- Detailed Write up on Dr Mod
- Should there be play in the parking brake handle...
- For 02-03 owners This seems kool
- Oxygen
- anyone know how TPS voltage effects performance
- Question about heater controls
- Replacing my brakes this weekend, any suggestions?
- Struts to match my springs!
- Mass air flow sensor bad, what do I do to get a new one?
- chattering noise when accelerating, timing chain??
- Advanced timing impressions
- Belt replacement
- Front 02 Sensor Replacement
- stupid question
- eBay FSTB owners, washers?
- vi solenoid vacuum routing...
- Weird Issue
- possible car problem...
- <$20 and fun with homelink
- Should I trade the Max.....
- Stillen Lip: Gettin' Mine, Who Else?
- tire rack referral number
- JDM headlights??
- Manual Transmission *stuck* !!! please help !!!!
- cold start idle problem with 2000 gle..
- I never knew what a great resource...
- Some Car Trouble
- How often do you change brake pads?
- Why do rear brakes wear out faster
- 02 sensor tsb 02-051a
- Power steering noise?
- Bad Motor Mounts?
- Official Coilover Thread!! For everyones benefit!
- What is the correct voltage for a working MAF?
- Nissan Autoparts Stores in Clearwater Florida
- Sold the Maxima
- Drive Train Warranty
- Looking Into Full Catman products
- New- First Post-Getting read to purchase Maxima-few questions
- Need Help 2k2 highbeams... Inspection time!
- WTF....Auto Climate Controls are STUCK in Econ mode!!! Anyone has an idea?!?
- Trunk Issue
- Went To Have My Snow Tires Put On And Had A Huge Disappointing Surprise
- !!!!exghaust Asistance!!!
- to anyone who bought the Helios kit
- Recommended Clutch (one step above stock)
- Berk intake - remove stock snorkle?
- IACV valve position
- Has anyone made LED taillights yet?
- Can anyone help with camshaft sensor
- DDE Problem, temporary, or i gotta change?
- 2k maxima ate another tranny!!!!
- Rear window SMASHED!
- post up photo of your 2000-2001 engine bay
- 2000 maxima gxe making a whinning noise somewhere in the engine when i turn it off.
- question on injectors
- Parking break not biting
- 2k2-2k3 HID headlight down the road visibility...how is it?
- EGR problem - top of guide tube totally clogged
- Iginition Coil Replacement
- o2 sensor & o2 simulator problem
- anyone remove that plate between TB and intake manifold?
- Best 19in Tires, Not Gonna Warp or Blow Out.
- Happy Birthday Tim!
- Insured Repairs: Headlights/Front Body?
- 1320 code
- Lowering your car.....
- fog light problems...
- Car has lowered further...springs or strut issue?
- People with cut springs.
- odd smell...
- stock headlight problem - HELP -
- how to retain dimmer function on sony head unit?
- Cat issues??
- question about compatibility
- Stickies update??!! Spark Plugs & Fuel Filter
- To ex-Berk/Frankencar intake owners - how does the GAB sound compare?
- Is it my hood?
- Code P0430
- Burning smell coming from the driver side rear wheel area????
- muffler/catback question
- PS2 Install Question
- Creeking noise when i shift my autotragic gears
- Identifying exhaust noise
- price check on aisle 2
- Quick Question: 15" wheels on 2K SE ?
- 225/35/19 too small of a tire on a 5th gen?
- Brake Problem
- AE limited Slip?
- Slipping Clutch
- stupid theory...
- Best place to get body parts
- Automatic to Manual Conversion?
- a/c pully bearing Q
- help, how to remove the throttle body
- Never seen this before
- Has anybody had this problem? and what it could be?
- Lube vs Grease.
- Frankencar owners step in!!!: fitment issues- Just Me??? (pics*)
- Best site to buy Maxspeed Springs
- Help, Please. Car is throwing CODES!!!
- Tuning the max...
- unorthodox ultra SSc pulley
- DIE Hard Battery
- shock absorbers...
- Ehh...dying fuse? Dashboard flickered when starting car.
- Tranny Weird!!!!
- best 5th gen?
- Light bulb question
- Freezing handbrake
- After Market Fog Lights Install
- new 5th gen bumper pics???
- Bump stops different for SE and GLE.
- Terrible Gas Mileage...?
- question about spring squeal.
- Happy Thanksgiving!
- Loss of low end torque........HELP!!
- Poor gas milage, possible causes?
- DR mod discussion
- Consult II = Bad @ss!
- License plate relocation
- REEEEEEEEE freak some 5.5 gen owners out
- Newest Generation short shifter opinions
- Is there anyway to aim our fogs?
- hotshot vs. cattman
- ignition coil diagnosis
- Coin Box Part #
- I'm so tired of my aftermarket rotors warping
- Can run Carfax reports
- Eibachs and bump stops
- Installing silverstars in head/fogs.
- Anyone Know Part Number?
- car jerks at 1800rpm in 1st and neutral...PLEASE HELP
- easiest way to install clearance bulbs
- First long road trip W/ codes
- hs headers on a 00fed spec w wideband
- 5.5 gen Problems Query (AC/Heater Blower)
- My car died a slow death last night....help
- Newbie 02 questions, INSPECTION FAILED
- o2 simulator?which one?
- ecu flash?
- Map light rewire?
- help my car got issues
- installed jic, getting squeeking in rear
- KSport GT Lowering Springs?
- cleaned TB and AICV now car is jumpy
- Anybody buy these rotors or pads from ebay??
- freak some 5.5gen owners out
- Poll: Yellow Fogs or Fogs to match headlights?
- headlight question
- Brake Upgrade Review.
- Tein h tech + illumina's = SMILES
- 5th gen tail lights.
- digital rear view install write up??
- Should I sell or install my nitrous kit?
- keyless entry
- Diamond Plate Trunk Cover
- Symptoms don not math with the code HELP
- Service engine soon reminder?
- Deductable on extended warranty?
- E-Break Tightening Bolt
- Deactivating the keyless entry horn when locking doors
- anyone blow a tokico HP (Blue)???
- Tried some new headlights out. (pics)
- Cattman y-Pipe + Frankencar B-Pipe= LOUD!!!
- Tire - Center Wear. Have you seen this? What pressure do you run?
- Latest tranny oil change
- compass mirror problem!
- 3 VIDEOS and 6 pictures of my new mods for the interior
- Will a 5.5 gen Y-Pipe fit a 5.0 gen?
- Nismo rad cap *pics* *56k die*
- Need Opinion on Pre-Cat Problem
- my quick, cheap and easy XM install..
- Steering wheel became harder to turn
- 02 GLE Spoiler?
- New Owner of a 2002 GLE
- Photoshop experts please step in.....please!
- What do you like?
- how to flash high beams w/out HIDs flashing?
- Shocks/Struts Thumping/Bumping Noises
- Dumb Question (search found nothing)
- 02 Maxima Navi CD...
- brake light
- FSB noise.
- Wanna introduce my self
- Blown fuse or relay???????? Help please
- Part Number For The Ae Door Sills
- Vibration and thumping noise, please help.
- Maxima Christmas!?
- O2 Sensor problems....
- People With cattman headers and After market Y-pipe
- need help with clips
- 60,000 Mile Service , What do they do?
- New Suspension = Clunking?
- 03 Max Fog Lights/Lamin-X --- Rant
- wow wow wow one preatty slow maxima
- ASA AR1 18x8
- Speedometer Question
- headers or drill out precats?
- What do you think?...
- Changing paint What Color....?
- Pepboys Nighmare!
- car didnt start, then weird start...help
- Possible To Adjust Sensitivity Of Stock Alarm?
- Tires, Tires
- Where is the water pump on the vq35?
- OBD 2 Code Reader
- Installed: FTSB and RASB
- Need grill for 2000 nissan maxima se
- Fog Re-Wire write up
- PIAA Plasma Spark Blue fog bulbs
- driving..then the car just died...
- Reguarding the '02-'03 Headlights being stolen easily
- For those with 20's
- How do you remove the grill from an '02?
- How to tell if cat is blocked?
- loud whiney noise when turning the wheel..belts? 2k2 se
- Last wash for the season b4 i store her...
- Gear lube or tranny?
- 19's Plus Bronx, NY Roads = this
- Timing advance – rare question
- cold in my max
- Auto Tranny shifting at 5k rpm?
- funky vais fixed...kinda
- adding amp to bose..help!
- will aftermarket springs damage front struts?
- Got My Car Back From The Shop!!!!!
- HELP!!! With fog light re-wire
- leaking cv boot...will this fix work??
- Bad wheel bearings lead to damaged hubs.
- what horns???
- Can you replace foglights yourself?
- New idea, exhaust powered BOV
- problem with starter
- Anyone removed AC off 5.5 gen?
- Engine sounds like it will blow up
- SE gauge cluster to a GLE?
- Found perfect Optima Red Top to fit max/I30
- Climate control bulbs????
- ººº1 picººº All my headlight and fog bulbs.
- Window Problems??
- P0420 - I'm pissed
- Need Help Deciding HIDs
- Question about AC condenser
- JIC or K-sports
- P0300 Related to Grounding Wire kit?
- Tokico Illuminas -- How are yours?
- 02-03 DDEs??
- Does anyone have the Tein SS (Super Street) Coilovers?
- Wierd
