- oil leak from filter area
- 2001 Maxima - L/R Front Hub and Bearings
- Tokico illumina Adjustment Indicator missing
- Looking For Str8 up Answer
- auto locks, dome and courtesy lights dont work
- IACV and motor mount replacement?
- no power
- Extend Oil Change Interval b/c of Adding Oil?
- 2003 nissan maxima 15" wheels, brake clearance issues?
- LED (L.E.D.) in Climate Control Slider
- Installing a volt gauge
- is this cheap crap...
- rear trailing arm bushings
- Burnt smell through vent
- Humming sound under engine cover
- 2001 SE Maxima, confusion at it's finest.
- Loud acceleration
- ABS Light
- 5.5 Gen Bose Headunit Specs to Upgrade?
- Notorious HP Power Steering hose leak
- Exterior nor interior lights work on combination switch position 1 or 2
- Gauge Cluster Swap - Canadian to US
- Feedback on I30 Crossmember on eBay - quick!
- Stretch Tire Questions... For My 2001 i30
- Audi S Style mirror
- Power Seats and Locks
- What is this for
- 5th gen audio
- ECU tune?
- Parasitic battery drain - pt 2
- Trans Noise - loud hum?
- '03 Maxima excessive fuel consumption
- ABS Speed Sensor Bolt Specs?
- [Video] 2003 Maxima Engine Noise Comes and Goes
- clutch masters fx250 + fidanza flywheel
- LH Side Airbag replacement- Advice?
- Airbag Recall
- Driving on P1320 ignition signal code
- 2000 Maxima Instruments Lights Seem Dimmer Than They Used To Be
- Bulb Question
- No designation on trunk
- 2000 Maxima SE problem
- Washer size for door sag fix?
- Whining Noise after replacing high pressure power steering hose
- Wet passenger Floor - A/C Drain
- 2001 special edition problems
- gonna be in the market for parts soon...
- does this IAC look good?
- Shift kit for an 01 maxima
- Ecu and ecm
- 2002 Nissan Maxima Gauge Cluster
- Really?!?
- Ignition Coil Resistance
- Sprayed foreign solvent into intake, now what?
- LED Headlight Kit
- No spark
- 2000 Maxima Questions
- Overheating....kind of
- I35 REAR heated seat wiring question
- Erratic tachometer needle 02 SE
- pro exhaust enthusiast advice needed!
- Tie rods inner and outer
- inexpensive ecu
- 2002 Nissan Maxima IAC Valve Location!
- Subframe pads
- Another misfire diagnosis thread
- Back in the Maxima game!
- GAB mod
- Plastic housing around wiring on driver's side
- O'reilly MasterPro ignition coils
- Drop resistor mod?
- What could it be?
- 2000 Maxmia misfiire only at IDLE, LOW RPM
- Anyone replaced the exhaust without using gaskets?
- 03 3.5 maxima auto tran
- anyone!!
- Navi/6CD changer help.
- Just picked up an Apexi Neo!
- Using my Apexi Neo anddd ... to datalog street tuning pulls
- Leaking Gas On Fill Up
- Nissan Maxima 2000 speedometer not working!
- rattling exhaust pipe
- 2000-2001 Infiniti I30fenderwell intake?
- help keyless problems
- Electrical Issue???
- Will wheel adapters be safe?
- Anyone have these Infiniti rims?
- Searching for CV axles and Lower control arms
- power steering issues
- Ghetto Air box mod?
- Mass air flow ground?
- help with i35 cluster swap
- 2000 Maxima transmission drain bolt washer
- P0011 code 03 max
- Help - before I get raped at the dealership!
- 2001 Max AE Starting problem.
- European A33 - MAF, AC tank
- How to fix any 2002 - 2006 Maxima (3.5L) oil consumption/leak
- water pump or head gasket?
- Obx exhaust headers?
- Obx headers question?
- Leaking Driver's side axle to tranny seal
- Should I?
- Super ebay deal: Nib kyb struts front pair -$65
- Does anyone know the OEM part number for fuel filter early MAXIMA?
- Scraping noise from front passenger side - while going straight- searched
- Screw the SS clutch line. NiCopp to the rescue!
- HID Mishaps
- 2002 maxima transmission fluid on dipstick
- Need upgrade advice
- Windshield washer reservior 02 I35
- Removing exhaust, just making sure.
- ECU swap, will it not start with out key reprog?
- Random high idle.
- help with codes!!
- 100,000 3.0 my neighbor is selling. Questions.
- Coolant reservoir rattle
- Just got chased by a psycho on the road!
- Has anyone gotten a recall notice about the Takata Airbags yet ?
- O2 sensors
- 2001 I30/Max Sunroof Resetting question - finding out WHY
- Exhaust System 5.5th
- engine knocking
- Demand for Tactrix?
- Mating 2.25 inch y-pipe to a 2.5 inch exhaust.
- Oil pressure problem
- Left side axle
- Will these wheels fit without rubbing?
- Need Help With Inner Tie Rod On My 02
- Recomendation for performance mods
- What "MODS" Have you done Using parts from other Makes?
- 2001 maxima just going off after start up
- Oooh beefy deep exhaust note vid, and possible combo
- O2 Simulator: Options
- 2000 Maxima Dash Lights not working
- Glasspack tube question?
- Help! Keyless entry remote is broken
- P0335 - Interesting issue
- Maxima milage
- Paint Discolouration
- 2001 full sized spare?
- 5th gen vacuum hose replacment kit?
- technical transmission question
- Engine Bay Pics
- 2001 AE Stock Quater mile time
- Catalytic Converter 2000 Maxima
- 2003 Maxima dies
- 02 maxima won't start need help
- Driver seat needs to be hit from the back so I can move it forward
- Water Leak into Passenger Side Floor After Heavy Rain - 2001 Max
- Obx Header Information
- Key and remote stolen
- 2000 Maxima GLE - Rims confusion?
- Won't Idle- stalls after IVAC and ECU repair
- Leaving the 5th Gen fold
- New Cheaper Alternative for Headers?
- Diagnosing 0300 and 1320 codes
- P1122 P1126 02 SE 125k
- Inner tierod replacement soon
- Just bought this transmission cooler
- What are the best lowering springs
- Rusted Bracket
- NWP spacer question
- Help with loose rotor after lug nuts tight! Please!!
- Speakers
- Best exhaust advice
- Click Click Boom?
- Driver window regulator.
- failed smog due to system not ready have some questions
- Bad fuel pump?
- 300zx calipers
- Purchase Advise
- Breaks squeak when turning or breaking
- Suggestions: Fog Light HID DRL
- 02 SE No Start After head unit install
- 2002 Maxima se 3.5 clutch
- '01 Maxima SE 62k miles trans issue.
- Tranny cooler?
- ECU Chip question sta509a
- ecm question can not.find answer help!
- Slow Maxima Test Drives & Brake/Exhaust Question
- Problems with my 5th gen
- Maxima who cut me off today
- Stillen Instagram - 5th Gens
- Spark plugs
- Exhaust System
- Comparison: 6th gen bbk or 300zx bbk??
- Need Part ASAP
- looking to do a cheap mod
- Flashing set on ccontrol over 85mph
- P1320 2000 Maxima
- exhaust leak
- Wheel Color
- SES gone away naturally?
- Dome light flickering
- option / alternate / cheap : Cabin air filter
- 02 Max, NATS?? Died, won't start.
- restore oxidized headlights or buy replacement set?
- Rattle from Passenger Side - suggestions?
- Power steering, which hose?
- 03 maxima common codes? Need help :'(
- New car - 2000 Ti Model
- Instrument Panel... dead
- Need Help ASAP
- max or quest?
- alt issues
- wont start
- Knock Sensor
- Need help deciding
- Replaced alternator,car is more responsive?
- 6 spd very hard to put into 6th gear
- *URGENT* Gen 6 BBK HELP!! * URGENT *
- Really loud Screeching Noise
- Rear Spoiler Removal
- posts giving wrong information about thread size
- Is it time to get rid of my 5th gen?? :cc
- VQ35DE Idle Exhaust Bump / Burp Weird
- Loud rear end clunk
- Front end suspension noise (Rattle)
- 03' maxima subwoofer not working
- Strange clicking sound from steering column
- CV Shaft on 2000 5-Speed
- Need help! Pulling under acceleration
- Inhibitor or new starter??
- m2 headers and y pipe
- Strange vibration when turning right?
- Can broken axle cause abs, traction, slip
- Advice
- I have so many questions about replacing ignition coils.
- eBay Radiator
- Stering wheel interface?
- Oil Level - Too High or Too Low
- Replace Catalytic Converter
- EVAP, CAT and codes....oh my!
- Help! No reverse after solenoid change!!!!
- 2000 no check engine light bulb??
- 2003 maxima break down
- broke down 2003 maxima
- Trunk carpet OEM?
- p1456 code won't go away!!
- Removing The Illuminas, Installing Koni Yellows
- car will not start
- parking lights to match yellow fogs
- 2001 Maxima Is miss firing
- Exhaust Question
- hey now! is this really that crazy of a deal for a Megan FSTB?
- New 2001 AE muffler?
- Seized jam nut
- Moaning noise from back wheels when backing up
- Cattman Exhaust Catback
