PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. 02 won't crank, tons of troublsheooting .. no luck
  2. Metra axxess steering wheel adapter install
  3. ProZ Flexomats All weather floor mats
  4. VQ35 running rich, what are the signs?
  5. VQ35DE & Lucas
  6. What's the warranty on parts?
  7. 2002 rpm drop to idle when I let off in D
  8. 137k maxima intermittent starting problem.
  9. How to install LED load resistors in brake lights???
  10. 2002 maxima SE memory seat cancel switch
  11. freeze plug question? i found the old freeze plug, can i reuse it?
  12. Brake problems - Caliper or MC or ?
  13. Small power steering leak w/ PICS
  14. Incessant wiper blade chatter - Bad windshield?
  15. Code p0750 transmission shaft speed sensor
  16. Strut Tower Brace
  17. Cold air kits - Ebay/Other stores?
  18. Proposal: Merging Gen 5 & I30/I35
  19. Car shuts off when engine is cold?
  20. Is it time to replace the front struts?
  21. Mpg
  22. Whether to or no to try Karlyn Coil Packs
  23. $200 to replace inner tie rod, and rear engine mount?
  24. Stagg Struts With Vogtland Springs?
  25. AC control Christmas lights
  26. Car dies rite after start
  27. Rpm's stuck issue
  28. Power Steering Suction Hose?
  29. 2001 maxima se w/246k maintenance
  30. 01 Maxima blown engine, 30k miles no oil change
  31. OEM oiled air filters
  32. P1612, P0455 and P0456 Codes
  33. WeatherTech Floor Mats
  34. Recent issues with stalling/ blinking lights/ weird shut offs
  35. Where do i get coilovers?
  36. Hanging wire next to transmission pan?
  37. Need your Opinion!!
  38. Brake Light (or Cruise Control) Rubber-Stopper
  39. 2003 GLE P0011 and P0021 codes!!!!!!
  40. 2003 Maxima Engine Install car....
  41. engine hestitates
  42. maf sensor
  43. CRAZY noise on startup?! Help!
  44. 2000 maxima cowbell noise
  45. 2002 Nissan Maxima rpm Rev
  46. Replaced IACV, luckily ECM is fine.
  47. 2000 Nissan exhaust
  48. Is this a stock exhaust replacement?
  49. ECU burned up on highway
  50. 2003 M/T hesitation TSB...anyone else??
  51. hey guys Transmission ? here on the 5th gens
  52. Misfire Problem: p0303
  53. Lowering my 5.5 gen with springs?
  54. lightly modded 2000 Max se vs 2007 Max Sl on a highway race?
  55. Nwp Spacers Install.. where did i go wrong
  56. Reprogramming Symptoms: What are they? - New Question on ECU/IACV issue
  57. a arm brands/choices?
  58. moog control arms installed. car rides like ****
  59. Weird clicking noise in front of car??
  60. 2001 maxima shutting off
  61. Lack of acceleration
  62. Will Instrument Cluster from 2000 SE fit 2002 SE?
  63. Fuel gauge repair
  64. Clutch Jerking (Slow Driving)
  65. Also new here and need help...
  66. New 2000 Maxima owner with 3 codes, need some advice plz
  67. 2002 Maxima Motor Shuts off While in traffic and coming to stop
  68. I need advice on The infamous fuel gauge problem please....
  69. I need help/advice with headlight aim screw
  70. Do the 5th and 5.5 gen have the same evap valves?
  71. crank no start when car warms up
  72. 3.5 engine seems loud when cold, quiet when hot?
  73. Alignment problem or tire balancing problem or both?
  74. 02' manual shifts rough going into 3rd
  75. 02 ABS Control unit (or relay) replacement
  76. Help! six codes for 2000 maxima
  77. Carrier Bearing Bolts in CV Axle Replacement (passenger side)
  78. 2016 Picture Thread!
  79. Service Engine light & Sputtering sound advice
  80. Man rear hub bearings are pricey!
  81. Limp mode after motor swap. Normal?
  82. 2000 odometer says 263000
  83. Has anyone ever bypassed the Crossover on the Bose Sub?
  84. Is My Windshield at The End of its Lifespan?
  85. 01 weatherstripping
  86. 20th anniversary occasionally vibrating when in park, drive, and reverse.
  87. Idling issue
  88. 2002 SE airbag issue!!!!
  89. Cracked headlights
  90. Eastern precat
  91. Sometimes Maxima Takes dozens of turns to start
  92. rev limiter removed - car gauge pro back pressure
  93. anyone know who can make custom intakes?
  94. 2000 Nissan Maxima.. With tons of issues
  95. nisssan maximum 2002
  96. Has any one ever had there ECU tuned/modified?
  97. Just got a 2000 maxima and I love it but have a few issues
  98. Just got a 2000 maxima and I love it but have a few issues
  99. Has anyone seen this???
  100. Throttle Body Spacer.. Worth it?
  101. 2003 Maxima crank no start. Can't communicate with ecu
  102. 01 max exhaust inlet size
  103. Y-pipe, cats, precats ... need some help!!!
  104. Fogs: Replace PIAA 4th time or take HID plunge
  105. how hard would it be to remove intake plenum and lower intake manifold?
  106. Bought Stinger Digital Battery Terminal, What about positive battery fuse?
  107. Aftermarket Cam/Crank Sensors?
  108. front strut binding?
  109. Bulb sizes
  110. P1800....o2 sensor harness disconnected
  111. Trans/clutch prob??? help
  112. 2003 Nissan Maxima engine swap
  113. Lip spoiler
  114. Driver side axle
  115. 2000 Max - where's the best deal for a OE IACV
  116. What are the Major Issues with 5th Maxima? Insights Please.
  117. 2000 Infiniti I30: Tranny Fluid Question
  118. Warped Head---Misfire ?
  119. Decals
  120. Shifter bracket?
  121. NOOB:Squeaky Belt and how to fix it
  122. Picked up my first Maxima
  123. Digital gauges
  124. Light tints
  125. My new clutch
  126. 2002 SE catback options?
  127. Valve Cover Job -Spark Plug Tube Seal Question
  128. Stalling
  129. Seat swap
  130. Is my alternator going?
  131. 2002 SE 100% wtf...
  132. Polished exhaust tips for new muffler
  133. Parking Brake Not "Seated" Right?
  134. 5th gen maxima help please
  135. 2003 fuel pump question!!!!!!!!!
  136. Body kit
  137. 2001 Maxima Engine/Motor Mounts
  138. Blue brake calipers
  139. P0430 whats the best aftermarket precat?
  140. door ajar dash light on
  141. Front end feels loose/ wobbly
  142. anyone successfully install headers
  143. Automatic Transmission Flush Method
  144. 2 key fobs stop working at same time!
  145. Unbearable noise in front end of car
  146. Blue Long Life Antifreeze
  147. New here Question about Rpms or other things
  148. Looking for a reliable alternator replacement
  149. Clutch and flywheel
  150. Front and rear bumper lip
  151. How to adjust hood?
  152. Vendor :: Nissanpartsdeal.com
  153. P0158/P0159 - No Emissions Req - Necessary?
  154. 5th gen Bose subwoofer issues!!!!!!!
  155. Ebay mesh grille 03 Max need pics
  156. Another Max bites the dust
  157. downpipe flexible is dead.....new downpipe
  158. Getting back in shape
  159. Turbo kit?
  160. NTK/DENSO sensors
  161. '01 Maxima trouble starting while warm (Videos)
  162. How much am I expecting for labor?
  163. Do you have to remove timing cover in order to get to freeze plug? 2000 Maxima.
  164. Possible Valve Cover Gasket Leak
  165. How do I remove camshafts?
  166. Always drive with headlights on?
  167. Flashing ECU - are the IACV, MAF effected?
  168. Rust Problems
  169. I think I have an exhaust leak
  170. My 2000 is leaking coolant from what looks like right above alternator by oil pan?
  171. Front wheel bearing brands
  172. Engine swap and Transmission question
  173. Seat Motor automatically moves forward... good times!
  174. Something is howling under the hood ... squeaky belts?
  175. Black interior with light blue exterior?
  176. Thoughts on this 2001 AE I may look at...
  177. Its been a long time! Status update/Motor mounts
  178. Bad ECM?
  179. performance tire suggestions
  180. Another fried ECM..well almost
  181. Battery/Brake light, confused
  182. 01 maxima idles roughs, stalls and loss of power.
  183. 5th gen - IACV/Throttle Body - Removal Problems
  184. Trace a Template of Block off Plate (BOP)
  185. Weird DTE?
  186. 03 Maxima idles than dies
  187. Disable Sunroof on 2003 I35
  188. Grinding Noise
  189. 2003 Maxima GLE suspension related!!!!!
  190. how to tell if radiator is shot? any particular brand to buy aviod?
  191. P0011 - No oil in IVT
  192. Rough idle(every 30 seconds)
  193. IASC Failure - Coolant Bypass?
  194. IASC/ECU failure - Replace 15A Fuse with 7.5A
  195. Another Clutch/trans issue 6 speed Max
  196. Oil too high on dipstick - PCV valve change?
  197. Stalling Immediately, fine with throttle
  198. New Front End Suspension - Alignment needed?
  199. 2002 nissan maxima
  200. Does the 3.5 engine have a coolant bleeder?
  201. Lossing coolant.
  202. Tire Chains vs Winter Beater?
  203. What part is this oil leaking spot?
  204. Coolant drip
  205. Wheel offset?
  206. Painting Stock rims
  207. A Matenance Question/Misfire
  208. In search of 20thAE hood and additional info
  209. Issue with steering when is cold
  210. Help me!!!!! Crankshaft bolt won't come off
  211. 02 Maxima 3.5 engine swap w/08 Quest 3.5
  212. Can someone please tell me wheres tranny fill plug for 2001 manual nissan maxima?
  213. Timing Cover Leak
  214. Pace setter Pre cat good or no?
  215. Crazy idea!
  216. Can you use automatic transmission fluid on a manual tranny?
  217. How to get to Throttle Body to Clean
  218. Low heat output
  219. Rattling under the hood and stalling! Help!
  220. Drink Holder Lid
  221. 2000 Infiniti I30 passenger side mirror
  222. Starter Issue and yes I searched.
  223. 200k i30 Suspension Newbie
  224. Car Seat
  225. Car stalling
  226. Catalytic Converter cost/replace myself?
  227. Rear brakes
  228. Headers and tuner?
  229. Having trouble getting Idle Air Volume Learning to stick
  230. remote start bypass
  231. Wheel fitment for 2001 Maxima
  232. Starting issues 2001 max
  233. 8th Gen Steering Wheel
  234. Idle relearn after disconnecting battery?
  235. MAF Question
  236. Camshaft position sensor issue
  237. Vibrations and noise
  238. 2003 Maxima Stalled
  239. Weight Reduction
  240. Need Help With With 5Th Gen Maxima New To.Forum
  241. New crank sensor still won't start
  242. Looking for a how to on separating low/high beams
  243. Paid of '02 maxima. Needs some body work, worth it?
  244. Speedometer Not Working Properly!!
  245. How often do you guys change the brake fluid?
  246. Noisy engine after oil change
  247. 5AT? .....what the...?
  248. 2002 wont start
  249. IACV cause of spillover problem?
  250. Programming key at dealership with new ecu
