PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 [129] 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. hot shot clearance issues.
  2. Repainted Maxima
  3. Where to buy KYB bump stop/ dust boot?
  4. i didnt drive my max for 6 weeks
  5. carbonfiber hood
  6. Broken side skirt...help
  7. z rims
  8. which hid kit in the GD section is better?
  9. spark plugs
  10. AC leaking excessive amount of water?
  11. 02 gets some new shoes
  12. when does the radiator fan come on? can it ba damaged?
  13. here comes another week without my car....
  14. Bridgestone recall
  15. Oil in one of my spark plug cavitys...
  16. header install/motor mount/bad idle?
  17. Only one tip on the exhaust is releasing..
  18. help. Problems w/ ABS,traction control
  19. Lease is coming up, What car should I get
  20. Car got scratched!
  21. repairs at dealership
  22. Left front speaker off with cd only
  23. Seats are too thin?
  24. Steering shakes under braking, new brakes.
  25. help needed....steerin wheel shakin
  26. Bosch MAFs
  27. Replacing O2 sensors HELP please
  28. ugly header heat shield, dont need it?
  29. Does the 02 GLE have side airbags?
  30. Is the interior of the Maxima stock?
  31. Flywheel recommendations anyone?
  32. What fuel grade do you run in your 5th gen Maxima?
  33. getting a bit frustrated!
  34. putting 02 tails in a 00
  35. Springs
  36. Strange starting noise
  37. Rockauto.com coupon expires Aug 30th
  38. Maxima Experts, Please Step Inside
  39. an e46 bixenon retro...done
  40. 2000 GLE Charcoal Grey-Window Tint
  41. Will it fit
  42. question about i30/i35 and the maxima
  43. How to reset airbag light? Help please
  44. 02 MAF Adapter -
  45. Driver seat motor
  46. Ran 1/2 tank on regular...
  47. Maximas off but making noise!!! HELP PLEASE!!!
  48. No More Push Starting!!!
  49. 5.5 Gen that are Currently Running Axxis Ultimate pads(Step in)
  50. Xtec Fog Light Owners - Similar Problems?
  51. Dying motor
  52. foul sulfur smell gets inside cabin.
  53. whos hap[y with their magnaflow?
  54. Best air intake
  55. Gutting Cali Front Pre-Cat
  56. need brakes
  57. Catalytic Convertor
  58. injen intake for 2k2 max
  59. Pulling intake to change spark plugs, where to disconnect from airbox side?
  60. cattman muffler
  61. 2002 guys with sunroof switch please step in..
  62. withdraw pains
  63. upgrading from a 97 to an 02
  64. when clearing headlights???
  65. P0139 & P1147 - ORG gurus please help!
  66. 2000 Gxe vs. 1998 Se
  67. window tint
  68. 2002 SE Valve seals bad
  69. Rattling when I let off the gas...
  70. Weird issue with '00VI.
  71. SES Light - Code 1380?
  72. Anyone have Tein EDFC Electronic Damping Kit?
  73. P1456 Code
  74. Turning over issue.
  75. Installed Tokico HP w/stock springs
  76. switching to regular gas?
  77. Tokico Illumina Suspension Kit
  78. Spark Plug/ Coil Pack problem
  79. omg i want these!!!
  80. Cali spec or Federal
  81. Best place to mount ballast
  82. 5.5gen HORN idea!
  83. Paint Code Front Grille
  84. P0135 - Location/How to Access 02 Sensor for Replacement?
  85. 00VI/VIAS Mystery Problem
  86. Left Headlight Out!
  87. 02-03 OEM HID stock wattage?
  88. Need A Response... Fast!!!
  89. engine surges when braking
  90. VQ35DE oil burjning issue - step inside
  91. CT Stuff for Sale-local pick up
  92. Getting a 5th Gen - What do I need to look out for?
  93. rear suspention pain...help
  94. P0011 and P0021
  95. For 5.5gen guys(vq35)
  96. Apexi Air Filter
  97. Wierd Problem with Foglight Rewire
  98. Weird Steering Issue
  99. A Question about vq35 injectors
  100. If You're Thinking of Going Aftermarket Navi w/ SIRIUS *PICS*
  101. A/C is not cold anymore....
  102. Need test-fit car for 1st set of new Cattman headers
  103. a/c problems! help!
  104. wats a good oil filter?
  105. weird sound comin from right front brake
  106. tranny fluid choices?
  107. installing STS
  108. aftermarket intake information clarification
  109. Did the 2001 GXE and SE come with different manual transmissions?
  110. problem after tune up
  111. 00-01 Maximas with P1320, step inside.
  112. cali spec y pipe
  113. Color Shift
  114. Nismo CAI
  115. P0430 and will under 90day 3000 mile lemon law
  116. Where to buy Raybestos QS?
  117. Painting headlights
  118. where is the plug for ODBII scan?
  119. Get 15 more horses power for $50 seriously.
  120. can i do this? "intake"
  121. question on brake kits
  122. how to remove front door panels?
  123. Cattman ypipe -bolt size
  124. oil-fouled spark plug
  125. What'a up w/Umnitza's predator lights?
  126. SOMEONE ELSE please make SFC's for 5th gen!!!
  127. Having problems installing clear corners...
  128. Another rim thread(opinions please)
  129. Is Warpspeed the only company that makes subframe connectors?
  130. 20th Anniversary Edition engine/valve cover
  131. clearing headlights today! [scared]
  132. Window Motor dieing?
  133. new tires, sloppy handling????
  134. BBK owners?
  135. Opinions!!!
  136. Opinions!!!!
  137. BEWARE of Throttle Body Issues!!!
  138. AC Controls doesn't iluminate any more
  139. Finally Fixed High Idle
  140. Looking for a 2000 manual swap part list...
  141. OMG LED's are great!
  142. Does ANYONE here have Philips Ultinons?
  143. GAB low-end concerns
  144. Stupid Question RSB
  145. Need Some Advice Cant Find In Search Car Hesitated!
  146. Popular settings for the Illumina struts and everyday driving.
  147. H4 glare shield
  148. Oil + Filter Change for VQ35DE engine
  149. Feels Like I Am Towing Something
  150. is 5th gen clutch soft or do i need a new one?
  151. help - unusually low idle
  152. 2k2 headlight conversion problem
  153. I need to balance my sound...
  154. Trailering/Towing Max
  155. How to adjust e-brake
  156. Carbon Hood vs Stock Hood
  157. where has warpspeed been?
  158. Maf 22680-am600 Is Weak!!!
  159. Exhaust flow... 2000 Auto GLE
  160. clicking noise from clutch & throtle...
  161. Rear section swap/install...no lift...good times
  162. read before commenting Need a link for replacing spark plugs
  163. Intake Hose Connection...
  164. 2001 O2 Sensors
  165. need some help....
  166. Umnitsa HID FOGs installed...WOW
  167. Headers, Install, ???
  168. These Error Codes...
  169. Axxis/PBR Metal Masters vs. Hawk HPS
  170. Too good to be true 5th gen for sale?
  171. Secret Weapon Intake??? Anyone?
  172. Benefits of Oil and Tranny cooler
  173. tokico illumina shock and strut new boots
  174. Airbag system on a 5th gen?!
  175. ebay projector headlights for 02-03 folks got a few questions
  176. FrankenCar Cold Air Intake System
  177. add this to the quick reference...
  178. good read on oil.
  179. Need Brake Pads and rotors,any Suggestion?
  180. 00 Cali EGR
  181. Timing Advance
  182. HID Head Light Adjustments
  183. help help help.
  184. New TWM 2nd Gen Maxima Shift Adapter
  185. Redlinemax.com-5th gen bumper, So Flexible
  186. People with Momo Ebrakes, Come in pls.
  187. A Present From Me To You
  188. Did some test drives...still love my Max!!
  189. Where to buy OEM Splash Guards for Maxima?
  190. What will happen if...?
  191. Header fitment
  192. HVAC bulbs ?
  193. Brakes viberate in reverse
  194. The Dealer Can Bite Me New TB
  195. Considering buying a 2k2 SE...but it has a couple problems
  196. P1320-Ignition Signal, what would be the cause
  197. JET V MOdule verses SAFC2
  198. where can I get a key and key fob for cheap?
  199. Cattman Y-Pipe News
  200. Wtf: Brake Failure Obo-74,000
  201. ECU Update...?
  202. squeeky windows
  203. Updated pics (56k, just get DSL already!)
  204. Brembo distributors
  205. 2001 Headlights
  206. 2001 Wind Noise TSB confusion
  207. Leather covers!
  208. Anyone w/exp on tranny coolers???
  209. Weird smell coming from the a/c
  210. black leather/vinyl match for 02-03??
  211. Stock OEM rotor?
  212. Does anyone know what kind of steering fluid 5.5 gens use?
  213. Slipping clutch.
  214. To keep or not to keep?
  215. Problem with AC
  216. shifter bushing heaven
  217. Help with HID bulb replacement
  218. Apexi SAFC
  219. Started Getting Some Buzzing......
  220. ported intake manifold
  221. For you guys who haven't auto-x'd your 5th gen...
  222. Nismo Front Brake Pads
  223. Some Help
  224. P1065-ECM Power Supply Circuit...help needed
  225. $155 for custom piping ??
  226. polarg dome bulb?
  227. addition of headers??????
  228. Torque Steer or Bad Motor Mount
  229. HELP ME PLZ!!! ...Slipping 2000 Tranny...
  230. JWT Filter-does it hook up right?
  231. Brembo Crossed drilled & slotted rotor's
  232. Headers/Catback or Coilovers First?
  233. synthetic Brushed Aluminum verus real aluminum dash kits
  234. White Headlight Housing??
  235. quick vias question
  236. Any 5gen have just Stillen front and rear lip?
  237. Own a light colored Max? Step inside please...
  238. Battery Leakage Causing Rusting
  239. g35 sedan muffler on a maxima?
  240. my car wants to stall
  241. MAF Sensor Instructions...?
  242. Replace MonsterFlow Air Filter?
  243. How to replace MAF sensor
  244. Alignment Question
  245. Stillen intake?
  246. P0171 - How do I fix this??
  247. 03 Brakes?
  248. Would these wheels look good
  249. Custom Fit Car Cover!
  250. Thought You Guys Might Enjoy
