- Please Help Me Identify this Part ...
- my maxima is fixed !
- ac recharging
- Air Bag Light Flashing
- Headlight Bulb Probs
- New to Forum a few questions/commments!
- Lost only key
- 02 max cps issue/ dead tach
- 2000 Maxima rattles/shakes @ 75 mph or above
- Definitive $3 fix for bose sub rattle
- still looking for possible causes ?
- Productive Weekend .....THEN.....
- do i have a blown head gasket or need a coolant flush ?
- Poor gas mileage and car idles very low what to look for?
- MAF sensor screws
- camshaft vs crankshaft position sensor
- turbo charging 2001 maxima
- Two Thermostats? on our 5th gen
- Clutch replacement, comparing options.
- Bypass master window switch ??
- F/S...2Head/ Fog lights..4 Bose Door speakers
- The Great Video Thread
- Rear rotor issues
- Replacing my manifold gaskets. NWP Phenolic guys, step inside
- Winshield washer pump location is exactly where?
- Car not starting/ code:p0011
- What should I sell my 2001 GLE for? New England Area
- Help me price Dad's I35?
- NOOB Replacing front and rear valve covers '03 Max... - Any tips, tricks or advice?
- Mystery rattle on acceleration in the 1.8k - 2.1k RPM range
- 01 5spd tranny leak
- Axle Shaft Seal
- P0300 and more?
- Starter Issue...Help Needed
- Steering Rack Bushings
- Vacuum problems after changing rear valve cover gasket
- New to the Forum. Having issues with my 03 Maxima GLE
- Value of my 2000 Maxima?
- what does this picture infer?
- 2000 SE - drivers window problem
- The Knock Sensor
- ISC Pot
- Loose eBrake Cable fix for Stillen RSB:
- Gen 5.5 Rear Caliper suggestions?
- '05 72k swap in my '02 186k 5.5 6MT (pics)
- ODD noises etc. after MVA
- 2001 Maxima SE Is It Worth Keeping?
- a/t light flashing, car wont move.
- axle boots
- p0720 issues vss
- 01 maxima ECM replace problems
- 01 Maxima Anniversary Edition
- Transmission Fluid Looks Like Engine Oil (oops)
- Engine cranks all day but won't start
- 2000 Nissan maxima shut down
- Help, is mechanic ripping me off?
- Replacement door shells
- Thanks for the help code 1320 and AirBag
- 2000 nissan maxima cluster problems
- Moog Control Arm?
- 5.5 maxima turbo v.s 911 turbo
- New guy, new car.
- VIDEO Blown head gasket - $3,000?
- Why UTEC is discontinued
- FS: Stillen front and rear lip
- 2001 AE Wet Coil?????HELP
- 2000 engine replacement questions
- 03 maxima trips off after 3 seconds
- Rebuilding my calipers
- Replace the Input Shaft Bearing for $70
- There is some justice in this world
- Changing driver side half shaft/axle
- Advice on Maxima (keep or sell)
- broke Alternator Wire Harness
- Install of new ES Trailing Arm bushings:
- Car starts but dies at random times
- What color you guys like better?
- Rear Licnese plate screw holders
- 02 6spd - Intermittent shift issues into 1st and 2nd?
- 2002 cutting off at stop
- Key Fob Car Thieves
- SurraTT you the man
- sorry not finding what i need, factory wheel specs for 03 max
- Is It Bad To Drive Without Calibrated TPS?
- Should I keep O/D on or off?
- so I dropped a sockets...
- Car hit in street .. what to do
- Western General (Extended Warranty) Any thoughts?
- Bad Shifting at Certain Times
- Wood shifter knob
- Little help
- Suspension issues
- New performance mods for the Maxima!
- Solenoid or not
- New NWP product coming soon!
- 01 Max Se SRS Light always on. Have used one from Wrecking Yard. Dangerous to change?
- Resonated Megan 240sx & 4th gen Too Long?
- rusty lower oil pan
- beat up exterior...but strong engine & trans
- P0335 pending code - 2001 Maxima GLE
- Will Love your help!!! My Max deserve more...
- I'm Baaaack...with a Stumper of a fog light issue
- Many things needing fixed, many questions...
- Headlight suggestions and opinions wanted
- New to Maxima's
- Sunroof Rattles When On Tilt Position
- raysbestos rotors- double layer
- Need to know bulb size for HI/Low and Fogs
- Cranks but does not start
- Dilemma, Iseeus with Precats (rattly/fluttery noise)
- 6th gen auto axle swap
- ...Carbon Fiber Door Pillars Kit
- Anyone running a 3" inlet muffler on 2.5" exhaust.
- Putters and stalls above 3000rpm in park. Same at low RPM in gear.
- High idle after installing header
- Raxle axles......
- SRS exhaust drones alot. Options?
- 2003 sub help
- location of relay to fuel pump
- Wheel well rusted out. Fix suggestions?
- Engine rattle right around 2.5K rpm
- How Do I Know If My IACV/ECM Wiring Harness Is Bad?
- 13 Years of the 2000 & survived recent storms/water
- I know... another intake thread.
- 03 maxima brake pads
- Aftermarket part availability
- Bad flex pipe! NEED HELP!!!!
- B&G springs
- Door Dent
- Intermittent lack of power, no CEL
- Nissan Air Bag Recall - update?
- One gauge light went out
- Mysterious wires and hoses! Noob nissan maxima help!
- Is this tire trash?
- Oil consumption + pre-cats
- 2000 Nissan Maxima can't shift into reverse
- uneven heaten rear brake discs
- 2000 Maxima stalling when stopping/idling
- Advance timing with android phone?
- cattman header install
- 2001 cruise control -no lights question
- Runs rough for a few seconds when started
- 2001 Bose Subwoofer Fix
- Hot shot header with out y-pipe section
- Warpspeed y-pipe Flex pipe question
- New zealand/ 2003 Cefiro same car as Maxima ? - Leaking Power steering
- 2000 Maxima SE Cranks But No Start
- Weird Hissing Sound (Engine)
- NM 2001 can't run after running out of gas and refill
- Nx Fuel Solynoid leaking..
- why is my car not starting
- Customized Nissan Badges
- 2001 Maxima GLE // Left Rear ABS Sensor
- Driver seat not moving up or down.
- VQ30DE motor
- 2000 SE Totaled or not
- '03 Max SE Motor Mounts Replacement Cost
- not getting brake fluid to though the rear pass barke line
- Starting problem No fuel
- Legit or not legit stillen lip kit 280bucks brand new?????
- Thoughts on new wheels
- Warm engine dies when started or sometimes when engaging clutch while driving.
- Accident...Now What?
- Practical Performance upgrade suggestions?
- Hole in my foglight pic included
- How Do I Calibrate Throttle Position Sensor?
- Found dealership to do advanced timing - quick question
- Engine knocking
- 2003 acceleration problem
- 2000 Nissan maxima Bumper Cover?
- New 02 Maxima SE owner
- Replacing all 4 brakes?
- How to choose a right code reader for our Maxi?
- Dave B
- lower radiator support fix price? Tristate
- Complete 5th gen air-inlet system
- time for a new car
- Time to change spark plugs
- Low Idle issues after alternator replacement
- What should i charge?
- Timing Advanced+Nitrous?
- AT Motor Mount Fix
- water pump
- o2 sensor nightmare
- Where can I get aftermarket headlights for the max?
- High Rev after AC recharge..cant reproduce?
- Cross member and radiator support rust problem
- Oil Consumption - Concerned - Your Thoughts?
- Complete Stillen "style" Kit
- catalytic converter
- Oxygen sensor codes: Is O2 Sim failing?
- Is the 2000 or 2003 Maxima more reliable?
- Old School Maxima Enthusiast finally gets a Maxima
- HOW TO: 350z Seats into a 5/5.5gen
- recently swapped a 98 vlsd auto tranny in my 5th gen
- Alternator bottom bolt wont come out help!
- Retrofitting Cruise control
- Anyone over 200k miles on there 5.5 ?
- 2003 6MT difficulty engaging 1st & Reverse after tranny build
- Crazy airbag question
- 2000 Maxima SE AT silently dead, help needed
- Engine shuts off while driving.
- Brighter Interior lights?
- blower motor cuts off untill i slam hood
- Thoughts about those rims?
- What to do what to do, cut springs? ZOMG!
- Has anybody heard about these wheels?
- Should I go for a VQ30 Maxima or a VQ35? 6Sp or Auto?
- Auto transmission Question
- Update for Cattman Headers
- 2001 Maxima GLE // ABS, TCS, Skid light on after replacing starter
- mod opinions?
- anyone ever heard of option-r catbacks?
- Speed Govenor Question
- Second Thermostat 00/01 Under IM DOES GO BAD...
- Back again....again
- Hot day issues
- Replacing Lug Wrench
- Steering wheel extremely light!
- 2000 I-30 with "cylinder 5 misfire code"
- headers
- Visual inspection HLSD or Open?
- Key stuck in ignition fix
- 5th gen pickup
- 00 Vias need Vaccum Line?
- ANOTHER WEIGHT REDUCTION THREAD!! just a little different
- Blower motor fuse keeps...blowing
- Speedo stops working intermittently
- Front & Rear Footwell LED's/Glove Box LED
- Under Hood Lighting Done
- 02 Maxima - VQ35DE - GLE - Low Rev Knocking
- Empty oil pan after oil change...
- This kid got under my skin
- How do you aim the foglights on a 2k Max?
- where is the switch for the glove box lamp?
- 02 max se 220km problem help
- Won't rev past 2.5k
- Need to replace struts ... Need Help
- 5th generation idle issue
- 2002 Maxima SE 6 Speed Issues
- Question about ECM Programming
- New Member - 5th gen 2000 Maxima SE
- Dealer says might need new computer
- airbag light code
- OBD II Monitors Not Ready
- Bosal pre-cat and need for gasket?
- Engine problems 2002 3.5 Maxima
- obviously I'm too damn stupid to figure it out myself
- Help on steering noise
- Looking 4 Headlight Mod Specialist/person..
