- Codes P0744 & P0507
- Where to buy Greddy EVO 2 exhaust
- Which engine mounts do i get for 2000 Maxima?
- Fog Lights
- Steering fluid leaking from big NUT on steering rack. Alternative to replacement?
- Steering wheel play
- ECM removal
- Which navs fit perfectly with GXE dash kit?
- Rough ride a flashing SES light
- No Power to Blower Motor
- Alternator question
- 02 Maxima - Can I replace PCV hose without removing Intake Manifold?
- Passenger Airbag Replacement
- Hello everyone. I have a few issues with my 2002 Maxima
- Strange random rubbing sound???
- Fog lights don't work
- Oil in PCV oil Catcher
- identify this bumper
- Attempting to make a blue clock the right way
- Front 02 Sensors
- What tires will fit 2002 Maxima GLE with 17 inch Nissan Rims
- New energy suspension parts for 5th gens
- 2001 se rear wheel wells rusted
- Guide to replace CV Axle on a 2000 Maxima?
- Transmission Help
- Infiniti swaps for 5th gen maxima
- noobie! need help!
- Another no start thread
- Do I have rod knock?
- timing? no start... HEEELLLLPPPPP
- 2001 Nissan Maxima Transmission Options
- 2002 maxima engine stumble issue
- power wire for 5th gen max! how to run???
- DC Sports CAI4208
- my car is shaking and i dont know y
- ABS pump replacement
- 03 Bose 6 CD going to aftermarket double din
- 2k maxima tps idle relearn problem
- New member asking forbsome help
- Noobie...ish here!
- Bulb not coming out of wedge
- Really bad torque steer
- TCS, ABS and SLIP lights illuminated
- Oily 2 and 4th spark plugs. Oil in intake. Intake "pipes" to 2 and 4th cyl are lower.
- P1456 help can't find leak
- Homemade PCV oil catcher?
- Header interchangabilty
- Stock navigation in the 2003 swapped.
- New Aftermarket replacement Exhaust
- Need help!!
- rides bumpy
- Crashed 02/03
- No air unless HVAC set to high (4)
- Are all the wiper arms... all the same 00'-03'
- Annoying pop that i can not figure out and has been there for years...
- New PCV valve and engine sputter
- Cold Air Intake can add horsepower
- Oil in intake manifold.
- need help for PCV
- Power steering supply hose
- Maxima won't crank!! Help please!!!!
- Climate control, radio bulb sizes?
- 3.0 engine swap problems
- Amazon Ignition Coils
- 02-03 Bose 6CD changer Audio cutout fix!! "RePosted"
- p0420 2002 maxima 6 speed
- Replacing Wiper Motor
- Where is fuel injector diagram? I cannot find it in service manual. Help!!!!
- Car troubles need halp asap
- Park/Fog light combo
- stripped out bolt and threads on frame
- Exhaust
- 2003 maxima cluster led bulb size?
- Anybody ever Used these Yellow Ignition Coils?
- Clutch?
- 2000 maxima starter issue or electrical :/?
- Looking for a write up
- So long Maxima, you served me well...
- 6 speed tranny disassembly question
- 2000 maxima starting problem plz help!
- Clear or smoked side markers on a titanium Maxima?
- Making side markers clear?
- can you id this hose ?
- Camshaft code
- Easiest fuel pump/regulator check.
- Warm start trouble
- Brake Grease - Definitive Answer?
- AE side skirts
- Variable valve timing solenoid
- Oil In Combustion Chamber
- Just bought a 5th Gen need help ASAP!!!
- Newbie with an '01
- Lower control arm replacement brand advice
- electrical issue, or nothing to worry about
- 2002 maxima sunroof
- Camshaft sensor
- belt size for the OBX uderdrive crank pulley
- Rear Calipers: 2000 fit 2003?
- I cannot find electrical diagram in service manual. (radiator fans)
- P0011, P0021 codes Cam, crank sensors?
- Name This part, P0505 3.0
- Oil Pressure light
- Camshaft Position Sensor Replacement
- Car cranks a lot before starting
- Should I buy a 2003 maxima se 160k
- Somebody Please Help!!!!
- Where to find Injen Intake
- Lowest suspension height
- 5 to 5.5 Headlights
- Low Throttle Response And bad MPGS
- turbo manifold for nissan maxima 2001
- Maxima Stereo Question
- Started car, shut off and didn't idle - gave it gas and was fine
- 2000 Maxima Engine Growl?
- speed sensor
- cats and o2 sensors
- Door panel upholstery mods?
- 03 Maxima need opinions to make exhaust quieter
- Stillen vs Anniversary
- Strong Engine Bay Smell with Sunroof Open
- aftermarket injectors
- Question To People Who Cleaned Up Their Engine Bay(hoses,wires)
- Tranny fluid question. Lucas??
- Leaking Antifreeze
- p0430
- no power when key turned
- seat fitment
- hey guys got myself a maxima
- Firewall factory hole location
- air filter concern
- 2001 i30 idling issue
- Exhaust help
- EBAY OE style AE replacement lights?
- 2001 Window Motor Removal Problem
- Dim SES light
- toggle switch installation
- 2000 12v outlet trouble
- HELP... Problem removing strut assembly
- Should I buy 2001 anniversary? 65000 miles.
- P0420 and cylinder misfires
- Problem with my maxima
- 01 Maxima no crank..stumped.
- Whose maxima??
- Question(dont bash me though)
- 2002 maxima light
- P0174 and hesitation between 2k and 3k rpms
- DTRL problem
- Oil cause alternator failure?
- Swappable interiors
- D2R low beam problems
- P0135-Black O2 sensor??
- Corner lights manually on all the time
- Custom Tail Lights
- Head rebuilt, now engine noise - with video
- 2001 Maxima Grounding
- 2001 Maxima Alarm Problem
- Cheapest coilovers
- removing low profile wheels
- Ignition Wire Conversion?
- Vibration Issues after Motor Mounts replaced
- AT Transmission Slipping, 2nd to 3rd
- Onslaught of CEL codes: P1800, P1572, P0113, P0183, P0011, P0021
- Intake manifold support bracket removal
- motor mount
- Some Quick Questions
- Hood Dampers
- Reverseless - back up lights on in neutral
- Maxima vs Porsche
- help random number misfire and ticking noise
- Transmission or clutch problem?
- Help me identify this sensor (With Pic)
- 02 nissan maxima wont start!!!
- 2000 maxima bad ign switch syptoms?
- Ignition coil
- Idle problem? Possible bad throttle body? Confused
- 02 maxima camshaft
- Junkyard find!
- exhaust thoughts
- Front Brake Pads Rattle
- Poor heater performance and cooling system issues.
- Really odd...need input.
- On going Electrical Problems. Any Input Needed.
- Someone pls check me: P1320 and P0100
- Interchangeable transmission Questions
- 03 maxima se vs 02 maxima glx
- 6 speed transmission.
- Long time no see!
- how to get more acceleration
- Speedometer is only HALF right!
- Brm exhaust
- Excessive Oil Consumption
- Tranmission Gurus. 5-speed in my AE is having issues.
- ••ü•• umnitza.com Orion V2 for Gen5.5 Special
- Question on rear license plate housing/bracket
- How to clear pending code in the ecu
- Who knows lifter measurements? Height and diameter? I have lifters from Corolla. 31D
- 2002 Maxima Knocking noise
- Cyl 5 Misfire! HELPPPPPP! Please :)
- 03 maxima idle dropping at idle
- Steering wheel control buttons - 2003 Maxima
- what's the part number?
- 370Z Seats in da max?
- 01 nissan maxima problems
- 2002 Nissan Maxima GLE with 240,000 miles for sale....
- Billet grill.
- 2000 maxima throttle body part identify
- Car stalling at low idle & power window issue
- Filling up and spilling
- 2000 Maxima-Power Windows or window lock Issue
- Eliminating Brake Judder - Long-term Lessons
- led brake lights
- Help decribing this problem.
- Some pics
- Grinding noise from the engine bay somewhere
- Oil in Spark Plug Chamger....What To Do?
- Do our cars require valve adjustments?
- Amazon sent me wrong knock sensor, will this work?
- Totaled the Max
- Where is the Coolant Temperature temp Sensor?
- Question on codes
- Hesitation 03 Maxima
- 00 maxima miss and no heat
- Shifter sits too far forward after 4th gen tranny installed
- Engine Identification
- Stuck connectors - how do you free disconnect?
- Which Cv axel after LSD swap?
- Anybody's Fidanza Flywheel strip easily?
- Burning Smell After Highway Driving
- Ebay struts
- My 2002 SE - May She RIP
- Replacing ECU and IAC
- Ripped o2 sensor trying to install.
- This cant be for real?!?!?!?
- VIAS Issue?
- 2000 max cranks,starts, immediately dies. Help!
- Heated Seats Question
- Idle pulley tensioner
- New Member 2000 Max So Cal Cranks Wont Start
- Did something to my Accord that I should have done to my Maximas
- Projector Headlights
- good suspension! !!!
- How many miles & the best spark plugs
- Cost of OEM Strut/Dust Boots
- 2003 mudflaps Still searching
- Tranny swap help please!!!!ASAP
- EGR problems after Obx V2 Headers install PO403 HELP ASAP
- duck quack engine noise
- Advance timing 2001 Maxima
- Black housing projectors
