PDA
View Full Version : 5th Generation Maxima (2000-2003)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360
  1. Winter is coming...Need winter wheels
  2. tps on a 03 max
  3. Replacing Ignition Coils, can I replace just one?
  4. This is driving me CRAZY! TCS/SLIP/SES!!
  5. My new sticker mod for mawr hp~!
  6. Schizoid SES Light
  7. Weird Noise
  8. need your opinion on ebay generic engine mount
  9. Opinions on gauge placement
  10. New Valve Covers to Replace PCV?
  11. Paradox Rear Strut Bar?
  12. Need help...any input...
  13. So....what the heck should I do.
  14. low idling
  15. Rough start up and rough shut down
  16. Seat options for the 5th gen
  17. Link to VAIS video...
  18. Exhaust ground strap broken...Problem?
  19. Vid/Pics of my double din install...
  20. Idling Issue
  21. 00-01 headlight eyelid help!!!!!!!!!!!!
  22. Gerbils under my dash??
  23. Loose front wheel nut
  24. Where P0345 camshaft sensor is located?????????????
  25. Changing rear brake pads!
  26. AE Lip replica
  27. nismo shift knob. Will it fit?
  28. GAB + OSCAI + Resonator Delete done.
  29. Help - Window wont go up
  30. Re-aiming headlights after drop?
  31. ES sway bar bushings installed now front end clunking?!?!
  32. help me please starting issue after car gets hot!!!
  33. Cattman Performance looking for a 5th gen Max in SoCal for 3" catback fit
  34. SHOW OFF your Engine Covers
  35. I now drive a race car every day!!!
  36. 2000 Steering gear replacement
  37. Testing coil packs
  38. how to clean the engine bay?
  39. Time to say goodbye
  40. Drive Belt - Did I get wrong part?
  41. Keyfob "Unlock" Trigger
  42. SLUGGISH
  43. need help with IACV light Symptons in message!!!!!!!!!!!!!!!!!!!!!!!!!
  44. installing 2003 maxima rear view mirror on a 2001
  45. Car Won't Start
  46. AFTERMARKET GRILL?
  47. Techone HID's install
  48. SES Codes P0011/P0021
  49. Intermittent Alt warn light
  50. ny input on these carbon fiber hoods or any other brands that is under $500
  51. Metallic knocking in front right wheel over cracks in the road?
  52. rpm dropping below 1000
  53. SES Reset I/M Relearn Procedure
  54. Why does my AC sounds like it revs up too much?
  55. So... my max got hit
  56. Is it time for new rear brake pads ....or maybe a wheel bearing?
  57. I30 15" BBS Wheels, will they fit?
  58. Good Quality Head Lights
  59. Clutch & radiator - HELP!
  60. 5.5 gen Stearing wheel wear. cover pealing off
  61. Safe to put oem headers and precats back? ***pics***
  62. Does SES light reset with #of turns of key
  63. 01 intake/headers comparison
  64. P0420 SES disappearing act.
  65. BOSE 6 CD Changer head unit question....
  66. homelink transmitter problem
  67. Understanding Maxima stock security
  68. Lubing a Squeeking Strut
  69. Air Conditioner Problem
  70. Berk Intake- AEM or Apexi
  71. Nissan Sport magazine!
  72. Head Gear??
  73. wire that leads to starter solenoid in ignition cluster.
  74. manual climate control
  75. Whirring/ faint grinding noise when accelerating
  76. power steering fluid is boiling!
  77. red taillight overlays
  78. replaced rear calipers...
  79. Riding height + front lip recommendations
  80. Clicking/clunking after start up when engine is completely cold.
  81. My car TOTALLED - But what a story!
  82. VAIS and intake...dirty???
  83. Quick question about window visors for the 5th gen
  84. carputer or the headunit i have now?
  85. reverse lights switch/sensor
  86. side marker connectors
  87. Weird noise coming from suspension....
  88. How to Paint your Engine Cover
  89. bad abs sensor? clean it or replace it?
  90. K sport strut replacement
  91. how to remove nuts withoput breaking their heads?
  92. Emergemcy Brake Question
  93. 03 maxima stalls right after startup when engine warm. Please help!
  94. Running real lean please help
  95. how do i erase the abs light?
  96. No Start - I'm thinking ignition switch
  97. which wheel spacer
  98. Disconected battery, cluster not working now..
  99. Strange problem, car sputtering when in drive...
  100. will a 2003 maxima's abs sensor work on a 2001?
  101. Hail Damage
  102. Question about rear illumina install
  103. Is it really possible?
  104. BLower motor!!
  105. Help Car won't start.
  106. No power locks, dome lights, or rear defroster
  107. can some one please tell me what i'm doing wrong here?
  108. question about 01 maxima brakes.
  109. NEED HELP ASAP KEYFOB QUESTION
  110. projector lights
  111. 6th gen caliper - price tripled!!! Other Options?
  112. Press-in ball Joint
  113. All 5.5Gen 6MT owners Step in .
  114. Keyfob question???
  115. Can someone help me find the Shift solenoid test thread?
  116. clutch grinding at high rpms??
  117. how to remove the tie rod ends on 2001 maxima
  118. 00 tranny shifting out of gear while driving
  119. O2 Sensor Headache, Fast Relief! 03MaxSE
  120. SS Clutch Line Install - Need Guidance
  121. how tight should i tighten the control arm nuts?
  122. 2000 transmission
  123. MAF cleaning on 02 maxima?
  124. TCM related question
  125. Oil on top of plug?
  126. $46.19? Cheapest price for a drop in K & N air filter?
  127. Clutch pedal engine vibration when completely depressed
  128. is it normal to have metal shaving on the magnets on the tranny oil pan
  129. My maximas starting problem. very odd (pics and videos inside)
  130. Cattman Performance continuously in business since 1998
  131. Keyless Remote Type on '02 Maxima
  132. A/C Screeching and then stops
  133. tranny is still leaking
  134. Conversion from HID to Halogen
  135. H&R or Eibach
  136. 00 Maxima making a screeching noise
  137. Fuel pressure drop after shut down
  138. HELP ME CAR NOISE
  139. Red Mud Flaps/Splash Guards
  140. Strange noise
  141. Looking through some old stuff.
  142. Driver Side HeadLight - Relay
  143. Starting problem
  144. What Els Can Be Wrong?- Can Anyone Help Me Please!?
  145. OEM Muffelor to the extension pipe is shot - HELP!
  146. Valve cover
  147. Radiator Fan Problem
  148. Aem Dryflow
  149. OBD Problem
  150. trying to trouble shoot P0335 code!!!
  151. where can i get the clear lenses for the 5.5gen headlights
  152. Noise coming from steering wheel
  153. Where to get a B pipe from?
  154. Can't remove O2 sensor...help!
  155. Unveiled: Pioneer AVIC F-Series Car Navigation [PICS]
  156. Dim Door Ajar Light
  157. Coil pack replacement DIY anyone?
  158. Headlight / Fog Wiring Harness?
  159. Bad Links in the Stickies..!
  160. 00 Max GLE vs 03 Max GLE
  161. some kind of gel
  162. Installing Hitch on '02 Max
  163. After market front pre-cat
  164. Stereo Harness Wiring Diagram, '03
  165. Alternator Ampere Output
  166. Jerk/thump when releasing clutch in neutral
  167. Max starts, then dies.
  168. Has your max done this?
  169. hesitation/slippage when low on gas?
  170. Help... Door speaker blown...
  171. axle bearings
  172. Click - No power. Electrical relay?
  173. driving under 1000 rpm
  174. 01 Bose Sub cut off....
  175. Keyfob Error
  176. How do you replace the check engine light bulb?
  177. 2000 to 2003 Front End Conversion.
  178. Just upgraded
  179. Question about phillips D2R bulbs
  180. starting problem
  181. Which bearing should I use?
  182. Would wiring a solar panel to the car be bad?
  183. WTF!! Happened to this Maxima??
  184. Does your 02-03 Maxima make a snorting sound?
  185. A/C is making a weird noise
  186. Overheating problems (no start)
  187. Difference in Nissan front brake pads part numbers-help!
  188. How much can I get for my max
  189. Illumina Piston Rod nut torque
  190. What is the year and mileage on your Max?
  191. One of my parking lights is not working?
  192. bose speaker dimensions....
  193. Weird engine start when warm?
  194. Jumpy Idle at start ups and quick stops
  195. Willood BIG BRAKE KIT need help!
  196. WHEN IT RAINS
  197. Shift Lock Woes -- Shifter Stuck in Park
  198. Clutch Problems - Random
  199. Tranny popping out of overdrive on the highway
  200. Transmision Saving?
  201. 5.5 Gen ECU Code help
  202. 00 Digital Climate control lights (Help)
  203. ENGINE AIR TEMPERATURE SENSOR
  204. Advice needed on Rusted out & leaky oil pan on 02 SE
  205. Factory Alarm randomly going off
  206. Let a relative barrow the car, now i got a blown clutch. Need Help!
  207. bottoming out with illumina/maxspeed/18"
  208. THE FIXING DEAD LINKS THREAD!!!!! EVERYONE PITCH IN!
  209. 5 spd Tranny issue
  210. How to: Upgrade your 5.5 gen alternator with a 4th gen gle/I30 one
  211. Speed shift/2-step installed
  212. Issues After ECM Reflash
  213. RE: 6th gen caliper fitment for 5th gen
  214. Engine Tired ?
  215. So I went to the junkyard and found
  216. Strut Disassembly
  217. Quick question in help of newbies...
  218. car noise?
  219. Just bought 00 max!
  220. Gauging Interest: Billet 5.5+ Gen Maxima MAF Adapters and/or MAF Tubes
  221. Car died. Please help
  222. power steering fluid disappearance
  223. Window wont roll up or down
  224. lower tie bar help stage 2
  225. RPM Question
  226. Brake system flush, how much fluid?
  227. Am I having Transmission problems?
  228. MAF & P0138 codes related?
  229. What is needed to remove Upper manifold intake?
  230. Rattling Noise During Acceleration
  231. Alternator / UDP Problem
  232. '03 stock stereo won't power on??
  233. ES Motor Mount bushings sit lower than OEM-> fitment issues?
  234. Front Axle Bearings
  235. Uh, oh... weird sqeal from front-end with knock underneath...
  236. Drive side seat motor - Big Trouble!
  237. Thanks for the suspension information
  238. Nissan FAST
  239. NGK Laser Iridium plugs
  240. broken sunroof - gets stuck
  241. Stillen rear sway bar hitting on lowered '02 SE
  242. Inspection Question \ HID Headlights
  243. Motor mounts for an 01 automatic...
  244. LED License plate lights
  245. radio install for 2001 maxima
  246. Knock sensor replacement on Cali spec engine?
  247. Which ES polyurethane bushings are worth installing besides rear trailing arm?
  248. rattling
  249. Grease inside front wheel
  250. Passenger Side Rear Brake Dragging.
