03 maxi, how to remove glass when the window is all the way down?
- Wheels 215/65R16
- Weird rubbing sound when making left turns...
- Parking brake adjustment
- Resonator choice
- differential bearings
- Lack of protection for fuel filler neck
- No start, no throttle response. Please help!
- Heat issue
- Opinions on 1A Auto parts quality/durability. Any experience?
- Which master window switch does mine take
- Mishimoto R2329-AT Radiator, Good or Bad?
- Well maxiiiboy? Speedo quit working, 2001 Maxima, Doesn't Have Speed Sensor
- Brakes Pulsing
- Caliper slider pin positions
- 2001 20th maxima transmission question
- Thermostat
- Matching OEM Vinyl
- Nissan Value Advantage cv axles
- Car immediately stalls on cold start unless I give it gas. Starts fine when warm.
- 5.5 gen tune-up, now no start :(
- What does underside gas tank look like?
- Unbelieveable--power steering leak fixed
- How to find out which master window switch I need?
- Looking To Buy Projector Headlights
- After market car alarm removal, what would you do?
- Just let a good deal slip away on 2002 Maxima SE
- Question about steering column under dash
- Engine Revs but no Acceleration
- P0430 persists even after new Y-Pipe
- Good wheel color with tanish-gold body?
- Where to buy tuning headlights
- Strange Starting Problem 01 Maxima
- Special Tool for Serpentine Belt?
- Passenger side fluid leaking
- What air intake is good for a 2003 SE Maxima?
- Need Advice on CV Boots
- Did I Break the PARK Pawl?
- Cattman ypipe hitting crossmember
- Mild power steering leak, and our friend Mr Lucas's Fluid
- Time to change Brake Rotors and Pads
- Chirping from engine bay when A/C is on?
- 03 SE - Throttle Irregularities
- Alternator wires replacement
- 03 max trans issue turned into massive leak
- Sexy Butts. Lol
- E manage blue?
- Would an I30 alternator fit my 03 maxima
- 03 maxima electrical questions and troubleshooting I need help!
- VIAS solenoid supposed to hiss?
- Pulling the Axle
- What Good Can Come From: Goodyear, Monroe Muffler and Meineke
- Control Arms, Suspension, and other work, any after market parts to be wary of?
- 2001 throwing p0420, p0430 and p0325
- Exhaust
- How to Install This type CV Boot Band?
- A question about motor oil
- Jacking Points?
- Need help on buying this 5th gen 01 max
- Diagnosing an Axle
- Cattman JWT Pop Charger Filter model number?
- Rattling Noise
- Passenger window dosent work, motor is good
- misfire in intake
- Max running off the road to the left and right hand.
- Rack n Pinion or ps pump?? 2000
- Cracked intake plenum
- Leaks
- NATS code generator
- 02 maxima
- Buying a 2nd 5th-gen. Check this out and give me pointers, please
- Battery draining over night
- 5th and 5.5gen PS suction hose any difference?
- Wheel bearing?
- P300 and running fine
- Problem with only left rear toe
- Southern Wisconsin Help
- Fixing a stuck slide-locking electrical connector
- Mystery oil leak???
- Limited Cattman Release
- *** I35 bogging replaced MAF no change ***Video***
- Does an '06 Altima steering knuckle fit an 00-01 Maxima?
- Best deal on OBX..
- battery light on dasboard is on
- Help Diagnose Engine Failure
- P1320 - Coils checked and are good?
- Foam piece around air intake snorkel
- P0305 and P0300 codes?
