PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 [134] 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. has anyone added auto up/down feature to rest of windows?
  2. Stolen headlight replaced...looks different from stock
  3. hp mods= tranny cooler needed?
  4. Websites for Tokico shocks and struts
  5. Helpppppp!!!!!
  6. Where is the orginal LED write up?
  7. Triple Gauge Pod for Passenger Side Pillar???
  8. Maf options?
  9. adjustable tint
  10. overhead console
  11. 5SPD tranny shot!!!
  12. Brake pros!!! I need your help!
  13. knock sensor
  14. Rear Strut, is this bad?
  15. Wiring Amp ?s
  16. What bushings in suspension do i have to change after time?
  17. Anybody having problems of noise when turning right or left after just starting car?
  18. $3000 to spend; what would you do?
  19. PIX of Octane Side skirts...
  20. couple of ?'s
  21. best non-HID headlights
  22. 2 quick questions
  23. New ECU
  24. I need 2 Maxima.org decals for my car......
  25. Sarona Side Skirts
  26. New owner - what color do I have?
  27. Good news on my transmission
  28. Eng/Tranny gurus. Can you please help diagnose this problem?
  29. forums.maxima.org down?
  30. Anyone have feedback on camber kits?
  31. 1157 AE corners
  32. 2000 gxe shock problem
  33. New Grill, Tires, Rims, Stereo
  34. brake grind noise with Brembo blank rotors
  35. 2002 side skirts
  36. where can i find octane sideskirts for cheap?
  37. Are Eibach springs a lot stiffer than H&R?
  38. Help with headers
  39. Front Lips
  40. Anyone have over 150k miles?
  41. Transponder Programming
  42. Random SES Light, Code P0455 - EVAP Control System Gross Leak
  43. Changing to illuminas/h&r. Any additional parts needed with these?
  44. What Would You Do?
  45. LED Window/Lock Switches Help?
  46. clutch
  47. Whine from top of motor??
  48. Problem loading pages on this site?
  49. How much longer do i have
  50. I need some major help!
  51. ABS, TCS Off, Slip Lights - No Codes Pulled
  52. opion's on clear/smoked corners
  53. Maxspeed and Illuminas going in today
  54. Imitation Stillen Rear fittment?
  55. Only when listening to cds? Anyone else get this?
  56. R34 Rear Conversion
  57. Hard choice!!!!!
  58. dust cover boots
  59. Anyone Who Knows How To Do Timing...help!!!
  60. How to open up the valve in the heater core to do a coolant flush
  61. quickie for all the experts
  62. 2k3 hood question
  63. Air Bag
  64. H-Tech's & Illumina's coming. A FEW ?'s though
  65. anyone know how to change the key ignition beeping sound thingy
  66. Is anyone using an AEM adjustable fuel pressure regulator?
  67. clear corner question
  68. is there a how to on.....
  69. 2 Quick Questions
  70. Any pics or info on gram light 57s pros??
  71. Ran over trash!
  72. Auto shifter stiffness?
  73. Installing leather/Vinyl door panels. Anybody done this on there own?
  74. VQ35s with knock/misfire/ping
  75. The NEW,aimable masterswitch LED HOW-TO; no soldeing to the OEM circutboard required!
  76. want to do the vb mod and get a tranny cooler
  77. Towing
  78. Aftermarket Cats
  79. Figured out what is wrong with new struts, now how do I fix it?
  80. Anyone ever use 94+ octane?
  81. Hids in 00/01 Housing
  82. Friction Band??
  83. Unorthodox UDPs for $95
  84. Got Suspension???
  85. Flashing OD light???
  86. Oil Light on start up.....
  87. Battery light comes on.
  88. clip of my exhaust
  89. What is it really worth
  90. Nissan Survey
  91. Starting problems - help please :-)
  92. Car not moving???
  93. 2k I30 gauges in a 2k Maxima
  94. Installing Splash Guards...
  95. Coasting In Neutral To Save Gas
  96. Has Anyone Tried This Intake
  97. Can you turn slotted rotors?
  98. Eibach and H-Techs, Whos got them with 18"?
  99. New struts and top bushings. Now a loud clunk over bumps???
  100. Carfax?
  101. 5 gen engine coil replacement
  102. Review: Active Tuning Custom Engine Grounding Kit
  103. Non-bose stereo question
  104. Clearence lights a b*tch...
  105. Battle of the 3.0 vs. 3.5 (autocross)
  106. Progress vs. H&R: I need your help!
  107. Has anyone found a bra for the AE?
  108. Right Bose speakers clipping
  109. door trim peeling off
  110. Engine Coil Problems 2x, need suggestions
  111. auto-dimming mirror rattle
  112. A/C problems
  113. Assistance Please!!
  114. Anyone ever heard of SS Auto Chrome HEADERS for 5th Gen??
  115. Dont forget about this!
  116. MPG Gas test
  117. clear corners question
  118. 2k maxima w/ bose door speakers....
  119. Vq35, TS extended rev limiter = safe?
  120. 2k1 AE vs. 2k1 330Ci Drag Race Outcome
  121. Buyer/Seller Rating?
  122. Michelin Pilot Sport A/S Balancing Issues
  123. 5.5 Gens With 6 -Speed Conversions(Step In)
  124. How do I adjust my Stillen RSB and how does it affect handling?
  125. Glovebox R&I on a 2k2....
  126. Wrecked the Max
  127. HID theft has hit Nome, Alaska
  128. Need Quick Help : Install Side Markers
  129. HID theft has hit Miami Kendall
  130. Rattling under the car?
  131. Altima SE-R exhaust?
  132. Splitfire DIS system adaptable to our needs?
  133. Walbro Fuel Pump
  134. 2000 GLE private party pricing?
  135. 2k gxe radio trim....
  136. Tuneup at 54k What I found
  137. Anyone wear out brake pads?
  138. turn signals on mirrors
  139. AVON Tech R Tires
  140. AT Grounding kit Install??
  141. 2K2 shift boot and console in a 2000
  142. Rear Axle
  143. Bank 1 Sensor 2 O2 Replacement
  144. Wrong size batter in my car!
  145. Your opinions on clear taillights...
  146. so i snapped the belt tensioner, but belt is still tight? help please...
  147. Mille Miglia EVO 5 19 x 8.5 help please
  148. Tranny cold shifting
  149. Illegal Y-pipes in NJ?!
  150. Another HID retro
  151. APEXi S-AFC II Installation
  152. Factory Service Manual
  153. Wheel locks
  154. Update on TB Cleaning & CEL
  155. Anyone running ssr gt3 rims???
  156. Any 5th gens hit 200K yet?
  157. Help!! Bought MAF without realizing the ECM needed upgrading
  158. 6 Disc CD changer
  159. how hard to replace the water pump ?
  160. Electrical Problem
  161. A/C problem?
  162. LED reverse light
  163. Brake upgrades for 5.5gens need spacer
  164. Steering Wheel Radio Controls
  165. Help: Need to replace motor mounts
  166. Cold Air Intake Problems
  167. Weird water in trunk problem!!
  168. New MAF new car WOW
  169. HELP!!!! Received Damaged Umnitza DDE's
  170. Clicking/whistling from wheel area after installing rims NEED HELP ASAP!!!
  171. Window Motor
  172. BERK Intake vs. FC Intake
  173. Sorry To bring up old thread about the VIAS Mod
  174. Camber kits
  175. Michelin brake dust repellant. GREAT STUFF!!!
  176. car start question
  177. Reverse lockout
  178. cargo net
  179. Hawk Brake Pads: HPS or Ceramic?
  180. P0140 o2 problem and reprogramming
  181. Production Date Mystery
  182. ethonol gas
  183. help 2001 AE 5 SPEED owners
  184. Car start to vibrate at 50+mph since tire rotation
  185. Frankencar Cat Back
  186. Took this picture tonight...
  187. serius problem, maf, tranny? hellp
  188. Everyone Dropped On Progress Or Stech On Stock Rims Please Come In
  189. Window motor going out?
  190. Exhaust Noise Drone
  191. Fenders
  192. So is it bad to have A/C on?
  193. Seafoam deep creep for throtle body
  194. Technosquare ECu
  195. Cattman Headers ?
  196. Light stalk for 02 backwards compatible for 01?
  197. Attention Alignment Gurus...
  198. 00-01 Projector Headlights from Custommaxima.com
  199. Last Time
  200. Where did you install you ballast/ignitor.
  201. O2 Sensor question
  202. Questions on 2000 SE before purchase...
  203. Cleaning MAF Sensor
  204. Need a quick answer
  205. Blown strut/shock sound?
  206. New pads/rotors in the front only? Recommended?
  207. Since when is it illegal to have an aftermarket exhaust on your car.
  208. Need Akebono pads ... any help?
  209. Eyelids finally?? check it out
  210. Top windshield molding off
  211. Face Lift?
  212. New rotors need new pads, how about new pads need new rotors???
  213. transmission VB Part number
  214. Towing your car across state??
  215. Cattman/SAFC II dyno graph. with a Baseline graph
  216. Best Short Throw for the 2k Max?
  217. 3.5L ebay headers, first impressions
  218. Cleaning rust off grille-tech inserts
  219. Fog light bulb
  220. quick 5 speed question
  221. Lazy 1-2 shift...lil grind.
  222. Hid Theft Has Hit Orlando!
  223. car got broken into last night
  224. Pinstriping removal...
  225. Stillen Grounding Kit. Pix Anyone?
  226. lower bumper grill painted?
  227. Ignition coil part #
  228. Installing Maxspeed and Illuminas during weekend.
  229. Thermostat question
  230. Frankencar exhasut installed but problems...
  231. Which bushings wear out the most?
  232. Replacing the Bank 2 pre-cat on a 2k CALI
  233. Saying Goodbye to My Fart Can
  234. I hate my door....
  235. Installation of clutch pedal assembly...
  236. beep noise
  237. Would a 4th gen rsb fit a 5th gen?
  238. wheel spacers *pics*
  239. Matt Blehm Grounding Kit vs . . .
  240. Evap Canister
  241. Helios 6000K HID Kit
  242. Are belts covered by 60k/Powertrain warranty? (Please help with issue)
  243. Checked everything.. and still not working
  244. brakes
  245. 4th Gen H&R Springs in a 5th Gen?
  246. AE headlights how to?
  247. Problem with Starter Removal *PICS*
  248. 3/4" rear wheel spacers help!!!
  249. I feel stupid.
  250. Lookie lookie whose selling their max
