PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Painted my grill black (pics)
  2. Questions about my 'new' 2002 Max SE
  3. Removing Eyelid
  4. My Max runs like a 4 cylinder. Is it MAF sensor problem?
  5. Getting ready to sell the Max
  6. ODD question perhaps!
  7. 5th gen lip on a 5.5gen??
  8. will these fit
  9. tune up the max
  10. Bucking
  11. 537 dte anyone?
  12. Painted my grill - how long until I can wash again?
  13. Wheel alignment question (Chart picture inside)
  14. Went to Technosquare for F-spec tune
  15. back from the tranny shop-Edge Racing & Transgo
  16. fluid in tie rod inner boots
  17. How long to install knock sensor - 5th gen
  18. GL-5 in my 6MT
  19. How much oil to add after teardown?
  20. Car Shakes HELP!!
  21. o2 placement install.. AEM uego
  22. [Need Help] Identify Odd Sound & Cause
  23. WTB 3.5 crank
  24. Throttle body making noises "BOV hehe" when revving engine
  25. Help, passenger window not working
  26. Headlight Problems
  27. Outer Tie Rod Removal: HELP!
  28. Replaced MAF due to P0171
  29. Nissan Engine Museum
  30. FYI: DaveB on Vaca
  31. Would you consider this car or go away ?
  32. Xenon headlight theft still an issue?
  33. Cornering lights?
  34. 2003 maxima megan test pipe video. Plus extra footage.
  35. 06 6spd Transmission in a 5.5gen?
  36. Strut bar fitment
  37. Trunk/Rear deck rattle
  38. No O2SIMULATOR.COM; now where?
  39. I was getting great mileage on my trip until...
  40. Spark Plug Seals -- Need Help
  41. Shift assembly differences 2002 vs 2003
  42. Which Muffler to get
  43. MAF Orientation -- does it matter?
  44. Water in HID Ballast Now I got different color HID in Fogs
  45. Need your advice...
  46. 300zx BBK PLZ HELP ASAP
  47. ECU issue?
  48. How do you put the motor back in timing?
  49. Blower moter?
  50. Just got a killer deal on 00-03 Megan OE-RS Catback
  51. Stage 2 Clutch Upgrade
  52. led bulbs for the map dome light?
  53. clear or smoked sidemarkers?
  54. Tire Size problem
  55. What do you do to make your cab look pretty?
  56. STS options
  57. Can you shut off Bose Subwoofer in Trunk???
  58. Insane quote from a body shop?
  59. rear coil bolt's size
  60. Slight buzzing noise while driving?
  61. Engine Swap Questions
  62. White exhaust smoke, sporadic heat, overheating...
  63. Weird sound after reving
  64. Suspension choice dilemna
  65. Aftermarket Starter, Are They Any Good?
  66. 2003 maxima 0-160 Video :hide:
  67. What a Difference Front Engine Mount Makes.
  68. problems after programming remote
  69. Injector Harness
  70. Has anyone had their stillen rear lip melt b/c of exhaust?
  71. Megan vs Eibach Lowering Springs?? HELP!!!
  72. programming transponder keys !!
  73. COIL PROBLEMS
  74. AEM vs. JWT Cone Filter Question
  75. how to black out window trim
  76. 5.5 jwt flywheel install
  77. Have to Give Multiple Tries to Start the Engine
  78. 2000 Misfire and blinking check engine light that goes away
  79. My motor mounts video..as the car is being driven.
  80. Blower motor on maximum overdrive
  81. Some suggestions on Fabrication for my Trunk
  82. 03 SE Body Parts
  83. Is my transmission shot?
  84. Engine REVs up when Clutch Pressed in
  85. I forgot to install a piece during fuel filter change ...
  86. serious problem after strut change
  87. Thumping after suspension change
  88. How do you permanently deleted your account?
  89. Progress Springs OEM Struts
  90. Fed spec exhaust manifold vs. CA question....
  91. Warpspeed Cat or Test Pipe???
  92. 2001 M/T Speedometer issue
  93. A/C Compressor dead??
  94. brake issues!!
  95. Odd starting issue, looking for some insight...
  96. Anyway to Disable Remote Front Window Roll-down
  97. Dress up your Engine Bay -- A Write-up for Nuts & Bolts
  98. ebrake help
  99. Oxygen sensor specs
  100. Headlight Bulb Question
  101. Copper Gasket for Exhaust Manifold (Headers)?
  102. Oil Changes in Months not Miles!??
  103. Jwt ecu wiring
  104. Awful wheezing/high pitch noise when RPM drops.
  105. 235/55/17 on Stock '02 Rims
  106. power loss
  107. Throttle pedal caught on floor mat ('03)
  108. Failed Curb Idle
  109. 2001 Stalls When Gassed up In Neut/Park
  110. Will a Nismo CAI for an 05-06 Altima work on a 5.5 gen?
  111. Mainenance at 170,000!!!???
  112. Tranny recommendation-WWYD?
  113. Coolant bypass mod?
  114. Odd Steering Loosenes Issue
  115. FCP Import LCA Kit?
  116. car fax reports?
  117. jus double checking on fw torque bolt on fidanza
  118. I LOVE this car !
  119. Replacing MAF, is this the right part?
  120. Steering gear remove/replace
  121. Power Steering Fluid???
  122. Ghustle Down....... again
  123. DOTCOM Racing Honeycomb Grill
  124. Need Car Fax
  125. More questions about Ignition Coils
  126. SSIM and AFR
  127. Drops and CV joint or other problems
  128. Any pics. 5th gen w/ Nismo 19" LM25 wheels
  129. Does anyone know how to do a Auto shift knob change?
  130. 2003 GLE 1st month impressions
  131. (PICS) ABS light on and Speedo and odometer not working after clutch change
  132. trunk lip spoiler pictures? rear window spoiler without factory spoiler?
  133. Changing Manual Climate Control Faceplate?
  134. Bose Headunit Replacement Options
  135. shipping questions?
  136. Failed E-Test AND awful noise; WITH VIDEO. Hard upshifts.
  137. Help with my Navigation!
  138. Koni Yellow deals?
  139. Heated Steering Wheel
  140. Removing/extending rev limiter
  141. lower control arms
  142. Blue smoke
  143. Blue smoke
  144. How to make it slower (yes, slower!)
  145. Maxima front end noise 5.5 gen.... Please help $$$
  146. Knock Sensor Location on DE-K Cali Spec?
  147. Major Power Loss 3.0L SE
  148. Whose car is this?
  149. Swapped my GLE door handles for SE ones
  150. Dirty Lights
  151. Custom or Cattman?
  152. suspension
  153. Splash Guard (Under Engine)
  154. 5th gen > Mazdaspeed3?
  155. Anyone ever disassemble their wiper motor?
  156. Resonator?
  157. p1122 code, just once so will it come back
  158. low cost p/s pressure hose
  159. miss fire
  160. thewheelconnection.com website/company?
  161. 16" SE 4th gen wheel, How wide tire?
  162. Flywheel bolt advice needed... reply within
  163. What is this sound???! (video)
  164. 5.5 = New Fog Light Style
  165. Remote Starter for Manual Transmission (6-speed)
  166. Opinions on new clutch, which one do you have?
  167. SPEEDING TICKET, but NO Radar?!?
  168. 2 axle seals later and I'm still leaking bad
  169. Finally trying to get rid of P0420!!!!
  170. already at 183K...
  171. 5.5 Gen with 183K
  172. Replacing my BOSE system...
  173. How to make the clutch catch low...
  174. Really odd ABS sensor problem: mechanic has no idea, need help
  175. P1320 coil power condenser
  176. Ball Joints and Tie Rod Ends
  177. 6spd TRANSMISSION Motor Mount Replacement
  178. 6 spd slave cylinder bad??
  179. Front and Rear Bearings
  180. Love my Maxima's!
  181. Which direction does the motor turn?
  182. Limp mode? Lost Reverse? and fans on///help
  183. Beefing up the bottom end
  184. Had engine rattle opened her up and LOOK AT THIS!!!
  185. Suspension Parts
  186. Starter Issues
  187. Washer low light/sensor
  188. Front (metail) knocking sound - Please help!!
  189. Squeeky Belt and Vibrating Alternator
  190. Which Foglights? If you have HID fogs PLEASE STEP INSIDE
  191. FML, got hit by a car with no insurance
  192. Housecor's How To's is gone?
  193. Need help IACV Higher Rpm then expected
  194. Starting problems + Accel when letting off gas..P0430 and evap canister codes
  195. LCA replacement?
  196. Mona-cef I'm coming for you....
  197. Kendall Synthetic Blend and Mighty Oil Filters?
  198. New Performance Modification: Camber Tires
  199. Dealership and NTB
  200. Cooling Fan Relays
  201. Broken Engine Mount??
  202. Preventing rusting of exhaust bolts for future work.
  203. painted rear lip but didn't turn out great ):
  204. Radiator options?
  205. Trying to remove exhaust cam sproket no-go
  206. Car not starting, getting fuel and spark.
  207. 2003 Maxima (good or bad)?
  208. Bedding in brakes and no more shimmy?
  209. Can a tune make the difference for me?
  210. E-Manage Ultimate problem
  211. Firestone
  212. Best Cooling Fan Replacement?
  213. Major Help PLEASEEE
  214. 6th Gen BBK: Will my stock 17s fit?
  215. P0113 - IAT Sen/Circuit code after 2k1 MAF swap. Help!
  216. Right front window
  217. Larger Repairs coming up - need Advice
  218. Love Taxis! (with pics)
  219. Suggested addition to tool box.
  220. Rubbing type sound when placing car in reverse. A/T
  221. strange noise coming from rear wheels
  222. Transmission FAILURES
  223. ported UIM and LIM FTW gains
  224. Lights, squeaks, and rattles. Ebrake?
  225. Gas Gauge Sticks around a 1/4 tank...
  226. Should i swap my hotshots onto my new maxima?
  227. If you could do it all over again....
  228. Car almost stalls upon start-up only when warm! Help!!
  229. Cat interchangeability between i30 and maxima.
  230. Does anyone have custom maxima headers on a 5.5 gen?
  231. Help! Cold start stumble/misfire issues and more but no CEL
  232. What RPM is too high to set cruise control at or drive at for that matter
  233. What RPM is too high to set cruise control at or drive at for that matter
  234. Musty Smell Culprit.. Ugh.....
  235. Rear beam to IRS dreams.
  236. Tokico Strut mounts and boots?
  237. k-sport coilover install
  238. Rarity of MT 5th gen in SW USA
  239. Vibration 60-82 mph
  240. Power seat problem (passenger side) I35
  241. Transmission problem?
  242. Poor Gas Mileage, what to check?
  243. Best deal on 5th gen crossmember motor mounts?
  244. Not getting power to the Rear Running Lights
  245. 2002 Clear Tail Lights
  246. Little Experiment: Franken-Bucket
  247. anyone seen 08 altima se 17s on the max before?
  248. whistling noise
  249. What's wrong with my strut?
  250. Horrible Handling!!
