- Custom Turn Signal mirrors. Ideas Please.
- Roof Spoiler pics **POST UP**
- Need you guys help.
- Looking for pics of battery tray and fuse block
- 02 Maxima Salvage?
- Is it possible to fit 02-03 headlights on a 01?
- Carpet I need CARPET
- progress rear sway bar?
- Difference between European and American Maxima
- question is this normal
- A/C Clutch interchangeability?
- megan racing coilover review
- STRANGE NOISE WHEN BACKING UP
- Cutting out when driving??
- Don't forget to tighten your throttle cables!
- differential fluid for VLSD
- Fuel Filter
- Approaching 200K: Need service/Maint. Advice
- Clear Side Marker question
- Stealth bulbs for Front Turn Signal
- LCA ES Bushing Install Help
- Differenc between OBX vs CATTMAN Headers!
- No power to signal bulb in Gauges, anyone experienced this?
- Catch Can Vacuum Leak
- water/methanol injection?
- replacing expansion valve
- yea... another trans thread
- Old 5 gen promotional video
- Front end lift and sway at wot
- Coilovers! What do you guys think? Or Loweing Springs
- Runs fine then bucks, hesitates, won't go over 40mph. Help!
- Stillen Front Lip Spoiler- To paint or not?
- Fog lights not working.. How to test for a short?
- ps delete fail or no fail....
- Dipstick marks: anyone figure how much?
- dek tb question?
- DIY: one peice ss clutch line
- Is this an ORG member? What exhaust is he using?
- Header install question
- Coilovers help!!!
- Does your 5th gen eat as much gas as mine?
- troubleshooting and estimated repair costs for 2002 Nissan Maxima OR sell it
- SES light comes on flashing, then disappears by itself an hour later...
- 03 maxima BOSE A/C console lights out
- CF AE Engine Cover - ChinoXclusive
- Does anyone know where I can buy this piece?
- rotors.. cobra or 6th gen>?
- Question on changing rims, rotors and brakes
- upgrade to se rear + black head lights
- Seats: My quest for something more delectiable.
- Quick question about heat shields on Precats
- P0507...FFS...Will update when fixed.
- Finally found a MT Max for sale in Vegas
- Wet Car Porn Picture thread. :-)
- Code P0135 Problem!
- Look what I bought for the Maxima
- High flow pre-cats for an 02 SE?
- New HID's are flickering
- Addco rear sway bar part #
- Diagnosis of 2 Sounds - Please Help (video)
- maxima lights in a spec v?
- Diference between A33 and A33B?
- airbag placement....
- Will a 2000 Maxima Engine Work in a 2001 Maxima
- Has anyone installed these Radiator Fans?
- Tried on some new shoes..
- Installing new radiator.
- Thinking about a paint job or touch up
- automatic shifter nobs
- Help with European Maxima part - is it the same?
- Non-Halo projectors?
- Is this important?
- 03 Misfires Under Woot at 4200 -5000rpm
- how low should i go?
- Radiator Fan Blade Broke Off
- has anyone dealt with budget exhaust lately?
- Installing Tein SS Coilovers with OEM Strut Mounts
- 17" wheels on 2000GXE
- Selling my Max and need to put a price on it!
- Headlights, Headlights...Retro/Ebay/5.5 Step in Gentlemen.
- Bumper sagging
- yes LR maf discussion again
- HELPPPP my turn signals out
- Lets see the cleanest pic of your max.
- Emblem Stuff
- Exhaust dissatifaction after Headers
- 2001 HEADLIGHT HID WIRING QUESTION
- Chain replacements....
- saggy H&R rears??? how bout a coil spring spacer ...
- Question about a newer VQ
- Thinking of getting a Stage II lower tie bar from Blemco
- Are fog styles the same from 00-03?
- what are some good rear spoiler (trunk) options?
- Question about fog bulbs?
- Max died on me!
- different size tires
- Feeling transmission shifting through steering wheel
- started ssim with mini port/polish
- Bulb Info Needed
- Crank pulley?? Your help requested.
- Another MPG tread, but somewhat different:)
- Radiator FAIL aftermath >>>>VIDEO<<<<
- 02/03 Replacement Headlight lens??
- Installing a Pac Swi-ps
- Maxima Camshafts
- Question on putting 03 gle rims on my 2000 max
- 350Z MASS AIR FLOW WORK ON 02 MAX?
- Transmission installation tips?
- Finally did it
- Center console lights won't work
- Maxima Wont Start
- Need help with wideband
- 470k resistor
- Wiring Map Light(s) to function when Dome turns on
- 5th / 4th gen rim options
- Just curious to know how many has had to replace radiator after 105k etc
- How many of you DON'T have an active check engine light?
- Key fob
- Rally Stripes?
- Car has a weird starting problem after getting it back from the dealer
- Brake fluid
- TunerMax 5th Gen to 5.5 Headlight Conversion Hook-UP Guide & DIY
- Brakes decision help needed
- Headlight Mounting Clip Broken?
- What to do with my TB?
- Does a TT 300zx fuel pump fit a 5th Gen Maxima
- Looked up facts on upgrading torque converter
- what is your 0 to 60 time????
- Replacement Key Fob
- 2 weeks of ownership and front bumper looks like crap
- WTF is in my Oil catch can. ice and sludge
- PROBLEMS ON AND OFF
- Post your cruising sound levels here... if you can!
- Help me pick out some aftermarket parts please
- Anyone else swap out motor mounts and regret it?
- Max_Kings Progress Thread
- obx header woes... bad install reveals itself after 1 year
- ses codes need help
- Center Console Swap?
- Shifter Button Problem
- Name that tune (with link to video)
- anyone tried these rotors?
- First Motor Swap - some questions
- NWP!!
- wheel upgrade question
- Motor Mount Questions
- Honk when locking doors...
- Car acting strange upon startup today - whining, didn't start the first time... help
- ECU Help!!
- GSP Passenger Axles SUCK! - 6MT - Pictures.
- powersteering belt removal???
- 5.5 Headlight Conversion - Anyone with DRL's done it?
- factory 6 1/2 bose sub replaced be kicker 6 1/2 sub
- warpspeed cat
- Gauge Cluster fuse blown. What fuse.
- Car wont start ...
- Have Vagcom ODBII cable will it work on the maxima?
- SES code issues
- PCV on an 03
- ebay OEM "style" tail lights, '01 SE style?
- 5.0 fuel filter - so much trouble !!!
- Anyone know where to get new radiator
- So I started cleaning up me new (to me) 6 speed '02
- Ground underneath body
- Rear brakes?
- Hesitation to shift along with SES light
- Keyless FOB Repair
- Moog shock bellows cracked
- Installed My S Techs
- 2002 Maxima Cigarette Lighter, has no power?? Help!
- Program sun visor garage door opener
- Door alignment.
- is the 5.5 gen sunroof suppose to fully open?
- Should I give up or throw more parts and money ?
- Finally back!!!
- BOSE question, left channel cutting out intermittently w/ CD player....
- Possible BCM problem
- Red vinyl - Tailights
- parts list for spark plug change on gen 5.5
- LRMAF and 3.5" intake does in fact make power over stock and 3" on a bolton 3.5
- Super short SRI... Rethink it!
- 02 max no go
- Replacing exhaust...
- anyone have the "ebay" or other carbon fiber grill?
- 02 replacement ... any advice?
- Quantitative/relevant technical information re: Top Speed governor
- GI Truax SFC limited production!
- tranny rebuild
- weird annoying noise coming from unknown sensor...
- Cheap Double Din Trim? Step in please...
- Coilover longevity?
- Another tranny bites the dust
- trans???
- 2k question regarding mileage
- Power Seat broke, and all I need is one little gear!
- More spacer? (pics)
- need help...electric problems after alternator change
- Service Manual
- Front End - Repairs & Work - Economy's of scale?
- Great gas mileage!
- 2k3 rearview mirror vibration
- Radiator Sucks!
- why transmission, why?
- 2001 AE maxima suspension!?
- what struts for H & R springs?
- Lost on my engine issues on my 2000 max....please help....
- Misfire Cyl 5, Has spark, compression and fuel
- Removing door molding [pics inside]
- what to lower my car on?
- rubbing noise from the middle of the car
- TunerMax Under hood lighting Mod DIY
- Anyone Ever Painted Around Rear License Plate?
- Anyone install ebay test pipe on 5.5?...
- Installed Ionic Dynamics Window Spoiler.
- Car shuddering: What to do?
- ? Gas needle goes to E,then has no power, but tank is full
- 2000/2001 TunerMax Grill Conversion DIY
- Quick question about tail light swap, and brief introduction.....
- 2002 Engine knocking noise
- I'm lost--"Fuse Block Connector M19"
- Help with transmission id
- help safcII
- Ultra High Performance Summer Tires Recommendations
- Anyone with g35 rims get their wheels to poke out a bit?
- Bose Headunit Cutout
- 6th gen seats in a 5.5gen
- Got wheel alignment today :)
- Vq35 parts
- instead of wheel spin, i get wheel hop ??
- Knock Sensor Intermittent Failure?
- Official Intro Thread. New Owners, Step In.
- OEM vs Aftermarket air filters
- cluster problem
- 3' equal length Y-pipe questions
- racing seats
- performance upgrades
- Heated Seat Switch
- sticking gas pedal!
- Eastern or Bosal PRECAT??
- check engine light has a "faint glow", any ideas?
- New ECM & IACV
- Added HID Fogs, And Venting.
- Insurance rates
- Dieseling after shut off/ heat not working
- replacing stock non bose radio
- Cold Start Problem with video
- Back on the road again!
- BBMAF - 76.2mm vs 82mm
- Rear strut mounts...
- Transmission problem? Or somthing else?
