- Tightening Front Bumper
- 2K alternator bad!
- Want to clarify
- Tired of saggy spare tire covers? Step inside
- Metal on metal sound on startup?
- Looking into grill options
- O2 sensor P0138 and P0140 ECU flash
- Blehmco Big brake kit questions
- help with electrical problem.
- P0011- Should I be concerned??
- quik question... bout intake
- LTB question
- Need help installing SS clutch line
- Tein SS Drop.......PICTURES INSIDE
- Starter replacement
- AT leak
- 2k2 hid problem
- Does anyone make a stiffer FRONT sway bar?
- Theft
- New Header + Stock exhaust clip *calling puppetmaster*
- XM subscribers step inside.
- steering wheel vibration after putting on 20's....why?
- LSD in an 01 non-AE?
- got rear ended...
- o2 simulator voltage question
- 5.5->6Gen BBK line question
- Anybody use Energy Suspension Polyurethane bump stops?
- Eibach Springs Installed Pics/Initial Review inside!
- 5.5max sounds like it has air coming into the cabin at hwy speeds
- Engine Signal wire? Where can I find it?
- No more bottoming out with H&R.
- Tein SS installed...
- 2003 SE vs 2005 SL handling
- Quick question about top speed
- Dealer take ??
- Something hitting the floorboards from underneath
- Anyone else's MPG guage way off???
- 5.5 Gen Muffler Question
- Engine Guru's Help!
- Need Help with spring install pics inside
- Running low beams with High
- anyone have a stillen lip with ae sides?
- Bose/Radio issues
- has anyone tried these replacement headlights?
- Oil change and ABS light
- MAF dying today... :(
- wtf....
- When to do a flush vs. a fluid change?
- Catch Can...does it make a hissing noise?
- Place Racing + Hybrid CAI - nice results
- Exhaust leak threads
- any help please..with gearshift
- drove a 5.5gen 6spd today......
- 5th gen on ebay... see a problem?
- SES Light - HELP please!
- Sea Foamed -> white smoke/deposit -> orange deposit
- is my slave cylinder broke?
- H4 bulbs in foglight??
- need to confirm a few thing about suspension
- Transmission Pan, Help Immediatly
- 2000 maxima top speed
- spark plug question
- Removing Rear Struts/Springs
- Exhaust tips w/o cutting stock exhaust
- Brake bleeding procedure?
- SES after car was on lift... twice
- '02 Base model SE 6MT ???
- "performance" alignment?
- New Tail lights?
- Oil found on tip of spark plug...
- To ANYONE who has non-installed aftermarket springs...step in
- Question On Codes/Check Engine
- An update after 15K miles with new brakes :(
- Clutch & flywheel question
- o2 sim problem
- Is it drive skills: '01 GXE 5-spd vs. Infinity G35?
- Flywheel position sensor
- problem,,,please help!!!
- frikin brakes again
- Sporatic Brake light
- Tinting Sunroof
- Oil leak in the spark plugs...
- rear brake light
- 5spd vq35de
- 2000 gle turning off
- anyone seen 300zx wheels on 5th gen?
- Need help choosing springs
- Are you using alignment kit w/ your lowering springs?
- Got Brake Fade Today need some info
- Cutting Bumpstops does this sound right?
- Front drivers side noise
- is 1000 high idle & IACV
- Flashing Airbag light
- Question for those with 2k4 Caliper Upgrade
- Halo Preojectors Headlights
- Strut dust boots - anyone have "aftermarket?"
- Spent 2 hours doing my first brake job...but questions
- Help with piggybacks!!
- Descreening MAF?
- Question about wheel bearing
- Quick code that dissapears?
- which rear brake pads to get?
- Fog Lights in a GXE
- HLSD problem?
- 9005 Piaa bulbs...problem...please help
- front strut bar
- Alternator Replacement HELP!
- Are the 350z cams the same
- e-brake "problem"?
- courtsey MAF replacement...
- Engine light goes on and off depending on weather
- Possible Additional Mounting location for SFCs
- rattling on acceleration
- Hella Supertones - Must use Hella Relay?
- Beating a dead horse--> 02 MT lips same as 02 Stillen Aero??
- Where to get shock/strut boot?
- warspeed y-pipe
- should i sell my auto and buy a stck??
- Installed MAF improperly?
- Illuminas w/ Front Springs Installed Only??
- 5.5 gen leather seats fit in 5th gen?
- E-brake replacement on 01 available?
- Sticky caliper: suggestions...
- Another POS Ebayer...
- 3.0 Six speed ???
- cheap wheel bearings?
- trying to find something out for a friend [selling a 2k SE auto]
- shattered sunroof
- Cf Hood
- VB mod what is it?
- Is Cold Air Intake causing this?
- Fog Light Rewire drain battery?
- Blinker problem...
- Change Flywheel leave stock clutch?
- engine valve clack
- Anyone tried these grill kits
- The Good And The Bad 56k warning
- Brake pads for 5th gen maxima(2000)
- Widest tires w/out rubbing?
- Window Tint Hahahahaha
- Stillen: oil cooler
- Do you need camber plates with the EIbachs?
- is this normal?!!
- Stop and Go = High Idle
- P0138 & P0158 codes
- Need Ya PPLZ Help!!!
- shaking while braking/driving
- Will 02 Place Racing intake fit 00 Maxima?
- super lean a/f ratio at idle!!!
- I cant believe this.... I'm so upset
- air/fuel ratio guage
- Car Shakes while applying the brakes
- dealer says timing can't be changed HAHA
- hate my seat....anything better out there?
- SES Appears & Disappears in 300 mi.?????
- which rear sway?
- New 5th Gen Owner!
- Big Thanks in order!!!!! IRISH44J AND EVERYONE ELSE INVOLVED
- Positive or Negative Ground
- Just bought Eibachs and Illuminas So PUMPED!
- tokico illumina struts good, bad?
- need help
- Erebuni CF hood any good ?
- Automatic shifter loose in drive
- Lookin for H&Rs for cheap
- My brakes are fawked.
- Worried about lack of engine oil...
- headlights
- what color rims on a merlot 02?
- lights in fan switch
- Using Tein EDFC with Stillen Camber Plates...
- muffler/exhaust questions
- Canuck Motorsports Springs....?
- cattman catback
- HELP! newb changing spark plugs
- Jet performance... worth the money?
- Possessed locks, voodoo brakes and questions inside>>>
- windshield trim
- Bose== 2002/2003
- O2 sensor
- Shiftplate LED exchange
- Starts then dies unless I put it in gear
- Low Tie Bar for 5th gen
- P0430 Catalyst Efficiency BelowThreshold
- cheapest price for h-techs?
- SES p0302... Help please
- Part #'s from Autozone - P038 & P039
- Reading the Dyno posted I have a question...
- Handling idea which I'm not sure has been brough up before
- New design for SFCs
- leaning and timing
- Could I/Should I enter my car in local shows?
- Wow it makes a BIG difference!
- *Sound clip* of stock exhaust minus B-pipe resonator.
- replacement fog lights
- Let's say you had 100 bucks to spend...
- DIY Oil Catch Can....
- How many quarts of oil does a 5th gen take?
- Cloth to leather swap 5.5
- How high?
- Need some quick help
- oil and pcv valve?
- Question about mesh grille
- 5 speed whine
- Rear replacement shocks for 2001 Maxima
- removing rear pillar HELP
- Ignition Coil Question
- Cail spec Y pipe
- ••ü•• What's Going On At Umnitza!!!
- need help with redline shift boot
- battery relocation to trunk mount tray/box
- autoenginuity thread
- custom third brake light
- Who tried voltage stabilizer???
- Lost my Maxima key and remote
- New lower balljoints+tie rod ends+ES bushings+camber
- AT trouble
- Y pipe on VQ35 questions
- 5th Gen Carbonfiber Trunk?
- What offset do i need for 18x8.5 rims...plz help
- MAF dies 655 miles away from home!
- Sunroof Problem: Tilt up and down works, but sunroof won't slide back
- Water in my factory rear spoiler light
- Cattman catback rattles/burning smell after install? **please step in**
- Custom SFC update Car went in the shop today
- IACV funny story
- Is there away to test the ign. coils?
- FSTB installed
- Car Alarm
- GRINDING! Front right wheel!
- 5.5 gen side airbags
- 6speed conversion UPDATE
- Why does my car alarm keep going off by itself?
- Hood pin questions
- Any current deals on SS Brakelines right now?
- My Final MAF questions
- Anyone Have A Lightened Flywheel Please Help
- ..Budget Y-Pipe Owners Step Inside..
- Wiring Diagram for '03 Max
- Ready to post Dynos tonight but need help from someone.
- Brakes and starting issue
- HOW TO: o2 sim install.....
- 01 tailights interchangeable w/ 02?
- MTEC super white H3 fogs Vs stock
- Need Help...
- another intake question to PO everyone
- must change ECU when changing IACV?
- 02 SE with no HID and no fogs?
- caliper weight
- Anybody used Nissans corrosion warranty?
