- cattman vs megan? Oh shoot...
- wanted to know
- Weird noise when crusing....help needed
- Engine swap, Won't start, need help...
- The NEW custom GPS ashtray mod (Garmin nuvi)
- Quest Wheels on 5th Gen
- Cattman 3" Catback Exhaust - Order Here!
- G37 Steering Wheel on an I35/Max?
- Anyone ever replace the gasket around the oil pan?
- Curious... has anyone seen my old car?
- Suggestions for trunk mounted bike rack w/ spoiler
- CustomMaxima Performance Headers??
- Chicken bones on top of engine....
- Ultinon's???
- I miss my Maxima
- Front bearing Replacement (Write up, Archives)
- Weid P0505 SEL Experience
- Losing electrical power when starting
- How to remove lights in doors?
- Where to find OEM or Reproduction Anniversary front lip pieces
- Engine noise
- All Aluminum Radiator
- What are the stock headlight bulbs on 2000 Maxima SE?
- How To Replace Air Filter On 2000 Maxima SE
- Starting Issue, 3rd starter in 2 weeks. new alti, please help!
- Wanted 2K2 or 2K3 SE interior Swap
- Hard starting issues
- Car smells like it's on fire.
- The hesitant Maxima
- transponder key failure
- Parking brake problem
- Strange Remote Keyless Entry Issue
- Belt Noise
- Rattling/Shaking Noise in Engine Need Help. . I've Searched
- BOSE sub cuts out
- A couple of new additions to my Maxima
- 5th Gen Forum Updates/Suggestions/Postwhore Thread
- Eibach vs. H&R springs
- Brand new Fogs already cracked!!
- to black out or not
- Good Replacement for OEM Cat?
- Helmholtz Resonator vs Straight MAF-TB Pipe
- Max overheating, need help asap
- Lisence plate LEDs
- How hard is it to swap from autotrans to manual
- Start sound - getting worse
- Supercharger Question
- Immobilizer/ECU problems
- Replacement buttons for nav system on 02 Max
- Sigh.... Rust...Help
- '95-'03 Motor Mount cross-reference...
- Anyone use a drop in AFE Dry Pro air filter?
- strut/shock replacement questions
- 5th Geners with D2s, step inside.
- Spark plugs
- air intake
- maxima led mirrors cover.. ive searched!!!!
- LOW IDLE ON 03 max how do i fix this
- lexus yellow capsule retrofit
- I30 with I35 gate shifter?
- Cattman Performance looking for 00/01 Max y-pipe customers in SoCal...
- 5.5 gen head lights
- HELP ME!!! Question about clutch oil
- help please
- Clicking noise in engine bay
- How Can I Fix My Arm Rest?
- WHAT size rims fit best the 2003 maxima se
- How To Install R34 Body Kit
- Tint Question
- wanting to wire door handle leds (i searched)
- Aftermarket Radiator options
- Audi headlight mod...
- Back in a Maxima I might hold the record!
- Seized caliber?
- No more clear tails for me
- What size belt would I need (AC Compressor)
- Help!! Has anyone ever mounted driver's side brackets on passenger seat???
- Painted Interior Pillars and Accessories Black
- Started to get oxidation in the headlight...time for..
- Oil leak problem
- 3.0 headers/ y-pipe on a 3.5?
- Just Passed 200K miles
- Help! Can't fold down rear seats!
- getting desperate. car stalls at red lights
- Consensus on Intermittant Hard Start Issue
- rear factory 02 sensor wire color sigification(federal)
- window problem
- Need Wire Schematic for 03 seats
- Pioneer unveils NEW products at 2010 CES [Video Coverage]
- Hood won't latch - broken support bracket?
- Transmission lost most of its fluid while on expressway...is the damage already done?
- Engine Oil Change Question
- Need Advise To Install ES Motor Mount Bushing
- Tie rods test
- Car wont start after replacing starter
- I want to overhaul my engine, where should I start
- opinions on 3k HIDs in fogs
- Changing MT fluid...i have a question
- Auto Transmission: Hard to get out of 'Park' sometimes
- lower clutch hose leaking
- Need advice on new Radiator.
- O/D light blinking and more
- DUMP QUESTION!!!!!
- Pros and Cons of Plugging PCV
- Stock stereo w/ passenger speakers cutting in & out
- 03 Airbag control module?
- Anyone know if theres a difference in fogs?????
- Where to shift???
- The other max on the road and potential mods.
- quick question help sidemarkers
- need clutch help
- Changing an engine
- H3 LED Bulbs for your fogs
- brake parts depending on build date
- o2 sim question
- Need peoples help here, bigtime.
- difference between build date parts
- Rear D2 Squeaking ???
- maf or fuel pump
- Good Deal Turns Into A Wheel Project (pics)
- NEW Oem Spoiler
- Deciding on a car.
- CHEAP trim panel clips
- Where can I find a carbon Fiber gauge bezel?
- MT Slipping
- yellow fogs
- The Maf Sensor
- Heater/Air Conditioner Whirring Sound
- Missing ABS...?
- Weather
- 3.5 6 speed swap in 2000 maxima question
- temperature sensor display question
- Passenger Side Cooling Fan Sounds Like A Meat Grinder
- P0303 Code (Cyl. 3 Misfire)
- bad wheel bearing symptoms but not wheel bearing?
- Coilover install going wrong
- HID Ballasts for 30000K bulbs
- what are the best spark plugs 03 100 k miles
- Help with struts
- Trying to lower coilovers
- On-going performance problem with new O2 codes
- Charging-Battery Issue
- Help please
- Lumpy idle sometimes. Any idea what it can be?
- P1320 301 coil wiring
- oil and gas in oil catch can?
- Best sizes for Angel Eyes?
- E-brake doesn't work, help would be appreciated
- My brother backed into my car
- and we strive to make 300hp with a vq35!
- rewiring light by the S/R
- How big is the stock resonator?
- Caliper Slider service
- USA Spec Ipod in 2003 5.5 Gen w/ 6CD
- Heated seat switch bulb replacement?
- rear lisence plate mount??
- My 6-speed reverse gear isnt working right? HELP PLZZZ
- True CAI vs SRI
- rev limiter
- Need help deciding on this repair :) Alternator or AC Comp
- Maxima vs. Bambi
- Car not accelerating
- Please help me!! it's an emergency
- Calibaration of Speedometer after replacement
- Problem with headlights and HID fog lights ('03 TE)
- Question about ABS codes
- What to do???
- Performance Enhancement "Real or Imaginary"
- dash lights
- Anyone ever use UpRev Engine Management?
- '01 head lamp change
- I feel like I'm hearing too much engine.
- Blower motor issue..
- question about wheels
- leaking valve cover
- Gopher/Rat ate cable insulation
- EPIC FAIL
- Wheel Bearing and hub replacement ?s
- Confirm Exhaust Manifold/Header Bolt Sixe
- Please help verify that these parts fit.
- Cold weather whistle sound from passenger side
- Cluth pedal getting hard to push in the cold weather.
- Do 4th Gen Spirng fit a 5th Gen???
- Where should I Idle.
- license plate bracket
- How come my 5th gen sucks at drifting in the snow?
- Dtrl are not coming on...
- P0138 & P0158 O2 Sensor Part Numbers
- Cold Engine/Cold Weather Start Up Issue
- Difference in manual gearbox between 2002 & 2003?
- 2k2 SE 1st Impressions. Advice?
- How much will this cost to get repaired/replaced?
- The scratch on my bumper.
- Walker muffler vs Cattman muffler?
- 6th gen bbk
- I only replaced the valve cover gaskets
- Another maf?????
- Awful night for the Max.
- Re-wiring foglights
- Automatic 4 speed to automatic 5 speed
- Confused about which valve cover is rear
- Y Pipe
- Wats interchangable from my max to I30T
- P0134 Code
- Sudden RPM drop at 1500 RPM - Video Included
- question about repair
- V2 OBX header owners step inside
- 2002 OEM Muffler - EXPOSED!
- VQ30DE-K parts Question
- UMMM What Is this Sprint booster... No delay in throttle response????
- stealership...
- Flowmaster Super 40 or Super 44 muffler
- WTB: aftermarker catback
- abs sensor dilemma
- New Throwout Bearing Grease
- need help!!
- Any issue with Audio control mount
- Speedo Question
- P0113, 2k1 to 2k2 MAF swap, ANNOYING!
- 5th & 5.5th gen Maf adapters
- Heater fan only works on High (#4)
- P0138*&*P0158. Help with buying sensors.
- Will the outside temperature change my tune?
- was it the maf?
- headers problem... Step in
- Help with replacing front wheel bearing...
- Out of Ideas, Transmission 1-2 Flare
- OEM Spoiler Questions
- some tuning and means to read info ? , Nmex you out there
- P0430 code and getting a new cat to fix the problem
- UTEC
- auto transmission- overdrive
- 6MT Owners, Cruising Engine Speed?
- Motor Mounts for an automatic trans vehicle?
- Flip-key fob thread
- i need help picking lowering springs
- Is this dent on the OEM bpipe normal? Pic inside
- '02 4AT Transmission problems, HELP plz. slipping, no OD, etc.
- will a 02 secu work in 01
- Bad MPG after Plug replacement
- "SLIP" and "TSC" lights are both constantly on...
- Does anyone have H&R springs with stock struts?
- Three Concerns about Max! :(
- a few questions.
- well i bought another 5.5 yesterday
- Wideband o2 Question
- 5.5 Gen: Code 455 - Odd fix, tested and confirmed.
- 5.5 Gen Stock Exhaust Issue
- headlight related: removing condensation, HID kits?
