- 2002 Nissan Maxima Rear Camber
- wheel bearing problems
- Suspension problems
- ABS Issue
- Clutch Replacement: Dealer says / Need input
- 5th Gen Non-Bose Base Head Unit AUX Input Mod...?
- Cattman headers
- Code p0400
- I'm Looking For All 4 Grey/Gray Window Bezels
- Maxima Headlight lid
- High pressure power steering line
- Headers!
- Ebay Front Catalytic Converter Question
- 5.5 Gen Tail Light Project
- Might be trading in my 2000 SE soon and want some opinions.
- Do not use AutoEcu!
- P0152 sensor 1, bank 2 circuit high voltage
- Fog light, Side marker, Trunk light don't work
- My 01' Headlights Retrofitted
- HELP!!! 03 maxima sounds like an 83 diesel mercedes!
- New short block installed, still having timing issue?
- Towing.
- Injen CAI worth the price?
- 2000 Nissan Maxima - Bank 1 and 2 Error Codes - California
- Differences in suspension between 2003 SE and GLE models (winter tire related)
- Precat removal (please don't flame)
- 02 maxima engine passanger side noise solved
- nut size?
- Question about my sisters 2004 3.5 altima
- Multiple Codes only on Highway
- b+ ring connector on alternator
- Power Window Problem
- Any good black friday toolset deals for newbs?
- Exhaust question I swear I'm not a ricer
- 2000 SE rear springs softer than 2000 Infiniti I30t springs?
- DRL Module same on 5 and 5.5??
- Ultra Racing Frame Stabilizing Products for A33?
- RTH: Alternator Noise when Turning by hand?
- 03 Max with P1448 code
- Rusted windshield frame
- P1320 again!!! After 3 month-- replaced Nissan OEM coils and NGK plugs
- 11.5 Years. Sad Day for me.
- Alternator Fire! Help!
- Running hot
- Cluster illumination issue
- Power loss over 3500 RPM
- Keep or Sell?
- AT clunk when shifting into D (or R), car stationary
- Where to mount an aftermarket GPS antenna?
- Washer nozzle is like a firehose.
- Whining engine
- Maxima 2002 Magnaflow exhaust system
- Got robbed for my wheels on the wrong car lastnight lol.
- Stock muffler with other exhaust mods/work?
- Rear Ignition Coil Access
- The most tough 5th gen radiator support EVER
- Need Exhaust (Y-Pipe) Advice
- downstream o2 sensors
- Replacement Jacking tools needed
- Motul 75w-85 gear oil
- Where do I go from here?
- Huge water leak under passenger dashboard
- Key Fobs won't program...?????
- 01 Max 20th AE Engine Troubles
- C1106???
- ....lost
- p0141
- What is recall R1302
- P0430 People Who have Replaced Cat
- Dash Instrument and Tail Lights are out, Please Help
- OEM '01 SE wheels
- Driver side window does not roll up
- 2000 Maxima Engine Swaps??
- Obx individual throttle bodys
- Grinding noise at shift points
- Keep blowing fuses and rear door will not open
- Still have two questions about struts and rust
- Front grille mod?
- Neutral Safety Switch or??? 2001 Maxima
- Help me, I did something stupid I think (Batt/Alt change)
- Electric cutout.
- radio install help
- Need help with starter problems.
- 2002 Maxima Warm Start almost stalls every time
- Newly purchased GLE - few questions
- will 5th gen mats fit in my 4th gen?
- 03 maxima 6mt wont start
- p0320 and engine misfire still AFTER replacing all 6 coils & spark plugs
- Is an Oil Drain Plug Gasket really nessesary?
- New motor or rebuild my current one?
- ballast replacement
- leaking power steering pump?
- thank you .org - oil cooler gasket(s) replaced
- pnp switch location on 01 5 speed tranny??
- Options for 5.5 gen Engine Swap
- Alternator issue
- What do you guys think I should do next?
- 5spd swap crank no start...
- Intake Swap
- Vafc2 setting
- Check engine light not showing on dash and 5 OBD2 codes.
- Heated seats/emergency brake problems
- PITFA MM bolt
- Opinions if i can win this race?????
- Stalling After Running
- What can cause the SES not to work?
- an other coolant problem if someone could please help.
- Steering and cold weather
- 02-03 steering wheel in 2000
- What gauge should i use to know when i need to top up oil?
- need help with this wiring ASAP please!
- glove box light.....help
- VQ engine cover emblem wrinkles
- Climate Control LCD Dimmer Wire
- Gas consumption question
- Burger delete?
- Help
- Radiator drain and fill
- bubbles in coolant overflow tank.
- 2003 engine rattle on shut down
- 03 Maxima, hot start problem
- Crazy electrical and feature mods; possible?
- 03 SE A/T threw P0042 - not in FSM and not on .org
- simulate key in ignition
- Climate control lights
- Climate Control Lights - Off
- intake plenum bracket missing. needed?
- Headlight Wiring Halos
- Cattman
- 03 occasional cold sart problem
- Battery Recommendations
- Question regarding ABS sensors
- Exedy & Fidanza VS JWT clutch and flywheel
- Difference between O2 Sim & Non-Fouler
- ECM remanufacturing questions
- IVAC / stepper motor question
- 5.5 gen with P0211 code and NO START
- gas mileage question
- Poor gas mileage after Non-Fouler install
- ABS light == NATS malfunction?
- Recirculation Button Climate Control Intake Door
- Oxygen sensor ... Dang ...
- Starter issues?
- Stall & restart problem
- headlight trouble
- 5th Gen Starting Problem
- Replaced thermostat today, seems to have resolved overheating problem.
- Oil pan leak
- You guys use www.autovin.de ?
- Alternator Bracket
- Power windows don't work
- stock vs. y pipe
- Squuf squuf squuf from the front: Any guesses?
- Keyless entry remote question HELP PLEASE GUYS?!
- STA509A- solder it myself questions
- Maximum width of tire for a 16x6.5
- How many miles
- 2002 5.5 Gen No Start - Dead TB?
- How to fix a shortage in the license plate light?
- Fail Safe Mode
- Rebuild or replace transmission?
- 2003 Nissan Maxima misfire
- P0430 replace pre-cat or install main cat
- 2001 Maxima worth fixing?
- 2000 coils fit 2001AE?
- sourcing a new engine
- Advice on this engine noise. Background info and audio clip included.
- Improving handling and steering for $600
- High ressure PS hose help
- Fluctuating Temp Gauge. Car Shutting Off. Scary Swerve. 3 Issues after major work.
- well i bit the bullet and got the maxima...
- Dora2012
- Keyless Entry Programming Issue
- 2003 maxima steering rack bushings replacement?
- what Racing steering wheel+hub combo?
- Dim Headlight
- 02 5.5 gen non bose radio right side channel not working no sound
- Metal Shavings; Paranoid or is a serious problem in my [near] future?
- The recall has it!
- New Member with a couple questions
- 2001 maxima idle problem please help
- VIDEO: possible engine knock? please watch
- Replacing with loaded struts
- Soft brake pedal at stop
- 2003 Se Exhaust
- Transmission Question
- headers questions
- VQ35HR fuel injectors
- 5th Gen Maxima Evap Canister and Valve
- How to fix sagging door in 10 minutes.
- Violent shaking and noise with cold starts
- loss of coolant?
- High pitch whine throttle body sensor
- 2000 SE - tightening Power Steering Belt - HELP!!!
- Help With Bulb Size
- Unsolved Issues with my Maxima.
- O2 sensors/cat questions
- Shift solenoid valve A/T
- ICU imobilized if detached?
- car wont start, what to check besides the starter?
- Bad cats... best place to buy OBX headers
- oil to top of dispstich- head gasket?
- What is this rear suspension part called?
- How much would you pay for a 2001 SE 5 speed?
- Fast Left Turn Blinker - 2001 Maxima
- my car wont shift into any gears
- Xmission ATF hose for ATF fluid change
- Possible c/v axle problem??! Help!
- ECU- Choosing right one from junkyard
- rear brakes clunking
- Headers from Sparktec?
- Serpentine belt not aligning properly
- Shock Sensor on Stock alarm on 03 Maxima
- Help with P0447
- Need some help please. Stock side skirt exact measurement
- Headache with Rear Brake Calipers (Both Sides)
- 5.5 gen synchro cost
- Sensen struts input
- Bad relay flasher or bad ground?
- Stagg ShS struts
- DRL Module Inspection
- 00 Maxima Immobilizer/Check engine issue?
- Do I35 rearseats/b pillars fit?
- Does anyone know mattblehmco?
- Cat confusion for California-spec Max?
- Dave Burnett
- Help
- Idle problem and noise from manifold
- I will pay top dollar for someone to solder my LED's
- Need help From guys who did the fog lights HID conversion
- Alternator or Battery?
- Fail safe at WOT
- Got new shocks now there is a squeal when turning right
- Motor mounts help
- precat problem
- Need help BOSE or Non BOSE Head unit?
- Cylinder wall has a black vertical line
- Shift Bezel Repaint???
- New Engine???
- Clutch Noise and sticking pedal or Adventures in amatuer car repair
- For those Car Gauge Pro users
- Hot start issue, hour cool down and it is fine
- 300zx calipers on 2002 maxima
- possible coils go bad at 1 after another?
- which cyls lean out first on vq30 +N2o?
- Slow acceleration, Poor Gas Mileage & Light vibration when idle
- Reverse Light bypass, or other option?
- 03 maxima 6 speed tranny
- P0455 just what I need
- ? Regarding 5.5 motor mounts
