- Installing cattman headers, need some help
- squeaky blower motor
- Fog light mod
- OBDII Port Relocation?
- Urgent - Help finding paint !!!!
- Suspension squeaking sound or birds in the trunk
- 2002 Bose Stereo
- will a 6th gen maf sensor fit a 5.5??
- Am I the only one this stuff happens to?
- rear window switch lights dont light up..?
- KYB GR2 - Stock springs not sitting properly...
- Doors, Help ! WHAT THE HELL
- How do YOU clean your cai filter?
- Didn't pass inspection - Car not ready for testing??
- Day after the blizzard........ Codes
- Been a while
- Price of Clutch Job
- Finally Fixed power lock rear defrost trunk
- climate control question?
- Will this O2 sensor work?
- Body Damage! How much would it cost
- 5.5 Gen Part Removal Assistance
- 2002 6MT - Popping out of 6th gear
- Replacing rear valvecover....
- help me diagnose my tranny
- Sold my 6th Gen Maxima and bought a 5.5gen
- Ebay Coils? sounds convincing
- Can I put M3 Hid ballasts into my 03 maxima?
- A/c Control lights
- NEW TO THE FORUM....WHAT DO U GUYS THINK!!!!!
- 2002 AT No Reverse
- Post up your snow pics!!
- TIRE WEAR CONCERN!!
- Intake Spacer Question
- another wrecked maxima (planning a come back)
- Frankencar catback 2003 maxima
- Help with Camshaft Position Sensor
- just my luck!
- WHERE THE HECK IS THE ECU LOCATED on a 2001 Maxima SE??
- PCV Valve locations?
- TCS off/SES/SLIP all on....
- Does bigger rims means bigger brakes?
- Cold Weather Question about coilovers (A33)
- Clutch Fluid Leaking
- "I'm Back" Advice?
- your intake id size.. some quick ?s
- will o2 sim or spark plug fouler fix codes P0138 & P1146
- 02 problem with fan for ac / heat need advice
- rasp RAsp RASSPP!!!!
- c8 coilover taking one for the team
- Driver side FOG and CORNER light. Not working.
- "03" 6spd tranny..bad diff bearing.
- Clicking noise after transmission fluid change
- bent control arm?
- ABS Codes and basic trouble shooting
- 5th Gen - Exhaust System Diagram
- ABS Sensor
- hows this dash kit?
- Heated Cloth Seats
- nissan bose integration adapter
- I need a ECU for 2001 Maxima SE anyone have one?
- Custom Maxima 2.5" single tip cat-back review
- need a parts list for a manual swap!!
- Speedometer Pinion question
- Drivers seat mod..
- 225/60r16 Tires work with 2001 i30
- Need new key(s)
- Extending 02 length?
- Did my belts and Idler pulley today: Some Observations
- Idiot rubs against my max!
- Middle of doing belts.... Need Help
- Using SSIM on current setup?
- climate control issue memory loss
- Is driving my car without the A/C belt harmful to my car?
- Car Involved in Accident (Pics Included)
- Ebay find: All weather floor mats
- Actual bulb size for 02-03 low beams?
- replacement hid
- Wanting 260whp...
- Throttle body cleaning help
- Catalytic Converter Gasket question
- Huge engine clunk and other maintenance questions
- Where to buy Philips 85126+ D2R bulb?
- Replacing control arm
- cruise control blinking in my 5.5
- Help with bodywork
- Towing capacity?
- Need Help, 02 Sensor Wiring Diagram color codes
- Moved into a 5th Gen. Titanium Edition :-)
- Tranny flush or no?
- I have a sewing machine under my hood...
- Tokico illumina rear adjustment
- Tranny sound!!
- Alternate Torque Damper Kit?
- SES cleared on its own??? wth?
- heater problem
- Other B-Pipe options?
- FSTB: Where to buy one?
- Cattman out of stock, now what?
- OE alarm issues
- Blower motor resistor?
- HID kit messes up radio..
- Help please!
- 5.5 Gen Bi-Xenon HID Projector Retrofit
- RS6F51H vs RS6F52H Transmission
- 2000 Maxima odd symptoms described. Can anyone help?
- engine clicking noise coming from this part. what is it??? pic attached
- Warpspeed test pipe in an otherwise stock exhaust-sound clip
- coolent problems please step inside
- Reverse Lights Don't Work
- Little help from my Friends?
- 2002 I35, O2 sensor location question
- HELP 3RD ALTINATOR IN 6 MNTHS
- Just drop it
- Badgeless Grille On Ebay- 02-03 Type
- Power Steering leak help
- Pretension Sensor
- Crankshaft Position Sensor (p1336) - Car driving rough...?
- Service questions on 01 GLE
- New Lower Control Arm Install Question
- 3.5 Sterling Silver Window Tinting?
- The Murder of a 2k2 MAF Sensor v.Exposed!
- What happened to the search function
- How hard is it to remove the headlight assembly?
- Trac Slip ABS Light On Constantly
- What would you like to see NWP do next for the 5th Gen?
- Energy Suspension bushings LCA part #
- Dash lights, license plate lights don't work..
- Stock airbox
- 5.5 Stock Air Box
- Altima vs Maxima Half Shaft size/fitment
- Energy Motor Mount inserts help!
- Replaced fuel pump assembly ... now car wont start?
- P0158 code
- Custom audio install in trunk w/ pics
- car dies on me while driving, help!!!
- Headers search help
- Fuel Pump Assembly from 03 works on a 00?
- auto climate control problem
- gas mileage
- Vias delete plus Injen cai=bad??
- URGENT HELP!
- My new 20mm wheels spacers
- Electrical Mystery.. Battery?
- Not hating on nwp vias delete.... but..
- fog light ????s
- abs sensor insanity
- Exhaust Replacement Eminent...
- ECU Question
- Should I worry about ANOTHER bad maf?
- ABS Codes? Anybody have the table/chart?
- Diecast model of maxima??
- Air conditioning problem
- Throwing code P0462, researched, but I have a few questions
- Verification that MAF is Blown
- ***Cost to replace front CV axles
- Ebay Housings...Which HID's?
- New Setup. BBK and 19's what a dream
- usb port how-to
- Turn signals do not work after Bose to aftermakret swap
- Front end clunking over rough/broken pavement - Solution
- "Trip" botton does not work after Bose to aftermarket swap
- What are the signs of a failing Starter?
- Newest product from Blue Bat
- help Adjusting the Camber on 95 maxima.
- Farewell 01 Maxima and Mods..Thank You
- Transmission Filter Problems
- Bad start to Thanksgiving yesterday - first crash.
- Struts
- No will power = horsepower?
- brake calipers seized
- Idle Speed after getting a new Throttle Body
- Happy Thanksgiving to all 5G Maxima owners
- Black Friday 20% off AutoParts
- Tire fitment question Quick
- Need help: What is this part?
- 5th Gen Tech Question
- ? FOr yous fitment/wheel/offset gurus
- Need a how to on removing calipers
- 01 VQ 3.0 DE-K oil leak
- Odometer light
- CV Axle Nut Breakage-Almost caused an accident.
- Need help with battery terminal
- Just bought a 2001 MAXIMA SE wont idle when cold unles..................HELP PLEASE
- Exhaust and Brake caliper
- clunky noise.. Help
- Speedometer Sticks Sometimes
- Rear Defroster Wire
- Thinkin bout buying a 2000 maxi 5spd
- Only the right hand side of my A/C Lights are on
- E-brake problem????
- NWP Spacers Re-use Review
- Will I make it home...
- OEM Foglight kit
- *NEW OWNER* Where can I find a nav CD for an 02?
- Hood Supports - Strongarm struts
- Engine Replacement?
- Exhaust Suggestion
- 2k2 to 2k1 MAF swap with pictures
- Think I'm gonna take the Eibach Springs out
- Will a stock navi fit a non navi from factory max??
- Productive day v. precats and test pipe
- I am thinking of buying a 2002 SE
- i need Help quick hurry plz any ideas?
- P0140/P0160 w/Headers+O2sim
- UTEC Installed
- When changing belts...
- Weird Knocking/Clicking Over Bumps
- Who has double din with bose?? help please
- New Bushing Links advice
- Tranny Swap Problem!!! Need help ASAP
- Polarg M-6 for reverse lights
- AT light flashes and output shaft speed sensor code??
- I know I'm probably going to get blasted for this, but...
- Brake problems
- Umnitza reviews
- Trunk mat
- headlight help needed - dust covers same?
- has anyone used this muffler???
- Light smoke coming from engine and smell of burning water or coolant.
- fog light problem
- 2000 and 2001 Transmission Differences
- Downhill Lag?
- added 2 cans fuel injector cleaner - got 2 codes
- fog rewire ?
- So I can't afford a CF hood, so this is what I did.
- Oil consumption problem
- water gathering behind B Pillar?
- maf
- Exhuast fitment
- Installed new ignition tumbler... car wont start! Help?
- Am I missing Fuses?
- Knocking sound
- 4DSC decal on your 5th Gen
- Gauges acting funny
- automatic climate control
- How to fix heated seats TUTORIAL
- How to remove the seat airbag w/o ruining the seat?
- Ralco RZ STS instructions?
- maf, o2 sensor, and gear 1 and 2 ratio
- WTB: VQ35DE or VQ30DE-K motor
- DexronVI no good for JATCO auto
- E/S motor Mount bushings
- help to disable keyless entry/trunk?
- Rear brake calipers siezed?
- Dash light problem
- Brake Bias and the 6th Gen BBK
- Lightened Flywheel - Idle Speed
- Any "quick fixes" for a rusted radiator support?
- Cosmo UDP Belt Size???
