- Looking for a FOB
- kyowa racing wheels
- Anybody got a Stealin intake? What hardware does it use?
- Install Kit for 02 maxima
- Any way to Duplicate Key cheap?
- Annoying noise coming from the back...**soundclip included**
- Engine Block
- Hot long should front axles take to put on
- BBK Brake distances
- am i doing something wrong... is this how its supposed to be? (shifting)
- P1147 & P0139 codes being thrown, need some help
- ABS sensor
- crazey key fob problem
- 5th Gen's for MOTM?
- Battery or Alternator???!!
- power stering belt makes loud squeaking sound when the engine is cold
- Gas tank help.. help me fix my idiotic mistake...
- Codes P0139 and P1148
- for sh*ts and giggles...
- O2 sensors rip-off?
- 5th Gen Produciton Dates
- How to cut bumpstops properly?
- Some s.o.b...
- seat belt mechanism
- 2000 Climate control issue
- Bad starter or alternator?
- Whats your reason for no stillen side skirts?
- Double Din
- To those w/ Clear/Smoke Rear Side Markers
- Clearing Turn signals on 02-03 Headlights
- My Clear Side Marker fell off!!!
- simple Intake question
- Whos the owner
- CHSML HOLE COVER??????
- Difference Between 5 and 5.5 Gen Muffler?
- Need Advice for 5th Gen purchase
- need input on these headlights....
- HID Ballast Location Pic's
- ABS Troubleshooting - How do I get the actuator/control connector off?
- HELP, new noise in front right wheel
- Interior lights, windows, locks, not working...
- For those with Hawk HPS
- Rear springs/struts bad...replace all?
- problems with LED lights
- MAF, O2 sensors replaced but car still sluggish..
- What to expect in repairs
- tein coilovers opinions/pics
- 02-03 aftermarket OEM fog lights questions
- VIAS?
- 2002 Auto Transmission Cooler
- NOISE From my Tokico Blue struts
- Time For Wheels but I need help....
- Steering wheel clunk...
- does anyone have???
- This is a new one !
- Why does my 2000 keep blowing starters
- two body repair questions
- WTB stuff but I keep posting it in the wrong forum
- brake and battery lightstays on...alternator is brand new!!wtf?
- WTB .... IN LONG ISLAND
- Will eibach coilovers used on a 93 accord fit my 2000 maxima?lemee kno asap
- 5 spd swap?
- Brake Pedal too Close to Gas Pedal
- White or Blue LED for the lights on the doors
- Replacing Door Moulding
- Ebay foglight housings
- window tint
- Vehicle Immobilizer System restart??
- Swapping 03 6spd into 00-01 possible?
- New bulbs
- Sunroof opening at random
- Will I like a Gen 5
- Dual Exhaust [photoshop]
- 2000 se steering problem
- Dim SES light
- 3" maf housing
- 02-03 Maxima w/remote XM satelite mounted?
- fog light poll
- Taillight tint..
- Strange Noise - Help Identify
- My Gauges are Complete!
- Completing My Exhaust
- Where I mounted my drop resistor switch
- Anyone using Mobil1 ATF synthetic in their Automatic 5th gen?
- Do i need a NEW clutch and flywheel?
- 01 MAXIMA WITH 3.0 AND 6 SPEED STOCK?
- P0440 Evap Small Leak Code
- quick motor mount question
- Hood Shaking
- emission control information
- How toget wire through fire wall
- Running angel eyes at night
- Where to buy stainless steel fasteners?
- Oil in spark plug tube guys please chime in
- TCS and LSD
- Where can I get this grill?
- Tint on Grey Lustre...
- memory seats on a 2001
- Re: air filter replacement
- alternator issues
- eBAY Grills? New? Opinions wanted.
- HID's are in......a few pix
- guages in km/h???
- Possible valve noise and solution?
- thermostat
- Moisture on Passenger Floor
- 2000 SE Sunroof Issue
- Rotors and Pads
- frankencar
- Wilwood/fastbrakes install
- window switch reset
- car bouncing
- Attempted thief damage
- Rear brake pad question... quick answer?
- 350Z Clutch doesn't bolt up to my 02 SE (Noise)
- MEMORY SEATS ADD ON!??
- Maxspeed strut combo
- Heated Steering Wheel out of wack??
- What is this stuff on the inside of my rim? Oil/grease look to it.
- EVERYTHING you NEED to know about HIDs, projectors, etc!!
- import showdown in Ga....video
- Need help fast....HID wiring problems
- Listening Test
- Need some input please
- I have the 6th gen brakes ... what about SPARE wheel/tire?
- 2002-03 signal light question
- 100,000 MILES AND @ 2 CODES
- VQ35 injector size.
- jackhammer type noise from front passenger side of car...need help ASAP
- would they clear a bbk...
- Advice/Questions on Springs/ Struts
- Annoying squeaking coming from clutch actuator thingy
- Difference in tint %
- Need to do Emissions Testing . . . ?
- electrical issues
- does anyone know...
- Color Matching High Beams and Fog Lights to HIDs
- gauge cluster lens
- Engine Revs Dropping?
- Oil Filters - PureOne, Mobil 1, OEM ?
- wireing low beams and high beams together
- Need some electrical help - Auto door locks and Int. Lights don't work
- nosiy belt tensioner ...
- None of the FAQs seem to be working and I have a question
- Single Disc Bose to 6 Disc Bose
- where to buy parts
- Looking at a 2000 SE auto that needs an engine
- Alarm Help
- speed sensitive clunking from suspension?
- Possible solution to aftermarket HID glare problems
- Will a 5th gen intake fit a 5.5 gen Maxima?
- Sound deaden trunk to reduce exhaust noise?
- Which head is bank 2?
- Stock nissan HID temp?
- 00-01 fog lights on a 02-03?
- squeaking sound from the front please help :(
- Bypassing the A/C compressor
- The maxima is gone, thanks all
- transmission swap
- From H&Rs to Htechs. Heres my review
- Air Bag light Flashes every second while driving
- car dies when idelling...HELP.....
- Recommended Clutch and Flywheel
- Best place to order OEM Brake pads?
- something i noticed
- Lexus Style Fog Lights
- Fail-Safe MODE...ANyone ?
- It's partytime! Bar table in the Max.
- I had an accident with my maxy :( (pics inside)
- Slow Timing
- Gas Filler neck Pitted? Cause SES
- end link options
- Getting New Suspension..Camber?
- Dead battery that shouldn't have been.
- Shifter bushing
- YAY or NAY
- Berk intake
- advanced timing
- Cabin Air Intake
- Problems with all links
- spark plug part #
- Hard Shifting after Highway Driving
- Car dies upon startup
- Suggestions on Matching Running Lights to stock HIDs
- best/smooth struts for 01
- Problem with OEM Hid's
- Someone please help me...
- 00-01 Clutch life and replacement recommendations
- About to buy an 03, but have some questions
- those who have had eye lids on their headlights + hids, quick question
- battery light goes on and off...then everthing dies
- Cars sounds like its Rubbing on Stock Suspension / Rims
- Need good pics of OEM HIDs beam pattern
- 01 SE Bottoming out with a moderate load
- Quicker cure 4 check engine light!
- 2000 exhaust
- HID bulbs: where to buy?
- Newbs....READ THIS BEFORE YOUR FIRST POST!!!
- Removing REAR Sidemarkers
- fstb torque
- Newbie here with question about black tail compatability on 02
- E-Brake Noise
- Annoying tick within engine
- Just got my new valve covers (pic)
- anyone looking for a 3.5 act flywheel check this
- Do I need this piece? (Underbody)
- SES light comes on ONLY in certain conditions...HELP v.EVAP
- Need suggestions
- Ecu pinout diagram?
- radar detector
- Max won't stay idle.
- Replacing axles (CV issue)...what else to do
- Installed Hawk HPS brake pads and resurfaced front rotors.
- Where can I get lips for all sides for my 02 Maxi?
- My maxima is totaled!! Pics inside.
- Retro-Fit Fogs to HID's
- ABS self diagnosis
- Tail Relay for LED Replacement Bulbs?
- Clutch..& so POP POP
- CV boot protector
- Weird radio problem (Bose)
- car shaking on idle, SES light blinking...help please
- Fuel Pump control module: where is it?
- Rotora Rotors
- SES light
- plz help on rewire a 5 gen headlight to a 5.5 gen headlight~
- Removing epoxy?
- 2K2 feels like it's about to fall apart..
- 2000 -2001 MAF New part number
- Thoughts on Akebono brake pads
- Does anybody know this grill
- 2000 se gas smell
- 2003 Nissan Repair/Service Manual
- Humming Resonating Sound
- Rear wheel bearings bad?
- Steering wheel shakes while breaking
- clutch pedal to the floor :(
- How much to replace front axle on 2000 SE?
- Wilwood calipers: use the red ones they sent me?
- Ebay angle eye help!
- Wheel Studs the same for front and rear?
- P0455 -- EVAP large leak detected
- 4th gen suspension to fit onto 5th gen?
- will front bumper from 2002 or 03 fit 2001 maxima
- Video + exhaust sound clip and etc..
- Need to replace speed sensor but cant find it!
- 03 navigation in a 00 max????
- LE BRA
- Chrome Exhaust Trim - where to get?
- replaced the lights on the door with led's but have a little problem need help
