PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Bluetooth with Factory Bose radio
  2. Help with hanging part on 2000 Nissan Maxima
  3. Misfire advice
  4. ABS Actuator replacement
  5. Desprate help, Emission problem. 2000 Gle cali spec
  6. Good deal?
  7. Replaced Axles Countless Times
  8. Mass Air Flow----Multiple Misfire ? ?
  9. My AE restore
  10. Anybody use these bushings?
  11. Famous P0445 and P1448 - I tried but I need some advice
  12. Power Steering Hose replaced. Car makes whining noise now.
  13. Electrical problems
  14. are the rear brake calpiers all the same?
  15. Throttle response question
  16. P0420 or P0158 & P0159
  17. Help with the part in the picture and its impact
  18. High pressure power steering flare but stripped
  19. Code P0420?
  20. How many o2 sensors on 5.5 gen Maxima (2002)
  21. Advice on replacing catalytic converters
  22. Custom rear bumper
  23. HID Bulb Installation
  24. Gutted or Non Gutted what is more valuable for selling
  25. P0217 Code, all coolant Gone and car won't start.
  26. coil spring isolators?
  27. Need parts help, exhuast +
  28. 5.5 generation mods
  29. SES light with 4 codes
  30. What struts and springs do you recommend?
  31. 2002 maxima se issues
  32. Rear bagged coilovers
  33. Rough start (takes multiple cranks)
  34. for 2k2 2k3 owners, if you need a new MAF...
  35. Another one bites the dust
  36. Aftermarket Radios!!!
  37. Mobil 1 0W40 is some good stuff
  38. GAB - Great Results
  39. Dimmer Switch Doesn't Work?
  40. Grinding/scraping/servo motor noise after switching ignition off?
  41. Moisture in Headlight
  42. Weird sound and bumping, when idle
  43. Growling under load
  44. 4AT Electric mount question - Seeing engine movement while shifting at idle
  45. New Wheel Bearings Suppose To Be Like This?
  46. How do I know if my wheel bearing is bad or if it's both my bearing and hub?
  47. Belt problem?
  48. A/C compressor cycling in our cars
  49. Crossthreaded lug nut
  50. Midpipe creation or buying midpipe for jwt pop charger
  51. Steering issue 02 GLE
  52. Need some help with heated seat wiring.
  53. What are the connectors by the auto trans dipstick?
  54. bad tranny or getting ripped off?
  55. Rusted Lower Rad Support-Daughter Says Car Goes
  56. Automatic tranny upgrades
  57. Oil Light Flickering???? :confused:
  58. Should I get rid of my Maxima 2000 SE
  59. How do i install a line output converter?? 02 GLE w/Bose
  60. Looks like Power steering under carpet 02 Max
  61. 2000 maxima ECM / ECU programming for keys / immobilizer
  62. Upgrading Radio, question about Steering Controls
  63. Anniversary Edition Floor Mats?
  64. Rear door lock problem
  65. Power Window Failure: Need Guidance
  66. Good Maxima?
  67. Gas Gauge Reads Full 90% Of The Time
  68. Seafoam Over Advanced My Timing?!!
  69. Fuse question
  70. 5.5 Maxima 6 spd or 2003 g35 sedan
  71. A few questions about a 2001 Maxima SE..
  72. Tensioner pulley washer loose
  73. ae shift knob install
  74. Does Resetting Your ECU Reset MPG,Radio settings ect?
  75. 2003 i35 bad alternator
  76. LH headlight working intermittently - DRL issue?
  77. Transmission Filter ?
  78. Nissan Maxima QX 2000 model parts
  79. upgrading injectors
  80. Code P1130
  81. P0400 won't go off
  82. hose issues.
  83. Oh... oh I messed up
  84. It's alive
  85. Engine making a knocking noise
  86. Wierd clicking noise at startup
  87. parts websites
  88. The story of my beloved Maxima - Long Read
  89. OEM HID Headlight
  90. 2000 MAXIMA NO START with a 2000 ECU , but starts with a 2001 ECU
  91. Replaced passenger air bag module
  92. Radiator fans?
  93. appearance valve cover trim
  94. A33 3.0 V6 rpm problem
  95. Interior Fan not Working
  96. Engine Ping under light load 02 Max
  97. Maxima Front end conversion on 02 I35 Complete!!
  98. Interior differences 2002
  99. Front drivers wheel shakes when making right turns.
  100. Front End Vibration
  101. Slow Top End? (6spd)
  102. intake upgrage
  103. Air/Fuel rich.
  104. ECM diagram
  105. P0455 p0440
  106. New CV axles
  107. Rivets for splash guard
  108. help please
  109. modification suggestions
  110. Thanks Forum Members
  111. 2002 Maxima - How hard should I have to push to get driver side axle in?
  112. Passenger headlight goes out after a a few moments.
  113. Exhaust / Muffler Noise Choice
  114. I met a LEGEND on my birthday
  115. 2002 Nissan Maxima high flow cat help!
  116. Transmission questions
  117. Replacement CV Axle doesn't have cap that covers seal. Is this OK? (pics included)
  118. P0430-Fix or Say goodbye to Max
  119. Whining when turning wheel and accelerating
  120. Would you buy a 5.5 Gen?
  121. 03 3.5 clutch pedal
  122. Which In Tank Fuel Pump to buy?
  123. Resale value WTF?
  124. Share your wheels setup!
  125. Clips For the Trunk?
  126. Rear wheel hub bearing
  127. Exhaust Question 2002 Max
  128. Power steering pump?
  129. Is this mechanic taking me for a ride?
  130. A/C bearings going, better to self-replace or pay?
  131. Just Purchased
  132. Head Gasket Job----how much would you pay?
  133. Amp/Speakers to Replace Stock BOSE
  134. Replacing struts on 01 Maxima
  135. A big ol' wtf is that!?!
  136. strut bar on 2003 maxima
  137. 2000 maxima overheating
  138. Steering Wheel Removal
  139. Climate control and headlights??
  140. 2000 Maxima - ECM Fuse Keeps Blowing
  141. Front driver side noise. Bad axle? (Video included)
  142. Engine cranks but will not start 2001 Maxima
  143. Sticking e-brake
  144. MaxLife ATF
  145. My latest 2003 Maxima
  146. Code p0300?
  147. Leak Down Test---Is this Right ?
  148. rear bumper replacement
  149. Lower control arm
  150. Power Steering
  151. pre cat gut
  152. New 5.5 gen owner need some oil and exhaust advice
  153. 02 GLE Climate Control Problem
  154. 3 Windows Not Working -- Please Help!
  155. Evans Water Coolant?
  156. correct tire pressure
  157. Maf??
  158. no clutch pettle!
  159. Advice on transmisson prob 00 maxima
  160. Headers for a 5.5th gen really harder to find nowadays?
  161. Brand new fuel pump doesn't pump??!!
  162. Anyone ever swap a g35 sedan exhaust......
  163. Steering Issue
  164. finally bought a 5.5 gen
  165. Just had my PS pressure hose replaced...
  166. Red Bulbs or Red LEDs? (Aftermarket Taillights)
  167. Diagnosing alternator issue. Narrowed it down to a few causes but really need help.
  168. looking for a quiet muffler
  169. Possible CV failure?
  170. AC Charge-2003 Max
  171. strange electrical issues SECU?
  172. Shifting the car, is this just me?
  173. Spec V tranny
  174. 01 Maxima shifting problem
  175. 2002 6pd Maxima on Craigslist: Is it worth it?
  176. Location of reverse (back up) light fuse?
  177. 2003 Maxima rear ended someone, hood won't close fully
  178. Dreaded White Smoke ...(help) !
  179. Buy Bose subwoofer
  180. Will this SECU work with this key fob?
  181. thermal intake spacers car wont stay on after install
  182. Can someone Tell me what this is?
  183. Low brake fluid
  184. Intake manifold question
  185. Joining the 5th GEN with a 2000 MT
  186. Alternator getting Weak ? ? ?
  187. Transmission Sensor Part # Help - Error Codes P1574 and P0720
  188. rear sway bar instalation
  189. Rank your performance mods!
  190. Loud squeal, one of my pulleys?
  191. Drivers side window
  192. What's this part, what does it do?
  193. Help----Leak and Overheating ? ? ?
  194. 2001 Nissan Maxima - Tire Replacement
  195. No Air - My Experience with Repair
  196. Climate control question.....
  197. 2002 Maxima Headliner removal
  198. Clutch question
  199. Overheating issues
  200. Got a weird headlight set up on my new Max....
  201. My "not so ghetto" airbox mod
  202. I Found a Leak---Drip !
  203. Messed up Front wheel bearing
  204. Looking for a few part/fixes for the 5.5 I just picked up
  205. Slipping / Hitting rev limiter after TransGo kit install
  206. I am finally one of the cool kids........5th Gen purchase
  207. Steering Wheel Hub Adaptor?
  208. Are my es t/a bushings missing the metal clam shell?
  209. CV Axle Repair Question
  210. High idle when hot outside
  211. Overheat
  212. Maxima Lower radiator Support
  213. SES light shows O2 sensor not ready and converter not ready
  214. Hesitation. Slight bog lack of power
  215. Where to find front bumper without lip?
  216. 2002 Maxima Question
  217. 01 Maxima clucking noise
  218. Power sunroof stuck open (tilt)
  219. '02 headlights
  220. Opion on 5 gen
  221. is this the crankshaft sensor
  222. Infiniti I30t: Dash Lights Flickering / Car Won't Start?
  223. Ignition switch off battery light stays on dim
  224. Intake plenum options
  225. Possibly going back to stock. Value of Berk intake for 2000 Max?
  226. Rear Out of Alignment after new rear axel
  227. engine replacement questions
  228. looking for progress rear sway bar
  229. Urgent advice needed on water pump replacement
  230. steering wheel jerk
  231. Violent vibration on WOT (2-3K) + P0455, P1448, P0300
  232. Best exhaust cut out
  233. Blower Motor Results
  234. Speedometer Stops at 25-30 mph
  235. Intermittent misfire when hot at freeway speed?
  236. 2001 GLE automatic improvements
  237. AT Check light
  238. OPINION ---on 5 Gen Maxima's ?
  239. code p0507 idle problem
  240. 2000 I30 Fog Lights
  241. Maxima turns over then dies or doesn't start
  242. Vortech Supercharger Kit
  243. windshield replacement.
  244. performance muffler decisions
  245. Need some help
  246. 2000 fuel gauge
  247. 01 Cruise Control
  248. Alignment
  249. Please help new 01 i30 owner
  250. 2001 Maxima SE 5 speed 102k miles P0420 P0153
