- Brakes...
- Video of DDE, HID Fogs and Exhaust
- Suicide, Lambo doors on a max?
- ECU reset?
- HELP: Cold Weather Stall at Startup????
- Help. Cracked Fogs on the 03 - (stock bulbs)
- CEL came on last night, any idea?
- Few questions, emanage and headers
- Installing an exhaust DIY?
- HELP! Cattman Headers & Exhaust
- Upgrading to stronger 2k1 MAF?
- 6spd wheel hop?
- Maxima Wood Radio Bracket
- Help to change headlights from 02 to 01
- The worst headlights ever.......
- Final words on the D2's *must read*
- stupid rear cupholder question...
- changing harnesses for lights
- AE headlights
- catalytic converter problem.
- Original Tint % with 2003 SE?
- What do you guys think?
- Would an 85watt H3 melt '01 foglights?
- how to fix tick in blower fan area?
- big pics of that gringo sheet
- Heads from a 2K3
- Right high beam isnt working but low beam works...
- Removing radio bracket screws - How dio you guys do it?
- Zone 7 navigation Cd...who has one???
- RSB, now too loose in the fromt
- Sea Foam, I just bought one... will post any changes.....
- SES light is on - Code #P0021
- Any 00-01 have oem hid kit from 2k2-2k3 in their stock headlights?
- Gear shift "clicking" noise - Any ideas?
- Pre Cattman Mods Dyno Runs -- Results
- battery
- Problem W/Rear brake caliper piston
- 2k2 Navi - video feed
- I have a solution for the Bose "tick" problem.
- paint chip
- front end shimmy
- one-of-a-kind emblem on my max
- wind noise at rear glass area -- did TSB fix and it's worse!
- something funny bout our auto
- clunking noise
- Benefits of Y-Pipe only?
- Exhuast ?'s
- Anyone port & polish their 2k1?
- center caps
- remote start for 2k maxima
- ok, i am tired of BS, where do i get new MAF?
- Converting of the interior
- horrible gas mileage, should i seafoam?
- '04 350Z Stock Wheel Problems
- PIAA Xtreme Whites -- Melting Harness or no?
- best and brightest revese light...
- 4.3 litre 2k maxima engine bore?
- i'm stupid about the vacuum lines
- spark plug decision...
- I30 Bose HU VS. Maxima Bose HU
- bare metal foil makes emblem on steering chrome.
- Blue LED Interior Conversion...Done(56K Warning)
- digital climate control and leather seats
- Garnin NAV
- changing climate control
- Will anyone have a detailed writeup for VIAS fix?
- Help, need to buy O2 Sensor (have questions)
- Changing brake pads
- 2000 SE Power Driver's Seat
- Something I've never seen on the org. . . (big pic)
- Heated Mirror Install Experience?
- wheel bearings covered under the 60k powertrain?
- SES Codes....
- Throttle body cleaner?
- Story - headlights stolen and headlight poll
- Head Unit for 2002 SE
- What is this noise I hear
- remote programming
- Can anyone confirm the speed limiter?
- Powert Slot Rotor Plating
- Which Pads for 2K2 GLE with PowerSlot Rotors?
- ***AnYone With A Screen Radio ?? *** need HELP !
- altima se-r
- #2 stolen car in the USA....
- Hazing on guage-cluster cover...annoying...
- New Pics for a new member
- Injen from 95 Max to 2k/2k1 Max?
- Pictures of my gauge pod
- red sox anyone
- Remote garage door opener
- should i buy a maxima?
- Any one with a Cattman Cat Back.....Please step in step in.
- A/T slippage
- Classic or Aero lip which one?
- HELP! 'Sliding' type noise in dash
- automatic door lock
- slotted rotor installed? Which directions?
- Wiring Diagram for OEM Radio (Bose)
- Exedy Clutch Experience
- Help...Loud clicking noise from Clutch
- Help- My Car when starting
- Im excited after reading motor trend
- intake scoop or no scoop?
- Need Help!! Ignition Coil experts, spark plug pple..
- Audio Upgrade for 2002 SE...Considerations, Options
- 2000 infinti i30 audio question
- New sticker set for sale !!!
- clicking noise (like a relay)
- Programming the remote
- ABS RR RH SENSOR (OPEN) Need Help!
- Headlights for 00 GLE from an 02-03
- Oxygen sensors
- Trailer hitch install?
- Frankencar poly mounts 00?
- New paint job
- 2001 Factory Head Unit
- CD Player for 2002 SE
- ok, for the 5th genners with subs...
- Weird brake deal
- 2000 rattle and no solution
- What do you think about my stickers...
- Rattle when I start....?
- Brake repair questions
- tokico hp's with stock springs?
- 02/03 FSB question
- low MPG.. what can I do and how? help please
- exhaust fumes..too much?
- How do i know if my Water pump is goin
- Motor mounts Part #?
- Belt Replacement How-To
- Coolness. Possibly getting a 2002 and keeping 2001.
- brighter headlights
- Why would my exhaust sound louder?
- Steering wheel not centered during Highway Driving
- How to get rid of the bouncy side to side feeling in GLE?
- Looking for a Grille
- Intake: stock air scoop rattle
- All with 00-03 auto's that have a shifting problem step in (again)
- 2k 2k1 Manifold removal
- 1st to 2nd Gear Hesitation
- Clicking Sound
- Negotiating With Dealers
- Disconnected Exhaust??
- why the locked threads????
- Installed Berk.....Have Problem
- projector headlights
- Maxima 2nd Most Stolen?
- Mass Airflow Sensor
- #2 Most-Stolen Cars
- Caliper leaks break fluid
- bottom of the trunk fix....
- Installed bright reverse lights side by side pics
- hella optilux angel eye fogs
- Gas Mileage??
- difference between front and rear
- Stillen Header/race Pipe 02-03 Maxima 3.5l - M/s Ceramic Coated
- Steering wheel shake/vibration
- Harsh Braking
- Body colored grille or no? OPINIONS!!!
- Missing Fuses??
- My car is sluggish/slow
- maxima's are stolen across the US
- 02/03 maxima #2 stolen vehicle in US according to Wall Street Journal
- I dont get it (breaks) HELP!!!
- FYI -- 300degree nProbe compatibility
- Leather seat install 2002
- Tranny breakin
- Brake question by a "new do it yourselfer"
- pinging when i hit the gas
- uh oh 02 & 03 Max 2nd most stolen car
- 02 Max speaker color codes
- 02 sim Question
- OBDII 5th gen max
- Maxima 2nd most stolen car
- Maxima Rated # 2!!! ................
- 2002 SE Purchase - Further Questions
- Son of a *****
- boost sensor and air temp
- Help with coolant lines.
- technosquare ecu for 5th gens
- How T0 Reprogram ECU ?!
- Suggestions for a 2K2 or a 2K3 Purchase
- getting NISSAN navigation system !
- i think my Hood is loose, any suggestions?
- Car won't start after clutch replacement and tranny seal question
- 02-03 grille on an AE?
- New Tranny
- will 5th gen AE chrome door sills fit on 4th gen?
- What is this OBDII code?
- Got few questions
- rattle/ping noise from engine
- GD started on ABS Dynamics Lip Kit for 5th gens
- "New" 2002 Max and Interior Lighting questions
- removing rear side marker light
- LED Tail lights?
- ECU reprogramming
- can I easly put a digital climate control in a non one?
- Should I install fogs before winter?
- alternator sound
- My DDE Stupidity!!!
- Power/Heated Seat Wiring Harnesses...
- Instrumentation Bulb # 2001 Max
- Is this TRUE?
- 02 Maxima DIED!!!
- would u replace coils if
- '02 Lower Control Arm Bushings
- Air bag light and AT light flashing for 5 seconds!
- Crazy 2k maxima problems.
- cold air intake
- Matching Dead Pedal to AE Pedals
- Maxima 2000-2001 and 2002-2003
- those with systems please enter
- 2 questions
- Any 00-01 owners here have 2k2-2k3 oem hid?
- Need info on data dots.
- 5spd conversion any one willing?
- oscilating tap like noise from A/C compressor, is it going bad?
- Front license plate assembly for 2003 SE? Or screw size needed?
- What modifications need to be made to 4th Gen Struts to work in a 5th Gen (2000)?
- HELP!!! Getting code P-1320, ignition coils bad
- DDE Issues
- Alternator replacement... DOne
- Passenger Window Switch
- anyone selling 2002 max radio?
- Cracked Fog lights?/Good replacement?
- Service Engine Soon light
- Whistling noise when engine is cold.
- JIC Magic Bullet Exhaust
- GXE Stock 16'' hubs
- Weird Noise/shaking
- Nissan Maxima 2001
- 0-60 and 1/4 times of Auto 3.0 and Manual 3.0 and Trans ability
- dumb question..
- what size spacers to use on 19x8.5 mm evo5?
- 02 Fog light rewire
- D2 owners and ABS sensor question for all.
- Looking to get hid's need some recommendation..!
- Where to find
- Umnitza Angel Eye Install
- ok to paint MT lip now ?
- Installing dash trim over the climate control PLEASE HELP!!
- Installed XTEC Hid Fog Kit. Instructions Inside!!
- Tool for Rear Brake Piston 03Maxima
- SES light reset instructions pLease!!!
- Where can I buy 02 MAx TRUNK mat?
- replace alternator
- Spring sleeve
- Underdrive Pulley
- BRAKES... question!!
- Comparison of MT lip and Stillen Lip
