- Black out emblems?
- Will Stillen Pads from a 00 fit an 02?
- need vb mod input..
- P0135 - O2 Heater Circuit Malfunction
- Vb Mod
- Does anyone have this setup?
- Brembo Rotors on 2k2-2k3?
- Please Help!! Dash Kit Help!
- RSB installation?????
- Water coming from muffler
- wheres the tcm located on a 2000se???
- Decently priced slotted rotors
- Pics of body color grille for Sterling Mist???
- Need feedback on Quality of these Headlights
- MaxxTuning front lip-painted and installed properly
- Need advanced help for interior lights mod - not working!
- A few new pics on cd page!
- Anybody pics of BLACK Ebrake handle and BLACK leather boot with tan leather
- Cutting springs OK?
- Will this MOD be beneficial...
- 100k plus club... need advice on tune up
- Who sells this grill?
- can someone help me run a carfax?
- Are these projector lights any good
- Pleace Racing Motor Mount Help
- OEM HID's for 2000 SE
- Front License Plate Holder: Has anyone removed it themselves?
- Can I change my 2k shift console to this?
- Thank you to all
- Which Cold Air Intake is the best???
- vogtland springs
- Where can I get 2k2-2k3 headlamps w/o HIDS
- NOISE when i turn off my car... ????
- An into, then a few questions.
- Where to buy Budget Y-Pipe?
- Foglight Film?
- Location Of O2 Sensor
- 02/03 maxima stats gen Qs.
- 2K Maxima SE 5 speed ECU TSB???
- another car audio question
- Why do people buy 2K2-2K3 UR UDPs.....
- Ok You may make fun of me....but
- allow me to introduce myself
- ghost code help
- Speeding ticket...Need Answers...Help
- 90 second epoxy for DDE install
- Need help again in interior lighting...Blkmax95c please step inside
- MAF Question
- restrictor plate questions
- Which Caliper Type?
- CEL ON P0171 system is running lean bank 1
- PO138/139 ECU codes again.
- Replacing Reverse light switch. Anyone done it?
- Anyone replaced Mass Air Flow sensor?
- Thinking of trading GLE for SE..NEED HELP!!
- Those who have done rear view Trunk cameras in the key hole...
- gettin my windows tinted
- 60K Tuneup?
- computer chip for added hp
- can anybody help me with this??
- 02-03 Maxima or WRX who would win?
- ACT or EXEDY STAGE 2 CLUTCH
- Some info on engine hesitation needed.
- Sick of it
- how do i rewire foglights to come on just by themselves?
- New to the Board
- rear defrost/antenna problem
- installing a 2002 navigation unit in a 2001?
- rear wind noise tsb
- Installing the H3 Hid system?
- Easier Downshifting Possible??
- Frankencar exhaust...anygood for my 03 6 speed?
- 300z calipers????
- Nissan Free 100 Point Inspection
- RSB Issue
- Rough shifts, but Nissan can’t find a thing…
- progress springs, but which struts???
- 2k2 Dyno: Cattman's Headers vs Y-pipe
- Clear Sides question
- Upgrading the Bose...what can you do to it?
- Honest Opinions required!
- All you peeps with body kits...
- need yay or nay on adjustable sway bar
- Maxima Commercial
- question about ghetto air box
- winning noise near TB (2k2)
- Where to find service manuals
- Just got cattman exhaust in the mail!
- To those dropped with springs come in
- Bolt pattern?
- Those with AE kits...
- I'm going to buy an o2 simulator. Which one do I need?
- Rotten Eggs???
- Sweet dude, I'm in!
- I'm no longer mad I didn't do the DROP yet!
- Has anyone experience battery problems???
- 2001 SE 20th Anniversary Edition VS. 2000 Infiniti I30
- P1147 and P0139
- For those with UMNITZA DDE's
- will vq30de cams fit vq30dek?
- POLL 96Integra vs 00Maxima for pickin up the ladies
- dont slide into a curb...it will cost some big bucks
- Should I buy a 6th Gen? Opinions Needed!
- could a nissan 350z or g35 exhaust system..
- The definitive thread for converting from Auto to Manual!!!!
- Stock alarm question
- Auto to Manual
- what size optima battery should go in my max.
- ahhhhhh....................
- 2k3 Warped Rotor Question
- need opinions
- P0140 Code = which O2 sensor?
- Those who have done the all red (circle) tails.....
- 4th genner installs manumatic. Can we?
- Replacement Battery
- VIAS stuff
- Spring/Strut Install Help
- Alarm randomly goes off...
- i need a stock 2k max wing
- HID High Beam Conversion / Replacement??
- removing the bezel around the stereo unit
- Bulbs for clear sidemarkers
- Engine Lights 0505(idle Air Control Malfunction) ???
- Engine hesitates when accelerating abruptly, whats the problem?
- Shaving Bump Stops? (Eibach/Tokico)
- 2003 Max - SERIOUS SERIOUS drivability issue
- Threw PO300 code
- Clear HIDS anybody had problems?
- What kind of lights did you guys use to replace these?
- Fluttering sound--wheel bearings, steelies, or tranny?
- After disconnecting battery do you have ...
- stillen y-pipe vs. cattmann y-pipe
- Spark Knock?
- Anyone know where to get one of these?
- 7507 bulbs for rear turn signal
- my horror story...
- Turn signal
- R.I.P. Kloogy's Pearle Max.......
- If you've upgrade your 00-01 BOSE, please step in
- rear windows?????????????
- Help! problem with window control switch
- Clear side marker installation
- need Engine mounts???
- Surging of the engine after I let off the gas after 4k RPMs.. Ideas?
- Racing seats whos got em
- P0420 TSB causes other problems besides SES light?
- Help! Electrical short
- Help, i need ur opinion!!!
- Flashing Airbag Light
- Disappearing Brake Fluid???
- A couple of new pics here.
- Replacing in cabin micro-filter?
- "MAXIMA" Light Up Door Sills
- tire and brake life
- Worst Day Of My Life And My Maximas Life
- straight pipe worth it?
- HID Fog Write Up
- what brand to replace my warped rotors with???
- rear rim hot!!!!!!!!!!!!!!
- DDE/Halos for 00/01 Maxes - MODS HELP!
- Compression test followup (2000 maxima)
- rear strut bar
- o2 sensors p0138
- 2000-2003 Maxima Vogtland Performance Springs
- grounding point for a manual tranny on a 2k2?
- Those w/ Illuminas & Progress or Tein S-techs
- want to buy a catback exhaust need opinons...
- Stock Shock Manufacturer
- Accidentally Resetting my Odometer?
- Comparing Drops!!
- Has anyone used these
- Leak above rear main seal - What is leaking??
- Cheaper coilovers on Ebay...
- Jacking up car after RSB
- What color is your maxima
- Sun roof problem
- stillen rear strut brace
- Ugh...aftermarket headlights WITHOUT the stupid Halos?
- Brake Pad Questions
- reverse lights bulb?
- Finally gathered a collection for viewing
- 30K Maintence
- More pics of D2 install, someones going to kill me for this
- Pics of D2 install
- Mother of all posts, D2 coilover install, thoughts and pics
- PIAA Xtreme whites or Sylviania Silverstars?
- What do u guys think of the new tein ss coilover system?
- someone please find me some angeleyes (or similiar) for a 2k1 max
- cattman muffer any good?
- Free Nissan 100 point checkup
- Need help locating cause of squeak
- any pics of 35% tint??
- brake pad replacement
- Passanger window....SLOW!!!!
- 02 max door hinge problems..
- Altima Horns...
- Do Hubcentric Spacers come w/ diff. outer bore diameter?
- best looking cosmetic mod?
- Service engine light P420
- im new here and have questions
- Strengtening the autotragic...
- Dealers arent sure which is cylinder number 2
- HELP, I screwed up my UDP install!!!!
- factory pads
- 18.4 mpg after performance mods...how can I make it better?
- Dads, Please Step In. (car seat question)
- Is my transmission failing?
- Any How-to's for MT Front Lip?
- HLSD Question
- Wheel bearing issues?
- Added more LED's to my car!! *video* *pics* LOOK!
- Axxis -Ultimate -brake pad installation HELP
- Update: 2k2 Auto Trans Issues
- Hella Supertone
- What is better Greddy EVO or Cattman Y-pipe?
- CP needs a few coilover testers
- need help on auto to m,anual swap :(
- Help, I'm Thinking Of Doing It!!!
- Cold sttttuuutttering problem
- dumb newbie shift knob question
- Pics wanted! smoked corner lights!
- 5th gen SC owners roll call....
- People with AE door sills step in..!
- MAF Replacement - Are these the right parts?
- Where did you buy your eyelids from?
- 02 sensor replacement?
- Maf $650 Cdn??? Wtf?
- need help - 2000 stuttering, stalling after startup, power dip at 3.5k rpm
- MAF sensor replacement
- Difference between Greddy EVO and EVOII??
- Fuel Injection Cleaner and Service Engine Soon Light
- Need help installing front and rear clear bumper lights
- Hopefully it is just me....A reason to mod!
- My new Mod!
- Replacing the Alternator???
- RSB U bolts......
- animals living in the car
- 2K2 SE steering wheel vibration when braking
- ne one install these headers
- What Battery Brand other than Optima works best?
- New Clutch Questions on Max for 5&6 Spd Drivers
- I got blk halo angel eyes headlights.....any seggestions on installation.
- Rewiring Stuff???
- 2000 maxima se prob help!
- anyone got pics of their 20 and/or 15% tint?
- 04 Irotors Slotted and blehmco BBK Kit -- 500 miles after the install
- 01 Brake and Battery on while driving HELP!!!
- how to.........
- Tune up questions?
- Does your rotors have this?
