- vq30det in 2000 max
- gas guage
- p1320 help-replaced coils
- SSIM'd my Car today
- SUper Bad Milage/ Need advice
- Unstable steering after axle shaft replacement
- D2 RS Series Coilovers - Info on a Groupbuy deal - checking for intrest free shipping
- how to tell if fuel injector/s bad?
- Getting to the washer parts in the hood
- Diesel sounds!
- Illumina Install: Part number question
- P1167, WB02 or new OEM O2 sensor?
- Electrical Issue: Loud Click
- Odd Noise - Suspension?
- Need opinions please!!
- Bulbs that match stock HIDs?
- egr removal problems
- Strut install party
- Upgraded cooling fans???
- 2000 maxima EGR issues
- Passenger inner tie rod replacement help
- Black roof and shark fins
- Exhaust and Headers Question
- A/t tranny slip
- Relay Noise !
- Help. Missing connection
- thinking about...
- custom gauge "pod"
- how do i reset ecu?
- MAF NEED YOUR HELP!!!
- Car won't start after alternator spark
- Heat Shield Fix 2002 Max in NY
- rsb installation
- MAF
- How to remove speaker grille?
- Help Me Understand IVTCP Sensors?
- Quick One
- Need Mounts!
- Vented Engine cover the Second** Pics **56kStayAway
- Resistor missing on MAF!!!What to do!!!
- Need help identifying Leak
- Cost of Clutch Master Cylinder
- suspension question...
- Wiring Question
- Finally found a used bumper cover!!
- How come a CAI is so much more effective on the altima SE-R?
- Car shakes in drive
- Saying goodbye to the 5th gen...
- transmission ground
- SES Studman's guide
- makes a load thump while turning
- Speedo Problem
- ae lip on 03 max
- Code P0440
- to convert from manual gear (stick) to automatic
- exhaust help.
- Keyless Entry Doesn't Work Anymore???
- Where is the Brake Booster Line?
- rattling noise in front pass side
- Sunroof tilt works but wont open
- Alignment printout
- Looking for wiring diagram to install shock sensor
- Clutch Problems
- 2003 leather seats in my 2000 se?
- Why would my sunroof tilt up on its own?
- Fairly New Battery but car will not start.
- K Sport Question
- Bad engine knocking....great
- Does the sotck non bose headunit play mp3s?
- Am I screwed?
- Best location for wideband o2?
- IGNITION
- Reprogramming TB
- Strut Tower Bar or Sway Bar
- downsides of buying a used max with high miles
- I think I found the source of my exhaust rattle
- all i can say is WOW. I love progress
- Blower motor won't turn on. What could be the problem?
- Mirror Compass not working, and wheel touch up question plz
- Just installed most of my grounding kit.
- heated leather seats for $200
- Strange noises
- 01 3.0V6 100/105K mile maintenance items
- timing advance and cell question???
- 100k mile club :-D
- driveshafts gon bad?
- does consult 1 work wiht 2001 maxima's
- CAR WONT START IMMEDIATELY
- Help my tranny!!!
- Electrical Malfunctions
- this guy does not know what he is talkin abaut
- Getting gas is a pain...
- MT tranny experts step in please
- 200,000 mile club
- O2 sensor locations
- Shifter bushing/swivel???
- 6MT passenger side axle woes
- these fell of my car dont know where they go
- TB question
- Engine/trans compatibility question???
- p0455 Help!
- New shocks & struts but now it rides like an old Cadillac
- Question for those who changed motor mounts
- shorter height shifter
- WTB OEM bra for 2002 Maxima
- code p0420 and TSB 00-070B
- What is this part?
- Rear Shock Mount Question
- BCM.....HELP ASAP
- Some Mean Person torched my car!
- Starter Problem?
- grounding kit?
- halo lights
- swapping my A.T. tranny with 6th gen?
- who can do timing advances....
- Center Beam Motor support stripped threads.
- Timing advance question...
- 03 max BOSE
- Spark plugs change
- Whats needed to lower my maxima?
- AE headlights
- How to ground the starter? (making grounding kit)
- PCV valve part #? 03
- tranny issues
- How to Advance Timing using the Nissan consult tool??
- Engine pulling advise...
- Huge Mileage Problem
- Need answers or suggestions?
- Vehicle Reliability Survey results
- Just got my H&R's and Illuminas!
- Lets discuss a theory of mine
- Noise after spacer install
- Should I resurface my rotors?
- How do you program the ignition transponder key?
- RADIO QUESTION?
- So I got my MAF adapter the other day
- so what happens whent he maf goes out?>
- What in the name of god has happened to my car!!? Valve help!
- 2000 Maxima Stock Radio Trim
- Strut Mount Assembly Question
- Bridgestone G 019 Grids?
- Acceleration problems... please help!
- side vent removal?
- Maintenance costs over lifetime of vehicle
- 22" on maxima slammed?? and Nex coilover SS reivew.
- Bouncy tach?
- I got Bad Luck!
- Just saved my self $110!! GREATEST DAY EVER!!
- New Belt squeaking: too tight or loose?!
- Dying Alternator?
- CF Hood in the winter
- hitches for bike racks?
- Smoked side markers
- front brake pad wear indicators 4 or 2?
- How to identify if the tranny I have is a 2003 or 2004?
- Ball joint nut
- Urgent help needed with tranny fluid flush.
- Just installed Starter and now it won't start!
- Two questions...odd noise and odd AC behavior
- Play in the steering wheel
- 2000 maxima se speakers amp and sub
- Maxima clutch pedal. feels kinda wierd.
- Soo.. someone backed into me. Options?
- Pending P0340, checked the grounds, replaced the sensor, now what?
- P1456 code?
- Troubleshooting codes on...03 maxima
- tach signal
- Getting my 6mt tranny replaced with a 6th gen one
- Finally replaced my cracked fog lens, and....
- Pcv Valve Grommet
- Sunroof sagging from one end
- Eastern Catalytic Converter
- Uneven heat thru vents
- Just finished installing Tokico Illumina's on my i35, impressions and some questions
- Does Anyone know?
- Extended Warranty Opinions
- #4 Ignition Coil Melting
- Suspension Work Needed
- Overheating issues
- Quick Alternator wiring question
- Wheel bearing maintence...?
- I Need a Clutch..help please.
- Has anybody ever gone up against a camaro Z71?
- ABS/noise issue
- Ebay headlights
- muffler from 00-01 fit on a 02-03 max?
- shift knob
- Trunk Supports
- 2000 Maxima Auto Radiator
- A32 Y-Pipe on A33?
- Poll- Engine pinging?
- TPS and APP sensors gone bad
- Still have front end clunking...
- Would this work in place of the oil catch can?
- Injen/Fujita Intakes
- Dumb question about oil level
- Steering Wheel Loose
- Rod bearingsr shot
- 5.5 --> 6th Gen Calipers - Is this Caliper Bent???
- 6MT issues
- Replacing coolant and radiator hoses - do i need special bleeding?
- Consult/blaZt for A33/A34
- weird rev jump.
- H.I.D.s?
- 01 GLE Sunroof Motor Problems (fuse not blown)
- How to know if my maf is no good
- annoying problem with driver side window
- Automatic Tranny Fluid Flush (I've searched!)
- Review of Timing Advance
- Replace ECM Myself?
- Illuminas and S-TEchs or Stock Shock/Strut with S-Techs
- Anyone else interested in a Cattman Y-pipe for a 5.5 Gen?
- 5.5 gurus step in please
- SAFC-II question(s)
- Window problem
- sensor help.. tps/app
- need help
- High beam, low beam
- rear window problem
- CV Joint Fail
- want new exhaust. but i want some preformance too.
- Canadian Max, exhaust Fed spec or Cali spec?
- Nitto Invo - Tire review [video]
- Got P0430 code not sure which O2 sensor on bank 2?
- squeaking sound when i turn left after all the repair and $$$$$
- Hypothetically how much hsould a mechanic charge for this?
- Extending Rev Limit...Possible?
- Who else has this problem with the manual shifter cover?
- Brake Sensor
- doeas anyone know if this will work with factory alarm?
- Car wont start and acting funny (electrical clicking)
- Timing advance from the dealer or Greddy EU?
- Check out the sig
- how much would installation cost for a y-pipe+ headers
- So After $700!....
- OIL in spark plug chamber
- hole in firewall for wiring.
- button under clutch pedal
- Clutch gets tighter when AC Runs and/or Temp Outside is Hot
- replacement muffler
- difference between egr and evap system?
- I have a question about the package I have
- Fuel guage light is out.
- Brake Rotor rust. very very ugllyyy
- Sound when car is in reverse
- Fog Light Relay Problem?
- Buttons not lighting up.
- Any 5.5 6mts with a Y pipe? Need some impressions
- Interior or Engine Bay Location of ABS Sensor
- Winter is coming...Need winter wheels
